CMCW2012F2R2KTT
CMCW2012F2R2KTT
    CYBERMAX(思博)
    CMCW2012F2R2KTT
CMCW2012F2R2KTT 数据手册
CMCW2012F2R2KTT 承 认 书 SPECIFICATION FOR APPROVAL CUSTOMER: CUSTOMER P/N: Cybermax P/N: CMCW2012F2R2KTT DRAWN NO.: CM18102705 DATE: REVISION NO. A 18.10.27 Signature: APPROVED BY Rev.01 CHECKED BY DRAWN BY 黄 谢 申 18.10.27 18.10.27 18.10.27 大燕 焕飞 双凤 Page 1 of 11 www.cybermaxtech.com CMCW2012F2R2KTT Chang Item DATE Rev.01 Page 2 of 11 www.cybermaxtech.com CMCW2012F2R2KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F2R2KTT CM18102705 PAGE: REVISION: DATE: 1/10 18.10.27 SHAPE & DIMENSION (UNIT:mm) Marking Code: PAD LAYOUT(MM): Size: Color: typeface: ELECREICAL SCHEMATIC: ELECREICAL SPECIFICATION MEAS. SPEC. ITEM CONDITIONS TEST FREQ. L 2.2 µH ± 10% DCR 220 mΩ ± 30%. 2.5MHz/0.1V Ta=25℃,Idc=0A Ta=25℃ Isat 0.74AMAX(0.9ATYP) 2.5MHz/0.1V △L/L≤30% Irms 1.04AMAX(1.4ATYP) 2.5MHz/0.1V △≦40℃ GENERAL SPECIFICATION Electrical specifications : Operation Temperature: Storage Temperature: at 25℃ -40~+125℃ -40~+125℃ (1)WIRE TYPE: ¢0.08mm (2)WINDING: 18.5Ts(Ref.) Rev.01 Page 3 of 11 www.cybermaxtech.com CMCW2012F2R2KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: Rev.01 CMCW2012F2R2KTT CM18102705 Page 4 of 11 PAGE: REVISION: DATE: 2/10 18.10.27 www.cybermaxtech.com CMCW2012F2R2KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: Rev.01 CMCW2012F2R2KTT CM18102705 Page 5 of 11 PAGE: REVISION: DATE: 4/10 18.10.27 www.cybermaxtech.com CMCW2012F2R2KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F2R2KTT CM18102705 PAGE: REVISION: DATE: 5/10 18.10.27 B.O.M Rev.01 Page 6 of 11 www.cybermaxtech.com CMCW2012F2R2KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F2R2KTT CM18102705 PAGE: REVISION: DATE: 6/10 18.10.27 Isat(飽和電流):電感瞬間的突波電流 CMCW2012F2R2KTT Rev.01 TME(秒) Lsat(A) L(UH) △L/L(%) 1 0.000 2.08 0.00% 1 0.108 2.08 0.00% 1 0.216 2.08 0.00% 1 0.324 2.07 -0.48% 1 0.432 2.06 -0.96% 1 0.540 2.03 -2.40% 1 0.648 1.98 -4.81% 1 0.756 1.90 -8.65% 1 0.864 1.76 -15.38% 1 0.972 1.53 -26.44% 1 1.080 1.16 -44.23% Page 7 of 11 www.cybermaxtech.com CMCW2012F2R2KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: PAGE: REVISION: DATE: CMCW2012F2R2KTT CM18102705 7/10 18.10.27 單點溫昇 TIME(S) Irms(A) 30 0.000 2.10 0.00% 30.0 0.0 30 0.108 2.10 0.00% 30.0 0.0 30 0.216 2.10 0.00% 30.0 0.0 30 0.324 1.10 -47.62% 31.0 1.0 30 0.432 2.06 -1.90% 32.0 2.0 30 0.540 2.04 -2.86% 34.0 4.0 30 0.648 1.98 -5.71% 36.0 6.0 30 0.756 1.85 -11.90% 38.0 8.0 30 0.864 1.65 -21.43% 42.0 12.0 30 0.972 1.36 -35.24% 46.0 16.0 30 1.080 0.95 -54.76% 51.0 21.0 ※DC bias current characteristics in the Rev.01 CMCW2012F2R2KTT L(uH) ΔL/L(%) Temp(℃) ΔT(℃) ambient temperature 25℃ Frequency 2.5MHz/0.1V Page 8 of 11 www.cybermaxtech.com CMCW2012F2R2KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: PAGE: REVISION: DATE: CMCW2012F2R2KTT CM18102705 8/10 18.10.27 TEST DATA FOR PREPRODUCTION SAMPLE TEST RESOLUTION DIMENSION (Unit:mm) MEAS. L D.C.R 长 宽 高 ITEM µH mΩ mm mm mm 2.2 220 ± ± Max.2.4 Max.1.73 1.3±0.1 10% 30% SPEC. TEST 2.5MHz/0.1 Isat FREQ. V 0.74A 1 2.09 246 1.97 -5.7% 2.22 1.62 1.29 2 2.08 249 1.95 -6.3% 2.26 1.65 1.28 3 2.09 247 1.97 -5.7% 2.25 1.62 1.25 4 2.09 247 1.97 -5.7% 2.24 1.64 1.29 5 2.10 244 1.95 -7.1% 2.28 1.62 1.24 6 2.09 246 1.96 -6.2% 7 2.10 245 1.95 -7.1% 8 2.08 250 1.92 -7.7% 9 2.08 246 1.96 -5.8% 10 2.07 248 1.92 -7.2% AVG. 2.087 246.8 1.952 -6.47% R 0.03 6 1.60 -4.20% APPROVED BY △L/L≦30% CHECKED BY 黄 18.10.27 大燕 Rev.01 Page 9 of 11 DRAWN BY 谢 18.10.27 申 18.10.27 焕飞 双凤 www.cybermaxtech.com CMCW2012F2R2KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F2R2KTT CM18102705 PAGE: REVISION: DATE: 9/10 18.10.27 PACKAGING 热封包装 Rev.01 Page 10 of 11 www.cybermaxtech.com CMCW2012F2R2KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: PAGE: REVISION: DATE: CMCW2012F2R2KTT CM18102705 10/10 18.10.27 PACKAGING 1.1 外箱: 39*38*18.5 cm 一箱裝 8 內箱 1.2 內箱: 18.7*18.4*8.3 cm 一箱装 5 卷制品 1.3 外箱材質: A 三 A 1.4 內箱材質: A=A 1.5 每 5 卷制品用一只静电袋包裝 1.6 每一静电袋內放一只袋干燥剂 1.7 每一卷上面依标签样式的要求贴上标签明细 1.8 出货內外箱贴上该箱內实际內容明细 1.9 出货标签规格如下: 尺寸=长度:39mm 宽度:29mm (如: 客戶有特殊要求時, 則依客戶要求實施.) 备注:如果捆包数量小于内箱捆包数量时就用内箱包装 Rev.01 Page 11 of 11 www.cybermaxtech.com
CMCW2012F2R2KTT
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发射极,4脚集电极,5脚门极,6脚发射极。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装形式。
CMCW2012F2R2KTT 价格&库存
很抱歉,暂时无法提供与“CMCW2012F2R2KTT”相匹配的价格&库存,您可以联系我们找货
CMCW2012F2R2KTT
    • 10+0.47952
    • 100+0.38621
    • 300+0.33956
    • 2000+0.27044
    • 4000+0.24246
    • 10000+0.22842
    库存:1037
