CQB150W-110S48-CMFD
CQB150W-110S48-CMFD
    CINCON
    封闭式 直流转换器 1 输出 48V 3.2A 160V 输入
CQB150W-110S48-CMFD 数据手册
CQB150W-110S CMFC(D) SERIES 150 WATT 4:1 INPUT ISOLATED DC-DC CONVERTERS Features  Efficiency Up to 91%  Fixed Switching Frequency  Regulated Outputs  Remote On/Off  Low No Load Power Consumption  Fully Protected (OTP/OCP/OVP/UVLO)  3000Vdc I/O Isolation  Operating Case Temperature -40 to +100℃  UL 60950-1 2nd (Basic Insulation) Approval for DC Modules  EN 50155 for EMC, Environmental and Characteristic  Shock & Vibration (EN 61373) Compliant  Fire & Smoke EN 45545-2 Compliant  Safety Meets IEC/EN/UL 62368-1  Build-In EMI Filter  Chassis Mount, Baseplate Cooled MODEL INPUT NUMBER CQB150W-110S3V3□-CMFC CQB150W-110S3V3□-CMFD CQB150W-110S05□-CMFC CQB150W-110S05□-CMFD CQB150W-110S12□-CMFC CQB150W-110S12□-CMFD CQB150W-110S15□-CMFC CQB150W-110S15□-CMFD CQB150W-110S24□-CMFC CQB150W-110S24□-CMFD CQB150W-110S28□-CMFC CQB150W-110S28□-CMFD CQB150W-110S48□-CMFC CQB150W-110S48□-CMFD OUTPUT OUTPUT CURRENT INPUT CURRENT % FULL LOAD EFF. CAPACITOR VOLTAGE VOLTAGE MIN. MAX. NO LOAD LOAD MAX. 43-160 VDC 3.3 VDC 0 mA 30 A 15 mA 1030 mA 87.5 30000uF 43-160 VDC 5 VDC 0 mA 30 A 15 mA 1530 mA 89 30000uF 43-160 VDC 12 VDC 0 mA 12.5 A 15 mA 1500 mA 91 12500uF 43-160 VDC 15 VDC 0 mA 10 A 15 mA 1500 mA 91 10000uF 43-160 VDC 24 VDC 0 mA 6.3 A 15 mA 1560 mA 88 6300μF 43-160 VDC 28 VDC 0 mA 5.4 A 15 mA 1560 mA 88 5400μF 43-160 VDC 48 VDC 0 mA 3.2 A 15 mA 1560 mA 89.5 1000μF NOTE: 1. Nominal Input Voltage 110 VDC 2. □ = N or none 3. VR1 is Used for Output Voltage Adjustment. 4. Refer to Application Note for Thermal Resistance and Derating Information. 5. TVS is Included for Input Surge Voltage Protection. 6. Recommend an External Fuse for Input Reverse Polarity Protection (Shunt Diode is Included Inside). 7.Output connector CN3 wafer with TAIWAN KING PIN TERMINAL P110I series and mate with JST housing PH series or equivalent. 8.CN1&CN2 connector: DINKLE EK500V-04P series or equivalent, suitable electric wire 24~12AWG (IEC 0.5~2.5mm2) PART NUMBER Series CQB150W- CQB150W Nominal Input Voltage II 110:110VDC Number of Outputs O S:Single Nominal Output Voltage XX 3V3:3.3VDC 05:5VDC 12:12VDC 15:15VDC 24:24VDC 28:28VDC 48:48VDC Remote On/Off Logic L None:Positive N:Negative Chassis Mount Type Heatsink -YYY Z Chassis CMF:Mount Built in Filter C:Open Frame D:With Cover +WW None:Blank HS:Heatsink HD:Heatsink+ Din Rail Part Number Example: CQB150W-110S12N-CMFC: Chassis Mount, 150W, 4:1 43-160Vdc Input, Single 12Vdc Output, Negative Logic, Open Frame www.cincon.com 1 REVISION: V15 CQB150W-110S CMFC(D) Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Input Voltage Input Surge Voltage Continuous All -0.3 100ms max. All Operating Case Temperature At the center part of base plate All Storage Temperature Typ. Max. Units 160 Vdc 200 Vdc -40 100 ℃ All -40 105 ℃ Device Min. Typ. Max. Units All 43 110 160 Vdc INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Turn-On Voltage Threshold Full load All 40.5 41.5 42.5 Vdc Turn-Off Voltage Threshold Full load All 37.5 38.5 39.5 Vdc Lockout Hysteresis Voltage Full load Maximum Input Current Vin=43V, Full load No-Load Input Current Vin=110V, Io=0A All 3 3V3 2.65 Others 4 Vdc A See Model Number Table mA OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Voltage Set Point Accuracy Vin=110V, Full load, Tc=25℃ Device Min. All -1.0 Typ. Max. Units +1.0 % Output Voltage Regulation 3V3Vo Load Regulation Full load to no load ±0.5 05Vo Others % ±0.2 Line Regulation Vin=High line to low line, full load All ±0.2 % Temperature Coefficient Tc=-40℃ to 105℃ All ±0.02 %/℃ 3V3Vo 100 Output Voltage Ripple and Noise (5Hz to 20MHz Bandwidth) Peak-to-Peak Full load, 1uF ceramic capacitors RMS. 5Vo 100 12Vo 100 15Vo 100 24Vo 200 28Vo 200 48Vo 300 3V3Vo 40 05Vo 40 12Vo 40 15Vo 40 24Vo 100 28Vo 100 48Vo Output Current Range Vin= 43 to 160V Over Current Protection Hiccup mode. Auto recovery All External Load Capacitance www.cincon.com All Full load (resistive) 110 125 A 160 % Continuous, Auto Recovery See Model Number Table 2 mV 150 See Model Number Table Short Circuit Protection mV uF REVISION: V15 CQB150W-110S CMFC(D) Series PARAMETER NOTES and CONDITIONS Output Voltage Trim Range Po≦max. rated power, Io≦Io_max. Output Voltage Remote Sense Range Po≦max. rated power, Io≦Io_max. % of nominal Vo Limited voltage, % of nominal Vo Over Voltage Protection Device Min. All -10 Typ. All Max. Units +10 % +10 % All 115 125 140 % Device Min. Typ. Max. Units EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=110V See Model Number Table % DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max. Step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (Constant resistive load) All ±5 % All 250 us Von/off to 10%Vo_set, Remote on All 50 Vin_min. to 10%Vo_set, Power up All 50 ms 10%Vo_set to 90%Vo_set All 50 ms ms ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS Isolation Voltage (100% factory Hi-Pot tested @2sec.) 1 Minute; input to output Isolation Resistance Input to output Device 1 Minute; input to case (base plate) 1 Minute; output to case (base plate) All Input to output Input to case (base plate) Output to case (base plate) www.cincon.com Typ. All 3V3Vo Isolation Capacitance Min. 3 100 Max. Units 3000 Vdc 2250 Vdc 500 Vac MΩ 1560 05Vo 1560 12Vo 1560 15Vo 1560 24Vo 1000 28Vo 1000 48Vo 1560 3V3Vo 5700 05Vo 4600 12Vo 7680 15Vo 4580 24Vo 4800 28Vo 6040 48Vo 5820 3V3Vo 9870 05Vo 2670 12Vo 15500 15Vo 19400 24Vo 6700 28Vo 6200 48Vo 15500 pF REVISION: V15 CQB150W-110S CMFC(D) Series FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse width modulation (PWM), fixed Device Min. Typ. Max. Units All 270 300 330 KHz 0 3.5 or Open Circuit 1.2 V 160 V Max. Units 160 V 1.2 V 0.3 1 mA 10 mA On/Off Control, Positive Remote On/Off Logic, Refer to -Vin Pin Logic Low (Module Off) Von/off at Ion/off=0.0uA, Pin open=off All Logic High (Module On) Von/off at Ion/off=1.0mA All PARAMETER NOTES and CONDITIONS Device Min. Typ. On/Off Control, Negative Remote On/Off Logic, Refer to -Vin Pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for Both Remote On/Off Logic) Off Converter Input Current Over Temperature Shutdown Over Temperature Recovery Von/off at Ion/off=1.0mA All Von/off at Ion/off=0.0uA, Pin open=on All Ion/off at Von/off=0.0V All 3.5 or Open Circuit 0 Shutdown input idle current All 5 Temperature at the center part of base plate, non-latching (DC module) All 105 ℃ All 100 ℃ GENERAL SPECIFICATIONS PARAMETER NOTES and CONDITIONS Device 3V3Vo MTBF Io=100% of Io_max.; MIL-HDBK - 217F_Notice 1, GB, 25℃ Min. Typ. 05Vo 544 12Vo 567 15Vo 608 662 28Vo 600 48Vo 603 -CMFC 222 -CMFD 246 -CMFD+HS 487 -CMFD+HD 504 Base plate Material Aluminum Potting Material UL 94V-0 (DC Module) Shock/Vibration EN 50155 (EN 61373) Compliant Humidity 95% RH max. Non condensing Altitude 3000m Operating altitude, 12000m Transport altitude Thermal Shock MIL-STD-810F Fire & Smoke EN 45545-2 Compliant EMI EN 50155 Compliant (external filter required for EN 50121-3-2) ESD EN 61000-4-2 Units 612 24Vo Weight Max. K hours grams Class A Level 3: Air ±8kV, Contact ±6kV Perf. Criteria A Radiated Immunity EN 61000-4-3 Level 3: 80~1000MHz, 20V/m Perf. Criteria A Fast Transient EN 61000-4-4 Level 3: On power input port, ±2kV Perf. Criteria A Surge EN 61000-4-5 Level 4: Line to earth, ±4kV, Line to line, ±2kV Perf. Criteria A Conducted Immunity EN 61000-4-6 Level 3: 0.15~80MHz, 10V Perf. Criteria A EN 50155 Class S2: 10ms interruptions, with external hold up circuit and Perf. Criteria A capacitor required EN 50155 Class C2: During a supply break of 30 ms, with external hold up Perf. Criteria B circuit and capacitor required CQB150W-110S CMFC(D) Series App Notes Interruptions of Voltage Supply Supply Change Over Application Note Link Packaging Information Link www.cincon.com Packaging Information 4 REVISION: V15 CQB150W-110S CMFC(D) Series Immunity to Environmental Conditions. Phenomenon Reference Clause(s) Reference Standard Test Conditions Result Class OT6 Temperature: -40℃ Duration: 2 hrs Class OT6 & ST0 Temperature: 85℃ Duration: 6 hrs Low Temperature Start-up test 13.4.4 EN 60068-2-1 Dry Heat Test 13.4.5 EN 60068-2-2 Low Temperature Storage Test 13.4.6 EN 60068-2-1 Temperature: -40℃ Duration: 16 hrs Pass Cyclic Damp Heat Test 13.4.7 EN 60068-2-30 Temperature: 25℃ - 55℃ Humidity: 90% RH Duration: 48 hrs Pass EN 61373 Temperature: 25℃±10℃ Humidity: 50% ±25% RH Frequency range: 5 ~ 150 Hz Vertical: 1.01 ⁄ Transverse: 0.450 ⁄ Longitudinal: 0.700 ⁄ Duration: 10 min / axis Pass EN 61373 Temperature: 25℃±10℃ Humidity: 50% ±25% RH Frequency range: 5 ~ 150 Hz Vertical: 5.72 ⁄ Transverse: 2.55 ⁄ Longitudinal: 3.96 ⁄ Duration: 5 hrs / axis Pass EN 61373 Temperature: 25℃±0℃ Humidity: 50% ±25% RH Frequency range: 5 ~ 150 Hz ±Vertical: 30 ⁄ ±Transverse: 30 ⁄ ±Longitudinal: 50 ⁄ Duration: 30ms x18 (Each axis 3 shocks) Pass Random Vibration Test Simulated Long Life Test at Increased Random Vibration Levels Shock Test 13.4.11 13.4.11 13.4.11 Pass Pass EN 45545-2 Fire & Smoke Test Conditions. Item Standard Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test www.cincon.com EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013 EN 60695-2-11:2001 EN 45545-2: 2013 EN 60695-11-10: 2013 5 Hazard Level HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 REVISION: V15 CQB150W-110S CMFC(D) Series CHARACTERISTIC CURVE Power Derating Curve 110 100 90 80 70 60 50 40 30 20 10 0 Output Power (%) Output Power (%) CQB150W-110S CMFC(D) Derating Curve with Heat Sink FLB254 (Vin=110V) 46 51 61 63 12,15 Vo 5,48 Vo 24,28 Vo 3V3 Vo 0 10 20 30 40 50 60 70 80 90 CQB150W-110S CMFD+HS(HD) Derating Curve (Vin=110V) 110 100 90 80 70 60 50 40 30 20 10 0 100 48 53 12,15 Vo 62 5,48 Vo 24,28 Vo 3V3 Vo 0 Ambient Temperature (℃) 10 20 30 64 40 50 60 70 80 90 100 Ambient Temperature (℃) CQB150W-110S CMFC(D) Derating Curve with Iron Plate 17x17x0.04 inch (Vin=110V) Output Power (%) 110 100 90 80 70 60 50 40 30 20 10 0 56 61 68 12,15 Vo 5,48 Vo 24,28 Vo 3V3 Vo 0 10 20 70 30 40 50 60 70 80 90 100 Ambient Temperature (℃) Performance Data CQB150W-110S3V3-CMFC Eff Vs Io @25 Deg. C CQB150W-110S3V3-CMFC Pd Vs Po @25 Deg. C 25 Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 72V 96V 110V 160V 70% 60% 50% 10% 20% 30% 40% 50% 60% 70% 80% 15 10 5 0 90% 100% 0% Current Load (%) www.cincon.com 43V 72V 96V 110V 160V 20 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 6 REVISION: V15 CQB150W-110S CMFC(D) Series CQB150W-110S05-CMFC Eff Vs Io @25 Deg. C CQB150W-110S05-CMFC Pd Vs Po @25 Deg. C 25 Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 72V 96V 110V 160V 70% 60% 50% 10% 20% 30% 40% 50% 60% 70% 80% 43V 72V 96V 110V 160V 20 15 10 5 0 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CQB150W-110S12-CMFC Eff Vs Io @25 Deg. C CQB150W-110S12-CMFC Pd Vs Po @25 Deg. C 25 Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 72V 96V 110V 160V 70% 60% 50% 10% 20% 30% 40% 50% 60% 70% 80% 43V 72V 96V 110V 160V 20 15 10 5 0 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CQB150W-110S15-CMFC Eff Vs Io @25 Deg. C CQB150W-110S15-CMFC Pd Vs Po @25 Deg. C 25 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 43V 72V 96V 110V 160V 60% 50% 10% 20% 30% 40% 50% 60% 70% 80% 43V 72V 96V 110V 160V 20 15 10 5 0 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CQB150W-110S24-CMFC Eff Vs Io @25 Deg. C CQB150W-110S24-CMFC Pd Vs Po @25 Deg. C 25 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 43V 72V 96V 110V 160V 60% 50% 10% 20% 30% 40% 50% 60% 70% 80% 20 15 10 5 0 90% 100% 0% Current Load (%) www.cincon.com 43V 72V 96V 110V 160V 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 7 REVISION: V15 CQB150W-110S CMFC(D) Series CQB150W-110S28-CMFC Eff Vs Io @25 Deg. C CQB150W-110S28-CMFC Pd Vs Po @25 Deg. C 25 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 43V 72V 96V 110V 160V 60% 50% 10% 20% 30% 40% 50% 60% 70% 80% 10 5 0 0% Output Power (%) CQB150W-110S48-CMFC Eff Vs Io @25 Deg. C CQB150W-110S48-CMFC Pd Vs Po @25 Deg. C Power Dissipation (W) 25 80% 70% 43V 72V 96V 110V 160V 60% 20% 30% 40% 50% 60% 70% 80% 43V 72V 96V 110V 160V 20 15 10 5 0 90% 100% 0% Current Load (%) www.cincon.com 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) 90% Efficiency (%) 15 90% 100% 100% 50% 10% 43V 72V 96V 110V 160V 20 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 8 REVISION: V15 CQB150W-110S CMFC(D) Series MECHANICAL SPECIFICATION 4.60[116.8] 4.200[106.68] CMFC 0.200[5.08] 4-Φ0.177[Φ4.50] 1 2 3 4 5 CN2 6 7 8 0.523[13.30] CN3 JP1 2.40[61.0] CN1 0.200[5.08] 2.000[50.80] VR1 JP2 2 1.26[32.0] 1 3 4 CN3 4.60[116.8] CMFD with Cover 4.200[106.68] 0.200[5.08] 4-Φ0.177[Φ4.50] JP1 1 www.cincon.com 2 CN3 9 3 4 2.49[63.4] 0.248[6.31] JP2 1.35[34.2] 0.523[13.30] CN3 2.000[50.80] VR1 5 CN2 6 7 8 1 CN1 2 3 4 CN1&CN2 PIN CONNECTION PIN Function +V Input 1 2 -V Input 3 Remote 4 Case +V Output 5 6 7 8 +V Output -V Output -V Output CN3 PIN CONNECTION PIN Function 1 -V Output -Sense 2 3 +Sense 4 +V Output *JP1:Short PIN1 & PIN2 *JP2:Short PIN3 & PIN4 All Dimensions In Inches (mm) Tolerance Inches: X.XX=±0.02, X.XXX=±0.010 Millimeters: X.X=±0.5, X.XX=±0.25 REVISION: V15 CQB150W-110S CMFC(D) Series MECHANICAL SPECIFICATION 4.60 [116.8] 2.62 [66.6] 0.19 [4.8] 3.00±0.04[76.2±1.0] CMFD+HS VR1 5 CN2 6 7 8 CN3 LED CN1 1 2 3 4 1 2 3 4 CN3 4-Φ0.13[Φ3.2] JP1 JP2 2.75 [69.9] 0.12 [3.0] 2.49 [63.4] 2.40 [61.0] max. 0.92 [23.5] 4.60 [116.8] CMFD+HD 0.19 [4.8] 2.62 [66.6] VR1 5 CN2 6 7 8 CN3 LED CN1 1 2 3 4 1 2 3 4 CN3 4-Φ0.13[Φ3.2] 0.92 [23.5] JP1 JP2 2.75 [69.9] 2.49 [63.4] PIN Function 1 +V Input 2 -V Input 3 Remote 4 Case 5 +V Output 6 +V Output 7 -V Output 8 -V Output CN3 PIN CONNECTION PIN Function 1 DIN RAIL CLIP +0.5 1.38+0.02 -0.04 35.0-1.0 [ 0.12 [3.0] 3.02 [76.7] max. 3.00±0.04[76.2±1.0] CN1 & CN2 PIN CONNECTION -V Output 2 -Sense 3 +Sense 4 +V Output *JP1:Short PIN1 & PIN2 *JP2:Short PIN3 & PIN4 All Dimensions in Inches[mm] Tolerance Inches: x.xx=±0.02, x .xxx=±0.010 Millimeters: x.x=±0.5, x.xx=±0.25 ] sales@cincon.com.tw www.cincon.com 10 REVISION: V15
CQB150W-110S48-CMFD 价格&库存
很抱歉,暂时无法提供与“CQB150W-110S48-CMFD”相匹配的价格&库存,您可以联系我们找货
