PRODUCT SPECIFICATION
SPEC. NO:
新弘智
DATE:
T-0602-015H
Nov.27,2018
CUSTOMER'S PRODUCT NAME:
EMTEK PRODUCT NAME:
CMF3216F-M Series
THIS SPECIFICATION IS:
□ FULLY ACCEPTED
□ DENIED
□ ACCEPTED UNDER THE FOLLOWING CONDITIONS
SIGNATURE:
NAME(PRINT):
TITLE:
本文件內容全部或部份,未經兆欣科技股份有限公
司同意不得以任何形式複製或其他用途
All rights reserved.This document or parts thereof,may
not be reproduced by any means or used in any manner
witout written permission of EMTEK CO.,LTD.
DATE:
FACTORY:
39,Chingao Rd.,(305)Hsinpu,
Hsinchu Hsien,Taiwan,R.O.C
TEL: 03-5894-433
FAX: 03-5894-523
1/9
SPEC. NO.
T-0602-015H
1. Scope
This specification applies ferrite Chip common mode filters CMF3216F-M Series
to be delivered to user
2. Product Identification
CMF 3216 F - 900 M - 2P - T
(1) (2) (3) (4) (5) (6) (7)
(1) Product name
(2) Shapes and dimensions
(3) Shielding Type
(4) Impedance【 at 100MHz】
900:90Ω
(5) Impedance Tolerance
M : 20%
(6) Number of Line
2P:2-Line
(7) Taping Type
3. Shapes and Dimensions [Dimensions in mm]
B
A
A : 3.2 ± 0.2
Epoxy
C
B : 1.6 ± 0.2
C : 1.8 ± 0.2
Terminations
Wires
①
④
(0.6)
(0.6)
②
(0.6)
③
Equivalent circuit
①
④
②
③
No Polarity
(0.6)
Drawn by
Checked by
Approved by
2/9
SPEC. NO.
T-0602-015H
4. Electrical Characterisitics
4-1 Electrical Spec.
Common-Mode
DC
Rated Current
Impedance
Resistance
Idc(mA) Max.
Z(Ω) at 100MHz Rdc(Ω) Max.
37 ±20%
CMF3216F-370M-2P-T
0.12
1000
50 ±20%
CMF3216F-500M-2P-T
0.20
500
67 ±20%
CMF3216F-670M-2P-T
0.30
500
Our Product Part
Number
Rated
Voltage
Vdc(V)
Withstanding
Voltage
Vdc(V)
50
50
50
125
125
125
Insulation
Resistance
(MΩ)Min.
10
10
10
CMF3216F-900M-2P-T
90 ±20%
0.30
500
50
125
10
CMF3216F-121M-2P-T
120±20%
0.30
370
50
125
10
CMF3216F-161M-2P-T
160 ±20%
0.40
340
50
125
10
CMF3216F-261M-2P-T
260±20%
0.50
310
50
125
10
CMF3216F-601M-2P-T
600±20%
0.80
260
50
125
10
CMF3216F-102M-2P-T
1000±20%
1.00
230
50
125
10
CMF3216F-222M-2P-T
2200±20%
1.20
200
50
125
10
4-2Characteristics(Reference)
CMF3216F-370M-2P-T
CMF3216F-670M-2P-T
1000
10000
Common mode
Common mode
Differential mode
Differential mode
100
Z (ohm)
Z ( ohm)
1000
100
10
10
1
1
1
10
Frequency(MHz)
100
1
10
100
Frequency(MHz)
1000
CMF3216F-161M-2P-T
CMF3216F-900M-2P-T
10000
0.1
1000
1000
Common Mode
Common Mode
Differential Mode
Differential Mode
Impendance(OHM)
Impedance(OHM)
1000
100
10
1
100
10
1
1
10
100
Frequency(MHz)
1000
1
10
100
Frequency(MHz)
1000
3/9
SPEC. NO.
T-0602-015H
CMF3216F-261M-2P-T
10000
CMF3216F-601M-2P-T
Common Mode
10000
Common Mode
Differential Mode
Differential Mode
1000
Impedance(OHM)
Impedance(OHM)
1000
100
10
100
10
1
1
10
100
1
1000
1
Frequency(MHz)
1000
CMF3216F-222M-2P-T
10000
Common Mode
Common Mode
Differential Mode
Differential Mode
1000
Impedance(OHM)
1000
Impedance(OHM)
100
Frequency(MHz)
CMF3216F-102M-2P-T
10000
10
100
100
10
10
1
1
1
1
10
100
Frequency(MHz)
1000
10
100
Frequency(MHz)
1000
4/9
SPEC. NO.
4-3 Test Equipment
4-3-1 Impedance
Measured by using Agilent E4991A RF Impedance Analyzer.
Measurement terminal
①
④
②
③
4-3-2 DC Resistance
Measured by using Chroma 16502 mill ohm meter.
①
④
②
③
4-3-3 Insulation Resistance
Measured by using Chroma 19073
Measurement voltage : 50v.
①
④
②
③
T-0602-015H
5/9
SPEC. NO.
T-0602-015H
5. Reliability Test
Operating temperature : -25 to +85℃
Specifications
Item
It
can
be
connected
on the
Solder ability
Terminal
strength
Storage temp and humidity : 20~25℃ ,60%RH max.
Test conditions
Apply cream solder to the test circuit board .
Recommendation soldering condition.
It is mounted on the recommendation soldering condition.
The terminal electrode and the ferrite
Solder a chip to test substrate , and then laterally apply a
must not be damaged.
load 0.9Kg in the arrow direction.
φ1.0
Test Board
Strength on The terminal electrode and the ferrite
pc board must not be damaged.
bending
Soldering a chip to a test substrate ,
bend the substrate by 2mm and then return.
45
45
Width side
40
100
10
length
Force
Dimensions in mm
R10
Test board : Glass base epoxy multiplayer board pc board pattern.
PC board pattern : Recommended PC board pattern.
6/9
Specifications
Item
High
Appearance : Ferrite shall not be
temperature damaged.
resistance Impedance : Within ±20% of the
initial value.
insulation resistance: >10(MΩ)
DC resistance : standard value
inside.
Humidity
resistance
Thermal cycle
SPEC. NO.
T-0602-015H
Test conditions
Temperature : +85±2℃
Applied voltage : Rated voltage
Applied current : Rated current
Testing time : 50±12 hours
Measurement : After placing for 24 hours min.
Humidity : 90 to 95%RH
Testing time : 500±12 hours
Temperature : -25℃,+85℃
kept stabilized for 30 minutes each.
Cycle : 5 cycle
1 cycle
+85℃
-25℃
Low
temperature
resistance
Vibration
30 min.
3 min
30 min.
Temperature : -25±2℃
Testing time : 48±12 hours
damaged.
Frequency : 10 to 50 Hz
Amplitude : 1.52 mm
Dimension and times : X ,Y and Z directions
for 2 hours each.
7/9
SPEC. NO.
T-0602-015H
6.Packaging
The packaging must be done not to receive any damage during transporting and storing
6-1 Tape dimensions
Ko
P1
P0
P
W
Bo
t
Ao
( Dimensions in mm; Tolerance:±0.1)
Symbol
Dimension
W
8
P
4
P0
P1
4
2
Ao
1.75
Bo
3.45
Ko
2
t
0.23
6-2 Reel dimensions
D
( Dimensions in mm )
Symbol
C
B
A
B
C
D
E
A
E
6-3 Tapping figure
Top cover tape
Carrier tape
Sprocket hole
Cavity (chip insert)
T
180
60
13
14.4
8.4
8/9
SPEC. NO.
T-0602-015H
6-4 Packaging Form
There shall not continuation more than two vacancies of the product.
(360 mm)
Blank
Leader.
Blank
Chip
(70 pitches)
(50 pitches)
): Reference
Material of carrier tape : Polystyrene
Material of cover tape : Polyester
6-5 Cover Tape Peel Strength
The force for tearing off cover tape is 0.05~0.69(N) in the arrow direction at
the following conditions:
Temperature : 5 ~ 35℃
Humidity : 45 ~ 85%
Atmospheric pressure : 860 ~ 1060 hpa
160 ~ 180。
Top cover tape
Base tape
6-6 Packing Quantity
φ180 mm reel T type : 2000 pcs./reel
9/9
SPEC. NO.
T-0602-015H
7. Recommended Soldering Conditions (Please use this product by reflow soldering)
7-1 Recommended Footprint
Termination Number : Please refer to the equivalent circuit in chapter 3.
0.4
0.6
3.7
1.6
1.05
1.6
7-2 Recommended Reflow Pattern
Reflow : until two times
10sec. Min.
255℃
217℃
Natural cooling
150sec Max..
150℃
60sec. Min.
7-2 Iron Soldering
Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip
directly touch the ferrite body outside of terminal electrode.
5 seconds max. at 260℃.
8. Attention in Case of Using
In case of using product ,please avoid following matters:
Splashing water or salt water
Dew condenses
Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia)
Vibrations or shocks which exceed the specified condition
Please be careful for the stress to this product by board flexure or something
after the mounting.
9. Other
Recommended wire wound inductors should be used within 6 months from the time of delivery.
很抱歉,暂时无法提供与“CMF3216F-102M-2P-T”相匹配的价格&库存,您可以联系我们找货
