CMLF0302-6R8MTT
CMLF0302-6R8MTT
    CYBERMAX(思博)
    SMD,3.5x3mm
    特性:优异的可焊性和高耐热性。出色的端子强度结构。采用压纹载带包装,可使用自动贴装机。应用:VCR电源。OA设备
CMLF0302-6R8MTT 数据手册
CMLF0302 Series Drum Core Surface Mount Unshielded Power Inductors ◆ Features Pb 1. Excellent solderability and high heat resistance. 2. Excellent terminal strength construction. 3. Packed in embossed carrier tape and can be used by automatic mounting machine. ◆ Applications Power supply for VCR,OA equipment ,LCD television set notebook, DC to DC converters, DC to AC inverters etc. ◆ Shape & Dimensions ◆ Lead Free Part Numbering CMLF 0302 - 100 M T (1) (2) (3) (4) (5) T (6) (1) Series Type (2) Dimension A X C (3) Inductance 2R2=2.2μH : : 100 (4) (5) (6) ; 100=10μH;101=100μH Inductance Tolerance:K=±10%, M=±20% Company Code Packaging : packed in embossed carrier tape Series A (mm) B (mm) C (mm) D (mm) CMLF0302 3.5±0.3 3.0±0.3 2.1±0.3 1.0 Typ ◆ Material Item Material a. Core Ferrite DR Core b. Wire Enamelled Copper wire c.Terminal Ag+Sn+SnPb Rev.01 Page 1 of 2 www.cybermaxtech.com CMLF0302 Series ◆ Specification Inductance (μH) DCR (Ω) max. IDC (A) max. CMLF0302-1R0MTT 1.0±20% 0.035 3.34 CMLF0302-1R2MTT 1.2±20% 0.040 2.50 CMLF0302-2R2MTT 2.2±20% 0.120 2.00 CMLF0302-3R3MTT 3.3±20% 0.108 1.55 CMLF0302-4R7MTT 4.7±20% 0.172 1.50 CMLF0302-5R6MTT 5.6±20% 0.192 1.35 CMLF0302-6R8MTT 6.8±20% 0.219 1.20 CMLF0302-8R2MTT 8.2±20% 0.247 1.15 CMLF0302-100MTT 10±20% 0.286 1.05 CMLF0302-150MTT 15±20% 0.468 0.95 CMLF0302-220MTT 22±20% 0.611 0.90 CMLF0302-330MTT 33±20% 0.962 0.85 CMLF0302-470MTT 47±20% 1.500 0.80 CMLF0302-680MTT 68±20% 2.000 0.78 CMLF0302-820MTT 82±20% 2.500 0.76 CMLF0302-101MTT 100±20% 3.000 0.75 CMLF0302-151MTT 150±20% 4.000 0.73 CMLF0302-221MTT 220±20% 5.500 0.70 CMLF0302-331MTT 330±20% 7.000 0.70 CMLF0302-471MTT 470±20% 12.000 0.69 Part Number CMLF0302 Series: ◆ Note (1) Inductance is measured by LCR-meter 4284A/4286A (HP) or equivalent. (2) Inductance test condition: CMLF0302: 1.0µH~8.2H:7.96MTTHz/0.5V, 10.0µH~82.0µH:2.52MTTHz/0.5V,More than 100.0µH at 1.0KTTHz/1.0V. (3) DC Resistance is measured by HP4338B Milliohms Meter or equivalent. (4) Rated current is measured by LCR-meter 3260B (WK) & DC Bias 3265B(WK) at 1.0KTTHz/1.0V. (5) Maximum allowable DC current is that which causes a 10% inductance reduction from the initial value, or coil temperature to rise by 40°C,whichever is smaller. (Reference ambient temperature 20°C). (6) Operating temperature -55℃ ~ +125℃. (7) All test data is referenced to 25℃ ambient. Rev.01 Page 2 of 2 www.cybermaxtech.com
CMLF0302-6R8MTT 价格&库存
很抱歉,暂时无法提供与“CMLF0302-6R8MTT”相匹配的价格&库存,您可以联系我们找货
