CQB150-300S05
CQB150-300S05
    CINCON
    模块
    隔离模块 直流转换器 1 输出 5V 30A 180V - 425V 输入
CQB150-300S05 数据手册
CQB150-300S SERIES 150 WATT 2:1 INPUT ISOLATED DC-DC CONVERTER Features  Efficiency Up to 89%  Fixed Switching Frequency  Regulated Outputs  Remote On/Off  Low No Load Power Consumption  Fully Protected (OTP/OCP/OVP/UVLO)  3000Vac I/O Isolation  Operating Case Temperature -40 to +105℃  Quarter Brick Size Meet Industrial Standard 2.28”x1.45”x0.5”  IEC/EN/UL 62368-1 (Reinforce Insulation) Approval  CB Test Certificate IEC62368-1  Shock & Vibration MIL-STD-810F(EN61373) Compliant  Fire & Smoke EN45545 Compliant  2000m Operating Altitude  -55℃ Operating Available (Suffix “-M2”) MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE OUTPUT CURRENT MIN. MAX. INPUT CURRENT NO LOAD FULL LOAD % EFF. CAPACITOR (2) LOAD MAX. CQB150-300S05 180-425 VDC 5 VDC 0 mA 30 A 10 mA 580 mA 86 10000μF CQB150-300S12 180-425 VDC 12 VDC 0 mA 12.5 A 10 mA 560 mA 89 8800μF CQB150-300S15 180-425 VDC 15 VDC 0 mA 10 A 10 mA 560 mA 89 8800μF CQB150-300S24 180-425 VDC 24 VDC 0 mA 6.25 A 10 mA 570 mA 88.5 3300μF CQB150-300S28 180-425 VDC 28 VDC 0 mA 5.4 A 10 mA 570 mA 88.5 3300μF CQB150-300S48 180-425 VDC 48 VDC 0 mA 3.2 A 10 mA 570 mA 89 1000μF NOTE: 1. Nominal Input Voltage 300 VDC. 2. Measured at 300Vin. 3. Require a Ceramic Capacitor 1500pF Connected Between –Vin to Case for All Models. 4. An External Input Capacitor 68uF for All Models are Recommended to Reduce Input Ripple Voltage. 5. -55℃ Start-up Screen per MIL-STD105E S1 Sampling Procedure for “-M2” Version. PART NUMBER Series Nominal Input Voltage Number of Outputs Nominal Output Voltage Remote On/Off Logic Mounting Inserts Operating Case Temp. Range CQB15 0- II O XX L -Y (Option) -Z (Option) None:Positive None:M3x0.5 Mounting Inserts 05:5.0VDC 12:12VDC CQB150 300:300 VDC S:Single 15:15 VDC None:-40~105℃ 24:24VDC 28:28VDC N:Negative 48:48VDC -C:Clear Mounting Insert (3.2mm DIA.) -M2:-55~105℃ Part Number Example: CQB150-300S12N-C-M2: Quarter Brick, 150W, 2:1 180-425Vdc Input, Single 12Vdc Output, Negative Logic, Clear Mounting Insert -55~105℃ Operating Case Temp. Range www.cincon.com 1 REVISION: V14 CQB150-300S Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Input Voltage Input Surge Voltage Continuous All -0.3 100ms max. All At the center part of case plate (with Derating) All -40 105 -M2 -55 105 All -55 125 ℃ Device Min. Typ. Max. Units All 180 300 425 Vdc Turn-On Voltage Threshold All 165 170 175 Vdc Turn-Off Voltage Threshold All 155 160 165 Vdc Lockout Hysteresis Voltage All 10 Vdc All 500 Vdc Operating Case Temperature Suffix “-M2” (with Derating) Storage Temperature Typ. Max. Units 425 Vdc 500 Vdc ℃ INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Input Over Voltage Lockout Turn-Off Voltage Threshold Turn-On Voltage Threshold Maximum Input Current Vin=180V, Full load No-Load Input Current Vin=300V, Io=0A All 440 Vdc All 1000 mA See Model Number Table Input Filter Pi filter. All Inrush Current (I2t) As per ETS300 132-2 All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz All mA 0.1 30 A2s mA OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Voltage Set Point Accuracy Vin=300V, Full load, Tc=25℃ Device Min. All -1.0 Typ. Max. Units +1.0 % Output Voltage Regulation Load Regulation Full load to no load All ±0.2 % Line Regulation Vin=High line to low line, full load All ±0.2 % Temperature Coefficient Tc=-40℃ to 105℃ All ±0.02 %/℃ 05Vo 100 Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Output ripple and noise measured with an external MLCC 1000pF connected between –Vin to Case, and 10uF aluminum and 1uF ceramic capacitor across output for 48Vout, and with 10uF tantalum and 1uF ceramic capacitor for others RMS. 12Vo 150 15Vo 150 24Vo 280 28Vo 280 48Vo 480 05Vo 60 12Vo 60 15Vo 60 24Vo 100 28Vo 100 48Vo Output Current Range Vin= 180 to 425V Over Current Protection Hiccup mode. Auto recovery Short Circuit Protection External Load Capacitance www.cincon.com All Full load (resistive) 110 125 A 160 % Continuous, Auto Recovery See Model Number Table 2 mV 200 See Model Number Table All mV uF REVISION: V14 CQB150-300S PARAMETER NOTES and CONDITIONS Output Voltage Trim Range Po≦max. rated power, Io ≦ Io_max. Output Voltage Remote Sense Range Po≦max. rated power, Io ≦ Io_max. % of nominal Vo Limited voltage, % of nominal Vo Over Voltage Protection Device Min. All -20 Typ. All Series Max. Units +10 % +10 % All 115 125 140 % Device Min. Typ. Max. Units EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=300V, Full load See Model Number Table % DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max. step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (constant resistive load) All ±5 % All 250 us Von/off to 10%Vo_set, Remote on All 250 Vin_min to 10%Vo_set, Power up All 250 ms 10%Vo_set to 90%Vo_set All 30 ms ms ISOLATION CHARACTERISTICS PARAMETER Isolation Voltage (100% factory Hi-Pot tested @2sec.) Isolation Resistance Isolation Capacitance NOTES and CONDITIONS Device 1 Minute; input to output All 1 Minute; input to case (base plate) All Min. Typ. 1 Minute; output to case (base plate) All Input to output All Input to output All Input to case (base plate) All None Output to case (base plate) All 10000 Max. Units 3000 Vac 4200 Vdc 2500 Vac 3500 Vdc 500 Vac 700 100 Vdc MΩ None pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse width modulation (PWM), fixed Device Min. Typ. Max. Units All 330 360 390 KHz On/Off Control, Positive Remote On/Off Logic, Refer to -Vin Pin Logic Low (Module Off) Von/off at Ion/off=1.0mA Logic High (Module On) Von/off at Ion/off=0.0uA, Pin open=on -M2 0 1.0 Others 0 1.2 All 3.5 75 V V V On/Off Control, Negative Remote On/Off Logic, Refer to -Vin Pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for Both Remote On/Off Logic) Leakage Current (for Both Remote On/Off Logic) www.cincon.com Von/off at Ion/off=0.0uA, Pin open=off Von/off at Ion/off=1.0mA All 3.5 75 -M2 0 1.0 Others 0 1.2 Ion/off at Von/off=0V All Logic high, Von/off=15V All 3 0.3 V 1 mA 30 uA REVISION: V14 CQB150-300S PARAMETER NOTES and CONDITIONS Off Converter Input Current Shutdown input idle current Temperature at the center part of base plate, non-latching Over Temperature Shutdown Device Over Temperature Recovery Min. Series Typ. Max. Units All 2.5 4 mA All 110 ℃ All 100 ℃ GENERAL SPECIFICATIONS PARAMETER MTBF NOTES and CONDITIONS Io=100% of Io_max.; MIL-HDBK - 217F_Notice 1, GB, 25℃ Device Plastic, DAP, UL 94V-0 Base plate Material Aluminum Potting Material UL 94V-0 Base: Copper Plating: Nickel with Matte Tin MIL-STD-810F/EN61373 Pin Material Shock/Vibration Typ. 300S05 810 300S12 870 300S15 930 300S24 900 300S28 790 300S48 1100 All 65 Weight Case Material Min. Max. Units K hours grams Humidity 95% RH max. Non Condensing Altitude 2000m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F Fire & Smoke EN45545-2 Compliant EMI Meets EN55032 & EN55022 Compliant (with external filter) ESD EN61000-4-2 Level 3: Air ±8kV, Contact ±6kV Perf. Criteria A Radiated immunity EN61000-4-3 Level 3: 80~1000MHz, 20V/m Perf. Criteria A Fast Transient EN61000-4-4 Level 3: On power input port, ±2kV, external input capacitor required Perf. Criteria A Surge EN61000-4-5 Level 4: Line to earth, ±4kV, Line to line, ±2kV Perf. Criteria A Conducted immunity Power Frequency Magnetic Field immunity Application Note Link EN61000-4-6 Level 3: 0.15~80MHz, 10V Perf. Criteria A EN61000-4-8 50/60Hz, 3A/m (r.m.s.) Perf. Criteria A Class A CQB150-300S Series App Notes Packaging Information Link Packaging Information Immunity to Environmental Conditions Phenomenon Reference Clause Vibration Test MIL-STD-810F Table 514.5C-VIII Figure 514.5C-6 MIL-STD-810F Shock Test MIL-STD-810F 516.5 Table 516.5-I MIL-STD-810F Thermal Shock Cycling Test MIL-STD-810F 503.4 Figure 503.4-1 MIL-STD-810F Thermal Humidity Cycling Test MIL-STD-810F Notice 3 Method 507.4 MIL-STD-810F www.cincon.com Reference Standard 4 Test Conditions Unit are Non-Operating Vibration Waveform: Random Vibration Frequency: 15 ~ 2000 Hz Vibration axis: X、Y、Z axis Duration: 1hr / axis Wave form: Sawtooth Wave Test Category: Crash Hazard Test for Ground Equipment Duration: 10 ms Peak Acceleration: 75 G Cross-Over Frequency: 80 Hz No. of Shock:Each axis 3 times Shock Direction: ±X, ±Y, ±Z axis Temperature: -55℃ to 105℃ Humidity: 95%RH Duration: 8hrs/ 3 times cycling & 4hrs dwell time Temperature: 60℃ to 30℃ Humidity: 95%RH Duration: 240 hrs Result Pass Pass Pass Pass REVISION: V14 CQB150-300S Series EN45545-2 Fire & Smoke Test Conditions Item Standard Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test Hazard Level EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013 EN 60695-2-11:2001 EN 45545-2: 2013 EN 60695-11-10: 2013 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 CHARACTERISTIC CURVE Power Derating Curve CQB150-300S12, 15, 24, 28, 48 Derating Curve without Heatsink (Vin=300V) 110 100 90 80 70 60 50 40 30 20 10 0 Output Power (%) 0 10 20 30 40 50 60 70 80 90 Output Power (%) Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 100 110 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 90 100 110 CQB150-300S05 Derating Curve with Heatsink QBL127 (Vin=300V) CQB150-300S12, 15, 24, 28, 48 Derating Curve with Heatsink QBL127 (Vin=300V) Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 10 Natural 100 ft./min. Ambient Temperature (℃) 110 100 90 80 70 60 50 40 30 20 10 0 0 110 100 90 80 70 60 50 40 30 20 10 0 Ambient Temperature (℃) Output Power (%) Output Power (%) CQB150-300S05 Derating Curve without Heatsink (Vin=300V) 20 30 40 50 60 70 80 90 100 110 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 Ambient Temperature (℃) www.cincon.com 110 100 90 80 70 60 50 40 30 20 10 0 10 20 30 40 50 60 70 80 90 100 110 Ambient Temperature (℃) 5 REVISION: V14 CQB150-300S 110 100 90 80 70 60 50 40 30 20 10 0 CQB150-300S12, 15, 24, 28, 48 Derating Curve with Heatsink QBT210 (Vin=300V) Output Power (%) Output Power (%) CQB150-300S05 Derating Curve with Heatsink QBT210 (Vin=300V) Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 90 Series 110 100 90 80 70 60 50 40 30 20 10 0 100 110 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 90 100 110 Ambient Temperature (℃) Ambient Temperature (℃) Performance Data CQB150-300S05 Eff Vs Io @25 Deg. C CQB150-300S05 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficiency (%) 90% 85% 80% 75% 180V 70% 300V 65% 60% 10% 425V 24 21 18 15 12 9 180V 6 300V 3 425V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) CQB150-300S12 Eff Vs Io @25 Deg. C CQB150-300S12 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficiency (%) 90% 85% 80% 75% 180V 70% 300V 65% 60% 10% 425V 24 21 18 15 12 9 180V 6 300V 3 425V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) CQB150-300S15 Eff Vs Io @25 Deg. C CQB150-300S15 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficiency (%) 90% 85% 80% 75% 180V 70% 300V 65% 60% 10% 425V 24 21 18 15 12 9 180V 6 300V 3 425V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 6 REVISION: V14 CQB150-300S CQB150-300S24 Eff Vs Io @25 Deg. C Series CQB150-300S24 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficiency (%) 90% 85% 80% 75% 180V 70% 300V 65% 60% 10% 425V 24 21 18 15 12 9 180V 6 300V 3 425V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) CQB150-300S28 Eff Vs Io @25 Deg. C CQB150-300S28 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficiency (%) 90% 85% 80% 75% 180V 70% 300V 65% 60% 10% 425V 24 21 18 15 12 9 180V 6 300V 3 425V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) CQB150-300S48 Eff Vs Io @25 Deg. C CQB150-300S48 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficiency (%) 90% 85% 80% 75% 70% 180V 65% 300V 60% 425V 55% 10% 24 21 18 15 12 9 180V 6 300V 3 425V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 7 REVISION: V14 CQB150-300S Series MECHANICAL SPECIFICATION Mounting lnserts M3*0.5 Through 2pl. Φ0.040[1.02] 6pl. 0.50[12.7] 0.60 [15.2] 1.86 [47.2] Φ0.059 [1.50] 2pl. 0.600 [15.24] BOTTOM VIEW 3 4 2 5 6 1 7 8 0.150 [3.81] 0.16 [4.1] 0.16 [4.1]min. 0.300 [7.62] 1.957 [49.70] 1.03[26.2] 1.45 [36.8] 0.525 [13.34] 0.150 [3.81] 2.28 [57.9] PIN CONNECTION PIN Function 1 +V Input 2 On/Off 3 -V Input 4 -V Output 5 -Sense 6 Trim 7 +Sense 8 +V Output All Dimensions in Inches[mm] Tolerance Inches:x.xx=±0.02 ,x.xxx=±0.010 Millimeters:x.x=±0.5 , x.xx=±0.25 sales@cincon.com.tw www.cincon.com 8 REVISION: V14
CQB150-300S05 价格&库存
很抱歉,暂时无法提供与“CQB150-300S05”相匹配的价格&库存,您可以联系我们找货
