V15
CHB350 SERIES
231 - 350 WATT 2:1 INPUT
DC-DC CONVERTERS
SINGLE OUTPUT
FEATURES
* 231-350W Isolated Output
* Efficiency to 92.5%
* Fixed Switching Frequency
* Input Under Voltage Protection
* Over Temperature Protection
* Over Voltage/Current Protection
* Remote On/Off
* Industry Standard Half-Brick Package
* Fully Isolated 1500VDC
* UL60950-1 Approval
* High Power Density 123W/in3
MODEL
NUMBER
INPUT
OUTPUT
VOLTAGE VOLTAGE
OUTPUT CURRENT
INPUT CURRENT
MIN.
MAX.
NO LOAD
% CAPACITOR
EFF. LOAD MAX.
FULL LOAD
CHB350-24S3V3□-X 18-36 VDC
3.3 VDC
0 mA
70 A
140 mA
10.94 A
88
10000µF
CHB350-24S05□-X
18-36 VDC
5 VDC
0 mA
70 A
260 mA
16.39 A
89
10000µF
CHB350-24S12□-X
18-36 VDC
12 VDC
0 mA
29.2 A
250 mA
16.13 A
90.5
10000µF
CHB350-24S24□-X
18-36 VDC
24 VDC
0 mA
14.6 A
60 mA
16.40 A
89
10000µF
CHB350-24S28□-X
18-36 VDC
28 VDC
0 mA
12.5 A
60 mA
16.11 A
CHB350-24S48□-X
18-36 VDC
48 VDC
0 mA
7.3 A
60 mA
16.22 A
90
100-2200µF
CHB350-48S3V3□-X 36-75 VDC
3.3 VDC
0 mA
70 A
90 mA
5.41 A
89
10000µF
CHB350-48S05□-X
36-75 VDC
5 VDC
0 mA
70 A
130 mA
8.01 A
91
10000µF
CHB350-48S12□-X
36-75 VDC
12 VDC
0 mA
29.2 A
100 mA
7.89 A
92.5
10000µF
CHB350-48S24□-X
36-75 VDC
24 VDC
0 mA
14.6 A
60 mA
7.98 A
91.5
10000µF
CHB350-48S28□-X
36-75 VDC
28 VDC
0 mA
12.5 A
60 mA
7.93 A
92
100-7000µF
CHB350-48S48□-X
36-75 VDC
48 VDC
0 mA
7.3 A
60 mA
7.93 A
92
100-2200µF
90.5 100-7000µF(3)
(3)
(3)
NOTE:
1. □= N or None, X can be L, I, C, IC
2. Nominal Input Voltage 24, 48VDC
3. The output terminal of 28Vout and 48Vout models required a minimum capacitor 100uF to maintain
specified regulation.
1
(3)
V15
SPECIFICATIONS
All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENRAL SPECIFICATIONS:
Input Voltage Range ..……………............ 24V ................. 18-36V
48V …………… 36-75V
Input Surge Voltage (100ms max.) .…..……. 24V ............. 50Vdc max.
48V ….…… 100Vdc max.
Under Voltage Lockout ………..….. 24Vin power up ….…..……..…. 17V
24Vin power down ………..…. 16V
48Vin power up …………...…. 35V
48Vin power down ………..…. 33V
Positive Logic Remote On/Off (note4)
Logic Compatibility ………… Open Collector ref to -Input
Module on …….……. >3.5Vdc to 75Vdc or Open Circuit
Module off ……..….……………………..….. 0 to < 1.2Vdc
Input Filter ………………………………………………..….……... Pi Type
Efficiency .................…..................................……........…....... See Table
Isolation Voltage ................ Input/Output ....………..….. 1500VDC min.
Input/Case, Output/Case ….. 1500VDC min.
7
Isolation Resistance .............................…..................…….... 10 ohm min.
Isolation Capacitance …………………..……………………… 2000pF typ.
Switching Frequency ......................... 3V3&5V ..................... 300KHz typ.
12V&24V&28V&48V …… 330KHz typ.
Operating Case Temperature ..………....….....……........ -40℃ to 100℃
Storage Temperature ……….………....…....……............ -55℃ to +105℃
Thermal Shutdown Case Temp …..….…………………..……. 110℃ typ.
Humidity .................................................... 95% RH max. Non condensing
MTBF………. MIL-HDBK-217F, GB, 25℃, Full Load ……… 700Khrs typ.
Dimensions .... Standard ..... 2.28×2.40x0.52 inches (57.9x61.0×13.2 mm)
OUTPUT SPECIFICATIONS:
Suffix “-L” ….……………. 2.28x2.40x0.50inches (57.9x61.0x12.7mm)
Voltage Accuracy …......................................………….......... ±1.0% max.
Case Material ................….....…… Aluminum Baseplate with Plastic Case
Transient Response: 25% Step Load Change ……..…………… 3.5VDC to 75VDC or open circuit
5. Suffix “-C” to the model number with clear mounting Insert. (3.2mm DIA)
6. Suffix “-I” to the model number with thin input pin models
(pin1 and pin4 =1.0mm).
7. Trim-up…………..connect a resistor between the trim pin and +Sense
Trim-down…….….connect a resistor between the trim pin and -Sense
8. The input terminal recommend to parallel with 220uF for 48Vin and
470uF for 24Vin ESR
很抱歉,暂时无法提供与“CHB350-24S3V3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 30+1154.2471230+148.99050
