CHB300W-110S48
CHB300W-110S48
    CINCON
    CHB300W-110S48
CHB300W-110S48 数据手册
CHB300W-110S SERIES 198-300 WATT 4:1 INPUT ISOLATED DC-DC CONVERTER Features  Efficiency Up to 91%  Fixed Switching Frequency  Regulated Outputs  Remote On/Off  Low No Load Power Consumption  Fully Protected (OTP/OCP/OVP/UVLO)  3000Vdc I/O Isolation  Operating Case Temperature -40 to +100℃  Half-Brick Size Meet Industrial Standard 2.28”x2.40”x0.50”  CB Test Certificate IEC 60950-1 (Except 3.3Vout)  UL 60950-1 2nd (Basic Insulation) Approval (Except 3.3Vout)  EN 50155 Compliant with External Circuits  Shock & Vibration EN 50155 (EN 61373) Compliant  Fire & Smoke EN 45545-2 Compliant  5000m Operating Altitude  Safety Meets IEC/EN/UL 62368-1 OUTPUT CURRENT MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. 3.3 VDC 0 mA CHB300W-110S3V3 43-160 VDC INPUT CURRENT % EFF. CAPACITOR NO LOAD FULL LOAD (1) LOAD MAX. 60 A 10 mA 2093 mA 86 60000uF MAX. CHB300W-110S05 43-160 VDC 5 VDC 0 mA 60 A 10 mA 3099 mA 88 60000uF CHB300W-110S12 43-160 VDC 12 VDC 0 mA 25 A 10 mA 3030 mA 90 25000uF CHB300W-110S24 43-160 VDC 24 VDC 0 mA 12.5 A 10 mA 3064 mA 89 12500uF CHB300W-110S28 43-160 VDC 28 VDC 0 mA 10.7 A 10 mA 3064 mA 89 10700uF CHB300W-110S48 43-160 VDC 48 VDC 0 mA 6.25 A 10 mA 2997 mA 91 4700uF NOTE: 1. Nominal Input Voltage 110 VDC. 2. An External Input Capacitor 220uF for All Models are Recommended to Reduce Input Ripple Voltage. 3. To Meet EN50155 and RIA12 refer to Application Note. PART NUMBER Series CHB300W- Nominal Input Voltage II Number of Outputs O Nominal Output Voltage XX Remote On/Off Logic Mounting Inserts L -Y (Option) None:Positive N:Negative None: M3x0.5 Mounting Inserts -C: Clear Mounting Insert (3.2mm DIA.) 3V3:3.3VDC 05:05VDC CHB300W 110:110 VDC S:Single 12:12VDC 24:24VDC 28:28VDC 48:48VDC Part Number Example: CHB300W-110S12N-C: Half Brick, 198-300W, 4:1 43-160Vdc Input, Single 12Vdc Output, Negative Logic, Clear Mounting Insert www.cincon.com 1 REVISION: V14 CHB300W-110S Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. -0.3 Typ. Max. Units 160 Vdc 200 Vdc Input Voltage Continuous All Input Surge Voltage 100ms All Operating Case Temperature At the center part of base plate (with derating) All -40 100 ℃ All -55 125 ℃ Device Min. Typ. Max. Units All 43 110 160 Vdc Turn-On Voltage Threshold All 40 42 43 Vdc Turn-Off Voltage Threshold All 37 39 40 Vdc Storage Temperature INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Lockout Hysteresis Voltage Maximum Input Current Vin=43V, Full load All 3 Vo=3.3V 5500 Others 8000 No-Load Input Current Vin=110V, Io=0A Input Filter Pi filter All Inrush Current (I2t) As per ETS300 132-2 All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz All Vdc mA See Model Number Table mA 0.1 40 A2s mA OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Voltage Set Point Accuracy Vin=110V, Full load, Tc=25℃ Device Min. All -1.0 Typ. Max. Units +1.0 % Output Voltage Regulation Load Regulation Full load to no load All ±0.2 % Line Regulation Vin=High line to low line, full load All ±0.2 % Temperature Coefficient Tc=-40℃ to 100℃ All ±0.02 %/℃ Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full load, 10uF aluminum solid and 1uF ceramic capacitors (for 3.3V & 5V: 47uF T521 KO CAP.
CHB300W-110S48 价格&库存
很抱歉,暂时无法提供与“CHB300W-110S48”相匹配的价格&库存,您可以联系我们找货
