Cree® XLamp® CMT2850 LED
Product Description
features
Table of Contents
The
• 22‑mm optical source
Characteristics.............................................2
• Available in 70-, 80- and 90‑ and
Operating Limits...........................................2
Cree
XLamp®
High-Current
LED Array family is optimized for
best‑in‑class lumen output, efficacy
and reliability at high drive currents.
XLamp CMT LEDs deliver performance
95‑minimum CRI options
• Cree EasyWhite® 2-, 3- and 5‑step
binning
Flux Characteristics, EasyWhite® Order
Codes and Bins............................................3
Flux Characteristics, Premium Color
in industry‑compatible packages and
• Premium Color 2- and 3-step binning
Order Codes and Bins..................................4
LESes, enabling lighting manufacturers
• Forward voltage option: 36‑V class
Relative Spectral Power Distribution,
to upgrade their designs for applications
• 85 °C binning and characterization
EasyWhite® LEDs..........................................5
such as track, downlight and outdoor
• Maximum drive current: 3500 mA
lighting.
• 115° viewing angle, uniform
Premium Color LEDs....................................6
XLamp
High-Current
LED
Arrays are available in 2‑step, 3‑step
and 5‑step EasyWhite bins.
chromaticity profile
Electrical Characteristics.............................8
• Top-side solder connections
Relative Luminous Flux................................9
• RoHS and REACh compliant
Typical Spatial Distribution..........................9
• UL recognized component
Performance Groups - Chromaticity........ 10
(E349212)
CLD-DS187 Rev 4
Product family data sheet
Premium Color Performance Groups Chromaticity.............................................. 11
Cree EasyWhite® Bins Plotted on the
1931 CIE Color Space............................... 12
Cree Premium Color Bins Plotted on the
1931 CIE Color Space............................... 13
Bin and Order Code Formats.................... 15
Mechanical Dimensions........................... 16
Thermal Design......................................... 17
Notes......................................................... 18
www.cree.com/Xlamp
Packaging.................................................. 19
Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and
EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC.
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
XLamp ® CMT2850 LED
Characteristics
Characteristics
Unit
Viewing angle (FWHM)
Minimum
Typical
degrees
115
V
Class 3A
ESD withstand voltage (JEDEC JS-001-2012)
Maximum
DC forward current
mA
3500*
Reverse current
mA
0.1
Forward voltage (@ 1400 mA, 85 °C)
V
33.8
37.2
Refer to the Operating Limits section.
Operating Limits
The maximum current rating of the CMT2850 depends on the case temperature (Tc) when the LED has reached thermal equilibrium
under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal
interface material and heat sink) and may vary when poor thermal management is employed. Either solder pad shown in the Mechanical
Dimensions section on page 16 can be used as the Tc measurement point.
Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree recommends a
maximum LES temperature of 140 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 13 for more
information on LES temperature measurement.
CMT2850
3600
85 °C, 3500 mA
3200
2800
If (mA)
2400
2000
1600
125 °C, 1346 mA
1200
800
400
50
75
100
125
150
Case Temperature (°C)
Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a
2
XLamp ® CMT2850 LED
Flux Characteristics, EasyWhite® Order Codes and Bins (If = 1400 mA, TJ = 85 °C)
The following table provides order codes for XLamp CMT2850 LEDs. For a complete description of the order code nomenclature, please
see the Bin and Order Code Formats section (page 15).
Nominal
CCT
Min.
Typ
Minimum
Luminous
Flux (lm)
70
73
7563
80
82
70
CRI
Typical
Luminous
Flux (lm)
2-Step
Group
Order Code
3-Step
Group
Order Code
5-Step
Group
Order Code
8132
65E
CMT2850-0000000N0B0A65E
7066
7597
65E
CMT2850-0000000N0H0A65E
73
7717
8298
57E
CMT2850-0000000N0B0A57E
80
82
7210
7753
57E
CMT2850-0000000N0H0A57E
90
92
6133
6594
70
73
7494
8058
50E
CMT2850-0000000N0B0A50E
80
82
7001
7528
50G
CMT2850-0000000N0H0A50G
90
92
6133
6594
50G
CMT2850-0000000N0U0A50G
70
73
7437
7997
40E
CMT2850-0000000N0B0A40E
80
82
6921
7442
40H
CMT2850-0000000N0H0A40H
40G
CMT2850-0000000N0H0A40G
90
92
5959
6408
40H
CMT2850-0000000N0U0A40H
40G
CMT2850-0000000N0U0A40G
80
82
6752
7260
35H
CMT2850-0000000N0H0A35H
35G
CMT2850-0000000N0H0A35G
90
92
5796
6232
35H
CMT2850-0000000N0U0A35H
35G
CMT2850-0000000N0U0A35G
70
73
6921
7442
30E
CMT2850-0000000N0B0A30E
80
82
6557
7050
30H
CMT2850-0000000N0H0A30H
30G
CMT2850-0000000N0H0A30G
90
92
5543
5961
30H
CMT2850-0000000N0U0A30H
30G
CMT2850-0000000N0U0A30G
80
82
6291
6765
27H
CMT2850-0000000N0H0A27H
27G
CMT2850-0000000N0H0A27G
90
92
5293
5691
27H
CMT2850-0000000N0U0A27H
27G
CMT2850-0000000N0U0A27G
80
82
5543
5961
22G
CMT2850-0000000N0H0A22G
6500 K
5700 K
5000 K
4000 K
57G
3500 K
3000 K
2700 K
2200 K
CMT2850-0000000N0U0A57G
Notes
Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI
measurements. See the Measurements section (page 18).
For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60.
3
XLamp ® CMT2850 LED
Flux Characteristics, Premium Color Order Codes and Bins (If = 1400 mA, TJ = 85 °C)
Fidelity
CRI*
2-Step
Min.
Typ
Minimum
Luminous
Flux (lm)
4000 K
95
98
5337
5739
L5A
CMT2850-0000-000N0Z0AL5A
3500 K
95
98
5195
5586
35H
CMT2850-0000-000N0Z0A35H
3000 K
95
98
4857
5223
30H
CMT2850-0000-000N0Z0A30H
2700 K
95
98
4599
4945
27H
CMT2850-0000-000N0Z0A27H
Min.
Typ
Minimum
Luminous
Flux (lm)
Typical
Luminous
Flux (lm)
90
92
5543
5961
80
82
6557
7050
90
92
5543
5961
95
98
4857
5223
Nominal
CCT
Typical
Luminous
Flux (lm)
Group
Order Code
Specialty
Nominal
CCT
3100 K
3000 K
CRI
2-Step
Group
L7B
L7C
Order Code
3-Step
Group
Order Code
31Q
CMT2850-0000000N0U0A31Q
30Q
CMT2850-0000000N0U0A30Q
Group
Order Code
30U
CMT2850-0000000N0U0A30U
CMT2850-0000000N0H0AL7B
CMT2850-0000000N0Z0AL7C
Notes
4
XLamp ® CMT2850 LED
Relative
Spectral Power Distribution, EasyWhite® LEDs
EZW 70 CRI
The following graphs are the result of a series of pulsed measurements at 1400 mA and TJ = 85 °C.
100%
90%
80%
70%
6500 K, 70 CRI
5700 K, 70 CRI
5000 K, 70 CRI
4000 K, 70 CRI
3000 K, 70 CRI
60%
50%
40%
30%
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
EZW 80 CRI
100%
90%
80%
6500 K, 80 CRI
70%
5700 K, 80 CRI
5000 K, 80 CRI
60%
4000 K, 80 CRI
50%
3500 K, 80 CRI
40%
3000 K, 80 CRI
30%
2700 K, 80 CRI
20%
2200 K, 80 CRI
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
5
XLamp ® CMT2850 LED
EZW 90 CRI
Relative Spectral Power Distribution, EasyWhite® LEDs - Continued
100%
90%
80%
5700 K, 90 CRI
70%
5000 K, 90 CRI
60%
4000 K, 90 CRI
50%
3500 K, 90 CRI
40%
3000 K, 90 CRI
30%
2700 K, 90 CRI
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
Relative Spectral Power Distribution, Premium Color LEDs
Fidelity
Fidelity
100%
90%
80%
70%
4000 K, Z CRI
60%
3500 K, Z CRI
50%
3000 K, Z CRI
40%
2700 K, Z CRI
30%
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
6
XLamp ® CMT2850 LED
Relative Spectral Power Distribution, Premium Color LEDs - continued
Speciality
Specialty
100%
90%
80%
70%
60%
31Q, 3100 K, 90 CRI
50%
40%
30%
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
Speciality
100%
90%
80%
70%
30Q, 3000 K, 90 CRI
60%
30U, 3000 K, 90 CRI
50%
L7B, 3000 K, 80 CRI
40%
L7C, 3000 K, Z CRI
30%
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
7
XLamp ® CMT2850 LED
The following graph is the result of a series of steady-state measurements.
38
Voltage (V)
37
36
Tc = 25 °C
Tc = 55 °C
35
Tc = 85 °C
Tc = 105 °C
34
33
32
900
1100
1300
1500
1700
1900
2100
2300
2500
2700
2900
3100
3300
3500
Current (mA)
8
XLamp ® CMT2850 LED
The relative luminous flux values provided below are the ratio of:
• Measurements of CMT2850 at steady-state operation at the given conditions, divided by
• Flux measured during binning, which is a pulsed measurement at 1400 mA at TJ = 85 °C.
For example, at steady-state operation of Tc = 25 °C, IF = 1500 mA, the relative luminous flux ratio is 120% in the chart below. A CMT2850
LED that measures 7050 lm during binning will deliver 8460 lm (7050 * 1.2) at steady-state operation of Tc = 25 °C, IF = 1500 mA.
240%
220%
200%
180%
160%
Tc = 25 °C
140%
Tc = 55 °C
120%
Tc = 85 °C
100%
Tc = 105 °C
80%
60%
40%
20%
0%
Far Field
900
1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500
Current (mA)
100%
Relative Luminous Intensity
80%
60%
40%
20%
-90
-70
-50
-30
-10
0%
10
30
50
70
90
Angle (º)
9
XLamp ® CMT2850 LED
Performance Groups - Chromaticity (Tj = 85 °C)
XLamp CMT2850 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
EasyWhite Color Temperatures – 2-Step
Code
40H
35H
30H
27H
CCT
4000 K
3500 K
3000 K
2700 K
x
y
0.3777
0.3739
0.3797
0.3816
0.3861
0.3855
0.3838
0.3777
0.4022
0.3858
0.4053
0.3942
0.4125
0.3977
0.4091
0.3891
0.4287
0.3975
0.4328
0.4064
0.4390
0.4086
0.4347
0.3996
0.4524
0.4048
0.4574
0.4140
0.4633
0.4154
0.4581
0.4062
EasyWhite Color Temperatures – 3-Step Ellipse
Center Point
Major Axis
Minor Axis
x
y
a
b
Rotation Angle
5700 K
0.3287
0.3417
0.00738
0.00360
72.0
5000 K
0.3447
0.3553
0.00840
0.00312
65.0
40G
4000 K
0.3818
0.3797
0.00939
0.00402
53.7
35G
3500 K
0.4073
0.3917
0.00927
0.00414
54.0
30G
3000 K
0.4338
0.4030
0.00834
0.00408
53.2
27G
2700 K
0.4577
0.4099
0.00834
0.00420
48.5
22G
2200 K
0.5066
0.4158
0.00980
0.00480
45.5
Major Axis
Minor Axis
y
a
b
Rotation Angle
Bin Code
CCT
57G
50G
EasyWhite Color Temperatures – 5-Step Ellipse
Bin Code
CCT
Center Point
x
65E
6500 K
0.3123
0.3282
0.01110
0.00550
61.0
57E
5700 K
0.3287
0.3417
0.01230
0.00600
72.0
50E
5000 K
0.3447
0.3553
0.01400
0.00520
65.0
40E
4000 K
0.3818
0.3797
0.01565
0.00670
53.7
30E
3000 K
0.4338
0.4030
0.01390
0.00680
53.2
10
XLamp ® CMT2850 LED
Premium Color Performance Groups - Chromaticity (Tj = 85 °C)
Fidelity
Code
L5A
35H
30H
27H
CCT
4000 K
3500 K
3000 K
2700 K
x
y
0.3764
0.3711
0.3784
0.3787
0.3847
0.3826
0.3825
0.3748
0.4022
0.3858
0.4053
0.3942
0.4125
0.3977
0.4091
0.3891
0.4287
0.3975
0.4328
0.4064
0.4390
0.4086
0.4347
0.3996
0.4524
0.4048
0.4574
0.4140
0.4633
0.4154
0.4581
0.4062
Specialty
Code
L7B
L7C
CCT
3000 K
3000 K
x
y
0.4263
0.3848
0.4296
0.3916
0.4361
0.3938
0.4326
0.3868
0.4192
0.3754
0.4224
0.3823
0.4291
0.3847
0.4257
0.3777
Bin Code
CCT
31Q
3100 K
Center Point
Major Axis
Minor Axis
x
y
a
b
Rotation Angle
0.4236
0.3888
0.00848
0.00455
50.3
30Q
3000 K
0.4305
0.3935
0.00834
0.00408
53.2
30U
3000 K
0.4274
0.3837
0.00834
0.00408
53.2
11
XLamp ® CMT2850 LED
Cree EasyWhite® Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C)
0.45
ANSI C78.377 Quadrangle
0.44
EasyWhite 5-step
0.43
EasyWhite 3-step
0.42
EasyWhite 2-step
2700 K
2200 K
2450 K
3000 K
3500 K
0.41
4000 K
0.40
CCy
0.39
5000 K
4500 K
5700 K
0.38
0.37
6500 K
0.36
0.35
7000K
0.34
0.33
0.32
0.54
0.53
0.52
0.51
0.50
0.49
0.48
0.47
0.46
0.45
0.44
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.29
0.31
CCx
12
XLamp ® CMT2850 LED
Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C)
Fidelity (2-step)
0.44
2700K
0.43
3000K
0.42
3500K
0.41
27H
4000K
CCy
0.40
30H
4500K
35H
0.39
0.38
L5A
0.37
0.36
0.35
0.48
0.47
0.46
0.45
0.44
CCx
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
13
XLamp ® CMT2850 LED
Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) - Continued
Speciality (2-step)
0.44
3000 K
0.43
0.42
3500 K
CCy
0.41
0.40
0.39
L7B
L7C
0.38
0.46
0.45
CCx
0.44
0.43
0.42
0.41
0.37
Speciality (3-step)
0.44
3000K
0.43
0.42
3500K
CCy
0.41
0.40
30Q
0.39
31Q
30U
0.38
0.46
0.45
CCx
0.44
0.43
0.42
0.41
0.37
14
XLamp ® CMT2850 LED
Bin codes and order codes are configured as follows:
Order Code
Bin Code
Series = CMT28
Series = CMT28
Internal code
Chromaticity bin
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Z = 95 CRI minimum
Vf class
P0 = 54-V class
Internal code
SSSSSCC-WWW-FF-GGR-AAAAA
SSSSSCC-HHHH-HHHGGRNNNNN
Kit code
Vf class
P0 = 54-V class
Performance class
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Z = 95 CRI minimum
Flux bin
0A = Not binned into flux bins
Performance class
15
UNAUTHORIZED PERSON
THE
WITHOUT
WRITTEN CONSENT
OF CREE INC.
D
XLamp ® CMT2850 LED
Dimensions are in mm.
28.00
±.20
Tolerances unless otherwise specified: ±.13
x° ± 1°
9.12
C
ø3.200
11.40
3.34
OPTICAL
REFERENCE
T2850N = 36‑V CMT2850
.90±.15
3.34
X1 X2 X3 X4 X5
X1
CCT
9.12
1 = 6500 K
11.40
28.00
±.20
8 = 2700 K
X2
11.40
M = EasyWhite or
R0.50
B
9.12
ø22.0
±0.2
ø24.0
Fidelity LED on the
±0.2
black‑body line
3.34
Q = Specialty LED below
R0.50
the black‑body line
11.40
U = Specialty LED below
ALL
UN
MIL
TO
Marking 2
X 1X CCT
(eg. 27.2700K, 30:3000K)
2
X 3X :4Flux Bin
X 5:CRI (B:70 H:80, U:90, Z:95
CRI
B = 70 CRI min
H = 80 CRI min
.55±.1
Marking 1
T2850: product family (CMT2850)
N:54V Voltage Class
A
bins
X5
3.34
OPTICAL REFERENCE
the black‑body line
X3 X4 Flux bin
9.12
6
5
THIRD ANGLE PROJEC
FO
4
3
U = 90 CRI min
Z = 95 CRI min
Tc measurement point: either the anode or cathode solder pad
16
SU
XLamp ® CMT2850 LED
Thermal Design
The CMT family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction
temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum
TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to
ensure that the CMT LED is being operated within its designed limits. LES temperature measurement provides additional verification of
good thermal design. Please refer to page 2 for the Operating Limit specification.
There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from solder point (TSP) to
ambient (Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please
refer to the Thermal Management application note. For CMT soldering recommendations and more information on thermal interface
materials (TIM), LES temperature measurement, and connection methods, please refer to the Cree XLamp CM Family LEDs soldering and
handling document.
To keep the CMT2850 LED at or below the maximum rated Tc, the case to ambient temperature
thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following
R_j-c
R_j-c
scale.
Tc
Tc
As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim)
R_tim
graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic
R_c-a
plus the thermal resistance of the heat sink (R_hs).
R_hs
CMT2850
Ta
Ta
100.00
Maximum R_c-a
10.00
Ta = 25 °C
Ta = 55 °C
1.00
Ta = 85 °C
Ta = 105 °C
0.10
0.01
900
1100
1300
1500
1700
1900
2100
2300
2500
2700
2900
3100
3300
3500
Current (mA)
17
XLamp ® CMT2850 LED
Notes
Measurements
The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only
and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number
of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated
values are provided for informational purposes only and are not intended or provided as specifications.
Pre‑Release Qualification Testing
Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp
LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs. Cree did not perform Room Temperature Operating Life
(RTOL) testing on the CMT2850 LED.
Lumen Maintenance
Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance.
For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document.
Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting.
Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect
the LED junction temperature.
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product
Ecology section of the Cree website.
REACh Compliance
REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA)
has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree representative to
insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available
upon request.
UL® Recognized Component
This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED
package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please
refer to the LED Eye Safety application note.
18
XLamp ® CMT2850 LED
Packaging
Cree CMT2850 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100
LEDs per carton. Each carton contains 100 LEDs from the same performance bin.
Dimensions are in inches.
Tolerances: ±.13
7.500
5
x° ±1°
4
6
3
5
2
R.375
4
NOTICE
ENTIAL. THIS PLOT AND THE INFORMATION
WITHIN ARE THE PROPRIETARY AND
L INFORMATION OF CREE, INC. THIS PLOT
COPIED, REPRODUCED OR DISCLOSED TO ANY
NSENT
ED PERSON WITHOUT
THE WRITTEN CONSENT
5.875
1
3
2
1
1.313
5.875
R .375
R .375
8.125
.875
.875
5.875
LABEL WITH CREE BIN CODE,
QUANTITY, LOT #
PATENT
LABEL
ISBIN
LOCATED
LABEL WITH
CREE
CODE,
QUANTITY, OF
LOTCARTON
ON
UNDERSIDE
TH CREE BIN
ANTITY, LOT #
PATENT LABEL IS LOCATED
ON UNDERSIDE .875
OF COVER
1.313
BAG
.38
.875
BAG
.38
L IS LOCATED
IDE OF COVER
LABEL WITH CREE BIN
CODE, QUANTITY, LOT #
LABEL WITH CREE BIN
LABEL WITH CREE BIN
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN
MILLIMETERS & BEFORE FINISH.
TOLERANCE UNLESS SPECIFIED:
LABEL WITH CREE BIN
.X
.XX
.XXX ±
X°
THIRD ANGLE PROJECTION
0.1
.05
.005
1 °
FOR SHEET METAL PARTS ONLY
.X
.06
.XX
.03
.XXX ±
.010
X°
2 °
6
WITH CREE
BIN
QUANTITY, LOT #
5
4
UNLESS OTHERWISE
SPECIFIED
3
DIMENSIONS ARE IN
notice.
Cree
, XLamp
TOLERANCE
UNLESS
SPECIFIED:and
.X
.XX
.XXX ±
X°
0.1
.05
.005
1 °
.X
.06
DRAWN BY
DRAWN BY
DATE
CHECK
DATE
APPROVED
DATE
4600 Silicon Drive
Durham, N.C 277
Phone (919) 361-
Fax (919) 313-530
TITLE
CXA15XX_DATASHEET
MATERIAL
SIZE
FINAL PROTECTIVE FINISH
SCALE
DATE
C
DRAWING NO.
CXA15XX_DATASHEET_BAG2013
0.500
2
CHECK
DATE
APPROVED
DATE
SHEET
Phone (919) 361-4770
Fax (919) 313-5303
TITLE
CXA15XX_DATASHEET
19
MATERIAL
SIZE
OF
1 Drive
4600 Silicon
Durham, N.C 27703
DRAWING NO.
