CMLW4020S2R2MST
CMLW4020S2R2MST
    CYBERMAX(思博)
    SMD,4x4mm
    特性:磁树脂屏蔽结构可将蜂鸣声降低至超低水平。铁氧体磁芯上的金属化处理使其具有出色的抗冲击性和耐用性。闭合磁路设计可减少漏磁和电磁干扰 (EMI)。额定电流比同等尺寸的传统电感器高30%。占用更少的P...
CMLW4020S2R2MST 数据手册
CMLW4020S Series Wire Wound SMD Power Inductor Pb ◆ Features 1、Magnetic-resin shielded construction reduces buzz noise to ultra-low levels; 2、Metallization on ferrite core results in excellent shock resistance and damage-free durability; 3、Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI); 4、30% higher current rating than conventional inductors of equal size; 5、Take up less PCB real estate and save more power。 ◆ Applications ◆ Lead Free Part Numbering 1、LED Lighting; 2、Mobile devices with multifunction such as adding color TV and camera; 3、Flat-screen TVs, blue-ray disc recorders, set top boxes; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems CMLW (1) (1) (2) (3) (4) 4020 (2) S (3) 100 M (4) (5) S T (6) (7) Series Type Dimension:L X H Material Code Inductance:2R2=2.2μH ; 100=10µH;101=100µH (5) Inductance Tolerance:M= 20%, N= 30% (6) Company Code (7) Packaging Tape Carrier Package ± ± : 7、Telecomm base stations ◆ Dimensions Recommended Land Pattern MLW 30/40/50/60/80 Series Unit:mm Series A B C D E F a Typ. b Typ. c Typ. CMLW4020S 4.0±0.2 4.0±0.2 2.0Max. 3.3±0.2 0.95±0.2 2.10±0.2 1.9 1.1 3.7 Rev.01 Page 1 of 4 www.cybermaxtech.com CMLW4020S Series ◆ Electrical Characteristics ( : ℃ ℃ ℃ ℃ 1) Operating temperature range Including self-heating) -40 ~ +125 2) Storage temperature range (packaging conditions): -10 ~+40 and RH 70% (Max.) ◆ Construction and material ◆ REFLOW-PROFILE Rev.01 Page 2 of 4 www.cybermaxtech.com CMLW4020S Series ◆ Specification Inductance Part Number @100KHz,1V (µH) Frequency MHz Saturation Current(A) Heat Rating Current(A) DCR S.R.F Isat Irms DC Resistance ±30% (Ω) Min.Self-resonant ( ) CMLW4020S Series CMLW4020S1R0MST 1.0±20% 0.029 75 4.85 2.15 CMLW4020S1R5MST 1.5±20% 0.035 71 4.45 1.98 CMLW4020S2R2MST 2.2±20% 0.040 49 3.40 1.85 CMLW4020S3R3MST 3.3±20% 0.070 44 3.20 1.40 CMLW4020S4R7MST 4.7±20% 0.075 42 2.35 1.34 CMLW4020S5R1MST 5.1±20% 0.085 42 2.30 1.27 CMLW4020S5R6MST 5.6±20% 0.090 30 2.20 1.22 CMLW4020S6R2MST 6.2±20% 0.115 36 2.15 1.08 CMLW4020S6R8MST 6.8±20% 0.125 33 2.20 1.04 CMLW4020S100MST 10±20% 0.165 26 1.60 0.90 CMLW4020S120MST 12±20% 0.175 26 1.50 0.88 CMLW4020S150MST 15±20% 0.230 24 1.35 0.77 CMLW4020S220MST 22±20% 0.350 15 1.05 0.62 CMLW4020S330MST 33±20% 0.550 11 0.85 0.49 CMLW4020S390MST 39±20% 0.650 11 0.82 0.46 CMLW4020S470MST 47±20% 0.710 10 0.74 0.44 CMLW4020S680MST 68±20% 1.060 7.7 0.61 0.36 CMLW4020S820MST 82±20% 1.170 7.2 0.56 0.34 CMLW4020S101MST 100±20% 1.350 6.3 0.52 0.31 ◆ Note 1:All test data is referenced to 20°C ambient; 2:Rated current: Isat or Irms, whichever is smaller; 3:Isat: DC current at which the inductance drops approximate 30% from its value without current; 4:Irms: DC current that causes the temperature rise (△T =40°C) from 20°C ambient. ◆ Standard Packing Quantity: :3000 pcs/reel Rev.01 Page 3 of 4 www.cybermaxtech.com CMLW4020S Series ◆ TYPICAL ELECTRICAL CHARACTERISTICS CMLW4020S Series Rev.01 Page 4 of 4 www.cybermaxtech.com
