COMPONENT SPECIFICATION
版次:第3版
N
A
M
E
MULTILAYER CHIP INDUCTORS
EBLS-201212
COMPOSITE SPECIFICATION
SPEC#
1
8
EBLS2012-101K
1. SCOPE
This specification applies to the EBLS-2012 series Multilayer Chip Inductors
2. STANDARD ATMOSPHERIC CONDITIONS
Unless otherwise specified the standard range of atmospheric conditions for
making measurements and tests is as follows:
Ambient temperature : 20±15℃
Relative humidity
: 30~70%
If there may be any doubt on the results, measurements shall be made within
the following limits :
Ambient temperature : 25±5℃
Relative humidity
: 30~70%
3. RATINGS
PART NO
EBLS2012-101K
INDUCTANCE
Q
AT 1 MHz 60mV
100μH±10%
Min
25
4. DIMENSION
SELF-RESONANT
FREQUENCY(MHz)
Min
7
DATE
REVISION
CHECKED BY APPROVED BY
JSHING
表格編號:034承認書 A
HSU
(Ω) Max
(mA)Max
3.1
2
OPERATING TEMP. RANGE : -40℃ ~ +85℃
STORAGE
TEMP. RANGE : -10℃ ~ +40℃
TYPE
L
W
T
A(m/m)
EBLS-2012 2.0±0.2
HISTORY
PLANNED BY
DC RESISTANCE RATED CURRENT
Chi Chi Huang
1.25±0.2
1.25±0.2
0.2~0.8
SIGN.
SIGN.
2
版次:第3版
N
A
M
E
EBLS-201212
SPEC# EBLS2012-101K
2
INDUCTANCE VS DC SUPERPOSITION CHARACTERISTICS
IMPEDANCE VS FREQUENCY CHARACTERISTICS
Q VS FREQUENCY CHARACTERISTICS
表格編號:034承認書 A
8
3
版次:第3版
3
MULTILAYER CHIP INDUCTORS COMPOSITE SPECIFICATION
EBLS-201212
SPEC# EBLS2012-101K
8
6) Reflow soldering conditions
˙ Pre-heating should be in such a way that the temperature difference between solder and ferrite
surface is limited to 150℃ max.Also cooling into solvent after soldering should be in such a
way that the temperature difference is limited to 100℃ max.
Unenough pre-heating may cause cracks on the ferrite, resulting in the deterioration of product
quality.
˙ Products should be soldered within the following allowable range indicated by the slanted line.
The excessive soldering conditions may cause the corrosion of the electrode, When soldering is
repeated, allowable time is the accumulated time.
Temperature(℃)
N
A
M
E
Temperature Profile
270
260
250
240
230
0 10 20 30 40 50 60 70
A
B
C
D
E
Slope of temp. rise
※ 1 to 5
Heat time
50 to 150 ※ sec
120 to 180 ※ ℃
※ ℃/sec
1 to 5
Heat temperature
Slope of temp. rise
※ ℃/sec
Time over 230℃
Peak temperature
90~120
sec
255~260
※ time
Peak hold
10 max.
sec
※No. of mounting
3
※ times
(Melting area of solder)
6-1 Reworking with soldering iron
Preheating
150℃, lminute
Tip temperature
280℃ max
Soldering time
3seconds max.
Soldering iron output
30w max.
End of soldering iron
∮3mm max.
˙Reworking should be limited to only one time.
Note:Do not directly touch the products with the tip of the soldering iron in order to
prevent the crack on the ferrite material due to the thermal shock.
Upper Limit
6-2 Solder Volume
Recommendable
Solder shall be used not to be exceed the upper limits as shown below.
Accordingly increasing the solder volume, the mechanical stress to product is also
increased. Exceeding solder volume may cause the failure of mechanical or electrical
performance.
表格編號:034承認書 A
4
版次:第3版
N
A
M
E
EBLS-201212
4
SPEC#
8
EBLS2012-101K
7 EQUIPMENT
7-1 IMPEDANCE
Impedance shall be measured with HP-4286A impedance
analyzer or equivalent system
7-2 DC RESISTANCE
DC resistance shall be measured using HP 4338 digital mili-ohm
meter with 4 terminal method.
8.MECHANICAL CHARACTERISTICS
ITEM
Specification
TEST CONDITIONS
TERMINAL Without deformation cases
Solder chip on PCB and applied 10N
STRENGTH impedance shall be satisfied ±20% (1.02Kgf) for 10 sec
DC resistance shall be satisfied.
Substrate
Without deformation cases,
After soldering a chip to a test substrate,
bending test inductance shall be satisfied ± 20% bend the substrate by 3mm hold for 10s
and then return.
Soldering shall be done in accordance
with the recommended PC board pattern
and reflow soldering.
Bending
unit : mm
0.8
45
40
45
100
RESISTANCE No visible damage
Solder Temp. : 265±3℃
TO SOLDER Electrical characteristics and mechanicalImmersion time : 6±1 sec
HEAT
characteristics shall be satisfied.
Preheating : 100℃ to 150℃, 1 minute.
SOLDER-
ABILITY
Consult standard MIL-STD-202
METHOD 210
95% min. coverage of all
metabolised area
Consult standard J-STD-002
表格編號:034承認書 A
Measurement to be made after keeping at room
temp for 24±2 hrs.
Solder : Sn-3Ag-0.5Cu
Solder temp. : 240±5℃
Immersion time : 3±1 sec
5
版次:第3版
N
A
M
E
EBLS-201212
SPEC#
5
EBLS2012-101K
9. RELIABILITY AND TEST CONDITIONS
9-1 HIGH TEMPERATURE RESISTANCE
a. Performance specification
1.Appearance:no mechanical damage
2.Inductance shall be with ±20﹪of the initial value
b.Test condition
1.Temperature +85℃±2℃
2.Applied current:Rated current
3.Testing time:1008±12hrs (maximum value)
4.Measurement:After placing at room ambient temperature for 24 hours minimum
9-2 HUMIDITY RESISTANCE
a.Performance specification
b.Test condition
1.Humidity:90 to 95﹪RH
2.Temperature:60±2℃
3.Applied current:Rated current (maximum value)
4.Testing tine:1008±12hours
5.Measurement:After placing at room ambient temperature for 24 hours minimum
9-3 TEMPERATURE CYCLE
b.Test condition
1.Temperature -40℃,+85℃ kept stabilized for 30 minutes each
2.Cycle:100 cycles
3.Measurement:After placing for 24hours minimum at room ambient temperature
4. step1. -40℃ temp±3℃ 30±3 minutes
step2. Room temperature 2to5 minutes
step3. +85℃ temp±2℃ 30±3 minutes
step4. room temperature 2to5 minutes
9-4 LOW TEMPERATURE STORAGE LIFE TEST
b.Test condition
1.Temperature -40℃±2℃
2.Testing time:1008±12hours
3.Measurement:After placing for 24 hours minimum at room ambient temperature
9-5 THERMAL SHOCK
b.Test condition
2.Cycle:100 cycles
3.Measurement:After placing for24 hours minimum at room ambient temperature
9-6 VIBRATION TEST
b.Test condition
1.Waveform:Sine wave
2.Frequency:10~55~10 Hz
3.Sweep time:1min
4.Amplitude:1.5mm(peak-peak)
5.Direction:X,Y,Z(3 axes)
6.Duration:2 hrs./axis,total 6 hrs.
表格編號:034承認書 A
版次:第3版
N
A
M
E
EBLS-201212
6
EBLS2012-101K
SPEC#
8
10. EMBOSSED CARRIER TAPE PACKAGING
10-1 DIMENSIONS
Unreeling direction
A0
1.5
±0.1
B0
2.35
±0.1
W
F
8.0
3.5
±0.1 ±0.05
E
1.75
±0.1
P1
4.0
±0.1
P2
2.00
±0.05
10-2 LEADER AND TRAILER TAPE
P0
D0
D1
K
T
T2
4.0 1.55 1.00 1.67 0.22 1.67
±0.1 ±0.05 ±0.1 ±0.15 ±0.05 ±0.25
10-3 DIRECTION THE DIRECTION SHALL BE SEEN FROM THE TOP OF COVER TAPE
Unreeling direction
10-4 REELS
PACKING QTY.
3,000 PCS REEL
表格編號:034承認書 A
版次:第3版
N
A
M
E
EBLS-201212
SPEC#
10-5 PEELING STRENGTH OF COVER TAPE
Cover tape
7
EBLS2012-101K
(10g~100g)
165°~180°
Test condition
1) peel angle:165°~180° vs carrier tape
2) peel speed:300mm/min
11.PACKAGING
1) Tape & Reel packaging in composite specification 6/8
2) Reel and a bag of desiccant shall be packed in Nylon or plastic bag
3) Maximum of 5 bags shall be packaged in a inner box
4) Maximum of 6 inner box shall be packaged in a outer box
12.Reel Label
Producing the goods label needs to indicate (1 ) Pb Free (2) RoHS Compliant
表格編號:034承認書 A
版次:第3版
N
A
M
E
EBLS-201212
13. STORAGE
SPEC#
8
EBLS2012-101K
13-1The solderability of the external electrode may be
deteriorated if packages are stored where they are
exposed to high humidity. Packages must be stored
at 40℃ or less and 70﹪RH or less.
13-2 The solderability of the external electrode may be
exposed to dust or harmful gas (hydrogen chloride,
sulfurous acid gas or hydrogen sulfide).
13-3 Packaging material may be deformed if packages are
stored where they are exposed to heat or direct sun-
light.
13-4 Minimum packages, such as polyvinyl heat-seal packages
shall not be opened until just before they are used.
If opened, use the reels as soon as possible.
13-5 Solderability specified in composite specification 4/8 shall be
for 6 months from the date of delivery on condition that
they are stored at the environment specified clause
13-1 & 13-2.
For those parts which passed more than 6 months shall
be checked solderability before it is used.
14. Quality System
■ ISO/TS16949
■ IECQ QC 080000
表格編號:034承認書 A
8
很抱歉,暂时无法提供与“EBLS321609-3R3K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31590
- 100+0.25478
- 300+0.22432
- 1000+0.20142
