CFM40S480
CFM40S480
    CINCON
    开放框架 AC DC 转换器 1 输出 48V 90 ~ 264 VAC 输入
CFM40S480 数据手册
V15 ︳ CFM40/60S SERIES 40/60 WATT OPEN FRAME AC-DC MODULES Features * Universal Input Range 90~264VAC * 2”x 4” Size * Industry Standard Pin Out * Efficiency to 87% * Continuous Short Circuit Protection * Meets EN55032 Class B and CISPR/FCC Class B * Approved IEC/EN/UL62368-1 CFM40 Series MODEL OUTPUT VOLTAGE OUTPUT CURRENT RIPPLE & NOISE VOLTAGE ACCURACY LINE REGULATION LOAD REGULATION % EFF. (Typ.) CFM40S033 CFM40S050 CFM40S090 CFM40S120 CFM40S150 CFM40S240 CFM40S300 CFM40S360 CFM40S480 3.3 V 5V 9V 12 V 15 V 24 V 30 V 36 V 48 V 6A 6A 4.45 A 3.34 A 2.67 A 1.67 A 1.33 A 1.11 A 0.834 A 50mV 1% 1% 1% 1% 1% 1% 1% 1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±0.5% ±0.5% ±0.5% ±0.5% ±0.5% ±0.5% ±0.5% ±0.5% ±0.5% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% 70% 76% 84% 85% 85% 85% 86% 87% 87% CFM60 Series MODEL OUTPUT VOLTAGE OUTPUT CURRENT RIPPLE & NOISE VOLTAGE ACCURACY LINE REGULATION LOAD REGULATION % EFF. (Typ.) CFM60S033 CFM60S050 CFM60S090 CFM60S120 CFM60S150 CFM60S240 CFM60S300 CFM60S360 CFM60S480 3.3 V 5V 9V 12 V 15 V 24 V 30 V 36 V 48 V 8A 8A 6.67 A 5A 4A 2.5 A 2A 1.67 A 1.25 A 50mV 1% 1% 1% 1% 1% 1% 1% 1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±0.5% ±0.5% ±0.5% ±0.5% ±0.5% ±0.5% ±0.5% ±0.5% ±0.5% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% 72% 77% 84% 85% 86% 86% 86% 88% 88% 1 V15 Specifications CFM40/60S Series Derating Curve Open Frame versions: Voltage …....………........….......................................................... 90~264Vac 120~370Vdc Frequency …………………………………………………………..... 47 to 63Hz CFM40S033, 40S050, 40S090, 60S033, 60S050, 60S090 100% Inrush Current ……………… Cold Start@25℃ ............. 50A max. @240Vac Leakage Current ……………………………………..….…….…… 1mA Typical OUTPUT SPECIFICATIONS: Holdup Time …………………………..………………...… 8ms typ. @115Vac Short Circuit Protection …………………..…… Hiccup Mode (Auto Recover) Over Voltage Protection ………………………….. TVS Component to Clamp Temperature Coefficient ……………………............................... ±0.05%/℃ Rated Load(%) INPUT SPECIFICATIONS: 75% 20LFM(Natural Convection) 50% 25% 0% 0 10 GENERAL SPECIFICATIONS: SAFETY AND EMC: Emission and Immunity ……………. EN55032 Class B, FCC Part 15 Class B EN61000-6-3, EN61000-3-2, EN61000-3-3 EN55024, EN61204-3, EN61000-6-1 Safety ……………………………. IEC/EN/UL62368-1, IEC/EN/UL60950-1 NOTE: 1. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple&noise measuring @20MHz BW. 2. Line regulation is measured from high line to low line with full load. 3. Load regulation is measured from full to 10% load. 4. Input connector mates with Molex housing 09-50-3031 and Molex 2878 series crimp terminal. 5. Output connector mates with Molex housing 09-50-3041 and Molex 2878 series crimp terminal. 6. Safety approvals do not apply to the covered versions, only to the openframe versions. 70 Rated Load(%) 75% 20LFM(Natural Convection) 50% 25% 0% 0 10 20 30 40 50 Ambient Temperature(oC) 60 70 Covered versions: CFM40/60XXX-CA CFM40S120, 40S150, 40S240, 40S300, 40S360, 40S480 100% Rated Load(%) MTBF ………….….… MIL-HDBK-217F, GB, 25℃/115VAC … 200Khrs min. Altitude ……………………..……………………………….…….……… 2000m Dimensions: Open Frame ….… 4.000x2.000x1.200Inches (101.60x50.80x30.48mm) -P …………..…… 4.000x2.000x1.275Inches (101.60x50.80x32.38mm) Covered ….......... 4.606x2.441x1.5750Inches (117.00x62.00x40.00mm) Weight ……………………………. CFM40/60: 170g/175g (0.38/0.39 Pounds) CFM40/60 Covered: 210g/215g (0.46/0.47 Pounds) 60 CFM40S120, 40S150, 40S240, 40S300, 40S360, 40S480 CFM60S120, 60S150, 60S240, 60S300, 60S360, 60S480 100% 75% 20LFM(Natural Convection) 50% 25% 0% 0 10 20 30 40 50 Ambient Temperature(oC) 60 70 CFM40S033, CFM40S050, CFM60S033, CFM60S050 100% Rated Load(%) Isolation ………………………..……………..…… Input to Output = 4,242VDC Operating Temperature ................................ 0 ~ 70℃(see Derating Curve) Storage Temperature …………………………....….......…........ -20~85℃ Humidity ....................................................... 93% RH max. Non-Condensing Cooling ………………………..………………………..... Natural Convection Switching Frequency ……………………………….…….……. 66KHz Typical 20 30 40 50 Ambient Temperature(oC) 75% 20LFM(Natural Convection) 50% 25% 0% 0 10 20 30 40 50 Ambient Temperature(oC) 60 70 Rated Load(%) CFM40S090, 60S090, 60S120, 60S150, 60S240, 60S300 CFM60S360, 60S480 100% 75% 20LFM(Natural Convection) 50% 25% 0% 0 2 10 20 30 40 50 Ambient Temperature(oC) 60 70 V15 Mechanical Specification All Dimensions are in inches(mm) Tolerance:Inches:X.XXX±0.02 Millimeters:X.XX±0.5 CFM40SXXX-P/CFM60SXXX-P CFM40SXXX/CFM60SXXX CFM40SXXX/CFM60SXXX-CA (Input and Output connector with PIN) 1.969 [50.00] 2.000 [50.80] 1.701 [43.20] 0.150 [3.80] 0.846 [21.50] 0.236 [6.00] VR 2.362 [60.00] PE 0.071 [1.80] 3.701 [94.00] 0.063 [1.60] PE 0.236 [6.00] 0.039 [1.00] 0.039 [1.00] Typical at 25˚C, nominal line and 75% load, unless otherwise Specified 3 1.701 [43.20] 0.370 [9.40] 2.441 [62.00] 4 .5* x0 M3 0.197 [5.00] 8] 3.1 [Φ 0.197 [5.00] 0.063 [1.60] 0.098 [2.50]max Vout(-) 1.575 [40.00] 5 .12 Φ0 4- PE Vout(+) ACL 1.275[32.38]max VR 0.17 [4.40] PE ACN 0.098 [2.50]max -Vout 8] 3.1 [Φ 2.000 [50.80] 1.701 [43.20] LED +Vout ACL 0.15 [3.80] 0.150 [3.80] LED ACN 5 .12 Φ0 4- 4.000 [101.60] 3.701 [94.00] 0.150 [3.80] 0.063 [1.60] 0.150 [3.80] 1.200 [30.48]max 3.520 [89.40] 0.150 [3.80] 0.246 [6.25] 0.150 [3.80] 0.156 [3.96] 0.657 [16.69] 4.000 [101.60] 0.614 [15.60] 0.311 [7.90] 4.606 [117.00]
CFM40S480 价格&库存
很抱歉,暂时无法提供与“CFM40S480”相匹配的价格&库存,您可以联系我们找货
CFM40S480
  • 1+154.92345
  • 5+137.69909
  • 20+124.81076
  • 100+116.19858
库存:19
