CFM61S150-T
CFM61S150-T
    CINCON
    开放框架 AC DC 转换器 1 输出 15V 90 ~ 264 VAC 输入
CFM61S150-T 数据手册
CFM61S SERIES 60 WATT OPEN FRAME AC-DC MODULES Features ⚫ Universal Input Range 90~264Vac ⚫ High Efficiency up to 90% ⚫ 2”x 2” Compact Size ⚫ Class II ⚫ No Load Input Power Consumption < 0.15W ⚫ Approved IEC/EN/UL 62368-1 Ed 3.0 ⚫ Approved EN 55032 and CISPR/FCC Class B ⚫ Continuous Short Circuit Protection ⚫ Over Voltage Protection ⚫ Peak Load (2 Times of Rated Current (Note7)) MODEL OUTPUT OUTPUT NUMBER VOLTAGE CURRENT CFM61S050 CFM61S120 CFM61S150 CFM61S240 CFM61S360 CFM61S480 5V 12 V 15 V 24 V 36 V 48 V Note: VOLTAGE RIPPLE & ACCURACY NOISE NOTE1 NOTE2 NOTE3 NOTE4 NOTE5 2% 1% 1% 1% 1% 1% 50 mV 120 mV 150 mV 240 mV 360 mV 480 mV ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% 86% 88% 88% 89% 89% 90% 8A 5A 4A 2.5 A 1.67 A 1.25A LINE LOAD %EFF. REGULATION REGULATION (Typ.) 1. Voltage accuracy is set at 100% full load. 2. Add a0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple & noise measuring @20MHz BW. (CFM61S050: Add a 0.1uF ceramic capacitor and a 47uF E.L. capacitor to output for ripple & noise measuring @20MHz BW.) 3. Line regulation is measured from 0Vac to 264Vac with 100% full load. 4. Load regulation measured from 10% to 100% full load. 5. Typical efficiency at 230 Vac and 75% full load at 25℃. 6. Standard input and output connectors (CN1 and CN2) wafer with TAIWAN KING PIN TERMINAL PVHI series and mate with JST housing VHR series or equivalent. 7. PL (Peak load function) Lasting time < 10 seconds with a maximum 10%. Duty cycle and must add external 100uF / 400V capacitor to BC+ & BC-. PART NUMBER Series CFM61 Number of Outputs O CFM61 S:Single Nominal Output Voltage XXX 050:5V 120:12V 150:15V 240:24V Type X Type YZ (Option) Blank:PCB Mount E:Encapsulated Blank PL: Peak Load Function T:Wafer 360:36V 480:48V Part Number Example: CFM61S120-E: Encapsulated, Single 12Vdc Output CFM61S120-E PL: Encapsulated, With PL, Single 12Vdc Output www.cincon.com 1 REVISION: V16 CFM61S Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units 90 264 Vac 120 370 Vdc All -30 80 ℃ Storage Temperature All -30 85 ℃ Operating Altitude All 5000 m Max. Units Input Voltage All Operating Temperature See Derating Curve INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Operating Voltage Range All 100 240 Vac Input Frequency Range All 47 63 Hz 1.5 A Maximum Input Current 100% Load, Vin=100Vac All Inrush Current Vin=240Vac, Cold Start @25℃ All 120 A All 0.25 mA Units Leakage Current (Touch) OUTPUT CHARACTERISTICS PARAMETER Output Voltage Set Point Operating Output Current Range Holdup Time NOTES and CONDITIONS Vin=90Vac~264Vac, Io=Io max, ambient temperature=25℃. Vin=90Vac~264Vac, See Derating Curve Device Min. Typ. Max. CFM61S050 4.9 5 5.1 CFM61S120 11.88 12 12.12 CFM61S150 14.85 15 15.15 CFM61S240 23.76 24 24.24 CFM61S360 35.64 36 36.36 CFM61S480 47.52 48 48.48 CFM61S050 0 8 CFM61S120 0 5 CFM61S150 0 4 CFM61S240 0 2.5 CFM61S360 0 1.67 CFM61S480 0 Vdc A 1.25 Vin=115Vac All 10 ms Load Regulation 10% Load to full load All ±1.0 % Line Regulation Vin=High line to low line All ±1.0 % Output Voltage Regulation Over Voltage Protection Output Ripple and Noise www.cincon.com Clamp output voltage 1. Add a 0.1uF ceramic capacitor and a 10uF aluminum electrolytic capacitor to output. (CFM61S050: Add a 0.1uF ceramic capacitor and 47uF aluminum electrolytic capacitor to output.) 2. Oscilloscope is 20MHz band width. 3. Ambient temperature=25℃ 2 CFM61S050 6.8 CFM61S120 15 CFM61S150 18 CFM61S240 30 CFM61S360 47 CFM61S480 56 Vdc CFM61S050 50 CFM61S120 120 CFM61S150 150 CFM61S240 240 CFM61S360 360 CFM61S480 480 mV REVISION: V16 CFM61S PARAMETER Short Circuit Protection Load Capacitance NOTES and CONDITIONS Device Auto recovery Min. Typ. Max. Units All 1. Input voltage is 115Vac and 230Vac 2. Output is 100% full load 3. Ambient temperature=25℃ CFM61S050 8000 CFM61S120 5000 CFM61S150 4000 CFM61S240 2400 CFM61S360 1680 CFM61S480 Efficiency Series 1. Input voltage is 230Vac. 2. Output is 75% full load 3. Ambient temperature=25℃ uF 680 CFM61S050 86 CFM61S120 88 CFM61S150 88 CFM61S240 89 CFM61S360 89 CFM61S480 90 % ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Input to Output 1 Minute (without dielectric breakdown) All Isolation Resistance Input to output All 100 Device Min. Typ. Max. Units 3000 Vac MΩ FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency All Typ. Max. 65 Units kHz GENERAL CHARACTERISTICS PARAMETER MTBF NOTES and CONDITIONS Device Io=100%; Ta=25℃ per MIL-HDBK-217F I o=100%, Ta=25℃, Telcordia SR332 @75% Load, 40℃ All Humidity Non-condensing Meets MIL-STD-810F Table 516.5,TABLE 516.5- I 10ms, each axis 3 times(±X、±Y、 ±Z axis) Meets MIL-STD-810F Table 514.5C-VIII, 15~2000Hz, X、Y、Z axis, 1 hr(each axis),. total 3 hrs All Vibration Weight Units k hours 2900 26 93 k hours % RH 75 g All 4 g CFM61SXXX 93 CFM61SXXX-E 190 CFM61SXXX CFM61SXXX-E CFM61SXXX-T Safety Max. All CFM61SXXX-T Dimension Typ. 350 All Life Time Shock Min. grams 96 2.00x2.00x1.398 Inches (50.80x50.80x35.50 mm) 2.136x2.136x1.409 Inches (54.25x54.25x35.80 mm) 2.700x2.000x1.343 Inches (68.58x50.80x34.10 mm) Class B Conducted Disturbance Class II, IEC/EN/UL 62368-1 EN 55032,EN 61000-3-2,EN 6100-3-3, EN 61000-6-3, EN 61000-6-4, 47 CFR FCC Part 15 Subpart B, ICES-003 Issue 7 EN 55032:2015+A11:2020, EN 61000-6-3:2007+A1:2011+AC:2012, 47 CFR FCC Part 15 Subpart B Radiated Disturbance EN 55032:2015+A11:2020, EN 61000-6-3:2007+A1:2011+AC:2012, 47 CFR FCC Part 15 Subpart B Class B Harmonic Current Emissions EN 61000-3-2:2019 Voltage Fluctuations & Flicker EN 61000-3-3:2013+A1:2019 EN 55035:2017+A11:2020, EN 61204-3:2000, EN 61000-6-1:2019, EN 61000-6-2:2019 IEC 61000-4-2:2008, Air discharge:±8kV, Contact discharge: ±4kV EMC Emission EMC Immunity Electrostatic Discharge (ESD) www.cincon.com Ed. 3.0 Class B Class A 3 Criterion A Criterion A Criterion A REVISION: V16 CFM61S Series GENERAL CHARACTERISTICS Radio-Frequency, Continuous Radiated Disturbance Electrical Fast Transient (EFT) IEC 61000-4-3:2020 Criterion A IEC 61000-4-4:2012, ±2kV Criterion A Surge Conducted Disturbances, Induced by RF Fields Power Frequency Magnetic Field Voltage Dips IEC 61000-4-5:2014+A1:2017, L-N: ±1kV Criterion A IEC 61000-4-6:2013+COR1:2015 Criterion A IEC 61000-4-8:2009 Criterion A IEC 61000-4-11:2020, Dip: 30% 10ms, Dip: 60% 100ms, Dip >95% 5000ms Criterion A Voltage Interruptions IEC 61000-4-11:2020, >95% 5000ms Criterion B Application Note Link CFM61S Series App Notes CHARACTERISTIC CURVE Power Derating Curve CFM61SXXX Series Output Power vs Ambient Temperature Output Power & Input Voltage 100% Rated Load (%) Rated Load (%) 100% 75% 50% CFM61SXXX Series 25% 0% 75% 50% 20 LFM(Natural Convection) 25% 0% 90 110 130 150 170 190 210 230 250 -30 -20 -10 0 10 20 30 40 50 60 70 80 Ambient Temperature (℃) Input voltage(V) Performance Data CFM61S120 (Eff Vs Io) 95% 90% 90% 85% 85% Efficiency (%) Efficiency (%) CFM61S050 (Eff Vs Io) 95% 80% 75% 115V 70% 65% 60% 10% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 75% 115V 70% 65% 230V 20% 80% 60% 10% 230V 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) 4 REVISION: V16 CFM61S CFM61S240 (Eff Vs Io) 95% 95% 90% 90% 85% 85% Efficiency (%) Efficiency (%) CFMS61S150 (Eff Vs Io) 80% 75% 115V 70% 65% 60% 10% 30% 40% 50% 60% 70% 80% 80% 75% 115V 70% 65% 230V 20% 60% 10% 90% 100% 230V 20% 30% Current Load (%) 90% 90% 85% 85% 80% 75% 115V 70% 65% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 60% 70% 80% 90% 100% 80% 75% 115V 70% 65% 230V 30% 50% CFM61S480 (Eff Vs Io) 95% Efficiency (%) Efficiency (%) CFM61S360 (Eff Vs Io) 20% 40% Current Load (%) 95% 60% 10% Series 60% 10% 230V 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) 5 REVISION: V16 CFM61S Series MECHANICAL SPECIFICATION CFM61SXXX 2.000 [50.80] 4 Φ0.039[Φ1.00] 1.800 [45.72] 2 2 4 1 3 1.168 [29.67] 1.168 [29.67] 0.800 [20.32] Φ0.039[Φ1.00] Φ0.071[Φ1.80] 1.800 [45.72] 0.118 [3.00]max 1.177 [29.90]max 1.398 [35.50]max BOTTOM VIEW 5 6 2.136 [54.25] 3 1 1.100 [27.94] 6 0.150 [3.80] 0.173 [4.40] 0.081 [2.05] 0.800 [20.32] 5 0.400 [10.16] 0.605 [15.37] 0.225 [5.72] 1.409 [35.80] 2.000 [50.80] 0.228 [5.80] 0.400 [10.16] CFM61SXXX-E 0.605 [15.37] 0.293 [7.44] 2.136 [54.25] PIN CONNECTION Pin Function 1 ACL 2 ACN +Vout 3 4 -Vout 5 BC+ 6 BCAll Dimensions In Inches[mm] Tolerance Inches:x.xxx= ± 0.02 Millimeters: x.xx = ± 0.5 2.700 [68.58] 2.400 [60.96] CFM61SXXX-T 0.150 [3.81] 4-Φ0.126[Φ3.2 6 1.343 [34.10]max 1.177 [29.90]max 0.118 [3.00]max 3 2.000 [50.80] CN1 1 0.150 [3.81] CN2 1 1.700 [43.18] 0] AC Input Connector(CN1):TKP PVHI-03N2 or equivalent Terminal Pin Function Mating Housing ACL 1 JST VHR-3N JST SVH-21T-P1.1 2 or equivalent or equivalent 3 ACN DC Output Connector(CN2):TKP PVHI-06 or equivalent Terminal Pin Function Mating Housing +Vout 1 +Vout 2 +Vout 3 JST VHR-6N JST SVH-21T-P1.1 or equivalent or equivalent -Vout 4 5 6 -Vout -Vout All Dimensions In Inches[mm] Tolerance Inches:x.xxx= ± 0.02 Millimeters: x.xx = ± 0.5 sales@cincon.com.tw www.cincon.com 6 REVISION: V16
CFM61S150-T 价格&库存
很抱歉,暂时无法提供与“CFM61S150-T”相匹配的价格&库存,您可以联系我们找货
CFM61S150-T
  • 1+261.193861+33.77947
  • 5+248.730535+32.16762
  • 10+243.5730710+31.50062
  • 25+236.9048925+30.63825
  • 80+228.7022780+29.57743
  • 160+223.95050160+28.96289
  • 320+219.29671320+28.36103
库存:15
