CLEO35-WIFI1
CLEO35-WIFI1
    BRIDGETEK
    CLEO35-WIFI1
CLEO35-WIFI1 数据手册
CleO35-WIFI Module Datasheet Version 1.0 Document Reference No.:BRT_000117 Clearance No.:BRT#082 Bridgetek Pte Ltd Datasheet CleO35-WIFI Module 1 Introduction The CleO35-WIFI module is a Wi-Fi accessory for the CleO series – the smart TFT display for Arduino. Designed with an ESP-12S Wi-Fi module from Ai-thinker using core processor ESP8266, the ESP8266 is among the most integrated Wi-Fi chips in the industry. Measuring just 5mm X 5mm, it requires minimal external circuitry and integrates a 32-bit Tensilica MCU, digital peripheral interface, antenna switch, RF balun, power amplifier, low noise receive amplifier, filters and power management modules all in one small package. The CleO35-WIFI module comes with a standard 16 pin 0.5mm pitch FFC cable, suitable for connecting directly to CleO35 modules or via the CleO_IO Shield to CleO50 modules enabling wireless communications to the system. As a plug in accessory to CleO it extends the CleO modules capabilities to include wireless monitor and control for smart devices around the home. 1.1 Features The CleO35-WIFI consists of ESP-12S WIFI module developed by Ai-thinker using an ESP8266. For the full list of ESP8266’s features, refer to the ESP8266 Datasheet. In addition, CleO35-WIFI has the following features:  Supports standard IEEE802.11 b/g/n  Integrated low power 32-bit MCU  Wi-Fi 2.4GHz, Support WPA/WPA2  Support STA/AP/STA+AP operation mode  +20dBm output power in 802.11b mode  On board PCB antenna  Compatible with Bridgetek CleO35  16 Pin 0.5mm Pitch FFC Flex interface Neither the whole nor any part of the information contained in, or the product described in this manual, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. This product and its documentation are supplied on an as-is basis and no warranty as to their suitability for any particular purpose is either made or implied. Bridgetek Pte Ltd will not accept any claim for damages howsoever arising as a result of use or failure of this product. Your statutory rights are not affected. This product or any variant of it is not intended for use in any medical appliance, device or system in which the failure of the product might reasonably be expected to result in personal injury. This document provides preliminary information that may be subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Bridgetek Pte Ltd, 178 Paya Lebar Road, #07-03, Singapore 409030. Singapore Registered Company Number: 201542387H Copyright © Bridgetek Pte Ltd 1 CleO35-WIFI Module Datasheet Version 1.0 Document Reference No.: BRT_000117 Clearance No.: BRT#082 2 Ordering Information Part No. Description CleO35-WiFi1 Wi-Fi accessory, built-in ESP-12S Wi-Fi module with 16pin 0.5mm pitch FFC flex interface 3 Program Support Demo applications are provided for CleO Wi-Fi http://brtchip.com/m-cleo/ for more information. Copyright © Bridgetek Pte Ltd modules by Bridgetek. Visit Bridgetek’s 2 website CleO35-WIFI Module Datasheet Version 1.0 Document Reference No.: BRT_000117 Clearance No.: BRT#082 Table of Contents 1 Introduction .................................................................... 1 1.1 Features .................................................................................... 1 2 Ordering Information ...................................................... 2 3 Program Support ............................................................. 2 4 Pin Out and Signal Description ........................................ 4 5 4.1 Module Description ................................................................... 4 4.2 Module Interface Signal Description ......................................... 4 Device Major Parameters ................................................ 6 5.1 Parameters ............................................................................... 6 6 Board Schematics ............................................................ 7 7 Mechanical Dimensions ................................................... 8 8 Contact Information ........................................................ 9 Appendix A – References ................................................... 10 Document References ..................................................................... 10 Acronyms and Abbreviations ........................................................... 10 Appendix B - List of Figures and Tables ............................. 11 List of Tables ................................................................................... 11 List of Figures ................................................................................. 11 Appendix C – Revision History ........................................... 12 Copyright © Bridgetek Pte Ltd 3 CleO35-WIFI Module Datasheet Version 1.0 Document Reference No.: BRT_000117 4 Clearance No.: BRT#082 Pin Out and Signal Description 4.1 Module Description U1 CN1 Figure 1 – CleO35-WIFI Top View No Feature 1 2 ESP-12S WIFI Module 16 pin 0.5mm pitch FFC Connector Table 1 - Module Feature Description Reference Designator U1 CN1 4.2 Module Interface Signal Description The pin description of CN1 is given in Table 2. Pin No Pin Name Type Description 1 WIFI_RST Input Reset Wi-Fi module (Active low signal) 2 WIFI_EN Input Enable Wi-Fi module (‘1’ to enable module) 3 WIFI_CFG0 I/O GPIO0 4 - NC No connection 5 VDD_3V3 Power 3V3 Supply 6 GND Ground Power ground 7 - NC No connection 8 - NC No connection 9 WIFI_TXD Output UART TXD 10 WIFI_RXD Input UART RXD Copyright © Bridgetek Pte Ltd 4 CleO35-WIFI Module Datasheet Version 1.0 Document Reference No.: BRT_000117 11 VDD_3V3 Power 3V3 Supply 12 GND Ground Power ground 13 - NC No connection 14 - NC No connection 15 - NC No connection 16 - NC Clearance No.: BRT#082 No connection Table 2 - CN1 Pin Description Note: GPIO 0 is configurable which can determines the booting mode ‘0’ : boot from UART ‘1’ : boot from flash boot Copyright © Bridgetek Pte Ltd 5 CleO35-WIFI Module Datasheet Version 1.0 Document Reference No.: BRT_000117 5 Clearance No.: BRT#082 Device Major Parameters 5.1 Parameters Categories WiFi parameters Hardware Parameters Software Parameters Items Values Wi-Fi Protocols 802.11 b/g/n Frequency Range 2.4GHz -2.5GHz (2400M-2483.5M) Operating Voltage 3.3V Operating Current 80mA (Average) Operating Temperature Range -40  C ~ 125  C Ambient Temperature Range Normal Temperature External Interface N/A Wi-Fi Mode Station/SoftAP/SoftAP+Station Security WPA/WPA2 Network Protocols IPv4,TCP/UDP/HTTP/FTP User Configuration AT Instruction Set, Cloud Server, Android/iOS App Firmware Upgrade UART Download/OTA(via network)/download and write firmware via host Table 3 - Parameters Parameters Min Frequency Range 2.4 Impedance Copyright © Bridgetek Pte Ltd Typical 50 Table 4 – Antenna Parameters Max Unit 2.4825 GHz Ohm 6 CleO35-WIFI Module Datasheet Version 1.0 Document Reference No.: BRT_000117 6 Clearance No.: BRT#082 Board Schematics Figure 2 - Sheet 1 – CleO35-WIFI Board Copyright © Bridgetek Pte Ltd 7 CleO35-WIFI Module Datasheet Version 1.0 Document Reference No.: BRT_000117 7 Clearance No.: BRT#082 Mechanical Dimensions 4.6 mm 35.3 mm 31.6 mm 50 mm Figure 3 – CleO35-WIFI Module Dimensions Copyright © Bridgetek Pte Ltd 1 1 7 . 8 m m 8 CleO35-WIFI Module Datasheet Version 1.0 Document Reference No.: BRT_000117 8 Clearance No.: BRT#082 Contact Information Head Quarters – Singapore Branch Office – Taipei, Taiwan Bridgetek Pte Ltd 178 Paya Lebar Road, #07-03 Singapore 409030 Tel: +65 6547 4827 Fax: +65 6841 6071 Bridgetek Pte Ltd, Taiwan Branch 2 Floor, No. 516, Sec. 1, Nei Hu Road, Nei Hu District Taipei 114 Taiwan, R.O.C. Tel: +886 (2) 8797 5691 Fax: +886 (2) 8751 9737 E-mail (Sales) E-mail (Support) E-mail (Sales) E-mail (Support) sales.apac@brtchip.com support.apac@brtchip.com sales.apac@brtchip.com support.apac@brtchip.com Branch Office - Glasgow, United Kingdom Branch Office – Vietnam Bridgetek Pte. Ltd. Unit 1, 2 Seaward Place, Centurion Business Park Glasgow G41 1HH United Kingdom Tel: +44 (0) 141 429 2777 Fax: +44 (0) 141 429 2758 Bridgetek VietNam Company Limited Lutaco Tower Building, 5th Floor, 173A Nguyen Van Troi, Ward 11, Phu Nhuan District, Ho Chi Minh City, Vietnam Tel : 08 38453222 Fax : 08 38455222 E-mail (Sales) E-mail (Support) E-mail (Sales) E-mail (Support) sales.emea@brtichip.com support.emea@brtchip.com sales.apac@brtchip.com support.apac@brtchip.com Web Site http://brtchip.com/ Distributor and Sales Representatives Please visit the Sales Network page of the Bridgetek Web site for the contact details of our distributor(s) and sales representative(s) in your country. System and equipment manufacturers and designers are responsible to ensure that their systems, and any Bridgetek Pte Ltd (BRT Chip) devices incorporated in their systems, meet all applicable safety, regulatory and system-level performance requirements. All application-related information in this document (including application descriptions, suggested Bridgetek devices and other materials) is provided for reference only. While Bridgetek has taken care to assure it is accurate, this information is subject to customer confirmation, and Bridgetek disclaims all liability for system designs and for any applications assistance provided by Bridgetek. Use of Bridgetek devices in life support and/or safety applications is entirely at the user’s risk, and the user agrees to defend, indemnify and hold harmless Bridgetek from any and all damages, claims, suits or expense resulting from such use. This document is subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Neither the whole nor any part of the information contained in, or the product described in this document, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyr ight holder. Bridgetek Pte Ltd, 178 Paya Lebar Road, #07-03, Singapore 409030. Singapore Registered Company Number: 201542387H. Copyright © Bridgetek Pte Ltd 9 CleO35-WIFI Module Datasheet Version 1.0 Document Reference No.: BRT_000117 Clearance No.: BRT#082 Appendix A – References Document References For module documentations, please refer to URL below: ESP8266 Datasheet : ESP8266 Datasheet ESP-12S Datasheet : ESP-12S Datasheet Arduino: https://www.arduino.cc/ CleOStuff tools: CleOstuff Acronyms and Abbreviations Terms CCK Description Complementary Code Keying DSSS Direct-Sequence Spread Spectrum OFDM Orthogonal Frequency-Division Multiplexing MCU MicroController Unit UART Universal Asynchronous Receiver/Transmitter WPA Wi-Fi Protected Access Copyright © Bridgetek Pte Ltd 10 CleO35-WIFI Module Datasheet Version 1.0 Document Reference No.: BRT_000117 Clearance No.: BRT#082 Appendix B - List of Figures and Tables List of Tables Table 1 - Module Feature Description .............................................................................................. 4 Table 2 - CN1 Pin Description ......................................................................................................... 5 Table 3 - Parameters .................................................................................................................... 6 Table 4 – Antenna Parameters ....................................................................................................... 6 List of Figures Figure 1 – CleO35-WIFI Top View ................................................................................................... 4 Figure 2 - Sheet 1 – CleO35-WIFI Board ......................................................................................... 7 Figure 3 – CleO35-WIFI Module Dimensions..................................................................................... 8 Copyright © Bridgetek Pte Ltd 11 CleO35-WIFI Module Datasheet Version 1.0 Document Reference No.: BRT_000117 Clearance No.: BRT#082 Appendix C – Revision History Document Title: CleO35-WIFI Module Datasheet Document Reference No.: BRT_000117 Clearance No.: BRT#082 Product Page: http://brtchip.com/m-cleo/ Document Feedback: Send Feedback Revision Changes Date Version 1.0 Initial Release 2017-06-09 Copyright © Bridgetek Pte Ltd 12
CLEO35-WIFI1 价格&库存
很抱歉,暂时无法提供与“CLEO35-WIFI1”相匹配的价格&库存,您可以联系我们找货
