CML3416S-60uH.Min
CML3416S-60uH.Min
    CENKER(岑科)
    SMD-4P,3.4x1.6mm
    贴片共模滤波器
CML3416S-60uH.Min 数据手册
RoHS COMPLIANT Halogen Free WIRE WOUND CHIP COMMON MODE COIL 片式共模绕线电感 ● FEATURES 特性 1.High common mode impedance at high frequency effects excellent noise suppression performance. 高频共模阻抗高,噪声抑制性能优良. 2.20Ω~2000Ω are optional for different noise level and signal frequency 对于不同的噪声电频和信号频率,选择20Ω~2000Ω阻抗. ● APPLICATIONS 用途 1.USB 2.0 line for personal computers and peripheral 电脑和外围设备的USB 2.0线路. 2.IEEE 1394 line for personal computers, DVC, STB 用于计算机、DVC、机顶盒的IEEE 1394线路. 3.LVDS, panel line for liquid display panels, graph card,etc. LVDS,用于液体显示面板的面板线,图形卡等. 3.USB 3.0 line or HDMI2.0 for personal computers and peripheral 电脑和外围设备的USB 3.0或HDMI2.0线路. ● PART NUMBERING SYSTEM 品名系统 CMC A 3216 B A: Type 型号 S - 102 - 2P - T C D E F B: External Dimensions 外形尺寸 A*C C: Material type 材料类型 D: Impedance Value 阻抗值 102 = 1000Ω E: Number of line 2P : 2-Line 双线 F: Packaging : T=Taping and reel ● SHAPES AND DIMENSIONS 外形尺寸 (Unit:mm) Recommended Land Pattern C A G F B E K D1 D2 D2 H TYPE(型号) A B C CMC1210 1.25±0.2 0.8±0.1 1.0±0.2 CMC2012 2.0±0.2 1.2±0.2 CMC3216 3.2±0.2 CML3416 D1 D2 E F G H K 0.33 Ref 0.36 Ref 0.10 Max 1.0 Ref 0.3 Ref 0.5 Ref 1.55 Ref 1.2±0.2 0.5 Ref 0.45 Ref 0.17 Max 1.2 Ref 0.4 Ref 0.8 Ref 2.6 Ref 2.0±0.2 1.6±0.2 0.7 Ref 0.6 Ref 0.22 Max 1.6 Ref 0.4 Ref 1.6 Ref 3.7 Ref 3.4±0.2 2.0±0.2 1.6±0.2 0.7 Ref 0.6 Ref 0.22Max 1.7 Ref 0.5 Ref 1.7 Ref 3.7 Ref CMC3225 3.2±0.2 2.2±0.2 2.5±0.2 0.7 Ref 0.7Ref 0.3Max 3.5Ref 0.6Ref 1.6 Ref 4.4Ref CMC4532 4.5±0.2 2.8±0.2 3.2±0.2 0.8 Ref 1.1 Ref 0.5 Max 3.2 Ref 1.0 Ref 2.7 Ref 5.1 Ref CML4532 4.5±0.2 2.8±0.2 3.2±0.2 0.8 Ref 1.1 Ref 0.5 Max 3.2 Ref 1.0 Ref 2.7 Ref 5.1 Ref Version A5 / Issue date:2022-4-19 ● STRUCTURE AND MATERIAL C A B D Part Components Material A Core Ferrite B I Core Ferrite C Wire Polyurethane enameled copper wire D Epoxy Epoxy resin ● ELECTRICAL CHARACTERISTICS 1. Operating temperature range : -40℃~105℃(Including self - temperature rise) 2. Storage temperature range (packaging conditions): -10℃~+40℃ and RH 70% (Max.) ● TEST AND MEASUREMENT PROCEDURES 1. Common Mode Impedance(Ω) Test equipment: Keysight E4991B / Agilent 4787A or equivalent 2. DC Resistance (DCR) Test equipment: Agilent34420A / Agilent 4338B or equivalent 3. Rated Current (Irms) Irms is direct electric current as chip surface temperature rose just 20 or 40 against chip initial surface temperature (Ta), Temper Rated Current ≥ 1A ∆T 40℃ Max 4. Insulation Resistance Test equipment: Chroma or equivalent TH2683A / ZX6583 ● RECOMMENDED SOLDERING TECHNOLOGIES Re-flowing Profile Preheat condition: 150~200 /60~120sec. Allowed time above 217C: 60~90sec. Max temp: 260 Max time at max temp: 10sec Solder paste: Sn/3.0Ag/0.5Cu Allowed Reflow time: 2 times max ● SPECIFICATION TABLE: CMC1210S Series Part No. Common Mode Impedance(Ω) Test Frequency (MHz) DCR (Ω) Max Max. Rated Current (mA) Rated Voltage (Vdc) Insulation Resistance (MΩ) Min. CMC1210S-200-2P-T 20±25% 100 0.15 500 50 10 CMC1210S-350-2P-T 35±25% 100 0.18 430 50 10 CMC1210S-600-2P-T 60±25% 100 0.30 400 50 10 CMC1210S-900-2P-T 90±25% 100 0.30 400 50 10 CMC1210S-121-2P-T 120±25% 100 0.40 260 50 10 CMC1210S-161-2P-T 160±25% 100 0.40 260 50 10 CMC1210S-181-2P-T 180±25% 100 0.40 250 50 10 CMC2012S-201-2P-T 200±25% 100 0.40 250 50 10 Part No. Common Mode Impedance(Ω) Test Frequency (MHz) DCR (Ω) Max Max. Rated Current (mA) Rated Voltage (Vdc) Insulation Resistance (MΩ) Min. CMC1210U-140-2P-T CMC1210U-350-2P-T CMC1210U-500-2P-T CMC1210U-600-2P-T CMC1210U-900-2P-T 14±25% 35±25% 50±25% 60±25% 90±25% 100 100 100 100 100 0.12 0.30 0.30 0.30 0.40 600 400 300 300 300 50 50 50 50 50 10 10 10 10 10 Part No. Common Mode Impedance(Ω) Test Frequency (MHz) DCR (Ω) Max Max. Rated Current (mA) Rated Voltage (Vdc) Insulation Resistance (MΩ) Min. CMC2012S-300-2P-T 30±25% 100 0.20 450 50 10 CMC2012S-800-2P-T 80±25% 100 0.30 400 50 10 CMC2012S-900-2P-T 90±25% 100 0.30 400 50 10 CMC1210U Series CMC2012S Series CMC2012S-121-2P-T 120±25% 100 0.30 400 50 10 CMC2012S-181-2P-T 180±25% 100 0.35 350 50 10 CMC2012S-201-2P-T 200±25% 100 0.35 330 50 10 CMC2012S-260-2P-T 260±25% 100 0.40 300 50 10 CMC2012S-371-2P-T 370±25% 100 0.45 300 50 10 CMC2012S-801-2P-T 800±25% 100 0.75 300 50 10 CMC2012S-901-2P-T 900±25% 100 0.80 150 50 10 CMC2012S-102-3P-T 1000±25% 100 0.80 150 50 10 Part No. Common Mode Impedance(Ω) Test Frequency (MHz) DCR (Ω) Max Max. Rated Current (mA) Rated Voltage (Vdc) Insulation Resistance (MΩ) Min. CMC2012U-300-2P-T CMC2012U-600-2P-T CMC2012U-900-2P-T CMC2012U-120-2P-T 30±25% 60±25% 90±25% 120±25% 100 100 100 100 0.20 0.30 0.30 0.35 400 300 300 330 50 50 50 50 10 10 10 10 Common Mode Impedance(Ω) Test Frequency (MHz) DCR (Ω) Max Max. Rated Current (mA) Rated Voltage (Vdc) Insulation Resistance (MΩ) Min. 100 100 100 100 100 100 0.30 0.50 0.80 1.00 1.20 1.20 370 310 260 230 200 200 50 50 50 50 50 50 10 10 10 10 10 10 100 1.70 200 50 10 CMC2012U Series CMC3216S/L Series Part No. CMC3216S-900-2P-T CMC3216S-260-2P-T CMC3216S-601-2P-T CMC3216S-102-2P-T CMC3216S-222-2P-T CMC3216S-242-2P-T CML3216S-600-2P-T 90±25% 260±25% 600±25% 1000±25% 2200±25% 2400±25% L:50uH~90uH @100khz CMC3225S Series Part No. CMC3225S-900-2P-T CMC3225S-161-2P-T CMC3225S-271-2P-T CMC3225S-501-2P-T CMC3225S-601-2P-T CMC3225S-801-2P-T CMC3225S-102-2P-T CMC3225S-222-2P-T CMC3225S-242-2P-T CML3225B-510-2P-T CML3225E-101-2P-T Common Mode Impedance(Ω) Test Frequency (MHz) 90±25% 100 160±25% 100 270±25% 100 500±25% 100 600±25% 100 800±25% 100 1000±25% 100 2200±25% 100 2400±25% 100 L:51uH+50%/-30% 100kHZ,0.1v L:51uH+50%/-30% 100kHZ,0.1v DCR (Ω) Max Max. Rated Current (mA) Rated Voltage (Vdc) Insulation Resistance (MΩ) Min. 0.05 0.12 0.13 0.20 0.20 0.20 0.30 0.30 0.30 0.70 1.50 1000 680 640 1000 1000 1000 750 640 640 200 150 50 50 50 50 50 50 50 50 50 80 80 10 10 10 10 10 10 10 10 10 10 10 CMC3225H Series Part No. Indutance(Ω) Test Frequency (MHz) DCR (Ω) Max Max. Rated Current (mA) Rated Voltage (Vdc) Insulation Resistance (MΩ) Min. CMC3225H-501-2P-T CMC3225H-102-2P-T 500±25% 1000±25% 100 100 0.10 0.10 2000 1500 50 50 10 10 Part No. Indutance(uH) Test Frequency (MHz) DCR (Ω) Max Max. Rated Current (mA) Rated Voltage (Vdc) Insulation Resistance (MΩ) Min. CML3416S-60uH.Min 60uH Min 100KHZ,0.1v 1.70 200 50 10 Part No. Common Mode Impedance(Ω) Test Frequency (MHz) DCR (Ω) Max Max. Rated Current (mA) Rated Voltage (Vdc) Insulation Resistance (MΩ) Min. CMC4532S-900-2P-T 90±25% 100 0.05 4000 50 10 CMC4532S-121-2P-T 120±25% 100 0.07 3000 50 10 CML3416S Series CMC4532S Series CMC4532S-201-2P-T CMC4532H-231-2P-T CMC4532S-331-2P-T CMC4532S-601-2P-T CMC4532H-601-2P-T CMC4532S-801-2P-T CMC4532H-102-2P-T CMC4532S-142-2P-T CMC4532S-1000Ω/Min CML4532S Series Part No. CML4532S-11uH CML4532S-220-2P-T CML4532S-51uH CML4532S-101-2P-T 200±25% 230±25% 330±25% 600±25% 600±25% 800±25% 1000±25% 1400±25% 1000ΩMin L:51uH+50%/30%@100khz 100 100 100 100 100 100 100 100 0.10 0.05 0.11 0.12 0.06 0.16 0.11 0.20 1500 3500 1500 1500 2500 1000 2100 700 50 50 50 50 50 50 50 50 10 10 10 10 10 10 10 10 10 1.00 200 50 10 Test Frequency (KHz) 300Ω Min@10MHz 100 500Ω Min@10MHz 100 1000 Min@10MHz 100 2000Ω Min@10MHz 100 Common Mode Impedance(Ω) DCR (Ω) Max 0.60 1.00 1.00 2.00 Max. Rated Current (mA) 360 310 230 200 Rated Voltage (Vdc) 50 50 50 50 Insulation Resistance (MΩ) Min. 10 10 10 10 L(uH) 11+50%/-30% 22+50%/-30% 51+50%/-30% 100+50%/-30% 1. Operating temperature range : -40℃~105℃(Including self - temperature rise) 2. Storage temperature range (packaging conditions): -10℃~+40℃ and RH 70% (Max.) 3. Rated Current (Irms) Irms is direct electric current as chip surface temperature rose just 20℃ or 40℃ against chip initial surface temperature (Ta) Temperature rise: Rated Current < 1A ∆T 20℃ Max Rated Current ≥ 1A ∆T 40℃ Max ● Impedance Vs Frequency Curve: CMC1210 Series CMC1210U Series CMC2012 Series CMC2012U Series CMC3216 Series CML3416 Series CMC3225 Series CMC3225 Series CML4532 Series CMC4532 Series ● PACKAGING SPECIFICATION : 1. Packaging - Cover Tape The force for tearing off cover tape is 10 to 100 grams in the arrow direction. Peel-off speed: 300mm/min. 2. Packaging - Tape & Reel D B0 W P A0 K0 Type Tape Dimension (mm) Reel Dimension (mm) Quantity (Pcs/Reel) W A0 B0 K0 D P A B C CMC1210 8 1.1 1.4 1.0 1.5 4 178 60 13 3000 pcs CMC2012 8 1.55 2.45 1.5 1.5 4 178 60 13 2000 pcs CMC3216 8 1.95 3.7 2.4 1.5 4 178 60 13 2000 pcs CML3416 8 1.95 3.7 2.4 1.5 4 178 60 13 2000 pcs CMC3225 12 2.9 3.5 2.7 1.5 8 330 10.75 2.3 3000 pcs CMC4532 12 3.7 4.85 3 1.5 8 178 60 13 500 pcs
CML3416S-60uH.Min 价格&库存
很抱歉,暂时无法提供与“CML3416S-60uH.Min”相匹配的价格&库存,您可以联系我们找货
