https://www.cincon.com
V16
CHB300W SERIES
300 WATT 4:1 INPUT
DC-DC CONVERTERS
SINGLE OUTPUT
FEATURES
*300W Isolated Output
* Efficiency to 92%
* Fixed Switching Frequency
* Input Under Voltage Protection
* Over Temperature Protection
* Over Voltage/Current Protection
* Remote On/Off
* Industry Standard Half-Brick Package
* Fully Isolated 1500VDC
* IEC/EN/UL 62368-1 Approval
MODEL
NUMBER
INPUT
VOLTAGE
OUTPUT
VOLTAGE
OUTPUT
CURRENT
MIN.
MAX.
0 mA
INPUT CURRENT
% EFF.
CAPACITIVE
LOAD MAX. (4)
NO LOAD
FULL LOAD
(2)
(3)
60 A
200 mA
14.12 A
88
88.5
CHB300W-24S05
9-36 VDC
5 VDC
CHB300W-24S12
9-36 VDC
12 VDC
0 mA
25 A
200 mA
13.74 A
91
91
CHB300W-24S15
9-36 VDC
15 VDC
0 mA
20 A
250 mA
13.74 A
91
91
CHB300W-24S24
9-36 VDC
24 VDC
0 mA
12.5 A
80 mA
14.20 A
88
88
CHB300W-24S28
9-36 VDC
28 VDC
0 mA
10.7 A
80 mA
14.12 A
88.5
88.5
CHB300W-24S48
9-36 VDC
48 VDC
0 mA
6.25 A
100 mA
14.20 A
88
88
CHB300W-48S05
18-75 VDC
5 VDC
0 mA
60 A
100 mA
6.94 A
89
90
CHB300W-48S12
18-75 VDC
12 VDC
0 mA
25 A
120 mA
6.94 A
92
92
CHB300W-48S15
18-75 VDC
15 VDC
0 mA
20 A
130 mA
6.80 A
92
92
CHB300W-48S24
18-75 VDC
24 VDC
0 mA
12.5 A
60 mA
6.98 A
90
89
CHB300W-48S28
18-75 VDC
28 VDC
0 mA
10.7 A
60 mA
6.94 A
91
89.5
CHB300W-48S48
18-75 VDC
48 VDC
0 mA
6.25 A
80 mA
7.02 A
90
89
470 -10000uF
330-10000uF
0-10000uF
220-4700µF
220-4700µF
220-2200µF
0-10000uF
0-10000uF
0-10000uF
0-4700µF
0-4700µF
220-2200µF
NOTE:
1. Nominal Input Voltage 24,48 VDC
2. Measure at 12VDC for 24Sxx and 24VDC for 48Sxx Models
3. Measure at Nominal Input Voltage
4. The Output Terminal of Models Required a Minimum Capacitor to Maintain Specified Regulation
5. Output Peak Power 350W < 3 seconds with Maximum Duty Cycle of 10%, Average Output Power not to Exceed 300W.
1
V16
SPECIFICATIONS
All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENRAL SPECIFICATIONS:
Input Voltage Range ..…………….......….......... 24V ….…….…… 9-36V
48V ………….. 18-75V
Input Surge Voltage (100ms max.) …………… 24V ……… 50Vdc max.
48V …….. 100Vdc max.
Under Voltage Lockout ………..... 24Vin power up ……………..…. 8.8V
24Vin power down ………..…. 8.0V
48Vin power up ……………..…. 17V
48Vin power down ………..…. 16V
Efficiency .................…..................................……..........…....... See Table
Isolation Voltage ................ Input/Output ....….....……..….. 1500VDC min.
Input/Case, Output/Case …… 1500VDC min.
Isolation Resistance .............................…..................…….... 107 ohm min.
Isolation Capacitance …………………….……………………… 2000pF typ.
Switching Frequency .............................................................. 220KHz typ.
Input Filter (note7) .……………..… 24SXX and 48S15…….…. LC Type
Other 48SXX …………… Pi Type
Operating Case Temperature ………...………….….….……-40℃ to 100℃
Storage Temperature ……….………....……...……............ -55℃ to +105℃
Thermal Shutdown Case Temperature …….……………….…. 110℃ typ.
Humidity .................................................... 95% RH max. Non Condensing
MTBF ………. MIL-HDBK, GB, 25℃, Full Load .………………600Khrs typ.
OUTPUT SPECIFICATIONS:
Dimensions ......................... 2.28x2.40x0.50 inches (57.9x61.0x12.7 mm)
Voltage Accuracy ..........................................………….......... ±1.0% max.
Transient Response: 25% Step Load Change .…….…………… 3.5VDC to 75VDC or open circuit
Module off ……………….………………………….….. 0 to < 1.2VDC
5. Suffix "N" to the model number with negative logic remote on/off.
Module on ……….……………………………………. 0 to < 1.2VDC
Module off ……………….….. >3.5VDC to 75VDC or open circuit
6. Trim-up………….. connect a resistor between the trim pin and +sense.
Trim-down…….…. connect a resistor between the trim pin and –sense.
7. The input terminal recommend to parallel with 1000uF for 24Vin, 470uF for 48S15
model and 220uF for other 48Vin models ESR
很抱歉,暂时无法提供与“CHB300W-48S24”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1624.413841+209.71670
- 36+1489.0095536+192.23560
- 60+1404.4584660+181.31980
- 108+1328.30995108+171.48880
