CMLF0504-3R3MTT
CMLF0504-3R3MTT
    CYBERMAX(思博)
    SMD,5.8x5.2mm
    特性:优异的可焊性和高耐热性。出色的端子强度结构。采用压纹载带包装,可用于自动贴装机。应用:VCR电源。OA设备电源
CMLF0504-3R3MTT 数据手册
CMLF0504 Series Drum Core Surface Mount Unshielded Power Inductors ◆ Features Pb 1. Excellent solderability and high heat resistance. 2. Excellent terminal strength construction. 3. Packed in embossed carrier tape and can be used by automatic mounting machine. ◆ Applications Power supply for VCR,OA equipment ,LCD television set notebook, DC to DC converters, DC to AC inverters etc. ◆ Shape & Dimensions ◆ Lead Free Part Numbering CMLF 0504 - 100 M T (1) (2) (3) (4) (5) T (6) (1) Series Type (2) Dimension A X C (3) Inductance 2R2=2.2μH : : (4) (5) (6) ; 100=10μH;101=100μH Inductance Tolerance:K=±10%, M=±20% Company Code Packaging : packed in embossed carrier tape Series A (mm) B (mm) C (mm) D (mm) CMLF0504 5.8±0.3 5.2±0.3 4.5±0.3 1.5 Typ. ◆ Material Item Material a. Core Ferrite DR Core b. Wire Enamelled Copper wire c.Terminal Ag+Sn+SnPb Rev.01 Page 1 of 3 www.cybermaxtech.com CMLF0504 Series ◆ Specification Inductance (μH) DCR (Ω) max. IDC (A) max. CMLF0504-1R0MTT 1.00±20% 0.015 6.10 CMLF0504-1R2MTT 1.20±20% 0.020 5.70 CMLF0504-1R5MTT 1.50±20% 0.025 5.10 CMLF0504-1R8MTT 1.80±20% 0.030 4.90 CMLF0504-2R2MTT 2.20±20% 0.035 4.80 CMLF0504-3R3MTT 3.30±20% 0.045 4.20 CMLF0504-4R7MTT 4.70±20% 0.060 3.30 CMLF0504-5R6MTT 5.60±20% 0.070 3.10 CMLF0504-6R8MTT 6.80±20% 0.080 3.00 CMLF0504-8R2MTT 8.20±20% 0.090 2.70 CMLF0504-100KTT 10.0±10% 0.100 2.50 CMLF0504-120KTT 12.0±10% 0.120 2.30 CMLF0504-150KTT 15.0±10% 0.140 2.20 CMLF0504-180KTT 18.0±10% 0.150 1.83 CMLF0504-220KTT 22.0±10% 0.180 1.40 CMLF0504-270KTT 27.0±10% 0.200 1.37 CMLF0504-330KTT 33.0±10% 0.230 1.28 CMLF0504-390KTT 39.0±10% 0.320 0.80 CMLF0504-470KTT 47.0±10% 0.370 0.72 CMLF0504-560KTT 56.0±10% 0.420 0.68 CMLF0504-680KTT 68.0±10% 0.460 0.61 CMLF0504-820KTT 82.0±10% 0.600 0.58 CMLF0504-101KTT 100.0±10% 0.700 0.52 CMLF0504-121KTT 120.0±10% 0.930 0.48 CMLF0504-151KTT 150.0±10% 1.100 0.40 CMLF0504-181KTT 180.0±10% 1.380 0.38 CMLF0504-221KTT 220.0±10% 1.570 0.35 CMLF0504-271KTT 270.0±10% 1.650 0.32 CMLF0504-331KTT 330.0±10% 1.700 0.28 CMLF0504-391KTT 390.0±10% 1.800 0.26 CMLF0504-471KTT 470.0±10% 2.300 0.23 CMLF0504-561KTT 560.0±10% 2.500 0.20 CMLF0504-681KTT 680.0±10% 3.000 0.19 CMLF0504-821KTT 820.0±10% 4.500 0.16 CMLF0504-102KTT 1000.0±10% 4.800 0.14 Part Number CMLF0504 Series: Rev.01 Page 2 of 3 www.cybermaxtech.com CMLF0504 Series ◆ Note (1) Inductance is measured by LCR-meter 4284A/4286A (HP) or equivalent. (2) Inductance test condition: CMLF0504: 1.0µH~8.2H:7.96MTTHz/0.5V, 10.0µH~82.0µH:2.52MTTHz/0.5V,More than 100.0µH at 1.0KTTHz/1.0V. (3) DC Resistance is measured by HP4338B Milliohms Meter or equivalent. (4) Rated current is measured by LCR-meter 3260B (WK) & DC Bias 3265B(WK) at 1.0KTTHz/1.0V. (5) Maximum allowable DC current is that which causes a 10% inductance reduction from the initial value, or coil temperature to rise by 40°C,whichever is smaller. (Reference ambient temperature 20°C). (6) Operating temperature -55℃ ~ +125℃. (7) All test data is referenced to 25℃ ambient. Rev.01 Page 3 of 3 www.cybermaxtech.com
CMLF0504-3R3MTT 价格&库存
很抱歉,暂时无法提供与“CMLF0504-3R3MTT”相匹配的价格&库存,您可以联系我们找货
