CL9193
300mA High PSRR LDO
GENERAL DESCRIPTION
The CL9193 is a low-dropout voltage regulator designed for portable and wireless applications that
require high PSRR, low quiescent current and excellent line and load transient response.
The CL9193 is designed to work with small 1uF input and output ceramic capacitors.
The CL9193 consumes less than 0.1uA in shutdown mode. The CL9193 is available in 5 pin
SOT23-5L packages. The output standards of 1.2V, 1.3V, 1.5V, 1.8V, 2.0V, 2.5V, 2.7V, 2.8V, 3.0V,
and 3.3V are available.
FEATURES
APPLICATIONS
Input Range
: 2.0V ~ 6.0V
CDMA/GSM mobile phone
Maximum Output Current
: 300mA
PDAs/MP3
High PSRR
: 70dB @ 1KHz
WLAN and bluetooth appliances
Low Quiescent Current
: 40uA (Typ.)
Cordless telephones
Shutdown Mode Current
: < 0.1uA
Battery powered portable devices
Dropout Voltage
: 150mV @ 100mA
Operation Ambient Temperature
: -40 ~ +85°C
Protection
:Current Limit &
SOT23-5L Package Available
Short Protect
TYPICAL APPLICATIONS
CL9193_EN Rev. 1.1
1
www.chiplink-tech.com
CL9193
300mA High PSRR LDO
PIN CONFIGURATION
SOT23-5L
PIN FUNCTIONS
SOT23-5
PIN NAME
FUNCTIONS
1
VIN
Power Input
2
GND
Ground
3
CE
Chip Enable
4
NC
No Connection
5
VOUT
Output
ESD & Latch-up Level
CL9193_EN Rev. 1.1
HBM ESD
4000V
MM ESD
400 V
Latch-up
400mA
2
CL9193
300mA High PSRR LDO
BLOCK DIAGRAM
ABSOLUTE MAXIMUM RATINGS
PARAMETER
SYMBOL
RATING
UNITS
INPUT VOLTAGE
VIN
6
V
OUTPUT CURRENT
IOUT
500
mA
OUTPUT VOLTAGE
VOUT
GND-0.3 ~ VIN +0.3
V
Pd
400
mW
OPERATING TEMP.
Topr
-25 ~ +85
C
STORAGE TEMP.
Tstg
-40 ~ +125
C
LEAD TEMP.
Tsolder
260C, 10s
POWER DISSIPATION (SOT23-5L)
CL9193_EN Rev. 1.1
3
CL9193
300mA High PSRR LDO
ELECTRICAL CHARACTERISTICS
(VIN = VOUT +1V,CIN=COUT=1uF,Ta=25C, unless otherwise stated)
PARAMETER
SYMBOL
Input Voltage
VIN
Output Voltage
VOUT
Max. Output
Current
Load Regulation
Dropout Voltage
CONDITIONS
IOUT(max)
∆VOUT
Vdif
MIN
TYP
MAX
UNITS
6.0
V
IOUT=40mA, VOUT
很抱歉,暂时无法提供与“CL9193A33L5M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23998
- 200+0.18911
- 600+0.16092
- 国内价格
- 10+0.21998
- 100+0.21668
- 600+0.14751
- 1200+0.14603
