CMLW8040S150MST
CMLW8040S150MST
    CYBERMAX(思博)
    SMD,8x8mm
    功率电感 SMD
CMLW8040S150MST 数据手册
CMLW8040S Series Wire Wound SMD Power Inductor Pb ◆ Features 1、Magnetic-resin shielded construction reduces buzz noise to ultra-low levels; 2、Metallization on ferrite core results in excellent shock resistance and damage-free durability; 3、Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI); 4、30% higher current rating than conventional inductors of equal size; 5、Take up less PCB real estate and save more power。 ◆ Applications ◆ Lead Free Part Numbering 1、LED Lighting; 2、Mobile devices with multifunction such as adding color TV and camera; 3、Flat-screen TVs, blue-ray disc recorders, set top boxes; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems CMLW (1) (1) (2) (3) (4) 8040 (2) S (3) 100 M (4) (5) S T (6) (7) Series Type Dimension:L X H Material Code Inductance:2R2=2.2μH ; 100=10µH;101=100µH (5) Inductance Tolerance:M= 20%, N= 30% (6) Company Code (7) Packaging Tape Carrier Package ± ± : 7、Telecomm base stations ◆ Dimensions Recommended Land Pattern Unit:mm Series A B C D E F a Typ. b Typ. c Typ. CMLW8040S 8.0±0.3 8.0±0.3 4.2Max. 6.3±0.3 2.00±0.3 4.00±0.3 3.8 2.2 7.5 Page 1 of 4 www.cybermaxtech.com CMLW8040S Series ◆ Electrical Characteristics ( : ℃ ℃ ℃ ℃ 1) Operating temperature range Including self-heating) -40 ~ +125 2) Storage temperature range (packaging conditions): -10 ~+40 and RH 70% (Max.) ◆ Construction and material ◆ REFLOW-PROFILE Page 2 of 4 www.cybermaxtech.com CMLW8040S Series ◆ Specification Inductance Part Number @100KHz,1V (µH) Frequency MHz Saturation Current(A) Heat Rating Current (A) DCR S.R.F Isat Irms DC Resistance ±30% (Ω) Min.Self-resonant ( ) CMLW8040S Series CMLW8040SR82NST 0.82±30% 0.008 94 13.80 6.30 CMLW8040S1R0NST 1.0±30% 0.008 89 9.85 6.30 CMLW8040S1R5NST 1.5±30% 0.010 67 8.15 5.65 CMLW8040S2R2MST 2.2±20% 0.012 41 7.10 5.15 CMLW8040S3R3MST 3.3±20% 0.017 27 6.50 4.40 CMLW8040S4R7MST 4.7±20% 0.019 24 5.90 4.10 CMLW8040S5R6MST 5.6±20% 0.021 24 6.00 3.85 CMLW8040S6R8MST 6.8±20% 0.024 20 4.55 3.60 CMLW8040S8R2MST 8.2±20% 0.026 17 4.20 3.45 CMLW8040S100MST 10±20% 0.029 15 3.60 3.30 CMLW8040S150MST 15±20% 0.047 12 2.95 2.60 CMLW8040S220MST 22±20% 0.069 9.5 2.40 2.10 CMLW8040S330MST 33±20% 0.097 7.8 2.05 1.80 CMLW8040S470MST 47±20% 0.136 6.4 1.75 1.55 CMLW8040S560MST 56±20% 0.148 6.4 1.55 1.45 CMLW8040S680MST 68±20% 0.196 4.9 1.45 1.25 CMLW8040S101MST 100±20% 0.290 4.2 1.15 1.00 CMLW8040S121MST 120±20% 0.334 3.5 1.05 0.95 CMLW8040S151MST 150±20% 0.410 3.5 1.10 0.85 CMLW8040S221MST 220±20% 0.599 3.5 0.85 0.80 CMLW8040S331MST 330±20% 0.889 2.8 0.68 0.64 ◆ Note 1 2 3 4 :All test data is referenced to 20°C ambient; :Rated current: Isat or Irms, whichever is smaller; :Isat: DC current at which the inductance drops approximate 30% from its value without current; :Irms: DC current that causes the temperature rise (△T =40°C) from 20°C ambient. ◆ Standard Packing Quantity: :1000 pcs/reel Page 3 of 4 www.cybermaxtech.com CMLW8040S Series ◆ TYPICAL ELECTRICAL CHARACTERISTICS CMLW8040S Series Page 4 of 4 www.cybermaxtech.com
CMLW8040S150MST 价格&库存
很抱歉,暂时无法提供与“CMLW8040S150MST”相匹配的价格&库存,您可以联系我们找货
