EC4SAW-48S05HN
EC4SAW-48S05HN
    CINCON
    SIP-7
    隔离模块 直流转换器 1 输出 5V 1.2A 18V - 75V 输入
EC4SAW-48S05HN 数据手册
EC4SAWH SERIES 6 WATT 4:1 INPUT ISOLATED DC-DC CONVERTER Features  Efficiency Up to 87.5%  Fixed Switching Frequency  Regulated Outputs  Negative Remote On/Off  3000Vdc I/O Isolation  Continuous Short Circuit Protection  Safety Meets IEC/EN/UL 62368-1  Shock & Vibration MIL-STD-810F Compliant OUTPUT CURRENT MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. MAX. 3.3 VDC 0 mA 1500 mA INPUT CURRENT % EFF. CAPACITOR FULL LOAD (3) (2) LOAD MAX. 4 mA 256 mA 81.5 80.5 4700 uF NO LOAD EC4SAW-24S33HN 9-36 VDC EC4SAW-24S05HN 9-36 VDC 5 VDC 0 mA 1200 mA 4 mA 292 mA 85.5 85.5 2200 uF EC4SAW-24S12HN 9-36 VDC 12 VDC 0 mA 500 mA 5 mA 291 mA 88 86 1100 uF EC4SAW-24S15HN 9-36 VDC 15 VDC 0 mA 400 mA 5 mA 286 mA 88 87.5 470 uF EC4SAW-24D05HN 9-36 VDC ±5 VDC 0 mA ±600 mA 4 mA 292 mA 85.5 85.5 1400 uF EC4SAW-24D12HN 9-36 VDC ±12 VDC 0 mA ±250 mA 6 mA 291 mA 88 86 660 uF EC4SAW-24D15HN 9-36 VDC ±15 VDC 0 mA ±200 mA 6 mA 289 mA 87 86.5 220 uF EC4SAW-48S33HN 18-74 VDC 3.3 VDC 0 mA 1500 mA 3 mA 127 mA 81 81 4700 uF EC4SAW-48S05HN 18-74 VDC 5 VDC 0 mA 1200 mA 3 mA 151 mA 84.5 83 2200 uF EC4SAW-48S12HN 18-74 VDC 12 VDC 0 mA 500 mA 3 mA 145 mA 88 86.5 1100 uF EC4SAW-48S15HN 18-74 VDC 15 VDC 0 mA 400 mA 3 mA 144 mA 88.5 87 470 uF EC4SAW-48D05HN 18-74 VDC ±5 VDC 0 mA ±600 mA 4 mA 149 mA 85 84 1400 uF EC4SAW-48D12HN 18-74 VDC ±12 VDC 0 mA ±250 mA 3 mA 144 mA 88 87 660 uF EC4SAW-48D15HN 18-74 VDC ±15 VDC 0 mA ±200 mA 3 mA 144 mA 88 87 220 uF NOTE: 1. Nominal Input Voltage 24 or 48VDC 2. Measured at Nominal Input Voltage 3. Measured at 12VDC for 24Vin, 24VDC for 48Vin PART NUMBER Series EC4SAW Nominal Input Voltage II Number of Outputs O Nominal Output Voltage XX Isolation Voltage Remote On/Off Logic L Y 33: 3.3VDC EC4SAW 24: 24 VDC 48: 48 VDC 05: 5.0VDC S: Single D: Dual 12: 12VDC H: 3000Vdc N: Negative 15: 15VDC Part Number Example: EC4SAW-24S12HN: 6W, 4:1 9-36Vdc Input, Single 12Vdc Output, 3000VDC Isolation, Negative Logic, www.cincon.com 1 REVISION: V10 EC4SAWH Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Input Voltage Continuous Input Surge Voltage 100ms max. Device Min. 24Vin -0.3 Typ. Max. 36 48Vin -0.3 74 24Vin 50 48Vin 100 Units Vdc Vdc Vo=3.3V With de-rating, above 61℃ Vo=5V Vo=±5V Operating Ambient Temperature Vo=12V -40 85 ℃ 105 ℃ 125 ℃ Units Vo=15V With de-rating, above 65℃ Vo=±12V Vo=±15V Maximum Case Temperature At the center part of case plate All Storage Temperature All -55 Device Min. Typ. Max. 24Vin 9 24 36 48Vin 18 48 74 INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Maximum Input Current Vin=9V, Full load. 24Vin 0.8 Vin=18V, Full load. 48Vin 0.4 No-Load Input Current Vin=24, 48V, Io=0A Input Filter Capacitive All Inrush Current (I2t) As per ETS300 132-2. Vin=Nominal, L=12uH, C=47uF, Load=Full load All Input Reflected Ripple Current A See Model Number Table mA 0.1 All Vdc 10 A2s mA OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Max. Units Voltage Set Point Accuracy Vin=24, 48V, Full load, Tc=25℃ All -1.5 Typ. +1.5 % Output Voltage Balance Vin=24, 48V, Full load, Tc=25℃ Dual -1.0 +1.0 % Output Voltage Regulation Load Regulation Full Load to No Load Line Regulation Vin=High line to low line, full load Cross Regulation Asymmetrical load 25%/100% Temperature Coefficient Tc=-40℃ to 85℃ Single ±0.5 Dual ±1.0 xxD05HN ±0.5 Others ±0.2 % % Dual ±5.0 % All ±0.03 %/℃ xxS15HN 120 Others 100 Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full load, Tc=25℃ Output Current Range Vin= 9 to 36V, 18 to 74V Over Current Protection Hiccup mode. Auto recovery See Model Number Table Short Circuit Protection External Load Capacitance www.cincon.com All All Full load (resistive) A 180 % Continuous, Auto Recovery See Model Number Table 2 mV uF REVISION: V10 EC4SAWH Series EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=24V, 48V Device Min. Typ. Max. See Model Number Table Units % DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (Constant resistive load) All ±5 % All 250 us Von/off to 10%Vo_set, Remote on All 15 ms Vin_min to 10%Vo_set, Power up All 15 ms 10%Vo_set to 90%Vo_set All 8 ms ISOLATION CHARACTERISTICS PARAMETER Isolation Voltage (100% factory Hi-Pot tested @2sec.) Isolation Resistance Isolation Capacitance NOTES and CONDITIONS Device 1 minute; Input to output, All Input to output All Input to output All Min. Typ. Max. Units 3000 Vdc 1000 MΩ 50 pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse wide modulation (PWM), Fixed Device Min. All Typ. Max. 580 Units KHz On/Off Control, Negative Remote On/Off logic, Refer to –Vin pin Logic High (Module Off) Von/off at Ion/off All Logic Low (Module On) Pin open=On, high impedance All Off Converter Input Current Shutdown input idle current All 2 4 mA 2.5 mA Max. Units GENERAL SPECIFICATIONS PARAMETER NOTES and CONDITIONS MTBF Io=100% of Io_max; MIL-HDBK - 217F_Notice 1, GB, 25°C Weight Device Typ. All 1850 All 4.8 Case Material Non-Conductive Black Plastic, UL 94V-0 Potting Material Shock/Vibration UL 94V-0 Base: Phosphor Bronze (C5191-H) Plating: Nickel and Bright Tin MIL-STD-810F Compliant Humidity 95% RH max. Non Condensing Altitude 2000m Operating Altitude, 12000m Transport Altitude Pin Material Min. K hours grams Thermal Shock MIL-STD-810F EMI Meets EN55032 (with external filter) ESD Meets EN61000-4-2 Level 2: Air ±8kV, Contact ±4kV Perf. Criteria A Radiated immunity Meets EN61000-4-3 Meets EN61000-4-4 Level 2: 80~1000MHz, 3V/m Level 2: On power input port, ±0.5kV, external input capacitor required Level 2: Line to earth, ±1kV, Line to line, ±0.5kV, external input capacitor required Level 2: 0.15~80MHz, 3V Perf. Criteria A Fast Transient Surge Conducted immunity Meets EN61000-4-5 Meets EN61000-4-6 Application Note Link Perf. Criteria A Perf. Criteria A Perf. Criteria A EC4SAWH Series App Notes Packaging Information Link www.cincon.com Class A Packaging Information 3 REVISION: V10 EC4SAWH Series CHARACTERISTIC CURVE Power Derating Curve Typical Derating curve for Natural Convection Output Power (%) 120% 100% 61 -40 65 80% 60% 40% Vo=3.3 & 5V 20% Vo=12 & 15V 105 0% -40 -20 0 20 40 60 80 100 Ambient Temperature (℃) Performance Data EC4SAW-24S33HN Eff Vs Io @25 Deg. C EC4SAW-24S33HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) Efficincy (%) 90% 80% 9V 70% 12V 24V 36V 60% 10% 1.2 1 0.8 0.6 9V 0.4 12V 24V 0.2 36V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) Output Power (%) EC4SAW-24S05HN Eff Vs Io @25 Deg. C EC4SAW-24S05HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) Efficincy (%) 90% 80% 9V 70% 12V 24V 36V 60% 10% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 1.2 1 0.8 0.6 9V 0.4 12V 24V 0.2 36V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 4 REVISION: V10 EC4SAWH EC4SAW-24S12HN Eff Vs Io @25 Deg. C EC4SAW-24S12HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) Efficincy (%) 95% 85% 75% 9V 12V 65% 24V 36V 55% 10% 1.2 1 0.8 0.6 9V 0.4 12V 24V 0.2 36V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) EC4SAW-24S15HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) Efficincy (%) 95% 85% 75% 9V 12V 65% 24V 36V 1.2 1 0.8 0.6 9V 0.4 12V 24V 0.2 36V 0 20% 30% 40% 50% 60% 70% 80% 0% 90% 100% Current Load (%) EC4SAW-24D05HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) Efficincy (%) 90% 80% 9V 70% 12V 24V 36V 1.2 1 0.8 0.6 9V 0.4 12V 24V 0.2 36V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) EC4SAW-24D12HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) 95% Efficincy (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) EC4SAW-24D12HN Eff Vs Io @25 Deg. C 85% 75% 9V 12V 65% 24V 36V 55% 10% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) EC4SAW-24D05HN Eff Vs Io @25 Deg. C 60% 10% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) EC4SAW-24S15HN Eff Vs Io @25 Deg. C 55% 10% Series 1.2 1 0.8 0.6 9V 0.4 12V 24V 0.2 36V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 5 REVISION: V10 EC4SAWH EC4SAW-24D15HN Eff Vs Io @25 Deg. C EC4SAW-24D15HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) Efficincy (%) 95% 85% 75% 9V 12V 65% 24V 36V 55% 10% 1.2 1 0.8 0.6 9V 0.4 12V 24V 0.2 36V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) EC4SAW-48S33HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) Efficincy (%) 85% 75% 18V 65% 24V 48V 74V 1.2 1 0.8 0.6 18V 0.4 24V 48V 0.2 74V 0 20% 30% 40% 50% 60% 70% 80% 0% 90% 100% Current Load (%) EC4SAW-48S05HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) Efficincy (%) 90% 80% 18V 70% 24V 48V 74V 1.2 1 0.8 0.6 18V 0.4 24V 48V 0.2 74V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) EC4SAW-48S12HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) 95% Efficincy (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) EC4SAW-48S12HN Eff Vs Io @25 Deg. C 85% 75% 18V 24V 65% 48V 74V 55% 10% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) EC4SAW-48S05HN Eff Vs Io @25 Deg. C 60% 10% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) EC4SAW-48S33HN Eff Vs Io @25 Deg. C 55% 10% Series 1.2 1 0.8 0.6 18V 0.4 24V 48V 0.2 74V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 6 REVISION: V10 EC4SAWH EC4SAW-48S15HN Eff Vs Io @25 Deg. C EC4SAW-48S15HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) Efficincy (%) 95% 85% 75% 18V 24V 65% 48V 74V 55% 10% 1.2 1 0.8 0.6 18V 0.4 24V 48V 0.2 74V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) EC4SAW-48D05HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) Efficincy (%) 90% 80% 18V 70% 24V 48V 74V 1.2 1 0.8 0.6 18V 0.4 24V 48V 0.2 74V 0 20% 30% 40% 50% 60% 70% 80% 0% 90% 100% Current Load (%) EC4SAW-48D12HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) Efficincy (%) 95% 85% 75% 18V 24V 65% 48V 74V 1.2 1 0.8 0.6 18V 0.4 24V 48V 0.2 74V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) EC4SAW-48D15HN Pd Vs Po @25 Deg. C 1.4 Power Dissipation (W) 95% Efficincy (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) EC4SAW-48D15HN Eff Vs Io @25 Deg. C 85% 75% 18V 24V 65% 48V 74V 55% 10% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) EC4SAW-48D12HN Eff Vs Io @25 Deg. C 55% 10% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) EC4SAW-48D05HN Eff Vs Io @25 Deg. C 60% 10% Series 1.2 1 0.8 0.6 18V 0.4 24V 48V 0.2 74V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 7 REVISION: V10 EC4SAWH Series MECHANICAL SPECIFICATION 0.70 [17.8] 0.14[3.5] Bottom View 1 2 3 0.36[9.2] 0.01 [0.3] 0.10 [2.5] 0.44[11.1] 0.02 [0.5] 0.16 [4.1] 0.86 [21.8] 6 7 8 0.08 [2.0] PIN CONNECTION Single Dual Pin -V Input -V Input 1 2 +V Input +V Input 3 On/Off On/Off 6 +V Output +V Output 7 -V Output Common 8 NC -V Output All Dimensions In Inches(mm) Tolerances : Inches millimeters X.XX±0.02 X.X±0.5 Pin ±0.002 ±0.05 0.02 [0.5] 8 REVISION: V10
EC4SAW-48S05HN 价格&库存
很抱歉,暂时无法提供与“EC4SAW-48S05HN”相匹配的价格&库存,您可以联系我们找货
