PRODUCT SPECIFICATION
SPEC. NO:
新弘智
T-0619-002L
DATE: Aug.9,2018
CUSTOMER'S PRODUCT NAME:
EMTEK PRODUCT NAME:
HSC1008-SERIES
THIS SPECIFICATION IS:
□ FULLY ACCEPTED
□ DENIED
□ ACCEPTED UNDER THE FOLLOWING CONDITIONS
SIGNATURE:
NAME(PRINT):
TITLE:
DATE:
FACTORY:
本文件內容全部或部份,未經兆欣科技股份有限公
司同意不得以任何形式複製或其他用途
All rights reserved.This document or parts thereof,may
not be reproduced by any means or used in any manner
witout written permission of EMTEK CO.,LTD.
39,Chingao Rd.,(305)Hsinpu,
Hsinchu Hsien,Taiwan,R.O.C
TEL: 03-5894-433
FAX: 03-5894-523
1/11
SPEC. NO.
T-0619-002L
1. Scope
This specification applies Ceramic Chip Inductance HSC1008-Series
to be delivered to user.
2. Product Identification
HSC 1008 - 10N □ - T
(1) (2) (3) (4) (5)
(1) Product name
(2) Shapes and dimensions
(3) Inductance
10N : 10 nH
(4) Tolerance
G=±2% , J=±5% , K=±10%
(5) Taping Type
3. Shapes and Dimensions
C
B
D
A max. : 2.90 mm
E
B max. : 2.54 mm
A
C max. : 2.03 mm
F
D ref.
E
G
Terminal
Terminal wraparound : Approx.
0.38mm both ends
: 1.30 mm
E:
0.45 ± 0.1 mm
F:
1.60 ± 0.1 mm
G:
2.0 mm
Equivalent circuit
No Polarity
Drawn by
Checked by
Approved by
2/11
SPEC. NO.
T-0619-002L
4. Electrical Characteristics
Customer
Our Product
Inductance
Inductance
Q/MHz
SRF(Min.)
RDC
Irms Max.
Part Number
Part Number
(nH)/MHz
Tolerance
Min.
(MHz)
(Ω)Max.
(mA)
28/500
7500
0.15
600
Yellow Violet Black
50/500
4100
0.08
1000
Brown Black Black
50/500
3300
0.09
1000
Brown
45/500
2500
0.10
1000
Brown Green Black
50/350
2500
0.11
1000
Brown Gray
55/350
2400
0.12
1000
Red
55/350
1600
0.13
1000
Red
60/350
1600
0.14
1000
Orange Orange Black
60/350
1500
0.15
1000
Orange White Black
65/350
1500
0.16
1000
Yellow Violet Black
65/350
1300
0.18
1000
Green
Blue
Black
65/350
1300
0.20
1000
Blue
Gray
Black
60/350
1000
0.22
1000
Gray
Red
Black
60/350
1000
0.56
650
Brown Black Brown
60/350
950
0.63
650
Brown
45/100
850
0.70
580
Brown Green Brown
HSC1008-4N7□-T
4.7/50
HSC1008-10N□-T
10/50
J
K
G
J
Color Coding
1st
2nd
3rd
K
G
HSC1008-12N□-T
12/50
J
Red
Black
K
G
HSC1008-15N□-T
15/50
J
K
G
HSC1008-18N□-T
18/50
J
Black
K
G
HSC1008-22N□-T
22/50
J
Red
Black
K
G
HSC1008-27N□-T
27/50
J
Violet Black
K
G
HSC1008-33N□-T
33/50
J
K
G
HSC1008-39N□-T
39/50
J
K
G
HSC1008-47N□-T
47/50
J
K
G
HSC1008-56N□-T
56/50
J
K
G
HSC1008-68N□-T
68/50
J
K
G
HSC1008-82N□-T
82/50
J
K
G
HSC1008-R10□-T
100/25
J
K
G
HSC1008-R12□-T
120/25
J
Red
Brown
K
G
HSC1008-R15□-T
150/25
J
K
3/11
SPEC. NO.
T-0619-002L
Customer
Part Number
Our Product
Inductance
Inductance
Q/MHz
SRF(Min.)
RDC
Irms Max.
Part Number
(nH)/MHz
Tolerance
Min.
(MHz)
(Ω)Max.
(mA)
Color Coding
HSC1008-R18□-T
180/25
45/100
750
0.77
620
45/100
700
0.84
500
Red
45/100
600
0.91
500
Red
45/100
570
1.05
450
Orange Orange Brown
45/100
500
1.12
470
Orange White Brown
45/100
450
1.19
470
Yellow Violet Brown
45/100
415
1.33
400
Green
Blue
Brown
45/100
375
1.40
300
Blue
Red
Brown
45/100
375
1.47
400
Blue
Gray Brown
45/100
360
1.54
360
Violet Green Brown
45/100
350
1.61
400
Gray
35/50
320
1.68
380
White Brown Brown
35/50
290
1.75
370
Brown Black
Red
35/50
250
2.00
310
Brown
Red
1st
2nd
3rd
G
J
Brown Gray Brown
K
G
HSC1008-R22□-T
220/25
J
Red
Brown
K
G
HSC1008-R27□-T
270/25
J
Violet Brown
K
G
HSC1008-R33□-T
330/25
J
K
G
HSC1008-R39□-T
390/25
J
K
G
HSC1008-R47□-T
470/25
J
K
G
HSC1008-R56□-T
560/25
J
K
G
HSC1008-R62□-T
620/25
J
K
G
HSC1008-R68□-T
680/25
J
K
G
HSC1008-R75□-T
750/25
J
K
G
HSC1008-R82□-T
820/25
J
Red
Brown
K
G
HSC1008-R91□-T
910/25
J
K
G
HSC1008-1R0□-T
1000/25
J
K
G
HSC1008-1R2□-T
1200/7.9
J
K
Red
4/11
SPEC. NO.
T-0619-002L
Customer
Our Product
Inductance
Inductance
Q/MHz
SRF(Min.)
RDC
Irms Max.
Part Number
Part Number
(nH)/MHz
Tolerance
Min.
(MHz)
(Ω)Max.
(mA)
HSC1008-1R5□-T
1500/7.9
28/50
200
2.30
330
Brown Green
Red
28/50
160
2.60
300
Brown Gray
Red
28/50
160
2.80
280
Red
Red
Red
22/25
135
3.20
290
Red
Violet
Red
22/25
110
3.40
290
Orange Orange
Red
20/25
100
3.60
260
Orange White
Red
20/25
90
4.00
260
Yellow Violet
Red
18/7.9
40
4.20
240
Green
Blue
Red
18/7.9
40
4.90
200
Blue
Gray
Red
18/7.9
25
6.00
170
Gray
Red
Red
18/7.9
25
8.00
150
Color Coding
1st
2nd
3rd
G
J
K
G
HSC1008-1R8□-T
1800/7.9
J
K
G
HSC1008-2R2□-T
2200/7.9
J
K
G
HSC1008-2R7□-T
2700/7.9
J
K
G
HSC1008-3R3□-T
3300/7.9
J
K
G
HSC1008-3R9□-T
3900/7.9
J
K
G
HSC1008-4R7□-T
4700/7.9
J
K
G
HSC1008-5R6□-T
5600/7.9
J
K
G
HSC1008-6R8□-T
6800/7.9
J
K
G
HSC1008-8R2□-T
8200/7.9
J
K
G
HSC1008-100□-T
10000/2.5
J
K
Brown Black Orange
5/11
SPEC. NO.
1. All specifications are calibrated with Coilcraft 1008CS series
2. When ordering, please specify tolerance and packaging codes. Ex: HSC1008-R12J-T
Tolerance : G = ±2% , J = ±5% , K = ±10%
Packaging : Clear tape and reel { standard }. *
3. L , Q、SRF : Agilent/HP E4991A+ Agilent/HP16197A
(The electrical specification test by the smallest gap position) or HP16193A
4. Rdc : DIGITAL MILLIOHM METER Chroma 16502, or equivalent.
5. Irms for a 15℃ rise above 25℃ ambient.
6. Operating temperature range from -40℃ to 125℃.
* Parts/Reel: 7” 2,000 Tape Width: 8mm
T-0619-002L
6/11
SPEC. NO.
5. Material list
Item
Material
Core
Al2O3 96%
Wire
Copper wire
Epoxy
UV Eopxy
T-0619-002L
7/11
SPEC. NO.
T-0619-002L
6.Reliability Test
Specifications
Item
Solderability The metalized area must have 90%
minimum solder coverage.
Resistance
to
soldering
heat
Test conditions
Dip pads in flux and dip in solder pot( 96.5 Sn/3.5 Ag
solder) at 255°C ±5°C.
There must be no case deformation or Inductors shall be reflowed onto a PC board using
change in dimensions.
96.5 Sn/3.5 Ag solder paste.
Inductance must not change more than Solder process shall be at a maximum temperature
the stated tolerance.
of 260°C.
For 96.5 Sn/3.5 Ag solder paste:>217°C for 90 seconds
Vibration
There must be no case deformation or Solder specimen inductor on the test printed circuit
board. Apply vibrations in each of the x,y and z
Inductance must not change more than directions for 2 hours for a total of 6 hours.
Frequency : 10~50 Hz
Amplitude
: 1.5mm
There must be no case deformation or Inductors shall be subjected to temperature 125±2℃
High
for 500±12 hours.
temperature change in dimensions.
resistance Inductance must not change more thanMeasure the test items after leaving the inductors at
Static
Humidity
room temperature and humidity for 2 hours.
Inductors must not have a shorted or Inductors shall be subjected to temperature 85±2℃
and 90 to 95%RH. for ten 24-hours.
openwinding.
at room temperature and humidity for 2 hours.
Component Inductors shall be subjected to 1.8Kg Inductors shall be reflow soldered (255°C ±5°C for
10 seconds) to a tinned copper substrate.
adhesion
A force gauge shall be applied to the side of the
(push test)
component.
The device must withstand the stated force
without a failure of the termination.
8/11
SPEC. NO.
T-0619-002L
Specifications
Test conditions
Item
Low
-40±2℃ for 500±12 hours.
than the stated tolerance.
at room temperature and humidity for 1 to 2
hours.
Resistance
to
solvent
There must be no case deformation,
Thermal
shock
There must be no case deformation or Inductors shall be subjected to 10 cycles to the
the following temperature cycle:
Inductors must withstand 6 minutes of alcohol or water.
change in dimensions, or obliteration
of marking.
1 cycle
30 min.
3 min.
+125℃
-40℃
30 min.
9/11
SPEC. NO.
T-0619-002L
7.Packaging
The packaging must be done not to receive any damage during transporting
and storing.
7-1 Tape dimensions
Ko
P1
P0
P
W
Bo
t
Ao
( Dimensions in mm; Tolerance:±0.1)
Symbol
W
P
P0
P1
Ao
Bo
Ko
t
Dimension
8
4
4
2
2.5
2.85
2
0.22
7-2 Reel dimensions
D
( Dimensions in mm )
Symbol
T
C B
A
A
B
180
C
13
D
14.4
E
8.4
E
7-3 Tapping figure
Top cover tape
Carrier tape
Sprocket hole
Cavity (chip insert)
60
10/11
SPEC. NO.
T-0619-002L
7-4 Packaging Form
There shall not continuation more than two vacancies of the product.
(360 mm)
Leader.
Blank
(50 pitches)
Chip
Blank
(70 pitches)
7-5 Cover Tape Peel Strength
The force for tearing off cover tape is 0.1~0.6(N) in the arrow direction at the following conditions:
Temperature : 5 ~ 35℃
Humidity : 45 ~ 85%
Atmospheric pressure : 860 ~ 1060 hpa
160 ~ 180。
Top cover tape
Base tape
7-6 Packing Quantity
φ180 mm reel type : 2,000 pcs./reel
11/11
SPEC. NO.
T-0619-002L
8. Recommended Soldering Conditions
(Please use this product by reflow soldering)
8-1 Recommended Footprint
1.02
1.27
1.02
2.54
Unit: mm
8-2 Recommended Reflow Pattern
Reflow : until two times
10sec. Max.
255℃
217℃
Natural cooling
150sec. Max.
150℃
60sec. Min.
8-3 Iron Soldering
Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip
directly touch the Ceramic body outside of terminal electrode.
5 seconds max. at 260℃.
9. Attention in Case of Using
In case of using product ,please avoid following matters:
Splashing water or salt water
Dew condenses
Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia)
Vibrations or shocks which exceed the specified condition
Please be careful for the stress to this product by board flexure or something after the mounting.
10. Others
10-1 Operating temperature range
: Ceramic Series :-40~+125℃
10-2 Storage condition
: Temperature 20°~25℃﹐Relative Humidity 40%~60%
10-3 Recommended wire wound inductors should be used within 6 months from the time of delivery.
很抱歉,暂时无法提供与“HSC1008-22NJ-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.19719
- 50+0.10494
- 150+0.04583
- 500+0.04085
- 2500+0.03688
- 5000+0.03488
