Cree® XLamp® CMA3090 LED
Product Description
features
Table of Contents
Cree’s XLamp® High‑Current LED Array
• 23‑mm optical source
Characteristics.............................................2
family is optimized for best‑in‑class
• Mechanical and optical design
Operating Limits...........................................3
lumen output, efficacy and reliability at
consistent with CXA3070 and
Flux Characteristics, EasyWhite® Order
high drive currents. XLamp CMA LEDs
CXB3070 LEDs
Codes and Bins - 48 V..................................4
share the same package design and
LES sizes as Cree’s industry‑leading
CXA2 Standard Density LEDs, enabling
lighting manufacturers to address a
• Available in 70-, 80-, 90‑ and
95‑minimum CRI options
• Cree EasyWhite® 2-, 3- and 5‑step
binning
Flux Characteristics, Premium Color
Order Codes and Bins - 48 V.......................5
Codes and Bins - 72 V..................................6
range of performance requirements
• Premium Color 2- and 3-step binning
for
• Forward voltage options: 48‑V class,
Order Codes and Bins- 72 V........................7
applications
such
as
track,
downlight and outdoor lighting using
72‑V class
Relative Spectral Power Distribution..........8
a single easy‑to‑use platform. XLamp
• 85 °C binning and characterization
Electrical Characteristics.............................9
High‑Current LED Arrays are available
• Maximum drive current: 3600 mA
Relative Luminous Flux............................. 10
in 2‑step, 3‑step and 5‑step EasyWhite
bins.
(48 V), 2400 mA (72 V)
• 115° viewing angle, uniform
chromaticity profile
Typical Spatial Distribution....................... 11
Performance Groups - Chromaticity........ 12
Premium Color Performance Groups -
• Top-side solder connections
Chromaticity.............................................. 13
• RoHS compliant
Cree EasyWhite® Bins Plotted on the
• UL® recognized component
1931 CIE Color Space............................... 14
(E349212)
CLD-DS163 Rev 0
Product family data sheet
Cree Premium Color Bins Plotted on the
1931 CIE Color Space............................... 15
Bin and Order Code Formats.................... 17
Mechanical Dimensions........................... 18
www.cree.com/Xlamp
Thermal Design......................................... 19
Notes......................................................... 21
Packaging.................................................. 22
Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite®
are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC.
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
XLamp ® CMA3090 LED
Characteristics
Characteristics
Viewing angle (FWHM)
ESD withstand voltage (JEDEC JS-001-2012)
Unit
Minimum
Typical
degrees
115
V
Class 3A
Maximum
DC forward current (48 V)
mA
3600*
DC forward current (72 V)
mA
2400*
Reverse current (48 V, 72 V)
mA
0.1
Forward voltage (48 V, @ 1800 mA, Tj = 85 °C)
V
45
50
Forward voltage (72 V, @ 1200 mA, Tj = 85 °C)
V
68
75
Refer to the Operating Limits section.
Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a
2
XLamp ® CMA3090 LED
Operating Limits
The maximum current rating of the CMA3090 depends on the case temperature (Tc) when the LED has reached thermal equilibrium
under steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal
interface material and heat sink) and may vary when poor thermal management is employed. Either solder pad shown in the Mechanical
Dimensions section on page 18 can be used as the Tc measurement point.
Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree recommends a
maximum LES temperature of 140 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 19 for more
information on LES temperature measurement.
4000
85 °C, 3600 mA
3600
3200
2800
If (mA)
2400
48 V
2000
1600
125 °C, 1385 mA
1200
800
400
50
75
100
125
150
Case Temperature (°C)
CMA3090
2600
85 °C, 2400 mA
2400
2200
2000
1800
If (mA)
1600
1400
72 V
1200
1000
125 °C, 923 mA
800
600
400
200
50
75
100
125
150
3
XLamp ® CMA3090 LED
Flux Characteristics, EasyWhite® Order Codes and Bins - 48 V (If = 1800 mA, TJ = 85 °C)
The following table provides order codes for XLamp CMA3090 LEDs. For a complete description of the order code nomenclature, please
see the Bin and Order Code Formats section (page 17).
Nominal
CCT
Min.
Typ
Minimum
Luminous
Flux (lm)
70
73
12,573
80
82
70
CRI
Typical
Luminous
Flux (lm)
2-Step
Group
Order Code
3-Step
Group
Order Code
5-Step
Group
Order Code
13,519
65E
CMA3090-0000000Q0B0A65E
11,746
12,630
65E
CMA3090-0000000Q0H0A65E
73
12,830
13,795
57E
CMA3090-0000000Q0B0A57E
80
82
11,986
12,888
57E
CMA3090-0000000Q0H0A57E
90
92
10,195
10,962
70
73
12,458
13,396
50E
CMA3090-0000000Q0B0A50E
80
82
11,638
12,515
50G
CMA3090-0000000Q0H0A50G
90
92
10,195
10,962
50G
CMA3090-0000000Q0U0A50G
70
73
12,364
13,295
40E
CMA3090-0000000Q0B0A40E
80
82
11,506
12,372
40H
CMA3090-0000000Q0H0A40H
40G
CMA3090-0000000Q0H0A40G
90
92
9,907
10,652
40H
CMA3090-0000000Q0U0A40H
40G
CMA3090-0000000Q0U0A40G
80
82
11,225
12,070
35H
CMA3090-0000000Q0H0A35H
35G
CMA3090-0000000Q0H0A35G
90
92
9,635
10,360
35H
CMA3090-0000000Q0U0A35H
35G
CMA3090-0000000Q0U0A35G
70
73
11,506
12,372
30E
CMA3090-0000000Q0B0A30E
80
82
10,900
11,720
30H
CMA3090-0000000Q0H0A30H
30G
CMA3090-0000000Q0H0A30G
90
92
9,215
9,909
30H
CMA3090-0000000Q0U0A30H
30G
CMA3090-0000000Q0U0A30G
80
82
10,459
11,246
27H
CMA3090-0000000Q0H0A27H
27G
CMA3090-0000000Q0H0A27G
90
92
8,799
9,461
27H
CMA3090-0000000Q0U0A27H
27G
CMA3090-0000000Q0U0A27G
6500 K
5700 K
5000 K
4000 K
57G
3500 K
3000 K
2700 K
CMA3090-0000000Q0U0A57G
Notes
Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI
measurements. See the Measurements section (page 21).
For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60.
4
XLamp ® CMA3090 LED
Flux Characteristics, Premium Color Order Codes and Bins - 48 V (If = 1800 mA, TJ = 85 °C)
Fidelity
CRI*
2-Step
Min.
Typ
Minimum
Luminous
Flux (lm)
4000 K
95
98
8,873
9,541
L5A
CMA3090-0000-000Q0Z0AL5A
3500 K
95
98
8,636
9,286
35H
CMA3090-0000-000Q0Z0A35H
3000 K
95
98
8,075
8,682
30H
CMA3090-0000-000Q0Z0A30H
2700 K
95
98
7,645
8,220
27H
CMA3090-0000-000Q0Z0A27H
Min.
Typ
Minimum
Luminous
Flux (lm)
Typical
Luminous
Flux (lm)
90
92
9,215
9,909
80
82
10,900
11,720
90
92
9,215
9,909
95
98
8,075
8,682
Nominal
CCT
Typical
Luminous
Flux (lm)
Group
Order Code
Specialty
Nominal
CCT
3100 K
3000 K
CRI
2-Step
Group
L7B
L7C
Order Code
3-Step
Group
Order Code
31Q
CMA3090-0000000Q0U0A31Q
30Q
CMA3090-0000000Q0U0A30Q
Group
Order Code
30U
CMA3090-0000000Q0U0A30U
CMA3090-0000000Q0H0AL7B
CMA3090-0000000Q0Z0AL7C
Notes
5
XLamp ® CMA3090 LED
Flux Characteristics, EasyWhite® Order Codes and Bins - 72 V (If = 1200 mA, TJ = 85 °C)
Nominal
CCT
Min.
Typ
Minimum
Luminous
Flux (lm)
70
73
12,573
80
82
70
CRI
Typical
Luminous
Flux (lm)
2-Step
Group
Order Code
3-Step
Group
Order Code
5-Step
Group
Order Code
13,519
65E
CMA3090-0000000R0B0A65E
11,746
12,630
65E
CMA3090-0000000R0H0A65E
73
12,830
13,795
57E
CMA3090-0000000R0B0A57E
80
82
11,986
12,888
57E
CMA3090-0000000R0H0A57E
90
92
10,195
10,962
70
73
12,458
13,396
50E
CMA3090-0000000R0B0A50E
80
82
11,638
12,515
50G
CMA3090-0000000R0H0A50G
90
92
10,195
10,962
50G
CMA3090-0000000R0U0A50G
70
73
12,364
13,295
40E
CMA3090-0000000R0B0A40E
80
82
11,506
12,372
40H
CMA3090-0000000R0H0A40H
40G
CMA3090-0000000R0H0A40G
90
92
9,907
10,652
40H
CMA3090-0000000R0U0A40H
40G
CMA3090-0000000R0U0A40G
80
82
11,225
12,070
35H
CMA3090-0000000R0H0A35H
35G
CMA3090-0000000R0H0A35G
90
92
9,635
10,360
35H
CMA3090-0000000R0U0A35H
35G
CMA3090-0000000R0U0A35G
70
73
11,506
12,372
30E
CMA3090-0000000R0B0A30E
80
82
10,900
11,720
30H
CMA3090-0000000R0H0A30H
30G
CMA3090-0000000R0H0A30G
90
92
9,215
9,909
30H
CMA3090-0000000R0U0A30H
30G
CMA3090-0000000R0U0A30G
80
82
10,459
11,246
27H
CMA3090-0000000R0H0A27H
27G
CMA3090-0000000R0H0A27G
90
92
8,799
9,461
27H
CMA3090-0000000R0U0A27H
27G
CMA3090-0000000R0U0A27G
6500 K
5700 K
5000 K
4000 K
57G
3500 K
3000 K
2700 K
CMA3090-0000000R0U0A57G
Notes
6
XLamp ® CMA3090 LED
Flux Characteristics, Premium Color Order Codes and Bins- 72 V (If = 1200 mA, TJ = 85 °C)
Fidelity
CRI*
2-Step
Min.
Typ
Minimum
Luminous
Flux (lm)
4000 K
95
98
8,873
9,541
L5A
CMA3090-0000-000R0Z0AL5A
3500 K
95
98
8,636
9,286
35H
CMA3090-0000-000R0Z0A35H
3000 K
95
98
8,075
8,682
30H
CMA3090-0000-000R0Z0A30H
2700 K
95
98
7,645
8,220
27H
CMA3090-0000-000R0Z0A27H
Min.
Typ
Minimum
Luminous
Flux (lm)
Typical
Luminous
Flux (lm)
90
92
9,215
9,909
80
82
10,900
11,720
90
92
9,215
9,909
95
98
8,075
8,682
Nominal
CCT
Typical
Luminous
Flux (lm)
Group
Order Code
Specialty
Nominal
CCT
3100 K
3000 K
CRI
2-Step
Group
L7B
L7C
Order Code
3-Step
Group
Order Code
31Q
CMA3090-0000000R0U0A31Q
30Q
CMA3090-0000000R0U0A30Q
Group
Order Code
30U
CMA3090-0000000R0U0A30U
CMA3090-0000000R0H0AL7B
CMA3090-0000000R0Z0AL7C
Notes
7
XLamp ® CMA3090 LED
The following graph is the result of a series of pulsed measurements at 1800 mA for the 48‑V CMA3090, 1200 mA for the 72‑V CMA3090
and TJ = 85 °C.
100%
Relative Spectral Power (%)
90%
80%
70%
60%
50%
3000 K, 80 CRI
40%
30%
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
8
XLamp ® CMA3090 LED
The following graphs are the result of a series of steady-state measurements.
50
49
48 V
Voltage (V)
48
47
Tc = 25 °C
46
Tc = 55 °C
Tc = 85 °C
45
Tc = 105 °C
44
43
42
41
400
800
1200
1600
2000
2400
2800
3200
3600
Current (mA)
76
74
72 V
Voltage (V)
72
Tc = 25 °C
70
Tc = 55 °C
Tc = 85 °C
68
Tc = 105 °C
66
64
62
300
600
900
1200
1500
1800
2100
2400
Current (mA)
9
XLamp ® CMA3090 LED
The relative luminous flux values provided below are the ratio of:
• Measurements of CMA3090 at steady-state operation at the given conditions, divided by
• Flux measured during binning, which is a pulsed measurement at 1800 mA at TJ = 85 °C for the 48‑V CMA3090.
Using the 48-V CMA3090 LED as an example,, at steady-state operation of Tc = 25 °C, IF = 1200 mA, the relative luminous flux ratio is 75%
in the chart below. A 48‑V CMA3090 LED that measures 9909 lm during binning will deliver 7432 lm (9909 * .75) at steady-state operation
of Tc = 25 °C, IF = 1200 mA.
200%
175%
48 V
150%
125%
Tc = 25 °C
Tc = 55 °C
100%
Tc = 85 °C
75%
Tc = 105 °C
50%
25%
0%
400
800
1200
1600
2000
2400
2800
3200
3600
Current (mA)
10
XLamp ® CMA3090 LED
Relative Luminous Flux - Continued
• Flux measured during binning, which is a pulsed measurement at 1200 mA at TJ = 85 °C for the 72‑V CMA3090.
Using the 72-V CMA3090 LED as an example,, at steady-state operation of Tc = 55 °C, IF = 1500 mA, the relative luminous flux ratio is
125% in the chart below. A 72‑V CMA3090 LED that measures 9,909 lm during binning will deliver 12,386 lm (9,909 * 1.25) at steady-state
operation of Tc = 55 °C, IF = 1500 mA.
200%
175%
72 V
150%
Tc = 25 °C
125%
Tc = 55 °C
100%
Tc = 85 °C
Tc = 105 °C
75%
50%
25%
0%
Far Field
300
600
900
1200
1500
1800
2100
2400
Current (mA)
100%
Relative Luminous Intensity
80%
60%
40%
20%
-90
-70
-50
-30
-10
0%
10
30
50
70
90
Angle (º)
11
XLamp ® CMA3090 LED
Performance Groups - Chromaticity (Tj = 85 °C)
XLamp CMA3090 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
EasyWhite Color Temperatures – 2-Step
Code
40H
35H
30H
27H
CCT
4000 K
3500 K
3000 K
2700 K
x
y
0.3777
0.3739
0.3797
0.3816
0.3861
0.3855
0.3838
0.3777
0.4022
0.3858
0.4053
0.3942
0.4125
0.3977
0.4091
0.3891
0.4287
0.3975
0.4328
0.4064
0.4390
0.4086
0.4347
0.3996
0.4524
0.4048
0.4574
0.4140
0.4633
0.4154
0.4581
0.4062
EasyWhite Color Temperatures – 3-Step Ellipse
Center Point
Major Axis
Minor Axis
x
y
a
b
Rotation Angle
5700 K
0.3287
0.3417
0.00738
0.00360
72.0
5000 K
0.3447
0.3553
0.00840
0.00312
65.0
40G
4000 K
0.3818
0.3797
0.00939
0.00402
53.7
35G
3500 K
0.4073
0.3917
0.00927
0.00414
54.0
30G
3000 K
0.4338
0.4030
0.00834
0.00408
53.2
27G
2700 K
0.4577
0.4099
0.00834
0.00420
48.5
Rotation Angle
Bin Code
CCT
57G
50G
EasyWhite Color Temperatures – 5-Step Ellipse
Bin Code
CCT
Center Point
x
Major Axis
Minor Axis
y
a
b
65E
6500 K
0.3123
0.3282
0.01110
0.00550
61.0
57E
5700 K
0.3287
0.3417
0.01230
0.00600
72.0
50E
5000 K
0.3447
0.3553
0.01400
0.00520
65.0
40E
4000 K
0.3818
0.3797
0.01565
0.00670
53.7
30E
3000 K
0.4338
0.4030
0.01390
0.00680
53.2
12
XLamp ® CMA3090 LED
Premium Color Performance Groups - Chromaticity (Tj = 85 °C)
Fidelity
Code
L5A
35H
30H
27H
CCT
4000 K
3500 K
3000 K
2700 K
x
y
0.3764
0.3711
0.3784
0.3787
0.3847
0.3826
0.3825
0.3748
0.4022
0.3858
0.4053
0.3942
0.4125
0.3977
0.4091
0.3891
0.4287
0.3975
0.4328
0.4064
0.4390
0.4086
0.4347
0.3996
0.4524
0.4048
0.4574
0.4140
0.4633
0.4154
0.4581
0.4062
Specialty
Code
L7B
L7C
CCT
3000 K
3000 K
x
y
0.4263
0.3848
0.4296
0.3916
0.4361
0.3938
0.4326
0.3868
0.4192
0.3754
0.4224
0.3823
0.4291
0.3847
0.4257
0.3777
Center Point
Major Axis
Minor Axis
x
y
a
b
Rotation Angle
3100 K
0.4236
0.3888
0.00848
0.00455
50.3
30Q
3000 K
0.4305
0.3935
0.00834
0.00408
53.2
30U
3000 K
0.4274
0.3837
0.00834
0.00408
53.2
Bin Code
CCT
31Q
13
XLamp ® CMA3090 LED
Cree EasyWhite® Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C)
0.44
2700 K
ANSI C78.377 Quadrangle
0.43
3000 K
EasyWhite 5-step
EasyWhite 3-step
0.42
3500 K
EasyWhite 2-step
0.41
4000 K
0.40
4500 K
CCy
0.39
5000 K
0.38
0.37
5700 K
0.36
6500 K
0.35
0.34
0.33
0.32
0.48
0.47
0.46
0.45
0.44
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.29
0.31
CCx
14
XLamp ® CMA3090 LED
Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C)
Fidelity (2-step)
0.44
2700K
0.43
3000K
0.42
3500K
0.41
27H
4000K
CCy
0.40
30H
4500K
35H
0.39
0.38
L5A
0.37
0.36
0.35
0.48
0.47
0.46
0.45
0.44
CCx
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
15
XLamp ® CMA3090 LED
Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) - Continued
Speciality (2-step)
0.44
3000 K
0.43
0.42
3500 K
CCy
0.41
0.40
0.39
L7B
L7C
0.38
0.46
0.45
CCx
0.44
0.43
0.42
0.41
0.37
Speciality (3-step)
0.44
3000K
0.43
0.42
3500K
CCy
0.41
0.40
30Q
0.39
31Q
30U
0.38
0.46
0.45
CCx
0.44
0.43
0.42
0.41
0.37
16
XLamp ® CMA3090 LED
Bin codes and order codes are configured as follows:
Order Code
Bin Code
Series = CMA30
Series = CMA30
Internal code
Chromaticity bin
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Z = 95 CRI minimum
Vf class
Q0 = 48-V class
R0 = 72-V class
Internal code
SSSSSCC-WWW-FF-GGR-AAAAA
SSSSSCC-HHHH-HHHGGRNNNNN
Kit code
Vf class
Q0 = 48-V class
R0 = 72-V class
Performance class
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Z = 95 CRI minimum
Flux bin
0A = Not binned into flux bins
Performance class
17
XLamp ® CMA3090 LED
Dimensions are in mm.
Tolerances unless otherwise specified: +.13
x° +1°
M3090Q = 48‑V CMA3090
M3090R = 72‑V CMA3090
X1 X2 X3 X4 X5
X1
CCT
1 = 6500 K
8 = 2700 K
X2
M = EasyWhite or
Fidelity LED on the
black‑body line
Q = Specialty LED below
the black‑body line
U = Specialty LED below
the black‑body line
X3 X4 Flux bin
bins
X5
CRI
B = 70 CRI min
H = 80 CRI min
U = 90 CRI min
Z = 95 CRI min
18
XLamp ® CMA3090 LED
Thermal Design
The CMA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction
temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum
TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to
ensure that the CMA LED is being operated within its designed limits. LES temperature measurement provides additional verification of
good thermal design. Please refer to page 2 for the Operating Limit specification.
There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from solder point (TSP) to
ambient (Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please
refer to the Thermal Management application note. For CMA soldering recommendations and information on thermal interface materials
(TIM), LES temperature measurement, and connection methods, please refer to the Cree XLamp CM Family LEDs soldering and handling
document.
To keep the CMA3090 LED at or below the maximum rated Tc, the case to ambient temperature
thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following
R_j-c
R_j-c
scale.
Tc
Tc
As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim)
R_tim
graphs, depending on the operating environment. The y‑axis in the graphs is a base 10 logarithmic
R_c-a
plus the thermal resistance of the heat sink (R_hs).
R_hs
Ta
Ta
Maximum R_c-a
10.00
48 V
1.00
Ta = 25 °C
Ta = 55 °C
Ta = 85 °C
Ta = 105 °C
0.10
0.01
400
800
1200
1600
2000
2400
2800
3200
3600
Current (mA)
19
XLamp ® CMA3090 LED
CMA3090
Thermal Design - Continued
10.00
Maximum R_c-a
72 V
1.00
Ta = 25 °C
Ta = 55 °C
Ta = 85 °C
Ta = 105 °C
0.10
0.01
300
600
900
1200
1500
1800
2100
2400
Current (mA)
XLamp ® CMA3090 LED
Notes
Measurements
The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only
and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number
of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated
values are provided for informational purposes only and are not intended or provided as specifications.
Pre‑Release Qualification Testing
Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp
LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs. Cree did not perform Room Temperature Operating Life
(RTOL) testing on the CMA3090 LED
Lumen Maintenance
Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance.
For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document.
Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting.
Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect
the LED junction temperature.
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product
Ecology section of the Cree website.
UL® Recognized Component
This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED
package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please
refer to the LED Eye Safety application note.
21
XLamp ® CMA3090 LED
Packaging
Cree CMA3090 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100
LEDs per carton. Each carton contains 100 LEDs from the same performance bin.
Dimensions are in inches.
Tolerances: +.13
5
6
4
5
x° +1°
7.500
3
4
R.375
3
2
2
1
1
OTICE
PLOT AND THE INFORMATION
HE PROPRIETARY AND
ON OF CREE, INC. THIS PLOT
ODUCED OR DISCLOSED TO ANY
NSENT
7.53
1.313
R .375
5.875
R .375
D
8.125
.875
1.313
8.15
C
1.313
LABEL WITH CREE BIN CODE,
QUANTITY, LOT #
.38
LABEL WITH CREE BIN
1.313
PATENT LABEL IS LOCATED
CODE, QUANTITY, LOT#
BAG
ON UNDERSIDE OF CARTON
PATENT LABELIS LOCATED
TH CREE BIN
.875
ANTITY, LOT #
BAG
.38
B
L IS LOCATED
IDE OF COVER
LABEL WITH CREE BIN
LABEL WITH CREE BIN
CODE, QUANTITY, LOT #
LABEL WITH CREE BIN
LABEL WITH CREE BIN
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN
MILLIMETERS & BEFORE FINISH.
TOLERANCE UNLESS SPECIFIED:
THIRD ANGLE PROJECTION
.X
.XX
.XXX ±
X°
0.1
.05
.005
1 °
FOR SHEET METAL PARTS ONLY
.X
.06
.XX
.03
.XXX ±
.010
X°
2 °
6
WITH CREE BIN
QUANTITY, LOT #
5
4
3 UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN
notice.
CreeUNLESS
, XLamp
and
TOLERANCE
SPECIFIED:
.X
0.1
.XX
.05
.XXX ± .005
X°
1 °
.X
.06
DRAWN BY
DATE
CHECK
DATE
APPROVED
DATE
4600 Silicon Drive
Durham, N.C 27703
Phone (919) 361-4770
Fax (919) 313-5303
A
TITLE
CXA30XX_DATASHEET
MATERIAL
SIZE
FINAL PROTECTIVE FINISH
C
SCALE
DRAWN BY
2
SHEET
0.500
1
DATE
CHECK
DATE
APPROVED
DATE
REV.
DRAWING NO.
CXA30XX_DATASHEET_BAG_2013
A
OF
1 /1
4600 Silicon Drive
Durham, N.C 27703
Fax (919) 313-5303
TITLE
CXA15XX_DATASHEET
22
MATERIAL
SIZE
DRAWING NO.
CXA15XX_DATASHEET_BAG2013
