CMF4532F-600-2P-Tms
CMF4532F-600-2P-Tms
    EMTEK(兆欣)
    SMD,4.5x3.2mm
    共模电感 SMD,4.5x3.2x2.8mm
CMF4532F-600-2P-Tms 数据手册
PRODUCT SPECIFICATION SPEC. NO: T-0602-141E 新弘智 DATE: Mar.14,2019 CUSTOMER'S PRODUCT NAME: EMTEK PRODUCT NAME: CMF4532F-SERIES-Tms THIS SPECIFICATION IS: □ FULLY ACCEPTED □ DENIED □ ACCEPTED UNDER THE FOLLOWING CONDITIONS SIGNATURE: NAME(PRINT): TITLE: 本文件內容全部或部份,未經兆欣科技股份有限公 司同意不得以任何形式複製或其他用途 All rights reserved.This document or parts thereof,may not be reproduced by any means or used in any manner witout written permission of EMTEK CO.,LTD. DATE: FACTORY: 39,Chingao Rd.,(305)Hsinpu, Hsinchu Hsien,Taiwan,R.O.C TEL: 03-5894-433 FAX: 03-5894-523 1/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-141E 1. Scope This specification applies ferrite Chip common mode filters CMF4532F-Series-Tms to be delivered to user. 2. Product Identification CMF 4532 F - 600 - 2P - Tms (1) (2) (3) (4) (5) (6) (1) Product name (2) Shapes and dimensions (3) Shielding Type (4) Impedance【 at 100MHz】 600:60Ω (5) Number of Line 2P:2-Line (6) For Customer Design 3. Shapes and Dimensions [Dimensions in mm] A:4.5±0.2 B:3.2±0.2 C:2.8±0.2 Drawn by Checked by Approved by 2/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-141E 4. Electrical Characterisitics 4-1 Electrical Spec. Common-Mode Common-Mode DC Rated Rated Withstanding Insulation Our Product Part Number Impedance Resistance Current Voltage Inductance Voltage Resistance Z(Ω) at 100MHz uH at 100KHz Rdc(Ω) Max. Idc(A) Max. Vdc(V) Vdc(V) (MΩ)Min. CMF4532F-600-2P-Tms 60 ±25% 0.05 2.0 50 125 10 CMF4532F-900-2P-Tms 90 ±25% 0.05 2.0 50 125 10 CMF4532F-161-2P-Tms 160 ±25% 0.08 2.0 50 125 10 CMF4532F-231-2P-Tms 230 ±25% 0.10 1.8 50 125 10 CMF4532F-421-2P-Tms 420 ±25% 0.10 1.6 50 125 10 CMF4532F-601-2P-Tms 600 ±25% 0.07 2.8 50 125 10 2.0 ±50% Rated Current Idc : DC current (A) that will cause an approximate △T of 40℃ 4-2 Characteristics (Reference) CMF4532F- 600-2P-Tms 1000 Differential mode Z 100 10 1 1 10 100 1000 Frequency (MHz) CMF4532F-161-2P-Tms 1000 Common mode Z Differential mode Z Impedance(Ω) Impedance(Ω) Common mode Z 100 10 1 1 10 100 Frequency (MHz) 1000 10000 3/9 SPEC. NO. PRODUCT SPECIFICATION 4-2 Characteristics (Reference) CMF4532F-421-2P-Tms 10000 Z (common mode) Z(differential mode) 1000 Z ( ohm) 100 10 1 0.1 1 10 100 1000 Frequency(MHz) 10000 CMF4532F-601-2P-Tms 10000 Z (common mode) Z(differential mode) Impedance( ohm) 1000 100 10 1 1 10 100 Frequency(MHz) 1000 10000 T-0602-141E 4/9 SPEC. NO. PRODUCT SPECIFICATION 4-3 Test Equipment 4-3-1 Impedance Measured by using Agilent E4991A RF Impedance Analyzer. Measurement terminal ① ④ ② ③ 4-3-2 DC Resistance Measured by using Chroma 16502 mill ohm meter. Measurement terminal ① ④ ② ③ Measurement terminal 4-3-3 Insulation Resistance Measured by using Chroma 19073 Measurement voltage : 50v, Measurement time: 60 sec. Measurement terminal ① ④ ② ③ T-0602-141E 5/9 PRODUCT SPECIFICATION SPEC. NO. T-0602-141E 5.Reliability Test Operating temperature : -40 to +125℃ Item Solderability Specifications Storage temp and humidity :-40 to 85℃, 70%RH max. Test conditions It can be connected on the Apply cream solder to the test circuit board . Recommendation soldering It is mounted on the recommendation soldering condition. condition. Terminal strength The terminal electrode and the Solder a chip to test substrate, and then laterally apply a ferrite must not be dam 160±25% load 1.8Kg in the arrow direction. Strength on The terminal electrode and the ferrite must not be damaged. pc board bending Soldering a chip to a test substrate , bend the substrate by 2mm and then return. Test board : Glass base epoxy multiplayer board pc board pattern. PC board pattern : Recommended PC board pattern. 6/9 PRODUCT SPECIFICATION Item Specifications High Appearance : Ferrite shall not be temperature damaged. resistance Impedance: Within ±20% of the SPEC. NO. T-0602-141E Test conditions Temperature : +125±2℃ Applied voltage : Rated voltage Applied current : Rated current initial value. Testing time : 500±12 hours insulation resistance: >10(MΩ) Measurement : After placing for 24 hours min. DC resistance : standard value Humidity resistance inside. Temperature : +85±2℃ Humidity : 90 to 95%RH Applied current : Rated current Applied voltage : Rated voltage Testing time : 500±12 hours Measurement : After placing for 24 hours min. Thermal cycle Temperature : -40℃,+125℃ kept stabilized for 30 minutes each. Cycle : 100 cycle Measurement : After placing for 24 hours min. +125℃ Low temperature resistance Vibration Temperature : -40±2℃ Testing time : 500±12 hours Measurement : After placing for 24 hours min. Appearance : Ferrite shall not be damaged. Frequency : 10 to 50 Hz Amplitude : 1.52 mm Dimension and times : X ,Y and Z directions for 2 hours each. 7/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-141E 6.Packaging The packaging must be done not to receive any damage during transporting and storing 6-1 Tape dimensions 3.0±0.2 6-2 Reel dimensions ( Dimensions in mm ) Symbol T φA φB 180+0,-3 φC 13±0.2 D 2.2±0.5 W 12.0±0.3 t 1.2 R 1 60+1, -0 6-3 Tapping figure Top cover tape Carrier tape Sprocket hole Cavity (chip insert) 8/9 PRODUCT SPECIFICATION SPEC. NO. T-0602-141E 6-4 Packaging Form There shall not continuation more than two vacancies of the product. Material of carrier tape : Polystyrene Material of cover tape : Polyester 6-5 Cover Tape Peel Strength The force for tearing off cover tape is 0.05~0.69(N) in the arrow direction at the following conditions: Temperature : 5 ~ 35℃ Humidity : 45 ~ 85% Atmospheric pressure : 860 ~ 1060 hpa 160 ~ 180。 Top cover tape Base tape 6-6 Packing Quantity φ180 mm reel T type : 500 pcs./reel 9/9 PRODUCT SPECIFICATION SPEC. NO. T-0602-141E 7. Recommended Soldering Conditions (Please use this product by reflow soldering) 7-1 Recommended Footprint 7-2 Recommended Reflow Pattern Reflow: until two times 7-3 Iron Soldering Use a solder iron of less than 30W when soldering, do not allow the soldering iron tip directly tough the ferrite body outside fo terminal electrode. 2 seconds max. at 280℃. 8. Attention in Case of Using In case of using product, please avoid following matters: Splashing water or salt water Dew condenses Toxic gas (Hydrogen sulfide, Sulfurous acid, Chlorine, Ammonia) Vibrations or shocks which exceed the specified condition Please be careful for the stress to this product by board flexure or something after the mounting. *Recommended wire wound inductors should be used within 6 months from the time of delivery.
CMF4532F-600-2P-Tms 价格&库存
很抱歉,暂时无法提供与“CMF4532F-600-2P-Tms”相匹配的价格&库存,您可以联系我们找货
