CMLF0705-221KTT
CMLF0705-221KTT
    CYBERMAX(思博)
    SMD,7.8x7mm
    功率电感 SMD
CMLF0705-221KTT 数据手册
???? CMLF0705 Series Drum Core Surface Mount Unshielded Power Inductors ◆ Features Pb 1. Excellent solderability and high heat resistance. 2. Excellent terminal strength construction. 3. Packed in embossed carrier tape and can be used by automatic mounting machine. ◆ Applications Power supply for VCR,OA equipment ,LCD television set notebook, DC to DC converters, DC to AC inverters etc. ◆ Shape & Dimensions ◆ Lead Free Part Numbering CMLF 0705 - 100 M T (1) (2) (3) (4) (5) T (6) (1) Series Type (2) Dimension A X C (3) Inductance 2R2=2.2μH : : (4) (5) (6) ; 100=10μH;101=100μH Inductance Tolerance:K=±10%, M=±20% Company Code Packaging : packed in embossed carrier tape Series A (mm) B (mm) C (mm) D (mm) CMLF0705 7.8±0.3 7.0±0.3 5.0±0.3 2.1 Typ. ◆ Material Item Material a. Core Ferrite DR Core b. Wire Enamelled Copper wire c.Terminal Ag+Sn+SnPb Rev.01 Page 1 of 3 www.cybermaxtech.com ???? CMLF0705 Series ◆ Specification Inductance(μH) 电感量 Test Freq 测试频率 测试频率 DCR(Ω) max. 直流电阻 IDC (A) max. 额定电 额定电流 CMLF0705-1R0MTT 1.00±20% 100KHz/0.25V 0.030 11.25 CMLF0705-1R5MTT 1.50±20% 100KHz/0.25V 0.040 8.35 CMLF0705-2R2MTT 2.20±20% 100KHz/0.25V 0.050 6.52 CMLF0705-2R7MTT 2.70±20% 100KHz/0.25V 0.060 6.06 CMLF0705-3R3MTT 3.30±20% 100KHz/0.25V 0.060 5.26 CMLF0705-4R7MTT 4.70±20% 100KHz/0.25V 0.070 4.54 CMLF0705-5R6MTT 5.60±20% 100KHz/0.25V 0.070 4.25 CMLF0705-6R8MTT 6.80±20% 100KHz/0.25V 0.070 3.45 CMLF0705-8R2MTT 8.20±20% 100KHz/0.25V 0.070 3.30 CMLF0705-100KTT 10.0±10% 100KHz/0.25V 0.070 3.20 CMLF0705-120KTT 12.0±10% 100KHz/0.25V 0.080 2.70 CMLF0705-150KTT 15.0±10% 100KHz/0.25V 0.090 2.00 CMLF0705-180KTT 18.0±10% 100KHz/0.25V 0.100 1.90 CMLF0705-220KTT 22.0±10% 100KHz/0.25V 0.110 1.70 CMLF0705-330KTT 33.0±10% 100KHz/0.25V 0.130 1.50 CMLF0705-390KTT 39.0±10% 100KHz/0.25V 0.160 1.40 CMLF0705-470KTT 47.0±10% 100KHz/0.25V 0.180 1.30 CMLF0705-560KTT 56.0±10% 100KHz/0.25V 0.240 0.94 CMLF0705-680KTT 68.0±10% 100KHz/0.25V 0.280 0.85 CMLF0705-820KTT 82.0±10% 100KHz/0.25V 0.370 0.78 CMLF0705-101KTT 100.0±10% 100KHz/0.25V 0.430 0.72 CMLF0705-151KTT 150.0±10% 100KHz/0.25V 0.640 0.58 CMLF0705-181KTT 180.0±10% 100KHz/0.25V 0.710 0.51 CMLF0705-221KTT 220.0±10% 100KHz/0.25V 0.960 0.49 CMLF0705-331KTT 330.0±10% 100KHz/0.25V 1.260 0.40 CMLF0705-391KTT 390.0±10% 100KHz/0.25V 1.770 0.36 CMLF0705-471KTT 470.0±10% 100KHz/0.25V 1.960 0.34 CMLF0705-561KTT 560.0±10% 100KHz/0.25V 2.000 0.33 CMLF0705-681KTT 680.0±10% 100KHz/0.25V 2.200 0.32 CMLF0705-821KTT 820.0±10% 100KHz/0.25V 2.900 0.25 CMLF0705-102KTT 1000.0±10% 100KHz/0.25V 3.900 0.20 Part Number 料号 CMLF0705 Series Rev.01 Page 2 of 3 www.cybermaxtech.com ???? CMLF0705 Series ◆ Note (1) Maximum allowable DC current is that which causes a 10% inductance reduction from the initial value, or coil temperature to rise by 40°C,whichever is smaller. (Reference ambient temperature 20°C). (2) Operating temperature -55℃ ~ +125℃. (3) All test data is referenced to 25℃ ambient. Rev.01 Page 3 of 3 www.cybermaxtech.com
CMLF0705-221KTT 价格&库存
很抱歉,暂时无法提供与“CMLF0705-221KTT”相匹配的价格&库存,您可以联系我们找货
