CM-BF561.
CM-BF561.
    BECOM
    BECOM - CM-BF561. - BLACKFIN, ADSP-BF561, CORE MODULE
CM-BF561. 数据手册
CM-BF561 Blackfin® Core Module The Core Module CM-BF561 is optimized for performance and parallel data processing. The module integrates processor, RAM, flash and power supply at a size of 31x36mm! It is based on the high performance ADSP-BF561 from Analog Devices. The CMBF561 is designed for commercial applications (commercial temperature range). It addresses 64MByte SDRAM via its 32bit wide SDRAM bus and has an onboard NOR-flash of 8MByte. Features CPU Analog Devices BF561 @ 600MHz RAM 64MByte SDRAM up to 133MHz INTERFACES FLASH 8MByte PPI 2 SPI 1 SPORT 2 TWI/I C emulation by GPIO UART 1 2 ADDITIONAL FEATURES Single 3.3V supply voltage On-board core voltage regulator Low voltage reset circuit Dual Core Processor TEMP. RANGE 0°C to +70°C VERSIONS Connector DIMENSIONS 31x36mm Development Support »» »» »» »» »» Applications EVAL-BF5xx Evaluation Board DEV-BF5xx Development Board DEV-BF5xxDA-Lite Development Board BLACKSheep® OS uClinux Port available Ordering Information Order No. Info 100-1211-2 CM-BF561-C-C-Q25S64F8 (CM-BF561) 100-1211-2-TR CM-BF561-C-C-Q25S64F8 (CM-BF561) Tape Reel 50pcs Bluetechnix Mechatronische Systeme GmbH Lainzerstraße 162/3 1130 Wien, Austria www.bluetechnix.com Tel.: +43 (1) 9142091 x 0 Fax.: +43 (1) 9142091 x 99 Email: office@bluetechnix.at »» »» »» »» »» »» »» »» »» »» Parallel signal processing Digital Still Cameras Digital Video Cameras Portable Media Players Digital Video Recorders Industrial and Instrumentation Set Top Boxes Consumer Multimedia Automotive Vision Systems Broadband Wireless Systems
CM-BF561. 价格&库存
很抱歉,暂时无法提供与“CM-BF561.”相匹配的价格&库存,您可以联系我们找货
