CMT1945-0000-000N0H0A40G
    WOLFSPEED
    High Power LED Module Light Source is a high performance energy efficient device which can handle hi...
CMT1945-0000-000N0H0A40G 数据手册
Cree® XLamp® CMT1945 LED Product Description features The • 14.5‑mm optical source Characteristics.............................................2 • Cree EasyWhite 2-, 3‑ and 5-step Operating Limits...........................................3 Cree XLamp® High-Current LED Array family is optimized for best‑in‑class lumen output, efficacy Table of Contents ® binning Flux Characteristics, Order Codes & Bins - and reliability at high drive currents. • Premium Color 2- and 3-step binning Standard LEDs..............................................4 XLamp CMT LEDs deliver performance • Standard & Premium Color LEDs Flux Characteristics, Order Codes & Bins - in industry‑compatible packages and available in 70, 80, 90 and 95 CRI Standard LEDs, Premium Color...................5 LESes, enabling lighting manufacturers minimum options Flux Characteristics, Order Codes and to upgrade their designs for applications such as track, downlight and outdoor lighting. High‑Current LED Arrays are now available in two different versions: Standard and eTone LEDs. • eTone™ LEDs available in 90 CRI minimum option Bins - eTone™ LEDs......................................6 Relative Spectral Power Distribution - • Forward voltage option: 36‑V class Standard LEDs..............................................7 • 85 °C binning and characterization Relative Spectral Power Distribution - • Maximum drive current: 2500 mA Standard LEDs, Premium Color...................8 • 115° viewing angle, uniform Relative Spectral Power Distribution - chromaticity profile eTone™ LEDs............................................. 10 • Top-side solder connections Electrical Characteristics.......................... 10 The eTone version delivers beautiful 90 • RoHS and REACh compliant Relative Luminous Flux............................. 11 CRI light quality at the same efficacy • UL® recognized component Typical Spatial Distribution....................... 11 as today’s standard 80 CRI LEDs. (E349212) CLD-DS166 Rev 5B Product family data sheet Performance Groups - Chromaticity........ 12 Featuring the same mechanical and Premium Color Performance Groups - optical characteristics as the Standard Chromaticity.............................................. 13 version, the eTone LEDs allow easy Cree EasyWhite® Bins Plotted on the upgrades from 80 CRI to 90 CRI without 1931 CIE Color Space............................... 14 sacrificing performance. Cree Premium Color Bins Plotted on the 1931 CIE Color Space............................... 15 www.cree.com/Xlamp Bin and Order Code Formats.................... 17 Mechanical Dimensions........................... 18 Thermal Design......................................... 19 Notes......................................................... 20 Packaging.................................................. 21 Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 XLamp ® CMT1945 LED Characteristics Characteristics Viewing angle (FWHM) ESD withstand voltage (JEDEC JS-001-2012) Unit Minimum Typical degrees 115 V Class 3A Maximum DC forward current - Standard mA 2500* DC forward current - eTone mA 1440* Reverse current mA 0.1 Forward voltage (@ 1200 mA, 85 °C) * V 34.7 38.2 Refer to the Operating Limits section. Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 2 XLamp ® CMT1945 LED Operating Limits The maximum current rating of the CMT1945 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Either solder pad shown in the Mechanical Dimensions section on page 18 can be used as the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree recommends a maximum LES temperature of 140 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 19 for more CMT1945 - Standard information on LES temperature measurement. 2750 85 °C, 2500 mA 2500 Standard LEDs 2250 2000 If (mA) 1750 1500 1250 125 °C, 962 mA 1000 750 500 250 0 0 25 50 75 100 125 150 Case Temperature (°C) CMT1945 - eTone 1500 85 °C,1440 mA 1375 eTone LEDs 1250 1125 If (mA) 1000 875 750 625 500 375 250 125 0 0 25 50 75 100 125 150 Case Temperature (°C) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 3 XLamp ® CMT1945 LED Flux Characteristics, Order Codes & Bins - Standard LEDs (If = 1200 mA, TJ = 85 °C) The following table provides order codes for XLamp CMT1945 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 17). Nominal CCT Min. Typ Minimum Luminous Flux (lm) 70 73 6126 80 82 70 CRI Typical Luminous Flux (lm) 2-Step Group Order Code 3-Step Group Order Code 5-Step Group Order Code 6587 65E CMT1945-0000000N0B0A65E 5723 6153 65E CMT1945-0000000N0H0A65E 73 6251 6721 57E CMT1945-0000000N0B0A57E 80 82 5839 6279 57E CMT1945-0000000N0H0A57E 90 92 4967 5341 70 73 6070 6526 50E CMT1945-0000000N0B0A50E 80 82 5670 6097 50G CMT1945-0000000N0H0A50G 90 92 4967 5341 50G CMT1945-0000000N0U0A50G 70 73 6024 6477 40E CMT1945-0000000N0B0A40E 80 82 5606 6027 40H CMT1945-0000000N0H0A40H 40G CMT1945-0000000N0H0A40G 90 92 4827 5190 40H CMT1945-0000000N0U0A40H 40G CMT1945-0000000N0U0A40G 80 82 5469 5880 35H CMT1945-0000000N0H0A35H 35G CMT1945-0000000N0H0A35G 90 92 4694 5047 35H CMT1945-0000000N0U0A35H 35G CMT1945-0000000N0U0A35G 70 73 5606 6027 30E CMT1945-0000000N0B0A30E 80 82 5310 5710 30H CMT1945-0000000N0H0A30H 30G CMT1945-0000000N0H0A30G 90 92 4490 4828 30H CMT1945-0000000N0U0A30H 30G CMT1945-0000000N0U0A30G 80 82 5095 5479 27H CMT1945-0000000N0H0A27H 27G CMT1945-0000000N0H0A27G 90 92 4287 4609 27H CMT1945-0000000N0U0A27H 27G CMT1945-0000000N0U0A27G 80 82 4490 4828 22G CMT1945-0000000N0H0A22G 6500 K 5700 K 5000 K 4000 K 57G 3500 K 3000 K 2700 K 2200 K CMT1945-0000000N0U0A57G Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 20). • For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 4 XLamp ® CMT1945 LED Flux Characteristics, Order Codes & Bins - Standard LEDs, Premium Color (If = 1200 mA, TJ = 85 °C) Fidelity CRI 2-Step Min. Typ Minimum Luminous Flux (lm) 4000 K 95 98 4323 4648 L5A CMT1945-0000-000N0Z0AL5A 3500 K 95 98 4207 4524 35H CMT1945-0000-000N0Z0A35H 3000 K 95 98 3934 4230 30H CMT1945-0000-000N0Z0A30H 2700 K 95 98 3725 4005 27H CMT1945-0000-000N0Z0A27H Min. Typ Minimum Luminous Flux (lm) Typical Luminous Flux (lm) 90 92 4490 4828 80 82 5310 5710 90 92 4490 4828 95 98 3934 4230 Nominal CCT Typical Luminous Flux (lm) Group Order Code Specialty Nominal CCT 3100 K 3000 K CRI 2-Step Group L7B L7C Order Code 3-Step Group Order Code 31Q CMT1945-0000000N0U0A31Q 30Q CMT1945-0000000N0U0A30Q Group Order Code 30U CMT1945-0000000N0U0A30U CMT1945-0000000N0H0AL7B CMT1945-0000000N0Z0AL7C Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 20). • For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 5 XLamp ® CMT1945 LED Flux Characteristics, Order Codes and Bins - eTone™ LEDs (If = 1200 mA, TJ = 85 °C) Nominal CCT CRI Min. Typ Minimum Luminous Flux (lm) 2-Step 3-Step Typical Luminous Flux (lm) Group Order Code Group Order Code 4000 K 90 92 5157 5545 40H CMT1945-0000-00PN0U0A40H 40G CMT1945-0000-00PN0U0A40G 3500 K 90 92 5086 5469 35H CMT1945-0000-00PN0U0A35H 35G CMT1945-0000-00PN0U0A35G 3000 K 90 92 5045 5425 30H CMT1945-0000-00PN0U0A30H 30G CMT1945-0000-00PN0U0A30G 2700 K 90 92 4841 5205 27H CMT1945-0000-00PN0U0A27H 27G CMT1945-0000-00PN0U0A27G Min. Typ Minimum Luminous Flux (lm) Typical Luminous Flux (lm) Group Order Code Group Order Code 3100 K 90 92 4992 5367 31Q CMT1945-0000-00PN0U0A31Q 3000 K 90 92 5045 5425 30Q CMT1945-0000-00PN0U0A30Q 30U CMT1945-0000-00PN0U0A30U Specialty Nominal CCT CRI 3-Step Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 20). • For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 6 XLamp ® CMT1945 LED Relative Spectral Power Distribution Relative Spectral Power Distribution - Standard LEDs EZW 70 CRI The following graphs are the result of a series of pulsed measurements at 1200 mA and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 6500 K, 70 CRI 5700 K, 70 CRI 5000 K, 70 CRI 4000 K, 70 CRI 3000 K, 70 CRI 60% 50% 40% 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) EZW 80 CRI 100% Relative Spectral Power 90% 80% 6500 K, 80 CRI 70% 5700 K, 80 CRI 5000 K, 80 CRI 60% 4000 K, 80 CRI 50% 3500 K, 80 CRI 40% 3000 K, 80 CRI 30% 2700 K, 80 CRI 20% 2200 K, 80 CRI 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 7 XLamp ® CMT1945 LED EZW 90 CRI Relative Spectral Power Distribution - Standard LEDs (Continued) 100% Relative Spectral Power 90% 80% 5700 K, 90 CRI 70% 5000 K, 90 CRI 60% 4000 K, 90 CRI 50% 3500 K, 90 CRI 40% 3000 K, 90 CRI 30% 2700 K, 90 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Spectral Power Distribution - Standard LEDs, Premium Color The following graphs are the result of a series of pulsed measurements at 1200 mA and TJ = 85 °C. Fidelity Fidelity 100% Relative Spectral Power 90% 80% 70% 4000 K, Z CRI 60% 3500 K, Z CRI 50% 3000 K, Z CRI 40% 2700 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 8 XLamp ® CMT1945 LED Relative Spectral Power Distribution - Standard LEDs, Premium Color (continued) Speciality Specialty 100% Relative Spectral Power 90% 80% 70% 60% 31Q, 3100 K, 90 CRI 50% 40% 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Speciality 100% Relative Spectral Power 90% 80% 70% 30Q, 3000 K, 90 CRI 60% 30U, 3000 K, 90 CRI 50% L7B, 3000 K, 80 CRI 40% L7C, 3000 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 9 XLamp ® CMT1945 LED EZW 90 CRI NBR (E-Tone?) Relative Spectral Power Distribution - eTone™ LEDs NBR data from: CMA1516_NBR_PrelimDatasheet_180911.xlsx The following graph is the result of a series of pulsed measurements at 1200 mA and TJ = 85 °C. 100% 90% Relative Spectral Power 80% 70% 60% 3000 K, 90 CRI 50% 40% 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Electrical Characteristics The following graph is the result of a series of steady-state measurements. 39 38 Voltage (V) 37 36 Tc = 25 °C Tc = 55 °C 35 Tc = 85 °C 34 Tc = 105 °C 33 32 31 300 500 700 900 1100 1300 1500 1700 1900 2100 2300 2500 Current (mA) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 10 XLamp ® CMT1945 LED Relative Luminous Flux The relative luminous flux values provided below are the ratio of: • Measurements of CMT1945 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 1200 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 55 °C, IF = 2100 mA, the relative luminous flux ratio is 160% in the chart below. A CMT1945 LED that measures 5710 lm during binning will deliver 9136 lm (5710 * 1.6) at steady-state operation of Tc = 55 °C, IF = 2100 mA. 200% Relative Luminous Flux 180% 160% 140% Tc = 25 °C 120% Tc = 55 °C 100% Tc = 85 °C 80% Tc = 105 °C 60% 40% 20% 0% 300 500 700 900 1100 1300 1500 1700 1900 2100 2300 2500 Current (mA) Far Field Typical Spatial Distribution 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 11 XLamp ® CMT1945 LED Performance Groups - Chromaticity (Tj = 85 °C) XLamp CMT1945 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Major Axis Minor Axis x y a b Rotation Angle (°) 5700 K 0.3287 0.3417 0.00738 0.00360 72.0 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 22G 2200 K 0.5066 0.4158 0.00980 0.00480 45.5 Major Axis Minor Axis y a b Rotation Angle (°) Bin Code CCT 57G 50G Center Point EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT Center Point x 65E 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 30E 3000 K 0.4338 0.4030 0.01390 0.00680 53.2 Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 12 XLamp ® CMT1945 LED Premium Color Performance Groups - Chromaticity (Tj = 85 °C) XLamp CMT1945 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. Fidelity EasyWhite Color Temperatures – 2-Step Code L5A 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3764 0.3711 0.3784 0.3787 0.3847 0.3826 0.3825 0.3748 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 Specialty EasyWhite Color Temperatures – 2-Step Code L7B L7C CCT 3000 K 3000 K x y 0.4263 0.3848 0.4296 0.3916 0.4361 0.3938 0.4326 0.3868 0.4192 0.3754 0.4224 0.3823 0.4291 0.3847 0.4257 0.3777 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 31Q 3100 K Center Point Major Axis Minor Axis x y a b Rotation Angle (°) 0.4236 0.3888 0.00848 0.00455 50.3 30Q 3000 K 0.4305 0.3935 0.00834 0.00408 53.2 30U 3000 K 0.4274 0.3837 0.00834 0.00408 53.2 Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 13 XLamp ® CMT1945 LED Cree EasyWhite® Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) 0.45 ANSI C78.377 Quadrangle 0.44 EasyWhite 5-step 0.43 EasyWhite 3-step 0.42 EasyWhite 2-step 2700 K 2200 K 2450 K 3000 K 3500 K 0.41 4000 K 0.40 CCy 0.39 5000 K 4500 K 5700 K 0.38 0.37 6500 K 0.36 0.35 7000K 0.34 0.33 0.32 0.54 0.53 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 14 XLamp ® CMT1945 LED Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) Fidelity (2-step) 0.44 2700K ANSI C78.377 Quadrangle 0.43 3000K 0.42 3500K 0.41 27H 4000K CCy 0.40 30H 4500K 35H 0.39 0.38 L5A 0.37 0.36 0.35 0.48 0.47 0.46 0.45 0.44 CCx 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 15 XLamp ® CMT1945 LED Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) - Continued Speciality (2-step) 0.44 ANSI C78.377 Quadrangle 3000 K 0.43 0.42 3500 K CCy 0.41 0.40 0.39 L7B L7C 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Speciality (3-step) 0.44 ANSI C78.377 Quadrangle 3000K 0.43 0.42 3500K CCy 0.41 0.40 30Q 0.39 31Q 30U 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 16 XLamp ® CMT1945 LED Bin and Order Code Formats Bin codes and order codes are configured as follows: Order Code Bin Code Series = CMT19 Series = CMT19 Internal code Chromaticity bin Version 0 = Standard P = eTone Vf class N0 = 36-V class Version 0 = Standard P = eTone CRI Specification B = 70 CRI minimum H = 80 CRI minimum SSSSSCC-WWW-FF-GGR-EAAAA U = 90 CRI minimum Internal code Z = 95 CRI minimum SSSSSCC-HHHH-HHEGGRNNNNN Kit code Vf class N0 = 36-V class Performance class CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Flux bin 0A = Not binned into flux bins Performance class Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 17 CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CONTAINED WITHIN ARE THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY UNAUTHORIZED PERSON THE WITHOUT WRITTEN CONSENT OF CREE INC. D XLamp ® CMT1945 LED Mechanical Dimensions Dimensions are in mm. 19.00 ±0.2 Tolerances unless otherwise specified: ±.13 x° ± 1° R2.00 5.46 .90±.15 3.19 C T1945N = 36‑V CMT1945 3.19 OPTICAL REFERENCE X1 X2 X3 X4 X5 X1 R.60 CCT 19.00 5.46 ±0.2 1 = 6500 K … 8 = 2700 K X2 B ø14.5 5.46 ±0.2 M = EasyWhite or ø16.0 Fidelity LED on the 3.19 ±0.2 black‑body line Q = Specialty LED below R.60 the black‑body line 3.19 U = Specialty LED below the black‑body line X3 X4 Flux bin Marking 2 X 1X CCT (eg. 27.2700K, 30:3000K) 2 X 3X :4Flux Bin X 5:CRI (B:70 H:80, U:90, Z:95 bins CRI B = 70 CRI min .55±.1 Marking 1 T1945: product family (CMT1945) N:36V Voltage Class A 0A = Not binned into flux X5 5.46 OPTICAL REFERENCE 6 5 4 ALL DIMENS UNLESS OT DIMENS MILLIMETER TOLERANC .XX .XXX X THIRD ANGLE PROJECTION FOR SHEET .X .XX .XXX X SURFACE 3 H = 80 CRI min U = 90 CRI min Z = 95 CRI min Tc measurement point: either the anode or cathode solder pad Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 18 XLamp ® CMT1945 LED Thermal Design The CMT family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure the CMT LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 3 for the Operating Limit specification. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from solder point (TSP) to ambient (Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please refer to the Thermal Management application note. For CMT soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the Cree XLamp CM Family LEDs soldering and handling document. To keep the CMT1945 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CMT1945 Ta Ta 100.00 Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 300 500 700 900 1100 1300 1500 1700 1900 2100 2300 2500 Current (mA) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 19 XLamp ® CMT1945 LED Notes Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs. Cree did not perform Room Temperature Operating Life (RTOL) testing on the CMT1945 LED. Lumen Maintenance Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or rom the Product Ecology section of the Cree website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks and eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 20 XLamp ® CMT1945 LED Packaging Cree CMT1945 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. Dimensions are in inches. Tolerances: ±.13 7.125 5 x° ±1° 4 6 3 5 R.375 4 2 1 3 2 1 NOTICE ENTIAL. THIS PLOT AND THE INFORMATION WITHIN ARE THE PROPRIETARY AND L INFORMATION OF CREE, INC. THIS PLOT COPIED, REPRODUCED OR DISCLOSED TO ANY NSENT ED PERSON WITHOUT THE WRITTEN CONSENT 5.875 1.125 5.875 R .375 R .375 7.625 .875 .875 5.875 LABEL WITH CREE BIN CODE, QUANTITY, LOT # PATENT LABEL ISBIN LOCATED LABEL WITH CREE CODE, QUANTITY, OF LOTCARTON # ON UNDERSIDE TH CREE BIN ANTITY, LOT # PATENT LABEL IS LOCATED ON UNDERSIDE .875 OF COVER 1.063 BAG .38 .875 BAG .38 L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QUANTITY, LOT # .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 .XX ± .03 .XXX ± .010 X° ± 2 ° 6 WITH CREE BIN QUANTITY, LOT # 5 4 Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change eTone™ is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 3 DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. ® withoutTOLERANCE notice. UNLESS Cree ,SPECIFIED: the Cree .X ± .XX ± .XXX ± X° ± 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 DRAWN BY DRAWN BY DATE CHECK DATE APPROVED DATE 4600 Silicon Drive Durham, N.C 277 Phone (919) 361- Fax (919) 313-530 TITLE CXA15XX_DATASHEET MATERIAL SIZE FINAL PROTECTIVE FINISH SCALE DATE C DRAWING NO. CXA15XX_DATASHEET_BAG2013 0.500 2 CHECK DATE APPROVED DATE SHEET logo, XLamp® and EasyWhite® are registered trademarks and Phone (919) 361-4770 Fax (919) 313-5303 TITLE CXA15XX_DATASHEET 21 MATERIAL SIZE FINAL PROTECTIVE FINISH OF 1 Drive 4600 Silicon Durham, N.C 27703 DRAWING NO. CXA15XX_DATASHEET_BAG2013
CMT1945-0000-000N0H0A40G 价格&库存
很抱歉,暂时无法提供与“CMT1945-0000-000N0H0A40G”相匹配的价格&库存,您可以联系我们找货
