V13
CFM10/15 SERIES
10/15 WATT OPEN FRAME
AC-DC MODULES
Features
* Universal Input Range 85~264VAC
* Efficiency to 83%
* Meets EN55032 Class B
* Approved IEC/EN/UL62368-1
* Continuous Short Circuit Protection
* Leakage Current 0.25mA Max.
* PCB Mountable
CFM10 Series
MODEL
OUTPUT
OUTPUT
VOLTAGE
CURRENT
RIPPLE &
NOISE
VOLTAGE
ACCURACY
NOTE 1
LINE
LOAD
% EFF.
REGULATION
REGULATION
(Typ.)
NOET 2
NOTE 3
NOTE 4
CFM1001S
5V
2000mA
1%
±1%
±0.5%
±1%
73%
CFM1002S
12V
840mA
1%
±1%
±0.5%
±1%
76%
CFM1003S
15V
670mA
1%
±1%
±0.5%
±1%
76%
CFM1005S
24V
420mA
1%
±1%
±0.5%
±1%
77%
CFM1007S
3.3V
2500mA
50mV
±1%
±0.5%
±1%
67%
CFM1009S
9V
1120mA
1%
±1%
±0.5%
±1%
72%
OUTPUT
OUTPUT
LINE
LOAD
%EFF.
VOLTAGE
CURRENT
REGULATION
REGULATION
(Typ.)
NOTE 2
NOTE 3
NOTE 4
CFM15 SERIES
MODEL
RIPPLE &
NOISE
VOLTAGE
ACCURACY
NOET 1
CFM1501S
5V
3000mA
1%
±1%
±0.5%
±1%
74%
CFM1502S
12V
1250mA
1%
±1%
±0.5%
±1%
80%
CFM1503S
15V
1000mA
1%
±1%
±0.5%
±1%
81%
CFM1505S
24V
630mA
1%
±1%
±0.5%
±1%
83%
CFM1507S
3.3V
3000mA
50mV
±1%
±0.5%
±1%
69%
CFM1509S
9V
1670mA
1%
±1%
±0.5%
±1%
76%
Specifications are subject to change without notice
1
V13
Specifications
CFM10/15 Series Derating Curve
INPUT SPECIFICATIONS:
100%
Rated Load(%)
Voltage …....………........…......................................................... 85~264Vac
120~370Vdc
Frequency ………………………………………….……………...... 47 to 63Hz
Input Current ……………….…..... 100Vac/0.5A max., 240Vac/0.25A max.
Inrush Current ……….. Cold Start@25℃ ……….…… 20A max. @115Vac
40A max. @230Vac
75%
50%
20LFM(Natural Convection)
25%
0%
Leakage Current …………………………………………………. 0.25mA max.
OUTPUT SPECIFICATIONS:
40
50
Ambient Temperature(oC)
60
70
Holdup Time ………………………………………….… 16ms typ. @115Vac
Short Circuit Protection ……………………. Hiccup Mode (Auto Recovery)
Over Voltage Protection ……………................... TVS Component to Clamp
SAFETY AND EMC:
Temperature Coefficient …………………...............................… 0.05%/℃
Emission and Immunity ……………....… EN55032 Class B, EN61000-6-3
GENERAL SPECIFICATIONS:
EN61000-3-2, EN61000-3-3, EN55024
Isolation ……………………………………..……. Input to output = 3000VAC
Operating Temperature .................................. 0 ~ 70℃ (see derating curve)
EN61204-3, EN61000-6-1
Safety ……………………………... IEC/EN/UL62368-1, IEC/EN/UL60950-1
Storage Temperature ……………………………...….......……........ -20~85℃
NOTE:
Humidity ...................................................... 93% RH max. Non condensing
Cooling …………………………………..……………….. Natural Convection
Switching Frequency …………………………...... CFM10: 100KHz Typical
CFM15: 67KHz Typical
MTBF …..…… MIL-HDBK-217F, GB, at 25℃/115VAC …… 200Khrs min.
Altitude ……………………..………………...………………………….. 2000m
Dimensions … CFM10: 2.599x1.772x0.906Inches (65.00x45.00x23.00mm)
1. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for
Ripple & noise measuring @20MHz BW.
2. Line regulation is measured from high line to low line with full load.
3. Load regulation is measured from full to 10% load.
4. Typical efficiency with 230VAC and max. load 25℃.
CFM15: 2.752x1.890x0.906Inches (69.90x48.00x23.00mm)
Weight …………………………………………...... CFM10: 60g (0.13Pounds)
CFM15: 80g (0.18Pounds)
Mechanical Specification
All Dimensions are in inches(mm)
Tolerance:Inches:X.XXX±0.02
Millimeters:X.XX±0.5
VR
0.039 [1.00]
0.039 [1.00]
0.071 [1.80]
0.071 [1.80]
2.126 [54.00]
2.441 [62.00]
Typical at 25˚C, nominal line and 75% load, unless otherwise Specified
2
0.906 [23.00]max
0.063 [1.60]
0.150 [3.80]
0.173 [4.40]
0.906 [23.00]max
0.063 [1.60]
2.752 [69.90]
0.079 [2.00]max
0.150 [3.80]
0.173 [4.40]
1.398 [35.50]
0.492 [12.50]
0.157 [4.00]
1.890 [48.00]
0.161 [4.10]
VR
2.559 [65.00]
0.079 [2.00]max
0.220 [5.60]
0.945 [24.00]
0.492 [12.50]
CFM15 Series
1.280 [32.50]
0.196 [4.97]
0.885 [22.47]
1.772 [45.00]
CFM10 Series
很抱歉,暂时无法提供与“CFM1509S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+141.109401+18.24929
- 5+134.360925+17.37652
- 10+131.5622210+17.01458
- 25+127.9609725+16.54884
