EC4AW-48S05H6
EC4AW-48S05H6
    CINCON
    DIP8 模块
    隔离模块 直流转换器 1 输出 5V 1A 18V - 72V 输入
EC4AW-48S05H6 数据手册
V12 EC4AW-H6 SERIES 5-6 WATT DC-DC CONVERTERS ︳ FEATURES * 5-6W Isolated Output * DIP-24 Package * Regulated Outputs * Efficiency to 85% * Continuous Short Circuit Protection * I/O Isolation Voltage 6000VDC * Reinforced Insulation Rated for Working Voltage 300VAC * 5uA Leakage Current * EMI Meets EN55032 Class A * Safety Meets IEC/EN/UL 62368-1 MODEL NUMBER INPUT VOLTAGE OUTPUT VOLTAGE EC4AW-24S05H6 9-36 VDC OUTPUT CURRENT INPUT CURRENT MIN.(4) MAX. 5 VDC 100 mA 1000 mA 10 mA 260 mA % EFF. NO LOAD FULL LOAD (2) (3) 81 CAPACITOR LOAD MAX. 80 1000uF EC4AW-24S12H6 9-36 VDC 12 VDC 50 mA 500 mA 10 mA 295 mA 85.5 85 500uF EC4AW-24D12H6 9-36 VDC ±12 VDC 25 mA ±250 mA 15 mA 298 mA 84.5 84 250uF EC4AW-24D15H6 9-36 VDC ±15 VDC 20 mA ±200 mA 15 mA 298 mA 84.5 84 200uF EC4AW-48S05H6 18-72 VDC 5 VDC 100 mA 1000 mA 5 mA 130 mA 81 80 1000uF EC4AW-48S12H6 18-72 VDC 12 VDC 50 mA 500 mA 5 mA 149 mA 85 84 500uF EC4AW-48D12H6 18-72 VDC ±12 VDC 25 mA ±250 mA 8 mA 150 mA 84 83 250uF EC4AW-48D15H6 18-72 VDC ±15 VDC 20 mA ±200 mA 8 mA 149 mA 85 84 200uF NOTE: 1. Nominal Input Voltage 24 or 48VDC 2. Measured at 12VDC for 24Vin Models, 24VDC for 48Vin Moldels 3. Measured at Nominal Input Voltage 4. Operation Under Minimum Load Will not Damage The Converter, But It May not Meet All Specifications 1 V12 SPECIFICATIONS All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range....……………...........……........ 24Vin .................. 9-36V 48Vin ................. 18-72V Under Voltage Protection ……....….. 24Vin power up ….….…....….. 8.8V typ. 24Vin power down ……….……. 8V typ. 48Vin power up ………..…. 17V typ. 48Vin power down ………….. 16V typ. Leakage Current ….…………………………………………… 5uA max . Input Filter ………………………………………………..….……... Pi Type Input Surge (100ms max.) ………….…...…..... 24Vin .................... 50V max. 48Vin ................... 100V max. Efficiency ..............................................................…..……... See Table Isolation Voltage ..........……………....……..…………….. 6000VDC min. Isolation Resistance .........................…..................……. 109 ohm min. Isolation Capacitance ………………..………….…………..…… 40pF typ. Reinforced Insulation ……… Creepage Distances …….….… 8mm min. Air Clearances ………………. 8mm min. Switching Frequency .......................…..........………………. 100KHz min. Operating Ambient Temperature ……………………..…... -40℃ to +71℃ De-rating, Above 71℃ ………………… Linearly to Zero Power at 100℃ Case Temperature (note4) ………………………………….. 100℃ max. OUTPUT SPECIFICATIONS: Storage Temperature ……………….....….......……........ -40℃ to +100℃ Voltage Accuracy .........................................…………………..…... ±1.5% max. Voltage Balance (Dual) .………….……………………………….…. ±2.0% max. Transient Response: 75% - 100% Step Load Change Error Band ………………….……………….… ±6% Vout Nominal Recovery Time ………………………………..…..……….. < 500us Ripple & Noise, 20MHz BW (with 0.1uF MLCC) .... 5V …... 100mV pk-pk max. EMI ……………………………... Conductive EMI Meet EN55032 Class A Humidity ……………………………..…… 95% RH max. Non Condensing MTBF …… MIL-HDBK-217-F, GB, 25℃, Full Load ……… 1430Khrs typ. Dimensions ……………..… 1.25x0.80x0.40 inches (31.8x20.3x10.2 mm) Case Material ……………………………… Non-Conductive Black Plastic Weight ……………………….………………………………………..... 13.1g 12V/15V … 1% pk-pk max. Temperature Coefficient .………………..……………………. ±0.05%/°C max. Line Regulation (note1) .……………………………...................…. ±0.5% max. Load Regulation .………….…...... Single (note2) ……….........…. ±0.5% max. Dual (note3) …...................…. ±1.0% max. Cross Regulation (Dual output) Load cross variation 25%/100% …. ±5% max. Output Short Circuit Protection .............................................….…. Continuous Start up Time …………………………………………………….……. 1.5ms typ. NOTE: 1. Measured from high line to low line. 2. Measured from full load to 10% load. 3. Measured from full load to 25% load. 4. Maximum case temperature under any operating condition should not be exceeded 100℃. Typical Derating curve for Natural Convection 120% LOAD(% ) 100% -40 71 80% -3.45%/℃ 60% 40% Natural Convection 20% 0% -40 0.08 [2.0] Case A Dimensions: 100 -20 0 20 40 60 o Ambient Temperature( C) 80 PIN CONNECTION SEE NOTE Pin 24 23 1 2 11 12 13 0.600 [15.24] 0.80 [20.3] 0.15 [3.8] +V Input +V Input 2 +V Input +V Input 12 13 15 0.40 [10.2] Dual Output 1 11 0.100 [2.54] 1.25 [31.8] BOTTOM VIEW Single Output Common NP -V Ouput +V Output NP -V Output 15 NP 23 -V Input -V Input 24 -V Input -V Input +V Output * NC-NO CONNECTION WITH PIN * NP-NO PIN NOTE:Pin Size is 0.02±0.002 Inch (0.5±0.05 mm)DIA All Dimensions In Inches (mm) Tolerances Inches: X.XX= ±0.02 , X.XXX= ±0.010 Millimeters: X.X= ±0.5 , X.XX=±0.25 2 100
EC4AW-48S05H6 价格&库存
很抱歉,暂时无法提供与“EC4AW-48S05H6”相匹配的价格&库存,您可以联系我们找货
