CMLO1040H Series
SMD Molding Power Inductor
◆ Features
Pb
、Magnetically shielded construction, low DC resistance;
、The use of magnetic iron powder ensure capability
for large current;
3、Low audible core noise;
4、Ideal for DC-DC converter applications in hand held
personal computer and etc;
5、Frequency Range: up to 3.0MHz;
6、RoHS compliant。
1
2
◆ Applications
、Smart phone、MID;
、Next-generation mobile devices with multifunction such
as adding color TV and digital movie cameras;
3、Flat-screen TVs, blue-ray disc recorders, set top box;
4、Notebooks, desktop computers, servers, graphic cards;
5、Portable gaming devices, personal navigation systems,
personal multimedia devices;
6、Automotive systems;
7、Telecomm base stations。
1
2
◆ Lead Free Part Numbering
CMLO
(1)
1040
(2)
H
(3)
100 M
(4) (5)
(1)
(2)
(3)
(4)
T
T
(6) (7)
Series Type
Dimension A X C
Material Code
Inductance 2R2=2.2μH
100=10μH 101=100μH
(5) Inductance Tolerance M= 20%, Y= 30%
(6) Company Code
(7) Packaging packed in embossed carrier tape
◆ Dimensions
Series
A±0.2(mm)
B±0.2 (mm)
C (mm)
D±0.1 (mm)
E±0.1 (mm)
CMLO1040H
10.8
10.0
4.0 Max
3.0
2.0
Rev.01
Page 1 of 4
www.cybermaxtech.com
CMLO1040H Series
◆ Specification
Part Number
μ
INDUCTANCE
Lo( H)
Ω
Rdc
(m )
Typ.
Max
Test a
condition
HEAT RATING
CURRENT(Idc)
DC AMPS1
(Typ.)
SATURATION
CURRENT(Isat)
DC AMPS2
(Typ.)
CMLO1040H Series
CMLO1040HR22MTT
0.22
0.8
1.0
100KHz/1V
35.0
60.0
CMLO1040HR33MTT
0.33
1.0
1.2
100KHz/1V
25.0
51.0
CMLO1040HR47MTT
0.47
1.3
1.68
100KHz/1V
24.0
35.0
CMLO1040HR56MTT
0.56
1.5
1.8
100KHz/1V
23.5
33.0
CMLO1040HR68MTT
0.68
1.9
2.4
100KHz/1V
20.0
30.0
CMLO1040H1R0MTT
1.0
3.0
3.3
100KHz/1V
18.0
28.0
CMLO1040H1R5MTT
1.5
3.8
5.5
100KHz/1V
12.0
24.0
CMLO1040H2R2MTT
2.2
5.8
7.0
100KHz/1V
12.0
18.0
CMLO1040H3R3MTT
3.3
10
11
100KHz/1V
10.0
16.0
CMLO1040H4R7MTT
4.7
12
19
100KHz/1V
8.5
13.0
CMLO1040H5R6MTT
5.6
100KHz/1V
8.0
11.0
CMLO1040H6R8MTT
6.8
22
25
100KHz/1V
7.0
10.0
CMLO1040H100MTT
10
27
30
100KHz/1V
5.5
8.5
CMLO1040H150MTT
15
32
45
100KHz/1V
4.5
7.0
CMLO1040H220MTT
22
51
66
100KHz/1V
4.0
5.5
CMLO1040H330MTT
33
79
92
100KHz/1V
3.5
5.0
CMLO1040H470MTT
47
101
145
100KHz/1V
3.0
3.7
CMLO1040H680MTT
68
155
205
100KHz/1V
2.3
3.0
CMLO1040H820MTT
82
205
285
100KHz/1V
2.0
3.0
CMLO1040H101MTT
82
265
300
100KHz/1V
1.5
2.0
NOTES:
1. DC current (Idc) that will cause an approximate T of 40
2. DC current (Isat) that will cause Lo to drop approximately 20%
3. All test data is referenced to 25 ambient
4. Operating Temperature Range -55 to +150
5. The part temperature (ambient + temp rise) should not exceed 150
under the worst operating conditions. Circuit design, component placement,
PWB trace size and thickness, airflow and other cooling provisions all affect
the part temperature. Part temperature should be verified in the end application.
Rev.01
Page 2 of 4
CMLO1040H Series
◆ Wave Soldering
◆ Hand soldering
Rev.01
Page 3 of 4
CMLO1040H Series
◆ Reliability Mechanical
℃ ~+125℃
-45℃ ~ + 1 2 5 ℃
-55
Rev.01
Page 4 of 4
很抱歉,暂时无法提供与“CMLO1040H150MTT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.59527
- 50+1.24146
- 150+1.08983
- 1000+0.90072
- 2000+0.81648
- 5000+0.76583
