CH70150AB5PR
CH70150AB5PR
    COSEMITECH(意瑞)
    SOP-8
    隔离集成式霍尔电流传感器
CH70150AB5PR 数据手册
CH701 Revised March 2022 CH701 3000VRMS Isolation, Hall Current Sensor IC in SOIC-8 Package Features • • • • • • • • • • • • • Reinforced isolation: 3000 VRMS Total output error: ±1.5% typical Primary conductor resistance: 0.8 mΩ Single supply: 3.3V or 5V Output voltage proportional to AC or DC current: ±5A, ±10A, ±20A, ±30A, ±40A, ±50A -3dB bandwidth: 120 kHz Response time: 4 µs Ratio-metric output from supply voltage Adjustable bandwidth and resolution with a filter pin Small-footprint SOIC-8 package suitable for replacing bulky transformers or shunt current sensing solutions Integrated shield virtually eliminates capacitive coupling from current conductor to die, greatly suppressing output noise due to high dv/dt transients Factory-trimmed sensitivity and quiescent output voltage for improved accuracy Chopper stabilization results in extremely stable quiescent output voltage Package ⚫ SO-8 ⚫ Application • • • • Variable-frequency inverters Motor control Over-current fault protection Load detection and management Functional Block Diagram Description The CH701 current sensor IC is an economical and precise solution for AC or DC current sensing in industrial, automotive, commercial, and communications systems. The small package is ideal for space-constrained applications while also saving costs due to reduced board area. Typical applications include motor control, load detection and management, switched-mode power supplies, and overcurrent fault protection. The device consists of a precise, low-offset, linear Hall sensor circuit with a copper conduction path located near the surface of the die. Applied current flowing through this copper conduction path generates a magnetic field which is sensed by the integrated Hall IC and converted into a proportional voltage. A precise, proportional voltage is provided by the low-offset, chopper-stabilized BCD Hall IC, Page 1/62 CH701 Revised March 2022 which is programmed for accuracy after packaging. The output of the device has a positive slope when an increasing current flows through the primary copper conduction path (from pins 1 and 2, to pins 3 and 4), which is the path used for current sensing. The internal resistance of this conductive path is 0.8 mΩ typical, providing low power loss. The terminals of the conductive path are electrically isolated from the sensor leads (pins 5 through 8). This allows the CH701 current sensor IC to be used in high-side current sense applications without the use of high-side differential amplifiers or other costly isolation techniques. The CH701 is provided in a small, low-profile surface-mount SOIC8 package. The leadframe is plated with 100% matte tin, which is compatible with standard lead (Pb) free printed circuit board assembly processes. Internally, the device is Pb-free, except for flip-chip high-temperature Pb-based solder balls, currently exempt from RoHS. The device is fully calibrated prior to shipment from the factory. Similar Products All products can be operated with 3.3V or 5V supply, and can measure AC and DC. Product Family Package RIP CH703 SOIC-8 1.2mΩ 120kHz CH701 SOIC-8 1.2mΩ 120kHz Bandwidth Current Range AECQ100(1) VISO Status NO 2100VRMS Released (contact factory) NO 3000VRMS Released ±5A, ±10A, ±20A, ±30A, ±40A, ±50A ±5A, ±10A, ±20A, ±30A, ±40A, ±50A CH701W SO-16W 0.8mΩ 120kHz ±20A, ±30A, ±40A, ±50A, ±60A, ±70A NO 4800VRMS Released CH706 1.2mΩ 450kHz ±5A, ±10A, ±20A, ±30A, ±40A, ±50A YES 3000VRMS Preliminary 0.8mΩ 450kHz ±5A, ±10A, ±20A, ±30A, ±40A, ±50A, ±60A, ±70A YES 4800VRMS Preliminary CH707W SO-16W 0.8mΩ 450kHz ±5A, ±10A, ±20A, ±30A, ±40A, ±50A, ±60A, ±70A YES 4800VRMS Preliminary *CH704 0.1mΩ 180kHz ±50A, ±100A, ±150A, ±200A YES 4800VRMS Released SOIC-8 CH706W SO-16W CFF-5 *CH704 supply voltage 4.5-5.5V. (1) AEC-Q100 available. Page 2/62 CH701 Revised March 2022 Revision History Change Date Revision Nov 2019 1 May 2021 1.1 Updated format July 2021 1.2 Added “Similar Products” section July 2021 1.3 Corrected AU serials zero voltage. Corrected ELin formula. Aug 2021 1.4 Updated “Similar Products” section Nov 2021 1.5 Updated product naming convention, add “F” for high-bandwidth version. Dec 2021 1.6 Updated top-side-marking factory tracking code from 6 characters to 5 characters Feb 2022 1.7 Updated CH70105**** order information March 2022 1.8 Removed CH70105AU5*/AU3*/BU5*/BB5*/CU3*/CB3*, CH7010AB3*/CU3* First draft Page 3/62 CH701 Revised March 2022 Table of Contents 1 PRODUCT FAMILY MEMBERS .......................................................................... 5 2 PIN DEFINITIONS AND DESCRIPTIONS ........................................................... 6 3 ABSOLUTE MAXIMUM RATINGS ...................................................................... 6 4 ESD PROTECTIONS ........................................................................................... 7 5 ELECTRICAL CHARACTERISTICS:................................................................... 8 6 APPLICATION INFORMATION ......................................................................... 58 7 PACKAGE INFORMATION ............................................................................... 61 Page 4/62 CH701 Revised March 2022 1 Product Family Members CH701 is available in a variety of versions. They are distinguished by a specific nomenclature code: CH701 XX X X X X X X Package Type R: Tape&reel Prefix CH701: Current sensor Hall IC Current Sensing range 05: The maximum absolute value is 5A 10: The maximum absolute value is 10A 20: The maximum absolute value is 20A 30: The maximum absolute value is 30A 40: The maximum absolute value is 40A 50: The maximum absolute value is 50A Chip Package Type P: SOP8 Bandwidth Selection F: High internal bandwidth Blank: Low internal bandwidth Supply Voltage Selection 5: the typical supply voltage = 5V 3: the typical supply voltage = 3.3V Output mode A: VIOUT is proportional to VCC B: VIOUT is set to 2.5V/0.5V C: VIOUT is set to 1.65V/0.33V Current Sensing directional U: unidirectional DC current B: Bidirectional AC current Notes for table 2: • CH70105**** available with “low internal bandwidth” version only, and provide by request only; suggest to use CH70110**** as alternatives, or contact factory for newer-gen CH706. • CH701***U* available with degraded temperature drift performance; provide by request only. Table 1 Part Number VCC (V) IPR (A) Sens (mV/A) Tj (°C) Packing CH70110AB5* CH70110BB5* CH70110CB3* CH70120AB5* CH70120AB3* CH70120BB5* CH70120CB3* CH70130AB5* CH70130AB3* CH70130BB5* CH70130CB3* CH70140AB5* CH70140AB3* CH70140BB5* CH70140CB3* CH70150AB5* CH70150AB3* CH70150BB5* CH70150CB3* 5±0.5 5±0.5 3.3±0.3 5±0.5 3.3±0.3 5±0.5 3.3±0.3 5±0.5 3.3±0.3 5±0.5 3.3±0.3 5±0.5 3.3±0.3 5±0.5 3.3±0.3 5±0.5 3.3±0.3 5±0.5 3.3±0.3 ±10 ±10 ±10 ±20 ±20 ±20 ±20 ±30 ±30 ±30 ±30 ±40 ±40 ±40 ±40 ±50 ±50 ±50 ±50 200 200 132 100 66 100 66 66 44 66 44 50 33 50 33 40 26 40 26 -40 to 150 Tape and Reel, 3000 pieces per reel Part Number VCC (V) IPR (A) Sens (mV/A) Tj (°C) Packing CH70105AB5* CH70105AB3* CH70110AU5* CH70110AU3* CH70110BU5* CH70120AU5* CH70120AU3* CH70120BU5* CH70120CU3* CH70130AU5* CH70130AU3* CH70130BU5* CH70130CU3* CH70140AU5* CH70140AU3* 5±0.5 3.3±0.3 5±0.5 3.3±0.3 5±0.5 5±0.5 3.3±0.3 5±0.5 3.3±0.3 5±0.5 3.3±0.3 5±0.5 3.3±0.3 5±0.5 3.3±0.3 ±5 ±5 10 10 10 20 20 20 20 30 30 30 30 40 40 400 264 370 264 400 200 132 200 132 133 88 133 88 100 66 -40 to 150 Tape and Reel, 3000 pieces per reel Table 2 Page 5/62 CH701 Revised March 2022 CH70140BU5* CH70140CU3* CH70150AU5* CH70150AU3* CH70150BU5* CH70150CU3* 5±0.5 3.3±0.3 5±0.5 3.3±0.3 5±0.5 3.3±0.3 40 40 50 50 50 50 100 66 80 52 80 52 2 Pin Definitions and Descriptions Number Name 1,2 3,4 5 6 7 8 IP+ IP– GND FILTER VIOUT VCC Function Terminals for current being sensed, fused internally Terminals for current being sensed, fused internally Signal ground terminal Terminal for external capacitor that sets bandwidth Analog output signal Device power supply terminal 3 Absolute Maximum Ratings Parameter Symbol Min Max Units Supply Voltage Reverse Supply Voltage VCC VRCC -0.1 6 - V V Output Voltage VIOUT - VCC +0.5 V Reverse Output Voltage VRIOUT -0.1 - V Operating Ambient Temperature TA -40 150 °C Storage Temperature TS -65 165 °C Junction temperature TJ(max) 165 °C Note 1: Exceeding the absolute maximum ratings may cause permanent damage. Exposure to absolute-maximum- rated conditions for extended periods may affect device reliability. Isolation Characteristics Characteristic Dielectric Strength Test Voltage Working Voltage for Basic Isolation Symbol VISO VWVBI Notes Agency type-tested for 60 seconds per UL 62368-1 (edition 3); production-tested at V_ISO for 1 second, in accordance with UL 62368-1 (edition 3). UL62368-1 (edition 3) replaces UL60950-1. Maximum approved working voltage for basic (single) isolation according to UL 62368-1 (edition 3). UL62368-1 (edition 3) replaces UL60950-1. Rating Unit 3000 VRMS 725 Vpk or VDC 513 Vrms Page 6/62 CH701 Revised March 2022 Thermal Characteristics Characteristic Symbol Test Conditions* Value Units Package Thermal Resistance (Junction to Ambient) RθJA 23 ºC/W Package Thermal Resistance (Junction to Lead) RθJL 5 ºC/W 4 ESD Protections Parameter Value Unit All pins 1) ±8000 V All pins 2) ±400 V ±1500 V All pins 3) 1) HBM (human body mode, 100pF, 1.5 kΩ ) according to MIL-STD-883H Method 3015.8 2) MM (Machine Mode C=200pF, R=0Ω) according to JEDEC EIA/JESD22-A115 3) CDM (charged device mode) according to JEDEC EIA/JESD22-C101F Page 7/62 CH701 Revised March 2022 5 Electrical Characteristics: Valid through the full range of TA , VCC = 5 V, CF = 0, unless otherwise specified Characteristic Symbol Test Conditions Min. Typ. Max. Unit Supply Current ICC VCC = 5 V, output open – 10 14 mA Output Capacitance Load CL VIOUT to GND – – 10 nF Output Resistive Load RL VIOUT to GND 4.7 – – kΩ RIP TA = 25°C – 0.8 – mΩ – 1.7 – kΩ Primary Conductor Resistance Internal Filter Resistance 2 RF(int) tr IP = IP(max), TA = 25°C, CL = 1 nF – 3 – μs tpd IP = IP(max), TA = 25°C, CL = 1 nF – 2 – μs tRESPONSE IP = IP(max), TA = 25°C, CL = 1 nF – 4 – μs BW Small signal –3 dB; CL = 1 nF – 120 – kHz Noise Density IND Input-referenced noise density; TA = 25°C, CL = 1 nF – 150 – µA(rms)/ √Hz Noise IN Input-referenced noise: CF = 4.7 nF, CL = 1 nF, BW = 18 kHz, TA = 25°C – 25 – mA(rms) Rise Time Propagation Delay Response Time Bandwidth Nonlinearity ELIN Through full range of IP ±1 % Sensitivity Ratiometry Coefficient SENS_RAT_ VCC = 4.5 to 5.5 V, TA = 25ºC COEF – 1.3 – – Zero-Current Output Ratiometry Coefficient QVO_RAT_ VCC = 4.5 to 5.5 V, TA = 25ºC COEF – 1 – – Saturation Voltage VOH RL = 4.7 kΩ, TA = 25°C VCC – 0.2 – V VOL RL = 4.7 kΩ, TA = 25°C – 0.2 V tPO Output reaches 90% of steadystate level, TA = 25°C, IP = IPR(max) applied – 62 – μs 3 Power-On Time Shorted Output-to-Ground Current ISC(GND) TA = 25ºC – 3.3 – mA Shorted Output-to-VCC Current ISC(VCC) TA = 25ºC – 45 – mA 1 Device may be operated at higher primary current levels, IP, ambient temperatures, TA, and internal leadframe temperatures, provided the Maximum Junction Temperature, TJ(max), is not exceeded. RF(int) forms an RC circuit via the FILTER pin. 3 The sensor IC will continue to respond to current beyond the range of IP until the high or low saturation voltage; however, the nonlinearity in this region will be worse than through the rest of the measurement range. 2 Page 8/62 CH701 Revised March 2022 CH70105AB5* Performance Characteristics: TA Range L, valid at Tj = – 40°C to 150°C, unless otherwise specified Characteristic Min. Typ.1 Max. Unit CC 4.5 – 5.5 V PR -5 – 5 A , VCC = 5V – 400 – mV/A Bidirectional, IP = 0 A, VCC = 5V – VCC × 0.5 – V IP = IPR(max), Tj = -40°C to 150ºC –2 ±1 2 % IP = IPR(max), Tj = -40°C to 150°C –1.5 ±1 1.5 % IP = 0 A, Tj = -40°C to 150ºC –10 ±6 10 mV Symbol Test Conditions Nominal Performance Supply Voltage V Current-Sensing Range I Sensitivity Zero-Current Output Voltage Sens V IOUT(Q) I PR(min)
CH70150AB5PR 价格&库存
很抱歉,暂时无法提供与“CH70150AB5PR”相匹配的价格&库存,您可以联系我们找货
