EVAL-BF5XX
EVAL-BF5XX
    BECOM
    BECOM - EVAL-BF5XX - BLACKFIN, USB 2.0 OTG, EVAL BOARD
EVAL-BF5XX 数据手册
Hardware User Manual EVAL-BF5xx Board V4.0 PRELIMINARY www.tinyboards.com Maximum Power at Minimum Size Contact Bluetechnix Mechatronische Systeme GmbH Waidhausenstr. 3/19 A-1140 Vienna AUSTRIA/EUROPE office@bluetechnix.at http://www.bluetechnix.com Document No.: 100-2205-4.0 Version 4 2007-05-03 Blackfin EVAL-BF5xx Hardware User Manual Table of Contents 1 Introduction ......................................................................................................................... 1 1.1 Overview ....................................................................................................................... 1 2 Functional Specification ...................................................................................................... 3 3 PCB Placement and Mechanical Outline............................................................................. 4 4 3.1 PCB Placement ............................................................................................................. 4 3.2 Mechanical Outline ....................................................................................................... 5 Connector Description ......................................................................................................... 6 4.1 X1 –RJ45 Ethernet Connector ...................................................................................... 6 4.2 X2 –SD-Card Connector (bottom Mount) .................................................................... 6 4.3 X3 – JTAG Bypass Connector ...................................................................................... 6 4.4 X6, X9 – USB Connectors ............................................................................................ 6 4.5 X5 UART Expansion Pads ........................................................................................... 7 4.6 X7, X8 Expansion Connectors ...................................................................................... 7 4.7 X10 – CAN Connector.................................................................................................. 7 4.8 X11 – Power Connector ................................................................................................ 7 4.9 X8 – Expansion Connector 1 ........................................................................................ 8 4.10 5 X7 – Expansion Connector 2 ................................................................................... 12 Switches, Jumper and LED Description ............................................................................ 17 5.1 S1 Ethernet Switch for CM-BF537E .......................................................................... 17 5.2 S2 Core Module Configuration ................................................................................... 17 5.3 S4 – UART Switch ..................................................................................................... 17 5.4 JP1 - Power Supply Jumper ........................................................................................ 17 5.5 JP2 – RTC Power Jumper ........................................................................................... 17 5.6 Buttons ........................................................................................................................ 18 5.7 LEDs ........................................................................................................................... 18 6 Boot Mode Description ..................................................................................................... 19 7 Using an Core Module with on board USB support .......................................................... 21 8 Installation ......................................................................................................................... 22 9 8.1 What is included in the package? ................................................................................ 22 8.2 Initial Board Setup ...................................................................................................... 22 Using the VDSP Flash Programming Tool ....................................................................... 26 9.1 Developing an Application ......................................................................................... 26 9.2 Overwriting BLACKSheep Code ............................................................................... 26 Blackfin EVAL-BF5xx Hardware User Manual 10 Known Bugs ................................................................................................................... 27 11 Product Changes ............................................................................................................. 28 12 Document Revision History ........................................................................................... 29 A List of Figures and Tables ................................................................................................. 30 Blackfin EVAL-BF5xx Hardware User Manual Edition 2007-02 © Bluetechnix Mechatronische Systeme GmbH 2007 All Rights Reserved. The information herein is given to describe certain components and shall not be considered as a guarantee of characteristics. Terms of delivery and rights of technical change reserved. We hereby disclaim any warranties, including but not limited to warranties of noninfringement, regarding circuits, descriptions and charts stated herein. Bluetechnix makes and you receive no warranties or conditions, express, implied, statutory or in any communication with you. Bluetechnix specifically disclaims any implied warranty of merchantability or fitness for a particular purpose. Bluetechnix takes no liability for any damages and errors causing of the usage of this board. The user of this board is responsible by himself for the functionality of his application. He is allowed to use the board only if he has the qualification. More information is found in the General Terms and Conditions (AGB). Information For further information on technology, delivery terms and conditions and prices please contact Bluetechnix (http://www.bluetechnix.com). Warnings Due to technical requirements components may contain dangerous substances. The Core Boards and Development systems contain ESD (electrostatic discharge) sensitive devices. Electrostatic charges readily accumulate on the human body and equipment and can discharge without detection. Permanent damage may occur on devices subjected to high-energy discharges. Proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Unused core boards and development boards should be stored in the protective shipping package. Blackfin EVAL-BF5xx Hardware User Manual BLACKFIN Products Core Modules: CM-BF533: Blackfin Processor Module powered by Analog Devices single core ADSP-BF533 processor; up to 600MHz, 32MB RAM, 2MB Flash, 120 pin expansion connector and a size of 36.5x31.5mm CM-BF537E: Blackfin Processor Module powered by Analog Devices single core ADSP-BF537 processor; up to 600MHz, 32MB RAM, 4MB Flash, integrated TP10/100 Ethernet physical transceiver, 120 pin expansion connector and a size of 36.5x31.5mm CM-BF537U: Blackfin Processor Module powered by Analog Devices single core ADSP-BF537 processor; up to 600MHz, 32MB RAM, 4MB Flash, integrated USB 2.0 Device, 120 pin expansion connector and a size of 36.5x31.5mm TCM-BF537: Blackfin Processor Module powered by Analog Devices single core ADSP-BF537 processor; up to 500MHz, 32MB RAM, 8MB Flash, 28x28mm, 120 pin expansion connector, Ball Grid Array or Border Pads for reflow soldering, industrial temperature range -40°C to +85°C. CM-BF561: Blackfin Processor Module powered by Analog Devices dual core ADSP-BF561 processor; up to 2x 600MHz, 64MB RAM, 8MB Flash, 120 pin expansion connector and a size of 36.5x31.5mm CM-BF527: From Q3 '07 a new Blackfin Processor Module powered by Analog Devices single core ADSP-BF527 processor will be available; key features are USB OTG 2.0 and Ethernet. 2x120pin expansion connectors are backwards compatible to other Core Modules. CM-BF548: From Q3 '07 a new Blackfin Processor Module powered by Analog Devices single core ADSP-BF548 processor will be available; key features are 64MB DDR SD-RAM 2x100pin expansion connectors. Development Boards: EVAL-BF5xx: Low cost Blackfin processor Evaluation Board with one socket for any Bluetechnix Blackfin Core Module. Additional periphery is available, such as a SD-Card. DEV-BF5xxDA-Lite: Get ready to program and debug Bluetechnix Core Modules with this tiny development platform including a USB Based Debug Agent. The DEV-BF5xxDA-Lite is a low cost starter development system including VDSP++ Evaluation Software License. Blackfin EVAL-BF5xx Hardware User Manual DEV-BF5xx-FPGA: Backfin Development Board with two sockets for any combination of Blackfin Core Modules. Additional periphery is available, such as SD-Card, Ethernet, USB host, multi-port JTAG including a USB based Debug Agent, connector for a LCD-TFT Display and connector for a digital camera system. A large on-board SPARTAN-3 FPGA and Soft IPs make this board the most flexible Blackfin development platforms ever developed. Available Q2 2007 EXT-Boards: The following Extender Boards are available: EXT-BF5xx-Audio, EXT-BF5xx-Video, EXT-BF5xx-Camera, EXT-BF5xx-Exp, *EXTBF5xx-LVDS, *EXT-BF5xx-ETH-USB, *EXT-BF5xx-AD/DA. Additional boards based on customer request *Available Q2 2007 Software Support: BLACKSheep: The BLACKSheep VDK is a multithreaded framework for the Analog Devices Blackfin processor family that includes driver support for a variety of hardware extensions. It is based on the realtime VDK kernel included within the VDSP++ development environment. LabVIEW: LabVIEW embedded support for the CM-BF537E, CM-BF537U and TCM-BF537 Core Modules based on the BLACKSheep VDK driver Framework. uClinux: All the Core Modules are supported by uClinux. The required boot loader and uClinux can be downloaded at http://blackfin.uClinux.org. BLACKFIN Design Service Based on over three years Blackfin experience Bluetechnix offers development assistance as well as custom design services and software development. Blackfin EVAL-BF5xx Hardware User Manual Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 1 Introduction The EVAL-BF5xx Board is a lightweight evaluation platform for all current and future Bluetechnix Core Modules (CM-BF533, CM-BF561, CM-BF537U, CM-BF537E, TCMBF537, future CM-BF52x). The small baseboard has all hardware necessary to test the performance of the Core Modules including a high-speed serial port directly connectable to a computers USB port, a CAN Interface and a SD-Card mass storage device socket. 1.1 Overview The EVAL-BF5xx Board includes the following components: 60 Pin Expansion Connector B USB to UART SD-Card Coremodules: CM-BF533 CM-BF537E CM-BF537U CM-BF561 TCM-BF537 CM-BF52x (*) DC/DC Power Supply (5V and 3V3) USB (for CM-BF5xxU) RJ-45 CAN (for CM-BF537E) 60 Pin Expansion Connector A Figure 1-1: Overview of the EVAL-BF5xx Board (*) available Q4 2007  DC/DC Converters o 5V@2A + 3V3@1.5A (draws its power from the 5V output of the DC/DC)  1 Core Module Slot o Supports all current Bluetechnix Blackfin based Core Modules  USB o Supports up to 915kbps UART-USB conversion. o Emulates a standard COM port on the computer. o Drivers for Windows and Linux available Blackfin EVAL-BF5xx Hardware User Manual Page 1 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size  JTAG o JTAG-Plug that supports all analog Devices JTAG Emulators.  Expansion Connector 1 o SPORT 0 o JTAG o UART o SPI o PPI1 (Parallel Port Interface 1) o PFs (Programmable Flags)  Expansion Connector 2 o Data Bus o Address Bus o Memory Control Signals o PPI21 (Parallel Port Interface 2) o Power Supply  2nd USB Connector (optional) o Can only be used together with the CM-BF537U Core Module which has an on-board NETPLX 2272 USB2.0 Device Chip o Future versions of the CM-BF52x may also make use of this USB connector.  RJ-45 Ethernet Plug o Only in combination with the CM-BF537E module o Standard 10BASE-T/100BASE-T Ethernet connection 1 Only available when using the CM-BF561 Core Module Blackfin EVAL-BF5xx Hardware User Manual Page 2 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 2 Functional Specification 60-pin : Data & Addr. Us, Mem. Control, (PPI2) Power Connector USB Device Connector UART Expansion SD-Card Connector CAN Connector DC/DC Power Supply USB-UART Converter USB/UART Switch SPI UART Coremodules: CM-BF533 CM-BF537E CM-BF537U CM-BF561 TCM-BF537 CM-BF52x (*) Button LED Reset RJ-45 Ethernet Connector USB Device Connector JTAG JTAG CAN Trasceiver 60-pin : JTAG, PPI-1, SPORT0, (SPORT1),UART, SPI, PFs Figure 2-1: Block Diagram (*) available Q4 2007 Figure 2-1 shows a detailed block diagram of the EVAL-BF5xx Board. Power connector and Power supply: The on-board DC/DC power supply generates 5V and 3V3 which are made available at the expansion connectors. The maximum current that can be drawn from the 5V is 2A, but take care this includes the current going into the 3V3 regulator as well as this regulator is powered by the 5V. The maximum current that can be drawn from the 3V3 is 1.5A but note that this means at least 1A additional load on the 5V connector. The serial port of the Core Module can be routed directly to the USB Port (USB/UART Switch (S4) Position 0 or to the UART Expansion Pads (USB/UART Switch S4 Position 1. An SD-Card connector mounted at the bottom of the board allows making use of file IO Functions delivered with the BLACKSheep Software. BLACKSheep supports SD-Cards and includes a FAT files system as well as the most relevant File IO Functions. The complete BLACKSheep software package can be purchased from Bluetechnix. The 2nd USB Device connector (colored in purple) can only be used with the CM-BF537U Core Module which has an on-board USB V2.0 Device (NET2272 by PLX-technology). Future Core Modules may make use of this connector as well. The RJ-45 Ethernet connector (colored in purple) can only be used in combination with the CM-BF537E Core Module which has an on-board Ethernet physical chip. Blackfin EVAL-BF5xx Hardware User Manual Page 3 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 3 PCB Placement and Mechanical Outline 3.1 PCB Placement Figure 3-1: Connector PCB Placement Blackfin EVAL-BF5xx Hardware User Manual Page 4 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 3.2 Mechanical Outline Figure 3-2: Mechanical Outline – Expansion Connector Placement Blackfin EVAL-BF5xx Hardware User Manual Page 5 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 4 Connector Description In the following the connectors shown in section 3.1 are described. 4.1 X1 –RJ45 Ethernet Connector Pin No. 1 2 3 4 5 6 7 8 Signal (Core Module) TX+ TXRX+ NC NC RXNC NC Description O O I I - Table 4-1: Ethernet Connector 4.2 X2 –SD-Card Connector (bottom Mount) Pin No. 0 1 2 3 4 5 6 7 8 9 10 Signal (Core Module) nCS MOSI GND 3,3V SPICLK GND MISO - Description (SD Card) DAT2 CD/DAT3 CMD VSS1 VDD CLK VSS2 DAT0 DAT1 CD WP Table 4-2: SD-Card Connector 4.3 X3 – JTAG Bypass Connector The JTAG connector is compliant to any Blackfin JTAG Emulator from Analog Devices. When an external JTAG emulator is attached the on-board JTAG is bypassed and the external one is automatically used. 4.4 X6, X9 – USB Connectors X6 is a standard USB-B Device Connector for the USB to UART converter X9 is a standard USB-B 2.0 Device Connector for the USB versions of the Core Modules Blackfin EVAL-BF5xx Hardware User Manual Page 6 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 4.5 X5 UART Expansion Pads When S4 is on position 1 the UART0 (TX,RX) is brought on the expansion pins and disconnected from the USB-UART Chip. Pin No. 1 2 3 4 Signal RxD Blackfin TxD Blackfin GND 3V3 Signal Type Input Core Module Output Core Module Regulated Power Table 4-3: UART Connector 4.6 X7, X8 Expansion Connectors The Expansion Connectors on the EVAL-BF5xx for a Stacked Height of 16mm are of the following type: Part X7, X8 Matching connector Manufacturer AMP (Stacked Height = 16mm) AMP Manufacturer Part Nr. 5-5179010-2 5179031-2 Table 4-4: EVAL-BF5xx Board connector types The matching connector, which is used for building an extender board, can be ordered from Bluetechnix. 4.7 X10 – CAN Connector Pin No. 1 2 Signal (Core Module) CAN+ CAN- Signal Type I/O I/O Table 4-5: CAN Connector 4.8 X11 – Power Connector The EVAL-BF5xx Board is shipped with a DC power cable which must be connected to an external power supply. Pin No. 1 2 3 Signal Description Vin (+6V to +16V DC) Input Preferable 12V DC (2A) Supply NC GND Table 4-6: Power Supply Blackfin EVAL-BF5xx Hardware User Manual Page 7 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size Vin GND Figure 4-1: Power Supply Connector 4.9 X8 – Expansion Connector 1 Pin 31 and 32 of the X8 are Vin of the external power supply minus the input protection diode voltage. These pins can be used for custom add-on board power supplies. Pin 29 and 30 of the X8 connector are +5V stabilized from the DC/DC that can be used for custom add-on boards or the extender boards. CM-BF533 (inserted): PIN No Signal 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 RSCLK0 TSCLK0 RSCLK1 TSCLK1 3,3V PPI0 PF15 / PPI4 PF11 / PPI8 PF7/SPISEL7/PPI12 PF3/SPISEL3/PPI_FS3 TMR0 RX SCK GND 5.0V Vin of X11 n.c. n.c. MISO PF0 / nSPISS PPI_CLK PF4/SPISEL4/PPI15 PF8 / PPI11 PF12 / PPI7 PPI3 GND DT1SEC DR1SEC DT0SEC Signal type I/O I/O I/O I/O PWR I/O I/O I/O I/O I/O I/O I I PWR PWR PWR I/O I/O I/O I/O I/O I/O I/O PWR O I O Blackfin EVAL-BF5xx Hardware User Manual Pin No 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 Signal DR0PRI DT0PRI DR1PRI DT1PRI 3,3V PPI2 PF13 / PPI6 PF9 / PPI10 PF5/SPISEL5/PPI14 TMR1 / PPI_FS1 PF1 / SPISEL1 MOSI BMODE0 n.c. 5.0V Vin of X11 n.c. BMODE1 TX PF2 / SPISEL2 TMR2 / PPI_FS2 PF6/SPISEL6/PPI13 PF10 / PPI9 PF14 / PPI5 PPI1 GND TFS1 RFS1 TFS0 Signal type I O I O PWR I/O I/O I/O I/O I/O I/O I/O I PWR PWR I O I/O I/O I/O I/O I/O I/O PWR I/O I/O I/O Page 8 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 59 DR0SEC I 60 RFS0 I/O Table 4-7: Connector X8 pin assignment for CM-BF533 CM-BF537E (inserted): Pin No 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 59 Signal Signal type RSCLK0/TACLK2 I/O TSCLK0/TACLK1 I/O CLK_out O PF4/TMR5/SPI_CS6 I/O 3.3V PWR PG0/PPI1D0 I/O PG4/PPI1D4 I/O PG8/PPI1D8/DR1SEC I/O PG12/PPI1D12/RE1PRI I/O PPI1SY3/PF7/TMR2 I/O PPI1SY1/PF8/TMR0 I/O PF1/DMAR1/TACI1/Rx0 I/O PF13/SCK I/O GND PWR 5.0V PWR Vin of X11 PWR n.c. n.c. PF12/MISO I/O PF14/SPI_SS I/O PPI1Clk/PF15/TMRCLK I/O PG15/PPI1D15/DT1PRI I/O PG11/PPI1D11/RFS1 I/O PG7/PPI1D7 I/O PG3/PPI1D3 I/O GND PWR PF5/TMR4/SPI_CS5 O PF10/SPI_SC1 I DT0SEC/CANTX/SPICS7 O DR0SEC/TACI0/CANRX I Pin No 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 Signal DR0PRI/ TACLK4 DT0PRI/SPI_CS2 SDA PF5/TMR4/SPI_CS5 3.3V PG2/PPI1D2 PG6/PPI1D6 PG10/PPI1D10/RSCLK1 PG14/PPI1D14/TFS1 PPI1SY1/PF8/TMR0 PF3/Tx1/TMR6/TACI6 PF11/MOSI BMODE0 n.c. 5.0V Vin of X11 BMODE2 BMODE1 PF0/DMAR0/Tx0 PF2/Rx1/TMR7 PPI1Sy2/PF8/TMR1 PG13/PPI1D13/TSCLK1 PG9/PPI1D9/TD1SEC PG5/PPI1D5 PG1/PPI1D1 GND PF6/TMR3/SPI_CS4 SCL TFS0 RFS0/TACLK3 Signal type I O I/O I/O PWR I/O I/O I/O I/O I/O I/O I/O I PWR PWR I I O I/O I/O I/O I/O I/O I/O PWR I/O I/O I/O I/O Table 4-8: Connector X8 pin assignment for CM-BF537E CM-BF537U (inserted): Pin No 1 3 5 7 9 Signal RSCLK0/TACLK2 TSCLK0/TACLK1 CLK_out PF4/TMR5/SPI_CS6 3.3V Signal type I/O I/O O I/O PWR Blackfin EVAL-BF5xx Hardware User Manual Pin No 2 4 6 8 10 Signal DR0PRI/ TACLK4 DT0PRI/SPI_CS2 SDA PF5/TMR4/SPI_CS5 3.3V Signal type I O I/O I/O PWR Page 9 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 59 PG0/PPI1D0 PG4/PPI1D4 PG8/PPI1D8/DR1SEC PG12/PPI1D12/RE1PRI PPI1SY3/PF7/TMR2 PPI1SY1/PF8/TMR0 PF1/DMAR1/TACI1/Rx0 PF13/SCK GND 5.0V Vin of X11 n.c. n.c. PF12/MISO PF14/SPI_SS PPI1Clk/PF15/TMRCLK PG15/PPI1D15/DT1PRI PG11/PPI1D11/RFS1 PG7/PPI1D7 PG3/PPI1D3 GND PF5/TMR4/SPI_CS5 PF10/SPI_SC1 DT0SEC/CANTX/SPICS7 DR0SEC/TACI0/CANRX I/O I/O I/O I/O I/O I/O I/O I/O PWR PWR PWR I/O I/O I/O I/O I/O I/O I/O PWR O I O I 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 PG2/PPI1D2 PG6/PPI1D6 PG10/PPI1D10/RSCLK1 PG14/PPI1D14/TFS1 PPI1SY1/PF8/TMR0 PF3/Tx1/TMR6/TACI6 PF11/MOSI BMODE0 n.c. 5.0V Vin of X11 BMODE2 BMODE1 PF0/DMAR0/Tx0 PF2/Rx1/TMR7 PPI1Sy2/PF8/TMR1 PG13/PPI1D13/TSCLK1 PG9/PPI1D9/TD1SEC PG5/PPI1D5 PG1/PPI1D1 GND PF6/TMR3/SPI_CS4 SCL TFS0 RFS0/TACLK3 I/O I/O I/O I/O I/O I/O I/O I PWR PWR I I O I/O I/O I/O I/O I/O I/O PWR I/O I/O I/O I/O Table 4-9: Connector X8 pin assignment for CM-BF537U TCM-BF537 (inserted) Pin No. 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 Signal RSCLK0/TACLK2 TSCLK0/TACLK1 PH15 / MIICRS PH7 / COL 3.3V PG0/PPI1D0 PG4/PPI1D4 PG8/PPI1D8/DR1SEC PG12/PPI1D12/RE1PRI PPI1SY3/PF7/TMR2 MDC PF1/DMAR1/TACI1/Rx0 PF13/SPI_SCK GND 5.0V Vin of X11 Signal type I/O I/O I/O I/O PWR I/O I/O I/O I/O I/O I/O I/O I/O PWR PWR PWR Blackfin EVAL-BF5xx Hardware User Manual Pin No. 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 Signal DR0PRI/ TACLK4 DT0PRI/SPI_SSEL2 SDA PH6/MIIPHYINT 3.3V PG2/PPI1D2 PG6/PPI1D6 PG10/PPI1D10/RSCLK1 PG14/PPI1D14/TFS1 PPI1SY1/PF8/TMR0 PF3/Rx1/TMR6/TACI6 PF11/SPI_MOSI BMODE0 n.c 5.0V Vin of X11 Signal type I O I/O I/O PWR I/O I/O I/O I/O I/O I/O I/O I PWR PWR Page 10 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 33 35 37 39 41 43 45 47 49 51 53 55 57 59 n.c. MDIO PF12/SPI_MISO PF14/SPI_SS PPI1Clk/PF15/TMRCLK PG15/PPI1D15/DT1PRI PG11/PPI1D11/RFS1 PG7/PPI1D7 PG3/PPI1D3 GND PH5/MIITxCLK PF10/SPI_SSEL1 DT0SEC/CANTX/SPI_SS EL7 DR0SEC/TACI0/CANRX I/O I/O I/O I/O I/O I/O I/O PWR I/O I O 34 36 38 40 42 44 46 48 50 52 54 56 58 BMODE2 BMODE1 PF0/DMAR0/Tx0 PF2/Tx1/TMR7 PPI1Sy2/PF8/TMR1 PG13/PPI1D13/TSCLK1 PG9/PPI1D9/TD1SEC PG5/PPI1D5 PG1/PPI1D1 GND PF6/TMR3/SPI_SSEL4 SCL TFS0 I I/O I/O I/O I/O I/O I/O I/O PWR I/O I/O I/O I 60 RFS0/TACLK3 I/O Table 4-10: Connector X8 pin assignment for TCM-BF537 CM-BF561 (inserted): Pin No 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 Signal RSCLK0 / PF28 TSCLK0 / PF29 PF11(Clk_out optional) PF7/SPISEL7/TMR7 3.3V PPI1D0 PPI1D4 PPI1D8 / PF40 PPI1D12 / PF44 PPI1SYNC3 PF3 / SPICS2 RX / PF27 SCK ARDY 5.0V Vin of X11 n.c. nABE1 MISO PF0/SPISS/TMR0 PPI1CLK PPI1D15 / PF47 PPI1D11 / PF43 PPI1D7 PPI1D3 GND Signal type I/O I/O I/O I/O PWR I/O I/O I/O I/O I/O I/O I/O I/O I PWR PWR O I/O I/O I I/O I/O I/O I/O PWR Blackfin EVAL-BF5xx Hardware User Manual Pin No 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 Signal DR0PRI DT0PRI / PF18 PF9 PF5/SPISEL5/TMR5 3.3V PPI1D2 PPI1D6 PPI1D10 / PF42 PPI1D14 / PF46 PPI1SYNC1 / TMR8 PF1/SPISEL1/TMR1 MOSI nABE2 n.c. 5.0V Vin of X11 nAMS3 nABE0 TX / PF26 PF2/SPISEL2/TMR2 PPI1SYNC2 / TMR9 PPI1D13 / PF45 PPI1D9 / PF41 PPI1D5 PPI1D1 GND Signal type I I/O I/O I/O PWR I/O I/O I/O I/O I/O I/O I/O O PWR PWR O O I/O I/O I/O I/O I/O I/O I/O PWR Page 11 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 53 55 57 59 PF4/SPISEL4/TMR4 PF8 DT0SEC / PF17 DR0SEC / PF20 I/O I/O O I 54 56 58 60 PF6/SPISEL6/TMR6 PF10 TFS0 / PF16 RFS0 / PF19 I/O I/O I/O I/O Table 4-11: Connector X8 pin assignment for CM-BF561 4.10 X7 – Expansion Connector 2 Attention: Pin 77 and pin 104 of the inserted Core Module are only available on the expansion connector X7. Pin 17 and pin 44 are only available if the 0 Ohm resistors R24 and R25 are mounted on the bottom of the PCB. The signals are routed to the USB connector X9 to support Core Modules with on board USB support. The Figure 4-2 shows the position of R24 and R25. Refer to the tables below to see witch signals corresponds to pin 17 and pin 44 depending on the Core Module inserted. R24 connects pin 17 and R25 connects pin 44. Figure 4-2: Position of 0 Ohm resistors R24 and R25 CM-BF533 (inserted): Pin No 1 3 5 7 9 11 Signal A1 A5 A9 A13 A17 ABE1 Signal type O O O O O O Blackfin EVAL-BF5xx Hardware User Manual Pin No 2 4 6 8 10 12 Signal A3 A7 A11 A15 A19 n.c. Signal type O O O O O Page 12 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 59 n.c. n.c. nBG 1) GND nAWE D0 D4 D8 D12 D15 D11 D7 D3 nRESET nARE VDD-RTC nBR n.c. n.c. ABE0 A16 A12 A8 A4 O O PWR O I/O I/O I/O I/O I/O I/O I/O I/O I O PWR I O O O O O 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 n.c. ADRY CLK_Out 25MHz nAMS3 NMI D2 D6 D10 D14 D13 D9 D5 D1 nAOE nAMS2 nBGH 2) n.c. n.c. n.c. A18 A14 A10 A6 A2 I O O I I/O I/O I/O I/O I/O I/O I/O I/O O O O O O O O O Table 4-12: Connector X7 pin assignment for CM-BF533 1) 2) The signal nBG is only available if the 0 Ohm resistor R24 is mounted on the bottom of the PCB. The signal nBGH is only available if the 0 Ohm resistor R25 is mounted on the bottom of the PCB CM-BF537E (inserted): Pin Signal Signal No type 1 A1 O 3 A5 O 5 A9 O 7 A13 O 9 A17 O 11 nABE1 O 13 GND 15 RXI 17 nBG 1) O 19 GND PWR 21 nAWE O 23 D0 I/O 25 D4 I/O Blackfin EVAL-BF5xx Hardware User Manual Pin No 2 4 6 8 10 12 14 16 18 20 22 24 26 Signal A3 A7 A11 A15 A19 LED_ACT RX+ ADRY CLK_out nAMS3 NMI D2 D6 Signal type O O O O O O I I O O I I/O I/O Page 13 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 59 D8 D12 D15 D11 D7 D3 nReset nARE VDD-RTC nBR TXLED_FD nABE0 A16 A12 A8 A4 I/O I/O I/O I/O I/O I/O I O PWR I O O O O O O O 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 D10 D14 D13 D9 D5 D1 nAOE nAMS2 nBGH 2) VA25 TX+ LED_SPEED A18 A14 A10 A6 A2 I/O I/O I/O I/O I/O I/O O O O PWR O O O O O O O Table 4-13: Connector X7 pin assignment for CM-BF537E 1) 2) The signal nBG is only available if the 0 Ohm resistor R24 is mounted on the bottom of the PCB. The signal nBGH is only available if the 0 Ohm resistor R25 is mounted on the bottom of the PCB CM-BF537U (inserted): Pin Signal Signal No type 1 A1 O 3 A5 O 5 A9 O 7 A13 O 9 A17 O 11 nABE1 O 13 GND 15 RXI 1) 17 USBD+ O 19 GND PWR 21 nAWE O 23 D0 I/O 25 D4 I/O 27 D8 I/O 29 D12 I/O 31 D15 I/O 33 D11 I/O 35 D7 I/O 37 D3 I/O 39 nReset I 41 nARE O Blackfin EVAL-BF5xx Hardware User Manual Pin No 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 Signal A3 A7 A11 A15 A19 LED_ACT RX+ ADRY CLK_out nAMS3 NMI D2 D6 D10 D14 D13 D9 D5 D1 nAOE nAMS2 Signal type O O O O O O I I O O I I/O I/O I/O I/O I/O I/O I/O I/O O O Page 14 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 43 45 47 49 51 53 55 57 59 VDD-RTC nBR TXLED_FD nABE0 A16 A12 A8 A4 PWR I O O O O O O O 44 46 48 50 52 54 56 58 60 USBD- 1) VA25 TX+ LED_SPEED A18 A14 A10 A6 A2 O PWR O O O O O O O Table 4-14: Connector X7 pin assignment for CM-BF537U 1) This pins are only available on the expansion connector if the 0 Ohm resistors R24 and R25 are mounted on the bottom of the board. The signals are routed to the USB connector X9. TCM-BF537 (inserted) Pin No. 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 59 Signal A1 A5 A9 A13 A17 nABE1 / SDQM1 PH3 / ETxD3 PH10 / ERxD2 PH13 / ERxCLK 1) GND nAWE D0 D4 D8 D12 D15 D11 D7 D3 nReset nARE VDD-RTC PH12 / ERxDV PH9 / ERxD1 PH2 / ETxD2 nABE0/SDQM0 A16 A12 A8 A4 Signal type O O O O O O I/O I/O I/O PWR O I/O I/O I/O I/O I/O I/O I/O I/O I O PWR I/O I/O I/O O O O O O Blackfin EVAL-BF5xx Hardware User Manual Pin No. 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 Signal A3 A7 A11 A15 A19 PH1 / ETxD1 PH8 / ERxD0 ADRY CLKBUF nAMS3 CLKOUT (SCLK) D2 D6 D10 D14 D13 D9 D5 D1 nAOE nAMS2 PH14 / ErxER 2) PH11 / ERxD3 PH4 / ETxEN PH0 / ETxD0 A18 A14 A10 A6 A2 Signal type O O O O O I/O I/O I O O I I/O I/O I/O I/O I/O I/O I/O I/O O O I/O PWR I/O I/O O O O O O Page 15 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size Table 4-15: Connector X7 pin assignment for TCM-BF537 1) The signal PH13 / ERxCLK is only available if the 0 Ohm resistor R24 is mounted on the bottom of the PCB. 2) The signal PH14 / ErxER is only available if the 0 Ohm resistor R25 is mounted on the bottom of the PCB CM-BF561 (inserted): Pin No Signal 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 59 nABE3 A5 A9 A13 PPI2SYNC1 PPI2D1 PPI2D5 PPI2D9 / PF33 PPI2D13 / PF37 GND nAWE D0 D4 D8 D12 D15 D11 D7 D3 nRESET nARE n.c. PPI2D12 / PF36 PPI2D8 / PF32 PPI2D4 PPI2D0 PPI2CLK A12 A8 A4 Signal type O O O O I/O I/O I/O I/O I/O PWR O I/O I/O I/O I/O I/O I/O I/O I/O I O I/O I/O I/O I/O I O O O Pin No 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 Signal A3 A7 A11 A15 PPI2SYNC2 PPI2D3 PPI2D7 PPI2D11 / PF35 PPI2D15 / PF39 nAMS1 NMI0 D2 D6 D10 D14 D13 D9 D5 D1 nAOE nAMS2 PPI2D14 / PF38 PPI2D10 / PF34 PPI2D6 PPI2D2 PPI2SYNC3 A14 A10 A6 A2 Signal type O O O O I/O I/O I/O I/O I/O O I I/O I/O I/O I/O I/O I/O I/O I/O O O I/O I/O I/O I/O I/O O O O O Table 4-16: Connector X7 pin assignment for CM-BF561 Blackfin EVAL-BF5xx Hardware User Manual Page 16 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 5 Switches, Jumper and LED Description 5.1 S1 Ethernet Switch for CM-BF537E This 8 pin DIP switch enables the Ethernet connector. It is necessary to switch them on for the Core Module CM-BF537E. Switch Settings On Off Description CM-BF537E 1 2 3 4 5 6 7 8 On Off 1 2 3 4 5 6 7 8 CM-BF533, CM-BF561 CM-BF537U, TCM-BF537, Table 5-1: Ethernet Switch 5.2 S2 Core Module Configuration Switch Settings S2 (only 5-8 shown) CM-BF533 and CM-BF561 Core Module inserted On Off 1 2 3 4 5 6 7 8 CM-BF537E, CM-BF537U and TCM-BF537 On Off 1 2 3 4 5 6 7 8 Table 5-2: Core Module Configuration (1-3 are for Boot Mode only) For switch settings 1-4 please refer to chapter 6 “Boot Mode Description”. 5.3 S4 – UART Switch Move S4 to position 0 to route the Core Modules RX and TX signals to USB Move S4 to position 1 to route the Core Modules RX and TX signals to X5 5.4 JP1 - Power Supply Jumper This jumper can be removed in order to insert an AMPERE METER for current measurement of the entire Core Module. 5.5 JP2 – RTC Power Jumper This jumper is used to connect the VDD-RTC pin of the Core Module to 3.3V. You can also use this jumper to connect a battery to the internal RTC of the Blackfin. Blackfin EVAL-BF5xx Hardware User Manual Page 17 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 5.6 Buttons The Button S3 is the main Reset Button of the Core Module. The Button S6 is a general-purpose input button on pin 18 of the Core Module. Core Module CM-BF533 CM-BF537U CM-BF537E TCM-BF537 CM-BF561 CM-BF52x Button S6 PF5 PG14 PG14 PG14 PF46 - Table 5-3: Pin assignment for button S6 5.7 LEDs V1, V2 and V3 are used for indicating Ethernet functionality (Table 5-4). Ethernet LEDs V1 V2 V3 Yellow Green Green Fullduplex Activity 100MB Speed LED Table 5-4: Ethernet LEDs The Led‟s V9 and V10 are connected to general-purpose IO pins 45 and 16 respectively (Table 5-5). Core Module CM-BF533 CM-BF537U CM-BF537E TCM-BF537 CM-BF561 CM-BF52x LED V9 PF8 PG11 PG11 PG11 PF43 - LED V10 PF9 PG10 PG10 PG10 PF42 - Table 5-5: Core Module LEDs The LED V14 indicates that the board is powered. Blackfin EVAL-BF5xx Hardware User Manual Page 18 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 6 Boot Mode Description Boot-settings for CM-BF561 (S2) only Switches 1 – 4 are shown Attention: Switch 4 is not used for boot mode settings. Please refer to section 7 to see the settings for switch 4. If you are using a CM-BF561 set switches 1-4 of S2 OFF! On Off 1 2 3 4 Due to the limited number of pins on the two connectors, the CM-BF561 can only set its boot mode on the core module itself by changing the resistor settings. See the CM-BF561 Manual for further details. Boot-settings for CM-BF533 (S2) only Switches 1 – 4 are shown Attention: Switch 4 is not used for boot mode settings. Please refer to section 7 to see the settings for switch 4. Switch Settings BMODE0,BMODE1 Boot Mode Description On Off 0 Execute from16Bit ext. mem. bypass ROM (Standard boot mode for uBoot) On Off 1 Boot from 8Bit or 16Bit EEPROM/Flash (Standard boot mode for BLACKSheep) On Off 2 Boot from SPI 8Bit On Off 3 Boot from SPI 16Bit 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 Table 6-1: Boot Mode CM-BF533 Boot-settings for CM-BF537E, CM-BF537U and TCM-BF537 (S2) only Switches 1 – 4 are shown Attention: Switch 4 is not used for boot mode settings. Please refer to section 7 to see the settings for switch 4. Switch Settings Boot BMODE0,BMODE1,BMODE2 Mode On 0 Off 1 2 3 4 Blackfin EVAL-BF5xx Hardware User Manual Description Execute from16Bit ext. mem. Bypass ROM (Standard boot mode for uBoot) Page 19 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size On Off 1 Boot from 8Bit or 16Bit EEPROM/Flash (Standard boot mode for BLACKSheep) On Off 2 Reserved On Off 3 Boot from serial SPI Memory On Off 4 Boot from SPI Host (slave mode) On Off 5 Boot from serial TWI memory On Off 6 Boot from TWI host (slave mode) On Off 7 Boot from UART host (slave mode) 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 Table 6-2: Boot Mode CM-BF537 Types Blackfin EVAL-BF5xx Hardware User Manual Page 20 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 7 Using an Core Module with on board USB support If you use a Core Module with USB support on board, for example the CM-BF537U set switch 4 of S2 to “on”. This connects the 5,0V pin of the USB connector X9 to pin 53 of the Core Module. If you don‟t use a Core Module with on board USB support the switch 4 of S2 should always remain “off”. Blackfin EVAL-BF5xx Hardware User Manual Page 21 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 8 Installation 8.1 What is included in the package? 1. EVAL-BF5xx Board 2. 1x DC power cable 3. 1x USB Device Cable 4. Support CD Note: The Core Modules are not shipped with the EVAL-BF5xx board, so you must order them separately. 8.2 Initial Board Setup The installation guide is written for Windows (Windows 2000 and WinXP). However for connecting the USB device the driver for MAC and LINUX are available on the CD. In order to set up und test your EVAL-board the following steps can be done: 1. Make sure the Jumper JP1 is set and the Switch S4 is in Position 0 as shown in Figure 8-1 . Figure 8-1: Setup of the EVAL-BF5xx Board Blackfin EVAL-BF5xx Hardware User Manual Page 22 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 2. Connect the EVAL-BF5xx Board to an external power supply using the included DC power cable. Input power can range from +6V to +16V DC however 12V is recommended. If you do not have a proper power supply you can order it from Bluetechnix (Ord. No.: 100 – 9030). 3. If you want to use an SD-Card, insert the SD-Card in the appropriate slot at the bottom side of the board. 4. Connect the EVAL-BF5xx Board via USB to the PC. The pre-flashed BLACKSheep starts and the LED mounted on the EVAL board starts blinking. On the PC usually the „Found New Hardware Wizard‟ opens. If the wizard is asking you to look at the windows update site, select “No, not this time” Blackfin EVAL-BF5xx Hardware User Manual Page 23 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size Choose: “Install from a list or specific location”. The driver is located on your support CD. This procedure has to be done twice, because at first the USB driver will be installed. Then the Hardware Wizard opens again, because the UART bridge driver has to be installed in addition using the same driver file. Please do the same again as described in this point. 5. Open the Windows device manager (Control Panel  System  Hardware) to see which COM port number has been assigned to the CP2101 UART-to-USB Chip. This number differs from computer to computer based on the already installed COM ports. (e.g. COM4) Blackfin EVAL-BF5xx Hardware User Manual Page 24 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 6. Open a Terminal program like the HyperTerminal included in Windows operating systems and open the respective COM port with 115200 Baud, 8 Data-bits, No Parity and 1 Stop bit, disable the Hardware flow control. 7. Reset the EVAL-BF5xx Board (Press main reset button). After this you will see the BLACKSheep boot-screen showing up. If you disconnect the device, you have to reconnect. This shows a sample boot screen. Depending on the current software version, you might get different boot messages. 8. You can find a simple hello world program on your support CD or in the download section of the Bluetechnix website (www.bluetechnix.com). To start the sample program, type “xmr UART” on your terminal program, then (Transfer  Send file) select the appropriate file “UART.ldr” depending on your Core Module, choose protocol “Xmodem” and send. After the download has finished type “exec UART” for executing the sample program. 9. Press reset to return to the BLACKSheep command line. Blackfin EVAL-BF5xx Hardware User Manual Page 25 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 9 Using the VDSP Flash Programming Tool 9.1 Developing an Application If you are developing your own projects with the VDSP++ development tools with a JTAG device you can use the flash programming tool included in the VDSP++ environment in order to flash your program on the core module. As flash driver you have to load the flash driver located on your EVAL-BF5xx Board support CD corresponding to the inserted Core Module. 9.2 Overwriting BLACKSheep Code If you overwrite intentionally or unintended the section in the flash containing the BLACKSheep code, you need a JTAG device and the VDSP++ flash tool to reprogram the flash. Flashing the appropriate BLACKSheep loader file (*.ldr) for your Core Module located on the CD, reinstalls the BLACKSheep code. The examples, drivers and the BLACKSheep software are under permanent development. Please refer to the download section of www.bluetechnix.com to get the latest version or updates. Blackfin EVAL-BF5xx Hardware User Manual Page 26 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 10 Known Bugs NONE Table 10-1: Known Bugs Blackfin EVAL-BF5xx Hardware User Manual Page 27 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 11 Product Changes Version Changes Table 11-1: Product Changes Blackfin EVAL-BF5xx Hardware User Manual Page 28 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size 12 Document Revision History Date Document Revision 2007-04-05 2007-03-12 2007-03-01 Layout and minor changes LED description updated Initial release of the document Table 12-1: Revision History Blackfin EVAL-BF5xx Hardware User Manual Page 29 Bluetechnix www.tinyboards.com Maximum Power at Minimum Size A List of Figures and Tables Figures: Figure 1-1: Overview of the EVAL-BF5xx Board ..................................................................... 1 Figure 2-1: Block Diagram ......................................................................................................... 3 Figure 3-1: Connector PCB Placement ...................................................................................... 4 Figure 3-2: Mechanical Outline – Expansion Connector Placement ......................................... 5 Figure 4-1: Power Supply Connector ......................................................................................... 8 Figure 4-2: Position of 0 Ohm resistors R24 and R25 ............................................................. 12 Figure 8-1: Setup of the EVAL-BF5xx Board ......................................................................... 22 Tables: Table 4-1: Ethernet Connector ................................................................................................... 6 Table 4-2: SD-Card Connector................................................................................................... 6 Table 4-3: UART Connector ...................................................................................................... 7 Table 4-4: EVAL-BF5xx Board connector types ....................................................................... 7 Table 4-5: CAN Connector ........................................................................................................ 7 Table 4-6: Power Supply ............................................................................................................ 7 Table 4-7: Connector X8 pin assignment for CM-BF533 .......................................................... 9 Table 4-8: Connector X8 pin assignment for CM-BF537E ....................................................... 9 Table 4-9: Connector X8 pin assignment for CM-BF537U ..................................................... 10 Table 4-10: Connector X8 pin assignment for TCM-BF537 ................................................... 11 Table 4-11: Connector X8 pin assignment for CM-BF561 ...................................................... 12 Table 4-12: Connector X7 pin assignment for CM-BF533 ...................................................... 13 Table 4-13: Connector X7 pin assignment for CM-BF537E ................................................... 14 Table 4-14: Connector X7 pin assignment for CM-BF537U ................................................... 15 Table 4-15: Connector X7 pin assignment for TCM-BF537 ................................................... 16 Table 4-16: Connector X7 pin assignment for CM-BF561 ...................................................... 16 Table 5-1: Ethernet Switch ....................................................................................................... 17 Table 5-2: Core Module Configuration (1-3 are for Boot Mode only) .................................... 17 Table 5-3: Pin assignment for button S6 .................................................................................. 18 Table 5-4: Ethernet LEDs......................................................................................................... 18 Table 5-5: Core Module LEDs ................................................................................................. 18 Table 6-1: Boot Mode CM-BF533 ........................................................................................... 19 Table 6-2: Boot Mode CM-BF537 Types ................................................................................ 20 Table 10-1: Known Bugs ......................................................................................................... 27 Table 11-1: Product Changes ................................................................................................... 28 Table 12-1: Revision History ................................................................................................... 29 Blackfin EVAL-BF5xx Hardware User Manual Page 30
EVAL-BF5XX 价格&库存
很抱歉,暂时无法提供与“EVAL-BF5XX”相匹配的价格&库存,您可以联系我们找货
