CFM60T-01
CFM60T-01
    CINCON
    开放框架 AC DC 转换器 3 输出 5V 12V -12V 90 ~ 264 VAC 输入
CFM60T-01 数据手册
CFM60T SERIES 60W TRIPLE OUTPUT AC-DC MODULES Features ⚫ Universal Input Range 90~264Vac ⚫ Efficiency to 83% ⚫ 2”x 4” Size ⚫ Meets Class I ⚫ Approval IEC/EN/UL 62368-1 ⚫ Approval EN 55032 Class B and CISPR/FCC Class B ⚫ Continuous Short Circuit Protection MODEL OUTPUT NUMBER VOLTAGE CFM60T-01 CFM60T-02 CFM60T-03 CFM60T-04 5V(V1) 12V(V2) -12V(V3) 5V(V1) 15V(V2) -15V(V3) 5V(V1) 24V(V2) -12V(V3) 3.3V(V1) 5V(V2) -12V(V3) OUTPUT CURRENT VOLTAGE RIPPLE& ACCURACY NOISE LINE LOAD O/P REGULATION REGULATION POWER %EFF. (Typ.) Min. Rated Max. NOTE1 NOTE2 NOTE3 NOTE4 Max. NOTE5 0A 0A 0A 0A 0A 0A 0A 0A 0A 0A 0A 0A 4.0 A 3.0 A 0.5 A 4.0 A 2.5 A 0.3 A 4.0 A 1.5 A 0.5 A 6.0 A 3.0 A 0.5 A 5.0 A 3.7 A 0.65 A 5.0 A 3.1 A 0.5 A 5.0 A 1.8 A 0.6 A 7.5 A 3.7 A 0.65 A ±2% ±5% ±5% 50 mV 120 mV 120 mV ±1% ±1% ±1% ±4% ±3% ±5% 62W 83% ±2% ±4% ±5% 50 mV 150 mV 150 mV ±1% ±1% ±1% ±4% ±3% ±5% 62W 83% ±2% ±3% ±5% 50 mV 240 mV 120 mV ±1% ±1% ±1% ±4% ±3% ±5% 62W 83% ±4% ±5% ±5% 50 mV 50 mV 120 mV ±1% ±1% ±2% ±5% ±4% ±5% 40.8W 78% Note: 1. Voltage accuracy is set at 60% rated load and 25℃ Ta. 2. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple & noise measuring @20MHz B.W. 3. Line regulation is measured from 103Vac~127Vac & 207Vac~253Vac with rated load. 4. Load regulation is defined by changing ±40% of measured output load from 60% rated load at other outputs set to 60% rated load. 5. Typical efficiency at 230 Vac and rated load at 25℃. www.cincon.com 1 REVISION: V16 CFM60T Series PART NUMBER Series CFM60 CFM60 Number of Outputs T T:Triple Output Nominal Output Voltage -XX V1:5V 01:V2:12V V3:-12V V1:5V 02:V2:15V V3:-15V V1:5V 03:V2:24V V3:-12V V1:3.3V 04:V2:5V V3:-12V Type -X (Option) None:Open Frame Part Number Example: CFM60T-01: Open Frame Type, 60W, Triple Output V1:5V, V2:12V, V3:-12V www.cincon.com 2 REVISION: V16 CFM60T Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, 100% full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Input Voltage Safety approvals only to the AC input All Operating Temperature See Derating Curve Min. Typ. Max. Units 90 264 Vac 120 370 Vdc All 0 60 ℃ Storage Temperature All -20 85 ℃ Operating Altitude All 2000 m Max. Units INPUT CHARACTERISTICS PARAMETER Device Min. Operating Voltage Range All 100 240 Vac Input Frequency Range All 47 63 Hz Maximum Input Current NOTES and CONDITIONS 100% full load, Vin=100Vac Leakage Current Inrush Current Vin=240Vac, Cold start at 25℃ Typ. All 1.5 A All 3.5 mA All 50 A Max. Units OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device CFM60T-01 CFM60T-02 Output Voltage Set Point Vin=Nominal Vin, Io=60% load, Tc=25℃ CFM60T-03 CFM60T-04 CFM60T-01 CFM60T-02 Operating Output Current Range Vin=90Vac~264Vac , See Derating Curve CFM60T-03 CFM60T-04 Holdup Time www.cincon.com Vin=115Vac All 3 Min. Typ. V1 4.9 5.0 5.1 V2 11.4 12.0 12.6 V3 -12.6 -12.0 -11.4 V1 4.9 5.0 5.1 V2 14.4 15.0 15.6 V3 -15.75 -15.0 -14.25 V1 4.9 5.0 5.1 V2 23.28 24.0 24.72 V3 -12.6 -12.0 -11.4 V1 3.17 3.3 3.43 V2 4.75 5.0 5.25 V3 -12.6 -12.0 -11.4 V1 0 4.0 5.0 V2 0 3.0 3.7 V3 0 0.5 0.65 V1 0 4.0 5.0 V2 0 2.5 3.1 V3 0 0.3 0.5 V1 0 4.0 5.0 V2 0 1.5 1.8 V3 0 0.5 0.6 V1 0 6.0 7.5 V2 0 3.0 3.7 V3 0 0.5 0.65 8 Vdc A ms REVISION: V16 CFM60T PARAMETER NOTES and CONDITIONS Device Min. Typ. Series Max. Units Output Voltage Regulation CFM60T-01 Load Regulation Defined by changing ±40% of measured output load from 60% rated load at other output set to 60% rated load. CFM60T-02 CFM60T-03 CFM60T-04 CFM60T-01 CFM60T-02 Line Regulation Vin=103Vac to 127Vac Vin=207Vac to 253Vac CFM60T-03 CFM60T-04 V1 ±4 V2 ±3 V3 ±5 V1 ±4 V2 ±3 V3 ±5 V1 ±4 V2 ±3 V3 ±5 V1 ±5 V2 ±4 V3 ±5 V1 ±1 V2 ±1 V3 ±1 V1 ±1 V2 ±1 V3 ±1 V1 ±1 V2 ±1 V3 ±1 V1 ±1 V2 ±1 V3 Over Current Protection Hiccup mode (auto recovery) All Short Circuit Protection Hiccup mode (auto recovery) All CFM60T-01 CFM60T-02 Over Voltage Protection Hiccup mode (auto recovery) CFM60T-03 CFM60T-04 CFM60T-01 Output Ripple and Noise 1. Add a 0.1uF ceramic capacitor and a 10uF aluminum electrolytic capacitor to output 2. Oscilloscope is 20MHz bandwidth 3. Ambient temperature=25℃ CFM60T-02 CFM60T-03 CFM60T-04 Efficiency www.cincon.com 1. Vin=230Vac 2. Output is 100% full load 3. Ambient temperature=25℃ 4 % % ±2 120 180 V1 7 V2 15 V1 7 V2 18 V1 7 V2 28 V1 6 V2 V1 V2 V3 V1 V2 V3 V1 V2 V3 V1 V2 V3 7 50 120 120 50 150 150 50 240 120 50 50 120 CFM60T-01 CFM60T-02 83 CFM60T-03 83 CFM60T-04 78 83 % Vdc mV % REVISION: V16 CFM60T Series ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Input to Output 1 Minute All Isolation Resistance Input to Output All 100 Device Min. Typ. Max. 4242 Units Vdc MΩ FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pout=max. rated power All Typ. Max. 65 Units kHz GENERAL SPECIFICATIONS PARAMETER MTBF Humidity Shock Vibration NOTES and CONDITIONS Io=100%; Ta=25℃ per MIL-HDBK-217F I o=100%; Ta=25℃ Telcordia SR332 Non-condensing Meet MIL-STD-810F Table 516.5,Table 516.5-I 10ms, each axis 3 times(±X、±Y、±Z axis) Meet MIL-STD-810F Table 514.5CVIII,15~2000Hz, X、Y、Z axis, 1 hour (each axis),. Total 3 hrs. Weight All Min. Typ. Max. 300 Units k hours 2590 All 93 % RH All 75 g All 4 g 160 grams All Dimensions Safety Device All 4.000x2.000x1.260 Inches (101.60x50.80x32.00 mm) Conducted Disturbance Class I, IEC/EN/UL 62368-1 EN 55032:2015+A11:2020, Class B EN 61000-3-2:2019, EN 61000-3-3:2013+A1:2019, FCC CFR 47 Part 15 EN 55032:2015+A11:2020, FCC CFR 47 Part 15 Class B Radiated Disturbance EN 55032:2015+A11:2020, FCC CFR 47 Part 15 Class B Harmonic Current Emissions EN 61000-3-2:2019 Class A Voltage Fluctuations & Flicker EN 61000-3-3:2013+A1:2019 EMC Immunity EN 55035:2017+A11:2020, IEC 61000-4-2, 3, 4, 5, 6, 8, 11 Electrostatic Discharge (ESD) Radio-Frequency, Continuous Radiated Disturbance Electrical Fast Transient (EFT) IEC 61000-4-2:2008, Air Discharge: ±8kV Contact, Discharge: ±4kV Criterion A IEC 61000-4-3:2020 Criterion A IEC 61000-4-4:2012, ±1kV Criterion A Surge Conducted Disturbances, Induced by RF Fields Power Frequency Magnetic Field IEC 61000-4-5:2014+A1:2017, L-N: ±0.5kV, ±1kV, L-E(Ground): ±0.5kV, ±1kV, ±2kV Criterion A IEC 61000-4-6:2013+COR1:2015 Criterion A IEC 61000-4-8:2009 Criterion A Voltage Dips IEC 61000-4-11:2020, Dips: 30% Reduction, Dips: >95% Reduction Criterion A Voltage Interruptions IEC 61000-4-11:2020, >95% Reduction Criterion B EMC Emission Application Note Link www.cincon.com Ed.3.0 CFM60T Series App Notes 5 REVISION: V16 CFM60T Series CHARACTERISTIC CURVE Power Derating Curve 100% Rate Load (%) 75% 50% 25% 20 LFM(Natural Convection) 0% 0 10 20 30 40 50 60 Ambient Temperature(℃) Performance Data CFM60T-01 (Eff Vs Io) CFM60T-02 (Eff Vs Io) 90% 90% Efficiency (%) 100% Efficiency (%) 100% 80% 70% 115V 60% 50% 10% 230V 20% 30% 40% 50% 60% 70% 80% 80% 70% 60% 50% 10% 90% 100% 115V 230V 20% 30% Current Load (%) CFM60T-03 (Eff Vs Io) Efficiency (%) 90% Efficiency (%) 90% 80% 70% 115V 60% 230V 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 60% 70% 80% 90% 100% CFM60T-04 (Eff Vs Io) 100% 20% 50% Current Load (%) 100% 50% 10% 40% 80% 70% 115V 60% 50% 10% 230V 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) 6 REVISION: V16 CFM60T Series MECHANICAL SPECIFICATION sales@cincon.com www.cincon.com 7 REVISION: V16
CFM60T-01 价格&库存
很抱歉,暂时无法提供与“CFM60T-01”相匹配的价格&库存,您可以联系我们找货
CFM60T-01
  • 1+385.240341+49.73130
  • 10+373.5106910+48.21710
  • 100+343.66135100+44.36380
