CFM70S360-P
CFM70S360-P
    CINCON
    DIP6 模块
    开放框架 AC DC 转换器 1 输出 36V 1.94A 90 ~ 264 VAC,120 ~ 370 VDC 输入
CFM70S360-P 数据手册
CFM70S SERIES 70 WATT OPEN FRAME AC-DC MODULES Features  Universal Input Range 85~264Vac  High Efficiency up to 91%  2”x 3” Open Frame Compact Size  Class I and Class II  No Load Input Power < 0.15W  Approval IEC/EN/UL 62368-1 Ed 3.0  Meets IEC/EN 60335-1  Approval EN 55032 Class B and CISPR/FCC Class B  Operating Altitude 5000m  Continuous Short Circuit Protection  Over Voltage Protection  Over Voltage Category OVC II & OVC III MODEL OUTPUT OUTPUT NUMBER VOLTAGE CURRENT VOLTAGE RIPPLE& LINE LOAD %EFF. ACCURACY NOISE REGULATION REGULATION (Typ.) NOTE1 NOTE2 NOTE3 NOTE4 NOTE5 CFM70S050 5V 10.0 A ±2% 150 mV ±0.5% ±1% 86% CFM70S120 12 V 5.80 A ±2% 120 mV ±0.5% ±1% 90% CFM70S150 15 V 4.65 A ±1% 150 mV ±0.5% ±1% 90% CFM70S240 24 V 2.92 A ±1% 240 mV ±0.5% ±1% 90% CFM70S360 36 V 1.94 A ±1% 360 mV ±0.5% ±1% 90% CFM70S480 48 V 1.46 A ±1% 480 mV ±0.5% ±1% 91% Note: 1. Voltage accuracy is set at 100% full load. 2. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple & noise measurement @20MHz BW. 3. Line regulation is measured from 90Vac to 264Vac with 100% full load. 4. Load regulation is measured from 10% to full load. 5. Typical efficiency at 230 Vac. 6. Standard input and output connectors (CN1 and CN2) wafer with TAIWAN KING PIN TERMINAL PVHI series and mate with JST housing VHR series and JST SVH-41T-P1.1 series crimp terminal and output connectors wire 16AWG. PART NUMBER Series CFM70 Number of Outputs O Nominal Output Voltage XX 050:05V 120:12V CFM70 150:15V S:Single Type -X (Option) None:Wafer P:PCB Mount CA:Cover 240:24V E:Encapsulated 360:36V S:Terminal Block 480:48V SD:Terminal Block with Din rail Part Number Example: CFM70S120: Open Frame, 70W, Single 12Vdc Output www.cincon.com 1 REVISION: V13 CFM70S Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Input Voltage Safety approvals only to the AC input (DC input no safety) All Operating Temperature See Derating Curve Storage Temperature Device Min. Typ. Units 85 264 Vac 120 370 Vdc All -30 80 ℃ All -30 85 ℃ IEC/EN/UL 62368-1 OVC II Operating Altitude Max. 5000 IEC/EN 62368-1 OVC III All 2000 Meets IEC/EN 60335-1 OVC II m 3000 INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Voltage Range Input Frequency Range Maximum Input Current 100% Load, Vin=100Vac Leakage Current Inrush Current Vin=240Vac, Cold start at 25℃ Device Min. All 100 All 50 Typ. Max. Units 240 Vac 60 Hz All 1.5 A All 0.1 mA All 130 A OUTPUT CHARACTERISTICS PARAMETER Output Voltage Set Point Operating Output Current Range NOTES and CONDITIONS Vin=Nominal Vin, Io=Io max., Tc=25℃ Vin=115Vac and 230Vac,Tc=25℃ Device Min. Typ. Max. CFM70S050 4.90 5 5.10 CFM70S120 11.76 12 12.24 CFM70S150 14.85 15 15.15 CFM70S240 23.76 24 24.24 CFM70S360 35.64 36 36.36 CFM70S480 47.52 48 48.48 CFM70S050 10.0 CFM70S120 5.80 CFM70S150 4.65 CFM70S240 2.92 CFM70S360 1.94 CFM70S480 Holdup Time Units Vdc A 1.46 Vin=115Vac All ms Load Regulation 10% Load to full load All ±1.0 % Line Regulation Vin=High line to low line % 10 Output Voltage Regulation Over Voltage Protection Hiccup mode (Auto recovery) All ±0.5 CFM70S050 6.3 CFM70S120 15.6 CFM70S150 18.0 CFM70S240 29.1 CFM70S360 43.3 CFM70S480 Over Current Protection Hiccup mode (Auto recovery) All Short Circuit Protection Hiccup mode (Auto recovery) All www.cincon.com 2 Vdc 56.8 110 140 % REVISION: V13 CFM70S PARAMETER NOTES and CONDITIONS Output Ripple and Noise 1. Add a 0.1uF ceramic capacitor and a 10uF aluminum electrolytic capacitor to output 2. Oscilloscope is 20MHz band width 3. Ambient Temperature=25℃ Load Capacitance 1. Vin=115Vac and 230Vac 2. Output is max. load 3. Ambient temperature=25℃ Device Min. Typ. Efficiency Max. CFM70S050 150 CFM70S120 120 CFM70S150 150 CFM70S240 240 CFM70S360 360 CFM70S480 480 CFM70S050 10300 CFM70S120 6000 CFM70S150 4700 CFM70S240 2920 CFM70S360 1980 CFM70S480 1. Input voltage is 230Vac 2. Output is rated load Series Units mV uF 930 CFM70S050 86 CFM70S120 90 CFM70S150 90 CFM70S240 90 CFM70S360 90 CFM70S480 91 % ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Input to Output 1 Minute All Isolation Resistance Input to output All 100 Device Min. Typ. Max. 4250 Units Vac MΩ FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pout=max. rated power All Typ. Max. Units kHz 65 GENERAL SPECIFICATIONS PARAMETER NOTES and CONDITIONS MTBF Humidity Shock Vibration Device Min. Io=100%; Ta=25℃ per MIL-HDBK-217F All 500 Non-condensing Meet MIL-STD-810F Table 516.5, Table 516.5-I 10ms, each axis 3 times(±X、±Y、 ±Z axis) Meet MIL-STD-810F Table 514.5CVIII,15~2000Hz, X、Y、Z axis, 1 hour (each axis),. Total 3 hrs. All Weight All 4 g CFM70S CFM70S-P 96.1 CFM70S-CA 183 CFM70S-E 223 236 P (PCB Mount) CA (Cover) All SD (Din rail type) www.cincon.com 3 93 k hours % RH g Open Frame (Wafer) S (Terminal Block) Units 75 CFM70S-S E (Encapsulated) Max. All CFM70S-SD Dimensions Typ. 94.1 grams 333 3.000x2.000x1.067 Inches (76.20x50.80x27.1 mm) 3.000x2.000x1.142 Inches (76.20x50.80x29mm) 3.598x2.520x1.358 Inches (91.40x64.00x34.50 mm) 2.170x3.140x1.201 Inches (55.20x79.80x30.50 mm) 2.170x4.200x1.201 Inches (55.20x106.60x30.50 mm) 2.170x4.200x1.783 Inches (55.20x106.60x45.30 mm) REVISION: V13 CFM70S Series GENERAL SPECIFICATIONS Class I, Class II, IEC/EN/UL62368-1 EN 55032: 2015+AC: 2016, 47 CFR FCC Part 15 Subpart B, EN 61000-3-2: 2019, EN 61000-3-3: 2013 EN 55032, 47 CFR FCC Part 15 Class B Radiated Disturbance EN 55032, 47 CFR FCC Part 15 Class B Harmonic Current Emissions EN 61000-3-2:2019 Voltage Fluctuations & Flicker EN 61000-3-3:2013 EMC Immunity EN 55035:2017 Electrostatic Discharge (ESD) Radio-Frequency, Continuous Radiated Disturbance Electrical Fast Transient (EFT) IEC 61000-4-2:2008, Air Discharge: ±8kV, Contact Discharge: ±4kV Criterion A IEC 61000-4-3:2020 Criterion A IEC 61000-4-4:2012, ±0.5kV, ±1kV, ±2kV Criterion A Safety EMC Emission Conducted Disturbance Ed 3.0 Class B Surge Conducted Disturbances, Induced by RF Fields Power Frequency Magnetic Field IEC61000-4-5:2014, L-N: ±2kV, L-E (Ground): ±4kV Criterion A IEC 61000-4-6:2013 Criterion A IEC 61000-4-8:2009 Criterion A Voltage Dips IEC 61000-4-11:2004, Dip: 30% Reduction, Dip >95% Reduction Criterion A Voltage Interruptions IEC 61000-4-11:2004, >95% Reduction Criterion B Application Note Link CFM70S Series App Notes CHARACTERISTIC CURVE Power Derating Curve CFM70SXXX (-P/CA) CFM70SXXX (-P/CA) 100 100% 80 LOAD (%) LOAD (%) 75% 50% 25% 40 20 20LFM(Natural Convection) 0% -30 -20 -10 60 20LFM (Natural Convection) 0 0 85 10 20 30 40 50 60 70 80 CFM70SXXX-E(S/SD) 100% 105 125 145 165 185 205 225 245 265 Vin Voltage (Vac) Ambient Temperature(℃) (Natural Convection) CFM70SXXX-E(S/SD) 100 80 LOAD (%) LOAD (%) 75% 50% 25% CMF70S050-E(S/SD) 60 40 20 20LFM (Natural Convection) for Others Model 0% -30 -20 -10 0 0 85 10 20 30 40 50 60 70 80 90 www.cincon.com 105 125 145 165 185 205 225 245 265 Vin Voltage (Vac) Ambient Temperature(℃) 4 REVISION: V13 CFM70S Series Performance Data CFM70S050 (Eff Vs Io) CFM70S120 (Eff Vs Io) 95% Efficiency (%) Efficiency (%) 90% 85% 115V 80% 90% 115V 85% 230V 75% 10% 20% 30% 40% 50% 60% 70% 80% 230V 80% 10% 90% 100% 20% 30% Current Load (%) 50% 60% 70% 80% CFM70S150 (Eff Vs Io) CFM70S240 (Eff Vs Io) Efficiency (%) 95% 90% 85% 115V 90% 85% 115V 230V 80% 10% 20% 30% 40% 50% 60% 70% 80% 230V 80% 10% 90% 100% 20% 30% Current Load (%) CFM70S360 (Eff Vs Io) 50% 60% 70% 80% 90% 100% CFM70S480 (Eff Vs Io) 95% Efficiency (%) Efficiency (%) 40% Current Load (%) 95% 90% 85% 115V 90% 85% 115V 230V 80% 10% 90% 100% Current Load (%) 95% Efficiency (%) 40% 20% 30% 40% 50% 60% 70% 80% 230V 90% 100% Current Load (%) www.cincon.com 80% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) 5 REVISION: V13 CFM70S Series MECHANICAL SPECIFICATION 26[ 0.1 4-Φ FG ] .20 Φ3 3 2.000 [50.80] 1.700 [43.18] CN2 1 CN1 1 0.150 [3.81] CFM70SXXX 4 AC Input Connector(CN1):TKP PVHI-03N2 or equivalent Pin Function Mating Housing Terminal ACL 1 JST VHR-3N JST SVH-21T-P1.1 2 or equivalent or equivalent 3 ACN 0.098 [2.50]max. 2.700 [68.58] DC Output Connector(CN2):TKP PVHI-04 or equivalent Pin Function Mating Housing Terminal +Vout 1 2 3 4 1.067 [27.10]max. 3.000 [76.20] 0.969 [24.60]max. FG 0.150 [3.81] 2.000 [50.80] 3-0.156 [3.96] 1.700 [43.18] 0.969 [24.60]max. 3.000 [76.20] CFM70SXXX-P 0.173 [4.40] CN1 PIN CONNECTION Function 1 ACL 2 ACN CN2 PIN CONNECTION Pin 1.142 [29.00]max. 0.098 [2.50]max. 2.700 [68.58] JST SVH-21T-P1.1 or equivalent ] 3 .2 0 6 [Φ Pin 0.473 [12.01] FG 0.150 [3.81] 0.173 [4.40] 0.150 [3.80] 0.484 [12.30] 2 0.150 [3.81] 0.307 [7.80] 1 2 3 4 CN2 CN1 1 JST VHR-4N or equivalent All Dimensions in Inches[mm] Tolerance Inches:X.XXX=±0.02 Millimeters:X.XX=±0.5 0.12 4- Φ FG +Vout -Vout -Vout Function 1 +Vout 2 +Vout 3 -Vout 4 -Vout All Dimensions in Inches[mm] Tolerance Inches: X.XXX=±0.02 Millimeters:X.XX=±0.5 Φ0.071[Φ1.80] Φ0.039[1.00] 2.642 [67.10] www.cincon.com 6 REVISION: V13 CFM70S Series MECHANICAL SPECIFICATION 3.598 [91.40] 3.299 [83.80] M 4- 0.150 [3.80] 0 .5 3* CFM70SXXX-CA AC Input Connector(CN1):TKP PVHI-03N2 or equivalent Pin Function Mating Housing Terminal ACL 1 JST VHR-3N JST SVH-21T-P1.1 2 or equivalent or equivalent 3 ACN 2.520 [64.00] 2.000 [50.80] CN2 1 CN1 1.382 [35.10] 4-0.157 [4.00] FG 4 DC Output Connector(CN2):TKP PVHI-04 or equivalent Pin 1 2 3 4 All Dimensions in Inches[mm] Tolerance Inches:X.XXX=±0.02 Millimeters:X.XX=±0.5 CFM70SXXX-E 1.201 [30.50] 1.358 [34.50] 0.260 [6.60] FG Function Mating Housing Terminal +Vout +Vout JST VHR-4N JST SVH-21T-P1.1 or equivalent or equivalent -Vout -Vout FG 1.700 [43.18] CN2 4 3 2 1 0.237 [6.01] 2 de -M3 pt *0 h .5 2. 5m m 1 0.307 [7.80] 0.571 [14.50] CN1 2 FG PIN CONNECTION 2.17 [55.2] 2.642 [67.10] 0.244 [6.20] 0.560 [14.22] 3.14 [79.8] 3-0.156 [3.96] 0.138[3.50] 6-Φ0.059[Φ1.50] Pin Function 1 ACL 2 ACN 1 +Vout 2 +Vout 3 -Vout 4 -Vout Wafer CN1 CN2 All Dimensions in Inches[mm] Tolerance Inches:x.xx=±0.03,x.xxx=±0.02 Millimeters:x.x=±0.7,x.xx=±0.5 0.221 [5.61] 2.700 [68.58] www.cincon.com 7 REVISION: V13 CFM70S Series MECHANICAL SPECIFICATION 4.20 [106.6] CFM70SXXX-S 3.858 [98.00] 0.169 [4.29] 1 2 2.17 [55.2] CN2 1 2 3 0.437 [11.10] CN1 1.299 [33.00] PE AC Input Connector(CN1):DINKLE EK350V-03P5 or equivalent Pin Function 1 2 PE ACL 3 ACN Mating Wire Range 16~30 AWG 1.201 [30.50] DC Output Connector(CN2):DINKLE EK500V-02P or equivalent Pin Function 1 +Vout 2 -Vout Mating Wire Range 12~16 AWG All Dimensions in Inches[mm] Tolerance Inches: x.xx=±0.03, x .xxx=±0.020 Millimeters: x.x=±0.7, x.xx=±0.50 4.20 [106.6] CFM70SXXX-SD CN1 1 2 3 DIN RAIL CLIP 0.504 [12.80] 1.378 [35.00] 1.783 [45.30] 1.280 [32.50] CN2 1 2 2.17 [55.2] PE AC Input Connector(CN1):DINKLE EK350V-03P5 or equivalent Pin Function 1 2 PE ACL 3 ACN Mating Wire Range 16~30 AWG DC Output Connector(CN2):DINKLE EK500V-02P or equivalent Pin Function 1 +Vout 2 -Vout Mating Wire Range 12~16 AWG All Dimensions in Inches[mm] Tolerance Inches: x.xx=±0.03, x .xxx=±0.020 Millimeters: x.x=±0.7, x.xx=±0.50 sales@cincon.com.tw www.cincon.com 8 REVISION: V13
CFM70S360-P 价格&库存
很抱歉,暂时无法提供与“CFM70S360-P”相匹配的价格&库存,您可以联系我们找货
