CMA1516-0000-000N0U0A27G
    WOLFSPEED
    Chip On Board LED Lighting Module
CMA1516-0000-000N0U0A27G 数据手册
Cree® XLamp® CMA1516 LED Product Description Features Table of Contents Cree’s XLamp® High‑Current LED Array • 9‑mm optical source Characteristics.............................................2 family is optimized for best‑in‑class • Mechanical and optical design Operating Limits...........................................2 lumen output, efficacy and reliability at high drive currents. XLamp CMA LEDs share the same package design and LES sizes as Cree’s industry‑leading CXA2 Standard Density LEDs, enabling lighting manufacturers to address a consistent with CXA15 and CXB15 Flux Characteristics, EasyWhite® Order LEDs Codes and Bins............................................3 • Available in 70-, 80- and 90‑ and 95‑minimum CRI options • Cree EasyWhite 2-, 3- and 5‑step ® binning Flux Characteristics, Premium Color Order Codes and Bins..................................4 Relative Spectral Power Distribution..........5 Electrical Characteristics.............................5 range of performance requirements • Premium Color 2- and 3-step binning Relative Luminous Flux................................6 for track, • Forward voltage option: 36‑V class Typical Spatial Distribution..........................6 downlight and outdoor lighting using • 85 °C binning and characterization EasyWhite® Performance Groups - a single easy‑to‑use platform. XLamp • Maximum drive current: 1050 mA Chromaticity.................................................7 High‑Current LED Arrays are available • 115° viewing angle, uniform Premium Color Performance Groups - applications such as in 2‑step, 3‑step and 5‑step EasyWhite ® bins. chromaticity profile Chromaticity.................................................8 • Top-side solder connections Cree EasyWhite® Bins Plotted on the • RoHS compliant 1931 CIE Color Space..................................9 • UL® recognized component Cree Premium Color Bins Plotted on the (E349212) CLD-DS159 Rev 0 Product family data sheet 1931 CIE Color Space............................... 10 Bin and Order Code Formats.................... 12 Mechanical Dimensions........................... 13 Thermal Design......................................... 14 Notes......................................................... 15 www.cree.com/XLamp Packaging.................................................. 16 Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 XLamp ® CMA1516 LED Characteristics Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees 115 V Class 3A ESD withstand voltage (JEDEC JS-001-2012) Maximum DC forward current mA 1050* Reverse current mA 0.1 Forward voltage (@ 450 mA, 85 °C) * V 35 38.5 Refer to the Operating Limits section. Operating Limits The maximum current rating of the CMA1516 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Either solder pad shown in the Mechanical Dimensions section on page 13 can be used as the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree recommends a maximum LES temperature of 140 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 14 for more information on LES temperature measurement. CMA1516 - 36 V 1100 85 °C, 1050 mA 1000 900 800 If (mA) 700 600 500 125 °C, 404 mA 400 300 200 100 0 0 25 50 75 100 125 150 Case Temperature (°C) Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 2 XLamp ® CMA1516 LED Flux Characteristics, EasyWhite® Order Codes and Bins (If = 450 mA, TJ = 85 °C) The following table provides order codes for XLamp CMA1516 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 12). Nominal CCT Min. Typ Minimum Luminous Flux (lm) 70 73 2306 80 82 70 CRI Typical Luminous Flux (lm) 2-Step Group Order Code 3-Step Group Order Code 5-Step Group Order Code 2480 65E CMA1516-0000000N0B0A65E 2155 2317 65E CMA1516-0000000N0H0A65E 73 2354 2531 57E CMA1516-0000000N0B0A57E 80 82 2199 2364 57E CMA1516-0000000N0H0A57E 90 92 1870 2011 70 73 2285 2457 50E CMA1516-0000000N0B0A50E 80 82 2135 2296 50G CMA1516-0000000N0H0A50G 90 92 1870 2011 50G CMA1516-0000000N0U0A50G 70 73 2268 2439 40E CMA1516-0000000N0B0A40E 80 82 2111 2270 40H CMA1516-0000000N0H0A40H 40G CMA1516-0000000N0H0A40G 90 92 1817 1954 40H CMA1516-0000000N0U0A40H 40G CMA1516-0000000N0U0A40G 80 82 2059 2214 35H CMA1516-0000000N0H0A35H 35G CMA1516-0000000N0H0A35G 90 92 1767 1900 35H CMA1516-0000000N0U0A35H 35G CMA1516-0000000N0U0A35G 70 73 2111 2270 30E CMA1516-0000000N0B0A30E 80 82 2000 2150 30H CMA1516-0000000N0H0A30H 30G CMA1516-0000000N0H0A30G 90 92 1691 1818 30H CMA1516-0000000N0U0A30H 30G CMA1516-0000000N0U0A30G 80 82 1919 2063 27H CMA1516-0000000N0H0A27H 27G CMA1516-0000000N0H0A27G 90 92 1614 1736 27H CMA1516-0000000N0U0A27H 27G CMA1516-0000000N0U0A27G 6500 K 5700 K 5000 K 4000 K 57G 3500 K 3000 K 2700 K CMA1516-0000000N0U0A57G Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 15). • For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 3 XLamp ® CMA1516 LED Flux Characteristics, Premium Color Order Codes and Bins (If = 450 mA, TJ = 85 °C) Fidelity CRI* 2-Step Min. Typ Minimum Luminous Flux (lm) 4000 K 95 98 1628 1750 L5A CMA1516-0000-000N0Z0AL5A 3500 K 95 98 1584 1703 35H CMA1516-0000-000N0Z0A35H 3000 K 95 98 1481 1593 30H CMA1516-0000-000N0Z0A30H 2700 K 95 98 1402 1508 27H CMA1516-0000-000N0Z0A27H Min. Typ Minimum Luminous Flux (lm) Typical Luminous Flux (lm) 90 92 1691 1818 80 82 2000 2150 90 92 1691 1818 95 98 1481 1593 Nominal CCT Typical Luminous Flux (lm) Group Order Code Specialty Nominal CCT 3100 K 3000 K CRI 2-Step Group L7B L7C Order Code 3-Step Group Order Code 31Q CMA1516-0000000N0U0A31Q 30Q CMA1516-0000000N0U0A30Q Group Order Code 30U CMA1516-0000000N0U0A30U CMA1516-0000000N0H0AL7B CMA1516-0000000N0Z0AL7C Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 15). • For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 4 XLamp ® CMA1516 LED Relative Spectral Power Distribution - White, Hot Binned, Baby Relative Spectral Power Distribution The following graph is the result of a series of pulsed measurements at 450 mA and TJ = 85 °C. 100% 90% Relative Spectral Power 80% 70% 60% 50% 3000 K, 80 CRI 40% 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Electrical Characteristics The following graph is the result of a series of steady-state measurements. 40 39 Voltage (V) 38 37 Tc = 25 °C 36 Tc = 55 °C 35 Tc = 85 °C Tc = 105 °C 34 33 32 31 100 200 300 400 500 600 700 800 900 1000 1100 Current (mA) Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 5 XLamp ® CMA1516 LED Relative Luminous Flux The relative luminous flux values provided below are the ratio of: • Measurements of CMA1516 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 450 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 55 °C, IF = 700 mA, the relative luminous flux ratio is 150% in the chart below. A CMA1516 LED that measures 1900 lm during binning will deliver 2850 lm (1900 * 1.5) at steady-state operation of Tc = 55 °C, IF = 700 mA. 225% Relative Luminous Flux 200% 175% 150% Tc = 25 °C 125% Tc = 55 °C Tc = 85 °C 100% Tc = 105 °C 75% 50% 25% 0% 100 200 300 400 500 600 700 800 900 1000 1100 Current (mA) Far Field Typical Spatial Distribution 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 6 XLamp ® CMA1516 LED EasyWhite® Performance Groups - Chromaticity (Tj = 85 °C) XLamp CMA1516 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Center Point Major Axis Minor Axis x y a b Rotation Angle (°) 5700 K 0.3287 0.3417 0.00738 0.00360 72.0 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 Rotation Angle (°) Bin Code CCT 57G 50G EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT Center Point x Major Axis Minor Axis y a b 65E 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 30E 3000 K 0.4338 0.4030 0.01390 0.00680 53.2 Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 7 XLamp ® CMA1516 LED Premium Color Performance Groups - Chromaticity (Tj = 85 °C) XLamp CMA1516 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. Fidelity EasyWhite Color Temperatures – 2-Step Code L5A 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3764 0.3711 0.3784 0.3787 0.3847 0.3826 0.3825 0.3748 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 Specialty EasyWhite Color Temperatures – 2-Step Code L7B L7C CCT 3000 K 3000 K x y 0.4263 0.3848 0.4296 0.3916 0.4361 0.3938 0.4326 0.3868 0.4192 0.3754 0.4224 0.3823 0.4291 0.3847 0.4257 0.3777 EasyWhite Color Temperatures – 3-Step Ellipse Center Point Major Axis Minor Axis x y a b Rotation Angle (°) 3100 K 0.4236 0.3888 0.00848 0.00455 50.3 30Q 3000 K 0.4305 0.3935 0.00834 0.00408 53.2 30U 3000 K 0.4274 0.3837 0.00834 0.00408 53.2 Bin Code CCT 31Q Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 8 XLamp ® CMA1516 LED Cree EasyWhite® Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) 0.44 2700 K ANSI C78.377 Quadrangle 0.43 3000 K EasyWhite 5-step EasyWhite 3-step 0.42 3500 K EasyWhite 2-step 0.41 4000 K 0.40 4500 K CCy 0.39 5000 K 0.38 0.37 5700 K 0.36 6500 K 0.35 0.34 0.33 0.32 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 9 XLamp ® CMA1516 LED Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) Fidelity (2-step) 0.44 2700K ANSI C78.377 Quadrangle 0.43 3000K 0.42 3500K 0.41 27H 4000K CCy 0.40 30H 4500K 35H 0.39 0.38 L5A 0.37 0.36 0.35 0.48 0.47 0.46 0.45 0.44 CCx 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 10 XLamp ® CMA1516 LED Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) - Continued Speciality (2-step) 0.44 ANSI C78.377 Quadrangle 3000 K 0.43 0.42 3500 K CCy 0.41 0.40 0.39 L7B L7C 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Speciality (3-step) 0.44 ANSI C78.377 Quadrangle 3000K 0.43 0.42 3500K CCy 0.41 0.40 30Q 0.39 31Q 30U 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 11 XLamp ® CMA1516 LED Bin and Order Code Formats Bin codes and order codes are configured as follows: Order Code Bin Code Series = CMA15 Series = CMA15 Internal code Chromaticity bin CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Vf class N0 = 36-V class SSSSSCC-HHHH-HHHGGRNNNNN Kit code Vf class N0 = 36-V class Performance class Internal code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Flux bin 0A = Not binned into flux bins Performance class Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 12 XLamp ® CMA1516 LED Mechanical Dimensions Dimensions are in mm. Tolerances unless otherwise specified: ±.13 x° ± 1° M1516N = 36‑V CMA1516 X1 X2 X3 X4 X5 X1 CCT 1 = 6500 K … 8 = 2700 K X2 M = EasyWhite or Fidelity LED on the black‑body line Q = Specialty LED below the black‑body line U = Specialty LED below the black‑body line X3 X4 Flux bin 0A = Not binned into flux bins X5 CRI B = 70 CRI min H = 80 CRI min U = 90 CRI min Z = 95 CRI min Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 13 XLamp ® CMA1516 LED Thermal Design The CMA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CMA LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 2 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from solder point (TSP) to ambient (Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please refer to the Thermal Management application note. For CMA soldering recommendations and information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the Cree XLamp CM Family LEDs soldering and handling document. To keep the CMA1516 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CMA1516 - 36 V Ta Ta 100.00 Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 100 200 300 400 500 600 700 800 900 1000 1100 Current (mA) Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 14 XLamp ® CMA1516 LED Notes Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs. Cree did not perform Room Temperature Operating Life (RTOL) testing on the CMA1516 LED. Lumen Maintenance Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product Ecology section of the Cree website. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 15 XLamp ® CMA1516 LED Packaging Cree CMA1516 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. Dimensions are in inches. Tolerances: ±.13 x° ±1° 5.875 5 4 6 3 5 4 R.375 NOTICE ENTIAL. THIS PLOT AND THE INFORMATION WITHIN ARE THE PROPRIETARY AND L INFORMATION OF CREE, INC. THIS PLOT COPIED, REPRODUCED OR DISCLOSED TO ANY NSENT ED PERSON WITHOUT THE WRITTEN CONSENT 5.875 2 1 3 2 1 .875 5.875 R .375 R .375 5.875 .875 .875 5.875 LABEL WITH CREE BIN CODE, QUANTITY, LOT # PATENT LABEL ISBIN LOCATED LABEL WITH CREE CODE, QUANTITY, OF LOTCARTON # ON UNDERSIDE TH CREE BIN ANTITY, LOT # PATENT LABEL IS LOCATED ON UNDERSIDE .875 OF COVER .875 BAG .38 .875 BAG .38 L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QUANTITY, LOT # .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 .XX ± .03 .XXX ± .010 X° ± 2 ° 6 WITH CREE BIN QUANTITY, LOT # 5 4 Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 3 DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. ® ® notice. CreeUNLESS , XLamp and TOLERANCE SPECIFIED: .X ± .XX ± .XXX ± X° ± 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 DRAWN BY DRAWN BY DATE CHECK DATE APPROVED DATE 4600 Silicon Drive Durham, N.C 277 Phone (919) 361- Fax (919) 313-530 TITLE CXA15XX_DATASHEET MATERIAL SIZE FINAL PROTECTIVE FINISH SCALE DATE C DRAWING NO. CXA15XX_DATASHEET_BAG2013 0.500 2 CHECK DATE APPROVED DATE SHEET EasyWhite® are registered trademarks and the Cree logo is a Phone (919) 361-4770 Fax (919) 313-5303 TITLE CXA15XX_DATASHEET 16 MATERIAL SIZE FINAL PROTECTIVE FINISH OF 1 Drive 4600 Silicon Durham, N.C 27703 DRAWING NO. CXA15XX_DATASHEET_BAG2013
CMA1516-0000-000N0U0A27G 价格&库存
很抱歉,暂时无法提供与“CMA1516-0000-000N0U0A27G”相匹配的价格&库存,您可以联系我们找货
