CMPA0527005F
CMPA0527005F
    WOLFSPEED
    射频放大器 IC 通用 500MHz ~ 2.7GHz 440221
CMPA0527005F 数据手册
CMPA0527005F 5 W, 0.5 - 2.7 GHz, 50 V, GaN HEMT Description CMPA0527005F is packaged gallium nitride (GaN) High Electron Mobility Transistor (HEMT) based monolithic microwave integrated circuit (MMIC). This device is matched to 50 ohms at the input and unmatched at the output. This device operates from a 50 V rail and is intended to be used as a predriver from 0.5 to 2.7 GHz. The transistor is available in a 6 leaded flange package. Package Types: 440221 PN: CMPA0527005F Typical Performance Over 0.5 - 2.7 GHz (TC = 25˚C), 50 V, PIN = 24 dBm, CW Parameter 0.5 GHz 1.0 GHz 1.5 GHz 2.0 GHz 2.7 GHz Units Small Signal Gain 20.4 20.8 21 20.5 19.5 dB Output Power 7.8 9.3 9.1 8.7 6.6 W Drain Efficiency 58.5 53.8 49.2 47.1 41.5 % Note: Measured in the CMPA0527005F-AMP1 application circuit Features • • • • • • Up to 2.7 GHz Operation 8 W Typical Output Power 20 dB Small Signal Gain Application Circuit for 0.5 - 2.7 GHz 50% Efficiency 50 V Operation Large Signal Models Available for ADS and MWO Rev 1.6 – September 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CMPA0527005F 2 Absolute Maximum Ratings (not simultaneous) at 25˚C Case Temperature Parameter Symbol Rating Units Conditions Drain-Source Voltage VDSS 150 Volts 25˚C Gate-to-Source Voltage VGS -10, +2 Volts 25˚C Storage Temperature TSTG -65, +150 ˚C Operating Junction Temperature TJ 225 ˚C Maximum Forward Gate Current IGMAX 1.2 mA 25˚C Maximum Drain Current IDMAX 0.5 A 25˚C Soldering Temperature TS 245 ˚C Screw Torque τ 40 in-oz Thermal Resistance, Junction to Case RθJC 18 ˚C/W Case Operating Temperature TC -40, +75 ˚C 1 2 3 4 85˚C Notes: 1 Current limit for long term, reliable operation 2 Refer to the Application Note on soldering at wolfspeed.com/rf/document-library 3 Measured for the CMPA0527005F at PDISS = 8.4 W 4 See also, Power Derating Curve on Page 5 Electrical Characteristics (TC = 25˚C) Characteristics Symbol Min. Typ. Max. Units Conditions Gate Threshold Voltage VGS(th) -3.8 -3.0 -2.3 VDC VDS = 10 V, ID = 1.2 mA Gate Quiescent Voltage VGS(Q) – -2.7 – VDC VDS = 50 V, ID = 0.11 A Saturated Drain Current2 IDS 0.78 1.12 – A VDS = 6.0 V, VGS = 2.0 V Drain-Source Breakdown Voltage VBR 100 – – VDC VGS = -8 V, ID = 1.2 mA DC Characteristics 1 RF Characteristics3,4,5 (TC = 25˚C, F0 = 2.7 GHz unless otherwise noted) Small Signal Gain S21 17 18.5 – dB VDD = 50 V, IDQ = 0.11 A PIN = 10 dBm Power Gain GP – 13.5 – dB VDD = 50 V, IDQ = 0.11 A Output Power POUT 38.6 39.5 – dBm VDD = 50 V, IDQ = 0.11 A Drain Efficiency η 49 58.0 – % VDD = 50 V, IDQ = 0.11 A Output Mismatch Stress VSWR – – 10:1 Y No damage at all phase angles, VDD = 50 V, IDQ = 0.11 A, POUT = 5 W CW CDS – 0.8 – pF VDS = 50 V, Vgs = -8 V, f = 1 MHz Dynamic Characteristics6 Output Capacitance Notes: 1 Measured on-wafer prior to packaging. 2 Scaled from PCM data 3 Measured in Cree’s production test fixture 4 PIN = 26 dBm 5 CW 6 Includes package Rev 1.6 – September 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CMPA0527005F 3 CMPA0527005F Typical Performance in CMPA0527005F-AMP1 Application Circuit Figure 1. Small Signal Gain, Return Losses versus Frequency of the CMPA0527005F VDD = 50 V, IDQ = 0.110 A Gain and Input Return Loss vs Frequency of the CMPA0527005F VDD = 50V, IDQ = 0.110A 25 15 Gain, Return Losses (dB) Gain, Return Losses (dB) 20 10 S22 5 S11 0 S21 -5 -10 -15 -20 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 Frequency (GHz) Frequency (GHz) Figure 2. Output Power, Power Added Efficiency and Gain vs Frequency of the CMPA0527005F as measured in demonstration amplifier circuit CMPA0527005F-AMP1 VDD = 50 V, IDQ = 0.110 A, PIN= 24 dBm CW, Tcase = 25°C Output Power (dBm), Efficiency (%), Gain (dB) Output Power (dBm), Efficiency (%), Gain (dB) 65 60 55 50 45 40 35 30 Output Power (dBm) 25 Efficiency (%) Gain (dB) 20 15 10 5 0 0.0 0.5 1.0 1.5 Frequency (GHz) 2.0 2.5 3.0 Frequency GHz) Rev 1.6 – September 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CMPA0527005F 4 CMPA0527005F Typical Performance in CMPA0527005F-AMP1 Application Circuit Figure 3. Gain (dB) and Efficiency (%) vs Output Power (dBm) of the CMPA0527005F as measured in demonstration amplifier circuit CMPA0527005F-AMP1 VDD = 50 V, IDQ = 0.110 A, Tcase = 25°C Gain (dB) and Efficiency (%) vs Pout (dBm) of the CMPA0527005F VDD = 50V, IDQ = 0.110A, Tcase=25C 25 Gain Drain Efficiency 1.5 GHz Gain (dB) 15 40 2.7GHz Gain (dB) 0.5 GHz Eff (%) 1.5 GHz Eff (%) Efficiency (%) Gain (dB) 0.5 GHz Gain (dB) Efficiency (%) 60 20 Gain (dB) 80 2.7 GHz Eff (%) 20 10 5 15.0 20.0 25.0 30.0 Output Power (dBm) 35.0 0 45.0 40.0 Output Power (dBm) Figure 4. Third Order Intermodulation Distortion vs Output Power measured in demonstration amplifier circuit CMPA0527005F-AMP1 VDD = 50 V, IDQ = 0.110 A, Tcase = 25°C, Δf= 1 MHz IMD3 (dBc) vs Pout (dBm) VDD = 50V, IDQ = 0.110A,Tcase=25C 0 -5 -10 IMD3 (dBc) IMD3 (dBc) -15 -20 -25 -30 -35 0.5GHz -40 1.5 GHz -45 -50 20.0 2.7 GHz 22.0 24.0 26.0 28.0 30.0 32.0 Output Power (dBm) 34.0 36.0 38.0 40.0 Output Power (dBm) Rev 1.6 – September 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CMPA0527005F 5 CMPA0527005F Typical Performance Figure 5. Simulated GMAX and K-Factor vs Frequency VDD =Simulated 50 V, IDQ = 0.110 A,CMPA0527005F Tcase = 25°C Gmax and K of VDD = 50V, IDQ = 0.110A 10 GMAX Gmax (dB) 8 21 6 19 4 K- Factor K-Factor GMAX (dB) GMAX (dB) 23 K- Factor 25 K-FACTOR 17 15 2 0.0 0.5 1.0 1.5 2.0 Frequency (GHz) 2.5 3.0 3.5 4.0 0 Frequency (GHz) CMPA0527005F Power Dissipation De-rating Curve Figure 6. Transient Power Dissipation De-Rating Curve 10 CW Power Dissipation (W) Power Dissipation (W) 8 6 4 2 0 0 50 100 150 Maximum Case Temperature (°C) 200 250 Maximum Case Temperature (°C) Note: Shaded area exceeds Maximum Case Temperature (See Page 2). Rev 1.6 – September 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CMPA0527005F 6 Source and Load Impedances D Z Source Z Load G Frequency (GHz) Z Load 0.5 143+j115 1 63.18+j93.20 1.5 39.49+j67.24 2 40.13+j42.78 2.3 40.19+j42.82 2.7 30.48+j29.17 Note 1. VDD = 50 V, IDQ = 0.110 A in the 440221 package Note 2. Optimized for power gain, PSAT and PAE S Electrostatic Discharge (ESD) Classifications Parameter Symbol Class Test Methodology Human Body Model HBM 1A (> 250 V) JEDEC JESD22 A114-D Charge Device Model CDM 2 (125 V to 250 V) JEDEC JESD22 C101-C Rev 1.6 – September 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CMPA0527005F 7 CMPA0527005F-AMP1 Application Circuit Schematic CMPA0527005F-AMP1 Application Circuit 5 4 3 2 1 J3 C8 C7 C6 L4 C9 C1 R1 C10 Rev 1.6 – September 2021 L3 L2 L1 C2 J2 C5 L6 C3 L5 C4 CMPA0527005F-TB1 3-000915R3 J2 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CMPA0527005F 8 CMPA0527005F-AMP1 Application Circuit Bill of Materials Designator Description Qty C1 CAP, 33PF, 5%, 0603, ATC 1 C2, C6, C9 CAP, 100PF, 5%, 0603, ATC 3 C3 CAP, 3PF, 5%, 0805, ATC 1 C4 CAP, 12PF, 5%, 0603, ATC 1 C5 CAP, 0.3pF, 5%, 0603, ATC 1 C7 CAP, 470pF, 5%, 0603,100V. X7R 1 C8 CAP, 33000pF, 0805,100V,X7R 1 R1 RES, 1/16W, 1206, 1%, 0 Ohms 1 L1,L2,L5 INDUCTOR,CHIP,1.6nH,0603CS SMT 3 L3 INDUCTOR,CHIP,4.3nH,0603CS SMT 1 L4 INDUCTOR,CHIP,15nH,0603HP SMT 1 L6 INDUCTOR,CHIP,12nH,0603CS SMT 1 Q1 Transistor CMPA0527005F 1 PCB, RO4350, CMPA0527005F Applications Board, 1.7" X 2.6"X0.02” 1 BASEPLATE, AL, 2.60 X 1.7 X 0.25 1 2-56 SOC HD SCREW 1/4 SS 4 #2 SPLIT LOCKWASHER SS 4 J1,J2 CONN, SMA, PANEL MOUNT JACK, FLANGE, 4-HOLE, BLUNT POST, 20MIL 2 J3 HEADER RT>PLZ .1CEN LK 5POS 1 CMPA0527005F-AMP1 Demonstration Amplifier Circuit Rev 1.6 – September 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CMPA0527005F 9 Product Dimensions CMPA0527005F (Package Type — 440221) Pin Number Qty Rev 1.6 – September 2021 1 NC 2 RFIN 3 Gate Bias 4 NC 5 RFOUT + Drain Bias 6 NC 7 Source 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CMPA0527005F 10 Part Number System CMPA0527005F Package Power Output (W) Upper Frequency (GHz) Lower Frequency (GHz) Cree MMIC Power Amplifier Product Line Table 1. Parameter Value Units Upper Frequency1 2.7 GHz Power Output 5 W Package Flange - Note1: Alpha characters used in frequency code indicate a value greater than 9.9 GHz. See Table 2 for value. Table 2. Rev 1.6 – September 2021 Character Code Code Value A 0 B 1 C 2 D 3 E 4 F 5 G 6 H 7 J 8 K 9 Examples: 1A = 10.0 GHz 2H = 27.0 GHz 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CMPA0527005F 11 Product Ordering Information Order Number Description Unit of Measure CMPA0527005F GaN HEMT Each CMPA0527005F-AMP1 Test board with GaN HEMT (flanged) installed Each Rev 1.6 – September 2021 Image 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CMPA0527005F 12 For more information, please contact: 4600 Silicon Drive Durham, North Carolina, USA 27703 www.wolfspeed.com/rf Sales Contact rfsales@cree.com Notes & Disclaimer Specifications are subject to change without notice. “Typical” parameters are the average values expected by Cree in large quantities and are provided for information purposes only. Cree products are not warranted or authorized for use as critical components in medical, life-saving, or life-sustaining applications, or other applications where a failure would reasonably be expected to cause severe personal injury or death. No responsibility is assumed by Cree for any infringement of patents or other rights of third parties which may result from use of the information contained herein. No license is granted by implication or otherwise under any patent or patent rights of Cree. © 2019 – 2021 Cree, Inc. All rights reserved. Wolfspeed® and the Wolfspeed logo are registered trademarks of Cree, Inc. Rev 1.6 – September 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com
CMPA0527005F 价格&库存
很抱歉,暂时无法提供与“CMPA0527005F”相匹配的价格&库存,您可以联系我们找货
