CFM61S SERIES
60 WATT OPEN FRAME
AC-DC MODULES
Features
⚫ Universal Input Range 90~264Vac
⚫ High Efficiency up to 90%
⚫ 2”x 2” Compact Size
⚫ Class II
⚫ No Load Input Power Consumption < 0.15W
⚫ Approved IEC/EN/UL 62368-1 Ed 3.0
⚫ Approved EN 55032 and CISPR/FCC Class B
⚫ Continuous Short Circuit Protection
⚫ Over Voltage Protection
⚫ Peak Load (2 Times of Rated Current (Note7))
MODEL
OUTPUT
OUTPUT
NUMBER
VOLTAGE
CURRENT
CFM61S050
CFM61S120
CFM61S150
CFM61S240
CFM61S360
CFM61S480
5V
12 V
15 V
24 V
36 V
48 V
Note:
VOLTAGE
RIPPLE &
ACCURACY
NOISE
NOTE1
NOTE2
NOTE3
NOTE4
NOTE5
2%
1%
1%
1%
1%
1%
50 mV
120 mV
150 mV
240 mV
360 mV
480 mV
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
86%
88%
88%
89%
89%
90%
8A
5A
4A
2.5 A
1.67 A
1.25A
LINE
LOAD
%EFF.
REGULATION REGULATION
(Typ.)
1. Voltage accuracy is set at 100% full load.
2. Add a0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple & noise measuring @20MHz BW.
(CFM61S050: Add a 0.1uF ceramic capacitor and a 47uF E.L. capacitor to output for ripple & noise measuring @20MHz BW.)
3. Line regulation is measured from 0Vac to 264Vac with 100% full load.
4. Load regulation measured from 10% to 100% full load.
5. Typical efficiency at 230 Vac and 75% full load at 25℃.
6. Standard input and output connectors (CN1 and CN2) wafer with TAIWAN KING PIN TERMINAL PVHI series and mate with JST
housing VHR series or equivalent.
7. PL (Peak load function) Lasting time < 10 seconds with a maximum 10%.
Duty cycle and must add external 100uF / 400V capacitor to BC+ & BC-.
PART NUMBER
Series
CFM61
Number of Outputs
O
CFM61
S:Single
Nominal Output Voltage
XXX
050:5V
120:12V
150:15V
240:24V
Type
X
Type
YZ (Option)
Blank:PCB Mount
E:Encapsulated
Blank
PL: Peak Load Function
T:Wafer
360:36V
480:48V
Part Number Example:
CFM61S120-E: Encapsulated, Single 12Vdc Output
CFM61S120-E PL: Encapsulated, With PL, Single 12Vdc Output
www.cincon.com
1
REVISION: V16
CFM61S
Series
TECHNICAL SPECIFICATIONS
(All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.)
ABSOLUTE MAXIMUM RATINGS
PARAMETER
NOTES and CONDITIONS
Device
Min.
Typ.
Max.
Units
90
264
Vac
120
370
Vdc
All
-30
80
Storage Temperature
All
-30
85
Operating Altitude
All
5000
m
Max.
Units
Input Voltage
All
Operating Temperature
See Derating Curve
INPUT CHARACTERISTICS
PARAMETER
Device
Min.
Typ.
Operating Voltage Range
All
100
240
Vac
Input Frequency Range
All
47
63
Hz
1.5
A
Maximum Input Current
100% Load, Vin=100Vac
All
Inrush Current
Vin=240Vac, Cold Start @25℃
All
120
A
All
0.25
mA
Units
Leakage Current (Touch)
OUTPUT CHARACTERISTICS
PARAMETER
Output Voltage Set Point
Operating Output Current
Range
Holdup Time
Vin=90Vac~264Vac, Io=Io max,
ambient temperature=25℃.
Vin=90Vac~264Vac, See Derating Curve
Device
Min.
Typ.
Max.
CFM61S050
4.9
5
5.1
CFM61S120
11.88
12
12.12
CFM61S150
14.85
15
15.15
CFM61S240
23.76
24
24.24
CFM61S360
35.64
36
36.36
CFM61S480
47.52
48
48.48
CFM61S050
CFM61S120
CFM61S150
CFM61S240
CFM61S360
CFM61S480
Vdc
A
1.25
Vin=115Vac
All
10
ms
Load Regulation
10% Load to full load
All
±1.0
Line Regulation
Vin=High line to low line
All
±1.0
Output Voltage Regulation
Output Ripple and Noise
www.cincon.com
Clamp output voltage
1. Add a 0.1uF ceramic capacitor and a 10uF
aluminum electrolytic capacitor to output.
capacitor and 47uF aluminum electrolytic
capacitor to output.)
2. Oscilloscope is 20MHz band width.
3. Ambient temperature=25℃
2
CFM61S050
6.8
CFM61S120
15
CFM61S150
18
CFM61S240
30
CFM61S360
47
CFM61S480
56
Vdc
CFM61S050
50
CFM61S120
120
CFM61S150
150
CFM61S240
240
CFM61S360
360
CFM61S480
480
mV
REVISION: V16
CFM61S
PARAMETER
Load Capacitance
Device
Auto recovery
Min.
Typ.
Max.
Units
All
1. Input voltage is 115Vac and 230Vac
2. Output is 100% full load
CFM61S050
8000
CFM61S120
5000
CFM61S150
4000
CFM61S240
2400
CFM61S360
1680
CFM61S480
Efficiency
Series
1. Input voltage is 230Vac.
2. Output is 75% full load
uF
680
CFM61S050
86
CFM61S120
88
CFM61S150
88
CFM61S240
89
CFM61S360
89
CFM61S480
90
ISOLATION CHARACTERISTICS
PARAMETER
Device
Min.
Input to Output
1 Minute (without dielectric breakdown)
All
Isolation Resistance
Input to output
All
100
Device
Min.
Typ.
Max.
Units
3000
Vac
MΩ
FEATURE CHARACTERISTICS
PARAMETER
Switching Frequency
All
Typ.
Max.
65
Units
kHz
GENERAL CHARACTERISTICS
PARAMETER
MTBF
Device
Io=100%; Ta=25℃ per MIL-HDBK-217F
I o=100%, Ta=25℃, Telcordia SR332
@75% Load, 40℃
All
Humidity
Non-condensing
Meets MIL-STD-810F Table 516.5,TABLE
516.5- I 10ms, each axis 3 times(±X、±Y、
±Z axis)
Meets MIL-STD-810F Table 514.5C-VIII,
15~2000Hz, X、Y、Z axis, 1 hr(each axis),.
total 3 hrs
All
Vibration
Weight
Units
k
hours
2900
26
93
k
hours
% RH
75
g
All
4
g
CFM61SXXX
93
CFM61SXXX-E
190
CFM61SXXX
CFM61SXXX-E
CFM61SXXX-T
Safety
Max.
All
CFM61SXXX-T
Dimension
Typ.
350
All
Life Time
Shock
Min.
grams
96
2.00x2.00x1.398 Inches
(50.80x50.80x35.50 mm)
2.136x2.136x1.409 Inches
(54.25x54.25x35.80 mm)
2.700x2.000x1.343 Inches
(68.58x50.80x34.10 mm)
Class B
Conducted Disturbance
Class II, IEC/EN/UL 62368-1
EN 55032,EN 61000-3-2,EN 6100-3-3, EN 61000-6-3, EN 61000-6-4, 47 CFR FCC Part 15
Subpart B, ICES-003 Issue 7
EN 55032:2015+A11:2020, EN 61000-6-3:2007+A1:2011+AC:2012, 47 CFR FCC Part 15 Subpart B
Radiated Disturbance
Class B
Harmonic Current Emissions
EN 61000-3-2:2019
Voltage Fluctuations & Flicker
EN 61000-3-3:2013+A1:2019
EN 55035:2017+A11:2020, EN 61204-3:2000, EN 61000-6-1:2019,
EN 61000-6-2:2019
IEC 61000-4-2:2008, Air discharge:±8kV, Contact discharge: ±4kV
EMC Emission
EMC Immunity
Electrostatic Discharge (ESD)
www.cincon.com
Ed. 3.0
Class B
Class A
3
Criterion A
Criterion A
Criterion A
REVISION: V16
CFM61S
Series
Radio-Frequency, Continuous
Electrical Fast Transient (EFT)
IEC 61000-4-3:2020
Criterion A
IEC 61000-4-4:2012, ±2kV
Criterion A
Surge
Conducted Disturbances,
Induced by RF Fields
Power Frequency Magnetic
Field
Voltage Dips
IEC 61000-4-5:2014+A1:2017, L-N: ±1kV
Criterion A
IEC 61000-4-6:2013+COR1:2015
Criterion A
IEC 61000-4-8:2009
Criterion A
IEC 61000-4-11:2020, Dip: 30% 10ms, Dip: 60% 100ms, Dip >95% 5000ms
Criterion A
Voltage Interruptions
IEC 61000-4-11:2020, >95% 5000ms
Criterion B
Application Note Link
CFM61S Series App Notes
CHARACTERISTIC CURVE
Power Derating Curve
CFM61SXXX Series
Output Power vs Ambient Temperature
Output Power & Input Voltage
100%
Rated Load (%)
Rated Load (%)
100%
75%
50%
CFM61SXXX Series
25%
0%
75%
50%
20 LFM(Natural Convection)
25%
0%
90
110
130
150
170
190
210
230
250
-30
-20
-10
40
50
60
70
80
Ambient Temperature (℃)
Input voltage(V)
Performance Data
CFM61S120 (Eff Vs Io)
95%
90%
90%
85%
85%
Efficiency (%)
Efficiency (%)
CFM61S050 (Eff Vs Io)
95%
80%
75%
115V
70%
65%
60%
10%
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
www.cincon.com
75%
115V
70%
65%
230V
20%
80%
60%
10%
230V
20%
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
4
REVISION: V16
CFM61S
CFM61S240 (Eff Vs Io)
95%
95%
90%
90%
85%
85%
Efficiency (%)
Efficiency (%)
CFMS61S150 (Eff Vs Io)
80%
75%
115V
70%
65%
60%
10%
30%
40%
50%
60%
70%
80%
80%
75%
115V
70%
65%
230V
20%
60%
10%
90% 100%
230V
20%
30%
Current Load (%)
90%
90%
85%
85%
80%
75%
115V
70%
65%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
www.cincon.com
60%
70%
80%
90% 100%
80%
75%
115V
70%
65%
230V
30%
50%
CFM61S480 (Eff Vs Io)
95%
Efficiency (%)
Efficiency (%)
CFM61S360 (Eff Vs Io)
20%
40%
Current Load (%)
95%
60%
10%
Series
60%
10%
230V
20%
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
5
REVISION: V16
CFM61S
Series
MECHANICAL SPECIFICATION
CFM61SXXX
2.000 [50.80]
4
Φ0.039[Φ1.00]
1.800 [45.72]
2
2
4
1
3
1.168 [29.67]
1.168 [29.67] 0.800 [20.32]
Φ0.039[Φ1.00]
Φ0.071[Φ1.80]
1.800 [45.72]
0.118 [3.00]max
1.177 [29.90]max
1.398 [35.50]max
BOTTOM VIEW
5
6
2.136 [54.25]
3
1
1.100 [27.94]
6
0.150 [3.80]
0.173 [4.40]
0.081 [2.05]
0.800 [20.32]
5
0.400 [10.16]
0.605 [15.37]
0.225 [5.72]
1.409 [35.80]
2.000 [50.80]
0.228 [5.80]
0.400 [10.16]
CFM61SXXX-E
0.605 [15.37]
0.293 [7.44]
2.136 [54.25]
PIN CONNECTION
Pin
Function
1
ACL
2
ACN
+Vout
3
4
-Vout
5
BC+
6
BCAll Dimensions In Inches[mm]
Tolerance Inches:x.xxx= ± 0.02
Millimeters: x.xx = ± 0.5
2.700 [68.58]
2.400 [60.96]
CFM61SXXX-T
0.150 [3.81]
4-Φ0.126[Φ3.2
6
1.343 [34.10]max
1.177 [29.90]max
0.118 [3.00]max
3
2.000 [50.80]
CN1
1
0.150 [3.81]
CN2
1
1.700 [43.18]
0]
AC Input Connector(CN1):TKP PVHI-03N2 or equivalent
Terminal
Pin Function Mating Housing
ACL
1
JST VHR-3N
JST SVH-21T-P1.1
2
or equivalent
or equivalent
3
ACN
DC Output Connector(CN2):TKP PVHI-06 or equivalent
Terminal
+Vout
1
+Vout
2
+Vout
3
JST VHR-6N
JST SVH-21T-P1.1
or equivalent
or equivalent
-Vout
4
5
6
-Vout
-Vout
sales@cincon.com.tw
www.cincon.com
6
REVISION: V16
很抱歉,暂时无法提供与“CFM61S120-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+261.501081+33.82916
- 5+249.017195+32.21418
- 10+243.8549410+31.54636
- 25+237.1781225+30.68261
- 80+228.9661880+29.62027
- 160+224.20895160+29.00485
- 320+219.54974320+28.40211
