CMLO0650H220MTT
CMLO0650H220MTT
    CYBERMAX(思博)
    SMD,7.1x6.6mm
    功率电感 SMD
CMLO0650H220MTT 数据手册
CMLO0650H Series SMD Molding Power Inductor ◆ Features Pb 、Magnetically shielded construction, low DC resistance; 、The use of magnetic iron powder ensure capability for large current; 3、Low audible core noise; 4、Ideal for DC-DC converter applications in hand held personal computer and etc; 5、Frequency Range: up to 3.0MHz; 6、RoHS compliant。 1 2 ◆ Applications 、Smart phone、MID; 、Next-generation mobile devices with multifunction such as adding color TV and digital movie cameras; 3、Flat-screen TVs, blue-ray disc recorders, set top box; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems; 7、Telecomm base stations。 1 2 ◆ Lead Free Part Numbering CMLO (1) 0650 (2) H (3) 100 M (4) (5) : : (1) (2) (3) (4) T T (6) (7) Series Type Dimension A X C Material Code Inductance 2R2=2.2μH 100=10μH (5) Inductance Tolerance M= 20%, Y= 30% (6) Company Code (7) Packaging packed in embossed carrier tape ; ; : ± : ± ◆ Dimensions Series A±0.3(mm) B±0.3 (mm) C (mm) D±0.3 (mm) E±0.3 (mm) CMLO0650H 7.1 6.6 5.0 Max 3.0 1.7 Rev.01 Page 1 of 4 www.cybermaxtech.com CMLO0650H Series ◆ Specification Ω Rdc (m ) Test a condition HEAT RATING CURRENT(Idc) DC AMPS1 (Typ.) SATURATION CURRENT(Isat) DC AMPS2 (Typ.) μ Typ. Max CMLO0650HR22MTT 0.22 1.1 1.3 100KHz/1V 30.0 35.0 CMLO0650HR47MTT 0.47 2.9 3.8 100KHz/1V 20.0 21.0 CMLO0650HR68MTT 0.68 3.2 4.2 100KHz/1V 18.0 16.0 CMLO0650HR82MTT 0.82 3.9 4.9 100KHz/1V 16.5 17.0 CMLO0650H1R0MTT 1.0 5.2 6.5 100KHz/1V 12.0 13.0 CMLO0650H1R5MTT 1.5 7.3 8.5 100KHz/1V 10.0 10.0 CMLO0650H2R2MTT 2.2 10.0 12.5 100KHz/1V 9.5 10.0 CMLO0650H3R3MTT 3.3 14.0 20.9 100KHz/1V 8.5 9.0 CMLO0650H4R7MTT 4.7 24.0 27.0 100KHz/1V 6.5 8.0 CMLO0650H6R8MTT 6.8 34.0 38.0 100KHz/1V 5.5 7.0 CMLO0650H100MTT 10.0 48.0 55.0 100KHz/1V 6.0 4.5 CMLO0650H150MTT 15.0 76.0 85.0 100KHz/1V 3.1 4.0 CMLO0650H220MTT 22.0 110 130 100KHz/1V 2.6 3.5 CMLO0650H330MTT 33.0 160 200 100KHz/1V 2.3 3.0 CMLO0650H470MTT 47.0 252 290 100KHz/1V 2.0 2.8 △ ℃ Part Number INDUCTANCE Lo( H) CMLO0650H Series NOTES: 1. DC current (Idc) that will cause an approximate T of 40 2. DC current (Isat) that will cause Lo to drop approximately 20% 3. All test data is referenced to 25 ambient 4. Operating Temperature Range -55 to +150 5. The part temperature (ambient + temp rise) should not exceed 150 under the worst operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. ℃ Rev.01 ℃ ℃ Page 2 of 4 ℃ www.cybermaxtech.com CMLO0650H Series ◆ Wave Soldering ◆ Hand soldering Rev.01 Page 3 of 4 www.cybermaxtech.com CMLO0650H Series ◆ Reliability Mechanical ℃ ~+125℃ -45℃ ~ + 1 2 5 ℃ -55 Rev.01 Page 4 of 4 www.cybermaxtech.com
CMLO0650H220MTT 价格&库存
很抱歉,暂时无法提供与“CMLO0650H220MTT”相匹配的价格&库存,您可以联系我们找货
