CMT2890-0000-000P0B0A40E
    WOLFSPEED
    CMT2890 Series High Current LED
CMT2890-0000-000P0B0A40E 数据手册
Cree® XLamp® CMT2890 LED Product Description features Table of Contents The • 22‑mm optical source Characteristics.............................................2 • Available in 70-, 80- and 90‑ and Operating Limits...........................................2 Cree XLamp® High-Current LED Array family is optimized for best‑in‑class lumen output, efficacy and reliability at high drive currents. XLamp CMT LEDs deliver performance 95‑minimum CRI options • Cree EasyWhite® 2-, 3- and 5‑step binning Flux Characteristics, EasyWhite® Order Codes and Bins............................................3 Flux Characteristics, Premium Color in industry‑compatible packages and • Premium Color 2- and 3-step binning Order Codes and Bins..................................4 LESes, enabling lighting manufacturers • Forward voltage option: 54‑V class Relative Spectral Power Distribution, to upgrade their designs for applications • 85 °C binning and characterization EasyWhite® LEDs..........................................5 such as track, downlight and outdoor • Maximum drive current: 3300 mA Relative Spectral Power Distribution, lighting. • 115° viewing angle, uniform Premium Color LEDs....................................6 XLamp High-Current LED Arrays are available in 2‑step, 3‑step and 5‑step EasyWhite bins. ® chromaticity profile Electrical Characteristics.............................8 • Top-side solder connections Relative Luminous Flux................................9 • RoHS and REACh compliant Typical Spatial Distribution..........................9 • UL recognized component Performance Groups - Chromaticity........ 10 ® (E349212) CLD-DS188 Rev 4 Product family data sheet Premium Color Performance Groups Chromaticity.............................................. 11 Cree EasyWhite® Bins Plotted on the 1931 CIE Color Space............................... 12 Cree Premium Color Bins Plotted on the 1931 CIE Color Space............................... 13 Bin and Order Code Formats.................... 15 Mechanical Dimensions........................... 16 Thermal Design......................................... 17 Notes......................................................... 18 www.cree.com/Xlamp Packaging.................................................. 19 Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 XLamp ® CMT2890 LED Characteristics Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees 115 V Class 3A ESD withstand voltage (JEDEC JS-001-2012) Maximum DC forward current mA 3300* Reverse current mA 0.1 Forward voltage (@ 1600 mA, 85 °C) * V 51.2 56.3 Refer to the Operating Limits section. Operating Limits The maximum current rating of the CMT2890 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Either solder pad shown in the Mechanical Dimensions section on page 16 can be used as the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree recommends a maximum LES temperature of 140 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 13 for more information on LES temperature measurement. CMT2890 3400 85 °C, 3300 mA 3200 3000 2800 2600 2400 2200 If (mA) 2000 1800 1600 1400 125 °C, 1269 mA 1200 1000 800 600 400 200 0 0 25 50 75 100 125 150 Case Temperature (°C) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 2 XLamp ® CMT2890 LED Flux Characteristics, EasyWhite® Order Codes and Bins (If = 1600 mA, TJ = 85 °C) The following table provides order codes for XLamp CMT2890 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 15). Nominal CCT Min. Typ Minimum Luminous Flux (lm) 70 73 12,530 80 82 70 CRI Typical Luminous Flux (lm) 2-Step Group Order Code 3-Step Group Order Code 5-Step Group Order Code 13,473 65E CMT2890-0000000P0B0A65E 11,706 12,587 65E CMT2890-0000000P0H0A65E 73 12,786 13,748 57E CMT2890-0000000P0B0A57E 80 82 11,945 12,844 57E CMT2890-0000000P0H0A57E 90 92 10,160 10,925 70 73 12,415 13,350 50E CMT2890-0000000P0B0A50E 80 82 11,599 12,472 50G CMT2890-0000000P0H0A50G 90 92 10,160 10,925 50G CMT2890-0000000P0U0A50G 70 73 12,322 13,249 40E CMT2890-0000000P0B0A40E 80 82 11,466 12,329 40H CMT2890-0000000P0H0A40H 40G CMT2890-0000000P0H0A40G 90 92 9,873 10,616 40H CMT2890-0000000P0U0A40H 40G CMT2890-0000000P0U0A40G 80 82 11,186 12,028 35H CMT2890-0000000P0H0A35H 35G CMT2890-0000000P0H0A35G 90 92 9,602 10,325 35H CMT2890-0000000P0U0A35H 35G CMT2890-0000000P0U0A35G 70 73 11,466 12,329 30E CMT2890-0000000P0B0A30E 80 82 10,862 11,680 30H CMT2890-0000000P0H0A30H 30G CMT2890-0000000P0H0A30G 90 92 9,184 9,875 30H CMT2890-0000000P0U0A30H 30G CMT2890-0000000P0U0A30G 80 82 10,423 11,207 27H CMT2890-0000000P0H0A27H 27G CMT2890-0000000P0H0A27G 90 92 8,769 9,429 27H CMT2890-0000000P0U0A27H 27G CMT2890-0000000P0U0A27G 80 82 9,184 9,875 22G CMT2890-0000000P0H0A22G 6500 K 5700 K 5000 K 4000 K 57G 3500 K 3000 K 2700 K 2200 K CMT2890-0000000P0U0A57G Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 3 XLamp ® CMT2890 LED Flux Characteristics, Premium Color Order Codes and Bins (If = 1600 mA, TJ = 85 °C) Fidelity CRI* 2-Step Min. Typ Minimum Luminous Flux (lm) 4000 K 95 98 8,843 9,508 L5A CMT2890-0000-000P0Z0AL5A 3500 K 95 98 8,606 9,254 35H CMT2890-0000-000P0Z0A35H 3000 K 95 98 8,047 8,653 30H CMT2890-0000-000P0Z0A30H 2700 K 95 98 7,619 8,192 27H CMT2890-0000-000P0Z0A27H Min. Typ Minimum Luminous Flux (lm) Typical Luminous Flux (lm) 90 92 9,184 9,875 80 82 10,862 11,680 90 92 9,184 9,875 95 98 8,047 8,653 Nominal CCT Typical Luminous Flux (lm) Group Order Code Specialty Nominal CCT 3100 K 3000 K CRI 2-Step Group L7B L7C Order Code 3-Step Group Order Code 31Q CMT2890-0000000P0U0A31Q 30Q CMT2890-0000000P0U0A30Q Group Order Code 30U CMT2890-0000000P0U0A30U CMT2890-0000000P0H0AL7B CMT2890-0000000P0Z0AL7C Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 18). • For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60. Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 4 XLamp ® CMT2890 LED Relative Spectral Power Distribution Relative Spectral Power Distribution, EasyWhite® LEDs EZW 70 CRI The following graphs are the result of a series of pulsed measurements at 1600 mA and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 6500 K, 70 CRI 5700 K, 70 CRI 5000 K, 70 CRI 4000 K, 70 CRI 3000 K, 70 CRI 60% 50% 40% 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) EZW 80 CRI 100% Relative Spectral Power 90% 80% 6500 K, 80 CRI 70% 5700 K, 80 CRI 5000 K, 80 CRI 60% 4000 K, 80 CRI 50% 3500 K, 80 CRI 40% 3000 K, 80 CRI 30% 2700 K, 80 CRI 20% 2200 K, 80 CRI 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 5 XLamp ® CMT2890 LED EZW 90 CRI Relative Spectral Power Distribution, EasyWhite® LEDs - Continued 100% Relative Spectral Power 90% 80% 5700 K, 90 CRI 70% 5000 K, 90 CRI 60% 4000 K, 90 CRI 50% 3500 K, 90 CRI 40% 3000 K, 90 CRI 30% 2700 K, 90 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Spectral Power Distribution, Premium Color LEDs The following graphs are the result of a series of pulsed measurements at 1600 mA and TJ = 85 °C. Fidelity Fidelity 100% Relative Spectral Power 90% 80% 70% 4000 K, Z CRI 60% 3500 K, Z CRI 50% 3000 K, Z CRI 40% 2700 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 6 XLamp ® CMT2890 LED Relative Spectral Power Distribution, Premium Color LEDs - continued Speciality Specialty 100% Relative Spectral Power 90% 80% 70% 60% 31Q, 3100 K, 90 CRI 50% 40% 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Speciality 100% Relative Spectral Power 90% 80% 70% 30Q, 3000 K, 90 CRI 60% 30U, 3000 K, 90 CRI 50% L7B, 3000 K, 80 CRI 40% L7C, 3000 K, Z CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 7 XLamp ® CMT2890 LED Electrical Characteristics The following graph is the result of a series of steady-state measurements. 57 56 55 Voltage (V) 54 Tc = 25 °C 53 Tc = 55 °C Tc = 85 °C 52 Tc = 105 °C 51 50 49 48 900 1200 1500 1800 2100 2400 2700 3000 3300 Current (mA) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 8 XLamp ® CMT2890 LED Relative Luminous Flux The relative luminous flux values provided below are the ratio of: • Measurements of CMT2890 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 1600 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 25 °C, IF = 1800 mA, the relative luminous flux ratio is 120% in the chart below. A CMT2890 LED that measures 9,875 lm during binning will deliver 11,850  lm (9,875 * 1.2) at steady-state operation of Tc = 25 °C, IF = 1800 mA. 200% 180% Relative Luminous Flux 160% 140% Tc = 25 °C 120% Tc = 55 °C 100% Tc = 85 °C 80% Tc = 105 °C 60% 40% 20% 0% 900 1200 1500 1800 2100 2400 2700 3000 3300 Current (mA) Far Field CXB data to get -90 to +90 Typical Spatial Distribution Relative Luminous Intensity 100% 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 9 XLamp ® CMT2890 LED Performance Groups - Chromaticity (Tj = 85 °C) XLamp CMT2890 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Center Point Major Axis Minor Axis x y a b Rotation Angle (°) 5700 K 0.3287 0.3417 0.00738 0.00360 72.0 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 22G 2200 K 0.5066 0.4158 0.00980 0.00480 45.5 Major Axis Minor Axis y a b Rotation Angle (°) Bin Code CCT 57G 50G EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT Center Point x 65E 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 30E 3000 K 0.4338 0.4030 0.01390 0.00680 53.2 Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 10 XLamp ® CMT2890 LED Premium Color Performance Groups - Chromaticity (Tj = 85 °C) XLamp CMT2890 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. Fidelity EasyWhite Color Temperatures – 2-Step Code L5A 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3764 0.3711 0.3784 0.3787 0.3847 0.3826 0.3825 0.3748 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 Specialty EasyWhite Color Temperatures – 2-Step Code L7B L7C CCT 3000 K 3000 K x y 0.4263 0.3848 0.4296 0.3916 0.4361 0.3938 0.4326 0.3868 0.4192 0.3754 0.4224 0.3823 0.4291 0.3847 0.4257 0.3777 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 31Q 3100 K Center Point Major Axis Minor Axis x y a b Rotation Angle (°) 0.4236 0.3888 0.00848 0.00455 50.3 30Q 3000 K 0.4305 0.3935 0.00834 0.00408 53.2 30U 3000 K 0.4274 0.3837 0.00834 0.00408 53.2 Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 11 XLamp ® CMT2890 LED Cree EasyWhite® Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) 0.45 ANSI C78.377 Quadrangle 0.44 EasyWhite 5-step 0.43 EasyWhite 3-step 0.42 EasyWhite 2-step 2700 K 2200 K 2450 K 3000 K 3500 K 0.41 4000 K 0.40 CCy 0.39 5000 K 4500 K 5700 K 0.38 0.37 6500 K 0.36 0.35 7000K 0.34 0.33 0.32 0.54 0.53 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 12 XLamp ® CMT2890 LED Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) Fidelity (2-step) 0.44 2700K ANSI C78.377 Quadrangle 0.43 3000K 0.42 3500K 0.41 27H 4000K CCy 0.40 30H 4500K 35H 0.39 0.38 L5A 0.37 0.36 0.35 0.48 0.47 0.46 0.45 0.44 CCx 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 13 XLamp ® CMT2890 LED Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) - Continued Speciality (2-step) 0.44 ANSI C78.377 Quadrangle 3000 K 0.43 0.42 3500 K CCy 0.41 0.40 0.39 L7B L7C 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Speciality (3-step) 0.44 ANSI C78.377 Quadrangle 3000K 0.43 0.42 3500K CCy 0.41 0.40 30Q 0.39 31Q 30U 0.38 0.46 0.45 CCx 0.44 0.43 0.42 0.41 0.37 Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 14 XLamp ® CMT2890 LED Bin and Order Code Formats Bin codes and order codes are configured as follows: Order Code Bin Code Series = CMT28 Series = CMT28 Internal code Chromaticity bin CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Vf class P0 = 54-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA SSSSSCC-HHHH-HHHGGRNNNNN Kit code Vf class P0 = 54-V class Performance class CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Flux bin 0A = Not binned into flux bins Performance class Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 15 UNAUTHORIZED PERSON THE WITHOUT WRITTEN CONSENT OF CREE INC. D XLamp ® CMT2890 LED Mechanical Dimensions Dimensions are in mm. 28.00 ±.20 Tolerances unless otherwise specified: ±.13 x° ± 1° 9.12 C ø3.200 11.40 3.34 OPTICAL REFERENCE T2890P = 54‑V CMT2890 .90±.15 3.34 X1 X2 X3 X4 X5 X1 CCT 9.12 1 = 6500 K 11.40 … 28.00 ±.20 8 = 2700 K X2 11.40 M = EasyWhite or R0.50 B 9.12 ø22.0 ±0.2 ø24.0 Fidelity LED on the ±0.2 black‑body line 3.34 Q = Specialty LED below R0.50 the black‑body line 11.40 U = Specialty LED below 0A = Not binned into flux ALL UN MIL TO Marking 2 X 1X CCT (eg. 27.2700K, 30:3000K) 2 X 3X :4Flux Bin X 5:CRI (B:70 H:80, U:90, Z:95 CRI B = 70 CRI min H = 80 CRI min .55±.1 Marking 1 T2890: product family (CMT2890) N:54V Voltage Class A bins X5 3.34 OPTICAL REFERENCE the black‑body line X3 X4 Flux bin 9.12 6 5 THIRD ANGLE PROJEC FO 4 3 U = 90 CRI min Z = 95 CRI min Tc measurement point: either the anode or cathode solder pad Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 16 SU XLamp ® CMT2890 LED Thermal Design The CMT family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CMT LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 2 for the Operating Limit specification. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from solder point (TSP) to ambient (Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please refer to the Thermal Management application note. For CMT soldering recommendations and more information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the Cree XLamp CM Family LEDs soldering and handling document. To keep the CMT2890 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CMT2890 Ta Ta Maximum R_c-a 10.00 1.00 Ta = 25 °C Ta = 55 °C Ta = 85 °C Ta = 105 °C 0.10 0.01 900 1200 1500 1800 2100 2400 2700 3000 3300 Current (mA) Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 17 XLamp ® CMT2890 LED Notes Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs. Cree did not perform Room Temperature Operating Life (RTOL) testing on the CMT2890 LED. Lumen Maintenance Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product Ecology section of the Cree website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 18 XLamp ® CMT2890 LED Packaging Cree CMT2890 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. Dimensions are in inches. Tolerances: ±.13 7.500 5 x° ±1° 4 6 3 5 2 R.375 4 NOTICE ENTIAL. THIS PLOT AND THE INFORMATION WITHIN ARE THE PROPRIETARY AND L INFORMATION OF CREE, INC. THIS PLOT COPIED, REPRODUCED OR DISCLOSED TO ANY NSENT ED PERSON WITHOUT THE WRITTEN CONSENT 5.875 1 3 2 1 1.313 5.875 R .375 R .375 8.125 .875 .875 5.875 LABEL WITH CREE BIN CODE, QUANTITY, LOT # PATENT LABEL ISBIN LOCATED LABEL WITH CREE CODE, QUANTITY, OF LOTCARTON # ON UNDERSIDE TH CREE BIN ANTITY, LOT # PATENT LABEL IS LOCATED ON UNDERSIDE .875 OF COVER 1.313 BAG .38 .875 BAG .38 L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QUANTITY, LOT # .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 .XX ± .03 .XXX ± .010 X° ± 2 ° 6 WITH CREE BIN QUANTITY, LOT # 5 4 Copyright © 2017-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 3 DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. ® ® notice. Cree , XLamp TOLERANCE UNLESS SPECIFIED:and .X ± .XX ± .XXX ± X° ± 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 DRAWN BY DRAWN BY DATE CHECK DATE APPROVED DATE 4600 Silicon Drive Durham, N.C 277 Phone (919) 361- Fax (919) 313-530 TITLE CXA15XX_DATASHEET MATERIAL SIZE FINAL PROTECTIVE FINISH SCALE DATE C DRAWING NO. CXA15XX_DATASHEET_BAG2013 0.500 2 CHECK DATE APPROVED DATE SHEET EasyWhite® are registered trademarks and the Cree logo is a Phone (919) 361-4770 Fax (919) 313-5303 TITLE CXA15XX_DATASHEET 19 MATERIAL SIZE FINAL PROTECTIVE FINISH OF 1 Drive 4600 Silicon Durham, N.C 27703 DRAWING NO. CXA15XX_DATASHEET_BAG2013
CMT2890-0000-000P0B0A40E 价格&库存
很抱歉,暂时无法提供与“CMT2890-0000-000P0B0A40E”相匹配的价格&库存,您可以联系我们找货
