V17
CFM20 SERIES
20 WATT OPEN FRAME
AC-DC MODULES
Features
* Universal Input Range 85~264Vac
* Efficiency to 81%
* Industry Standard Pin Out
* Meets EN55032 Class B
* Continuous Short Circuit Protection
* PCB Mountable Type is Available
MODEL
OUTPUT
MAX.
MIN.
VOLTAGE
LOAD
LOAD
RIPPLE &
VOLTAGE
LINE
LOAD
% EFF.
NOISE
ACCURACY
REGULATION
REGULATION
(Typ.)
NOTE 1
NOTE 2
NOTE 3
NOET 4
NOET 5
CFM2001S
5V
4400 mA
0A
1%
±1%
±0.5%
±1%
72%
CFM2002S
12 V
1800 mA
0A
1%
±1%
±0.5%
±1%
79%
CFM2003S
15 V
1400 mA
0A
1%
±1%
±0.5%
±1%
80%
CFM2005S
24 V
920 mA
0A
1%
±1%
±0.5%
±1%
81%
CFM2007S
3.3 V
4400 mA
0A
50mV
±1%
±0.5%
±1%
66%
CFM2009S
9V
2450 mA
0A
1%
±1%
±0.5%
±1%
76%.
Specifications are subject to change without notice.
1
V17
Specifications
CFM20S Series Derating Curve
INPUT SPECIFICATIONS:
120~370Vdc
Frequency ………………………………………….……………..... 47 to 63Hz
Inrush Current ………………….…………................... 40A max. @230Vac
Conducted EMI …………………………….…………... CISPR/FCC Class B
Leakage Current ………………………………………………….. 3.5mA max.
Rated Load(%)
100%
Voltage …....………........…........................................... 85~264Vac
75%
20LFM(Natural Convection)
50%
25%
0%
OUTPUT SPECIFICATIONS:
Holdup Time ……………………..……………………… 16ms typ. @115Vac
40
50
o
Ambient Temperature( C)
60
70
Short Circuit Protection ……………….…… Hiccup Mode (Auto Recovery)
Over Voltage Protection ……………................ TVS Component to Clamp
Temperature Coefficient ………………….......................... ±0.05%/℃ max.
GENERAL SPECIFICATIONS:
NOTE:
Isolation ……………………………………..…… Input to output = 4,242VDC
1. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for
Operating Temperature ................................ 0 ~ 70℃ (See Derating Curve)
Ripple & Noise measuring @20MHz BW.
Storage Temperature …………………………....….......……........ -20~85℃
2. Voltage accuracy is set at 100% rated load and 25℃ Ta.
Humidity …………………...….......….......... 93% RH max. Non Condensing
3. Line regulation is measured from high line to low line with full load.
Cooling …………………………………………………….. Natural Convection
4. Load regulation is measured from full to 10% load.
Switching Frequency ………………………………………….. 67KHz Typical
5. Typical efficiency at 230VAC and full load at 25℃.
MTBF ………………..… MIL-HDBK-217F, GB, 25℃/115VAC 300Khrs min.
6. Standard input and output connectors wafer with LONG CHU P3060
Altitude ………………………….……………………………………… 2000m
Dimensions ….….….. 3.501x2.000x0.906Inches (88.92x50.80x23.00mm)
series and mate with MOLEX housing 5195 series or equivalent.
7. Model “CFM200XS-P”: Connectors with pcb mountable type.
(CFM200XS-P) 3.501x2.000x 1.000Inches (88.92x50.80x25.40mm)
Weight …………………………….………………….…… 100g (0.22 Pounds)
SAFETY AND EMC:
Emission and lmmunity …………………………….…….… EN55032 Class B
EN61000-6-3, EN61000-3-2, EN61000-3-3
E N 5 5 0 24 , E N 6 12 0 4 - 3, E N 61 0 0 0 - 6 - 1
Safety ……………….…… EN/IEC/UL 60950-1, EN/IEC/UL 62368-1
Mechanical Specification
0.243 [6.17]
1.701 [43.20]
2.000 [50.80]
-Vout
0.173 [4.40]
PE
VR
0.071 [1.80]
0.040 [1.00]
3.019 [76.67]
Typical at 25˚C, nominal line and 75% load, unless otherwise Specified
2
PE
1.000 [25.40]max
VR PE
0.150 [3.80]
18]
Φ3.
25[
0.1
Φ
4
3.
18
All Dimensions are in inches(mm)
Tolerance:Inches:X.XXX±0.02
Millimeters:X.XX±0.5
+Vout
ACN
0.906 [23.00]max
0.
12
5[
Φ
0.063 [1.60]
0.079 [2.00]max
PE
4Φ
0.243 [6.17]
0.156 [3.96]
-Vout
0.150 [3.80]
0.063 [1.60]
0.079 [2.00]max
+Vout
ACN
3.501 [88.92]
3.202 [81.32]
0.240 [6.08]
ACL
2.000 [50.80]
ACL
1.701 [43.20]
0.150 [3.80]
0.311 [7.90]
0.486 [12.34]
3.501 [88.92]
3.202 [81.32]
0.240 [6.08]
0.150 [3.80]
0.625 [15.88]
CFM20XXS-P Series
0.150 [3.80]
CFM20XXS Series
很抱歉,暂时无法提供与“CFM2003S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+154.0052650+20.00451
