CI-B03CS01S
CI-B03CS01S
    CHIPINTELLI(启英泰伦)
    智能语音模组
CI-B03CS01S 数据手册
成都启英泰伦科技有限公司 CI-B03CS01S 产品规格书 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 1 / 17 成都启英泰伦科技有限公司 文件历史跟踪 DOCUMENT HISTORY PAGE 文档编号 NO:CI-ARD-470024 REV:A 版本号 Rev. NO. A 发起者 Originator 描述 Description 刘婷 新建 日期 Date 2019/09/20 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 2 / 17 成都启英泰伦科技有限公司 文件名 Title: CI-B03CS01S 产品规格书 生效日期 Effective Date: 2019-09-20 职位 Position 姓名 Name 发起者 Originator 刘婷 审核 Checked by 张飞 批准 Approved by 刘兵 签名 Signature 日期 Date Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 3 / 17 成都启英泰伦科技有限公司 目录 1 产品功能描述....................................................................................................5 2 模块板使用及技术参数....................................................................................6 2.1 模块板各功能介绍..................................................................................6 2.1.1 电源...............................................................................................7 2.1.2 IIC 接口..........................................................................................7 2.1.3 SPI 接口......................................................................................... 8 2.1.4 PWM..............................................................................................8 2.1.5 ESD 设计........................................................................................8 2.1.6 GPIO...............................................................................................8 2.1.7 UART.............................................................................................. 8 2.2 管脚定义.................................................................................................9 2.3 产品尺寸特性.......................................................................................13 2.4 电气特性...............................................................................................14 2.5 使用注意事项.......................................................................................14 3 包装..................................................................................................................16 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 4 / 17 成都启英泰伦科技有限公司 1 产品功能描述 产品名称:智能语音模组(intelligence voice module ) 模块可以实现的功能: (1)离线语音识别,主控 CI1103 语音识别芯片; (2)模组在 5 米安静环境下识别率能达到 97%以上,10 米超远距离语音识 别也可以正常工作; (3)模组板上设计有 LDO、DCDC 电源,模组外围供电设计简单。模组设计 有音频功放,外围只需接麦克风和喇叭即可正常工作; (4)模组接口丰富,包含 3 路 UART,1 组 SPI 接口,1 组 IIC(复用),5 路 PWM。模组可以贴片使用,调试和升级方便。 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 5 / 17 成都启英泰伦科技有限公司 2 模块板使用及技术参数 2.1 模块板各功能介绍 语音识别模块板为单面贴装,主要 IC 包括 CI1103、配套的 SPI NOR Flash、 SGM4890 等。模块支持单麦克风输入,经 CI1103 识别后送给功放芯片驱动喇叭 播放声音。 模块板上通过插针将 CI1103 芯片大部分功能 IO 口引出,方便开发者进行开 发。 模块板实物图如图 1 所示,具体排布位置请参考图 2。 图 1 产品实物图 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 6 / 17 成都启英泰伦科技有限公司 图 2 布局图 2.1.1 电源 如图 2 所示 5V 电源通过第 31 脚电源接口输入,5V 电压经过 LDO 降压为 3.3V 电压,5V 再经过一个 DCDC 降压为 1.2V。模组上 CI1103 需要 3.3V、1.2V 两种电 源才能工作,而功放部分采用 5V 电源供电。 2.1.2 IIC 接口 模组有一组 IIC 用于与外部器件通讯控制,需要增加 4.7K-10K 电阻上拉到 3.3V。 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 7 / 17 成都启英泰伦科技有限公司 2.1.3 SPI 接口 模组有一组 SPI 接口,可以外接 TF 卡或者显示屏,接 TF 卡 SPI 接口上需要 上拉电阻。 2.1.4 PWM 模组有 5 路 PWM 输出,分别为 PWM0、PWM1、PWM3、PWM4、PWM5, 具体应用参照表 1。 2.1.5 ESD 设计 模组上没有设计 ESD 器件, 对与 ESD 高要求的产品可以在底板的接口位置添 加 ESD 器件,包括 MIC、SPK、UART、电源等(详情请咨询 FAE)。 2.1.6 GPIO 模组板所有 IO 都可以配置为 GPIO,模组板一共 22 个 GPIO,所有 GPIO 为 3.3V 电平,与不能兼容电平对接必须进行电平转换,可参考图 3。 2.1.7 UART UART 为 3.3V 电平,与不能兼容电平对接必须进行电平转换,可参考图 3。 正常使用 UART 的收发功能只需和外部连接 UART_TX,UART_RX。 图 3 电平转换电路参考图 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 8 / 17 成都启英泰伦科技有限公司 2.2 管脚定义 表 1 管脚排列表 管脚号 1 管脚名称 GND I/O 类型 P IO 驱 动 IO 上电默 能力 认状态 - - 功能定义 地输入 1.PWM 输出通道 0 2 PWM0 IO,T+D 4mA 2.GPIO[15] IN,T+D 3.SDC_CARD_DETECT_N 1.BOOT_SEL 引脚,与 EN 短 3 SEL IO,T+D 4mA 接,进入调试模式 IN,T+D 2.I2S1_SDO 3.IIS_TEST 1.FLASH_PG_EN 引脚,与 EN 短接,进入 UART 升级模式 4 PG_EN IO,T+D 4mA - 2.I2S1_MCLK 3.IIS_TEST 4.SPI1_CLK 1.I2C1_SCL 5 SCL IO,T+U 4mA IN,T+U 2.UART1_RX 3.GPIO[24] 1.I2C1_SDA 6 SDA IO,T+U 4mA IN,T+U 2.UART1_TX 3.GPIO[23] 7 TX2 IO,T+U 4mA IN,T+U 1.UART2_TX 2.GPIO[25] Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 9 / 17 成都启英泰伦科技有限公司 3.I2C1_SDA 1.UART2_RX 8 RX2 IO,T+U 4mA IN,T+U 2.GPIO[26] 3.I2C1_SCL 4.EXT_INT[1] 9 PWM1 IO,T+D 4mA IN,T+D 10 TCK IO,T+D 4mA IN,T+D 11 TMS IO,T+U 4mA 12 PWM3 IO,T+D 4mA 1.PWM 输出通道 1 2.GPIO[16] 1.JTAG 时钟 2.GPIO[21] 1.JTAG 的 TMS 信号 2.GPIO[22] IN,T+D 1.PWM 输出通道 3 2.GPIO[18] 1.PWM 输出通道 4 13 PWM4 IO,T+D 4mA IN,T+D 2.GPIO[19] 3.I2C1_SDA 1.PWM 输出通道 5 14 PWM5 IO,T+D 4mA - 2.GPIO[20] 3.I2C1_SCL 15 SKP- - - - 喇叭输出 16 SKP+ - - - 喇叭输出 17 RIN - - - 麦克风负极输入 18 LIN - - - 麦克风正极输入 19 MCLK IO,T+D 4mA - 1.I2S1_MCLK 2.GPIO[31]/FLASH_PG_EN Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 10 / 17 成都启英泰伦科技有限公司 3.IIS_TEST 4.SPI1_CLK 1.I2S1_LRCLK 20 LRCK IO,T+D 4mA IN,T+D 2.GPIO[28] 3.IIS_TEST 4.SPI1_DIN 1.I2S1_SCLK 21 SCLK IO,T+D 4mA IN,T+D 2.GPIO[30] 3.IIS_TEST 4.SPI1_DOUT 1.I2S1_SDI 22 SDI IO,T+D 4mA OUT,T+D 2.GPIO[27] 3.IIS_TEST 4.SPI1_CS SDO 23 1.I2S1_SDO IO,T+D 4mA IN,T+D 2.GPIO[29]/BOOT_SEL[1] 3.IIS_TEST 1.SPI1_CLK 24 SPI1_CLK IO,T+D 8mA IN,T+D 2.GPIO[7] 3.SDC0_D2 4.SPI2_D3 1.SPI1_CS 25 SPI1_CS IO,T+U 4mA IN,T+D 2.GPIO[4] 3.SDC0_CLK 4.SPI2_D2 26 SPI1_DI IO,T+D 4mA IN,T+D 1.SPI1_DIN Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 11 / 17 成都启英泰伦科技有限公司 2.GPIO[5] 3.SDC0_CMD 4.SPI2_D0 1.SPI1_DOUT 27 SPI1_DO IO,T+D 8mA IN,T+D 2.GPIO[6] 3.SDC0_D3 4.SPI2_CLK 1.UART0_RX 28 RX0 IO,T+U 4mA IN,T+U 29 TX0 IO,T+U 4mA IN,T+U 30 3.3V P - - 3.3V 电源输出,note1 31 5V P - - 5V 电源输入 32 GND P - - 地输入 2.GPIO[1] 1.UART0_TX 2.GPIO[0] note1:3.3v 输出电流不超过 50mA。 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 12 / 17 成都启英泰伦科技有限公司 2.3 产品尺寸特性 产品尺寸正视图如图 4 所示。 图 4 产品尺寸图 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 13 / 17 成都启英泰伦科技有限公司 2.4 电气特性 表 3 电气特性参数表 参数 条件 最小值 4.5 模组输入电压 典型值 5 最大值 5.5 单位 备注 V NOTE1 NOTE2 模组播音状态电流 32 70 / mA / 45 80 mA / 25 / mA 模组工作环境温度 0 25 85 °C 模组存储环境温度 0 25 85 °C 模组存储湿度 0% / 5% RH IO 接口电平电压 3 3.3 3.6 V 焊接温度 / 220 245 °C 模组板尺寸 32mm X 32.82mm X 3.0mm (正常音量) 8 欧 2W 模组工作电流 待机电流 5V 供电 NOTE3 NOTE4 mm NOTE1:5V 为模组典型输入电压,输入超过 5.5V 电压会损坏模组。 NOTE2:需要为模组预留一组驱动能力为 500mA 的电源输入,喇叭播音瞬 间最大电流可能会达到 500mA。 NOTE3:典型值为静音状态测得。最大值为识别并播音,根据喇叭型号最大 可能需要 500 mA 电流的输入。 NOTE4:模组需要真空保存,开封后 4 小时焊接使用,没使用需要置于 5%RH 干燥柜并在 48 小时内焊接使用,在工厂暴露后需要烘烤。 2.5 使用注意事项 (1)5V 供电需保证 500mA 的额定供电能力,要求电源干净,纹波在 30mV 左右。 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 14 / 17 成都启英泰伦科技有限公司 (2)此模块板的 IO 电平部分为 3.3V 系统,如果 需要接 5V 或 2.5V 逻辑电平,必须加转接电路。 (3)模组板上 PG_EN 与 EN 短接,模组进入 JLINK 升级模式;BOOT_SEL 与 EN 短接,模组进入调试模式。 (4)通讯接口部分可以串联一个小电阻,如 22R。 (5)可以将模块上的喇叭和 MIC 接口引出到主板采用插座接口。 (6)UART0 的 TX 和 RX 信号需要接到底板上,需要通过 UART0 进行固件升 级。 (7)LAYOUT 的时候请注意,5V 输入处增加电容,MIC 走线尽量短;MIC 走线要注意屏蔽,SPK 走线尽量短而粗,走线区域不得有其它走线穿插。 (8)控制底板翘曲程度,防止模块焊接不良。 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 15 / 17 成都启英泰伦科技有限公司 3 包装 1. 装盘:把模块板放入塑料托盘,每一个托盘可装 18pcs,如图 5。 图 5 2. 装袋:将装好模块板的托盘放入防静电袋中真空包装,15 托盘为一袋共 270pcs,真空包装后的托盘如图 6,然后再把真空包放入盒子。 图6 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 16 / 17 成都启英泰伦科技有限公司 图 7 3. 装箱:每 4 包为一箱,每箱数量为 1080pcs。 Chipintelli Technology Co., Ltd. CONFIDENTIAL ALL RIGHTS RESERVED. This document is not to be reproduced, modified, adapted, published, translated in any material form in whole or in part nor disclosed to any third party without the prior written permission of Chipintelli Technology Co., Ltd. 联系邮箱:guang.li@chipintelli.com PAGE 17 / 17
CI-B03CS01S 价格&库存
很抱歉,暂时无法提供与“CI-B03CS01S”相匹配的价格&库存,您可以联系我们找货
