PRODUCT SPECIFICATION
SPEC. NO: T-0634-002J
新弘智
DATE: Jul.26,2018
CUSTOMER'S PRODUCT NAME:
EMTEK PRODUCT NAME:
BLN2012-500-2P-T
THIS SPECIFICATION IS:
□ FULLY ACCEPTED
□ DENIED
□ ACCEPTED UNDER THE FOLLOWING CONDITIONS
SIGNATURE:
NAME(PRINT):
TITLE:
本文件內容全部或部份,未經兆欣科技股份有限公
司同意不得以任何形式複製或其他用途
All rights reserved.This document or parts thereof,may
not be reproduced by any means or used in any manner
witout written permission of EMTEK CO.,LTD.
DATE:
FACTORY:
39,Chingao Rd.,(305)Hsinpu,
Hsinchu Hsien,Taiwan,R.O.C
TEL: 03-5894-433
FAX: 03-5894-523
1/9
SPEC. No.
T-0634-002J
1. Scope
This specification applies Wire Wound Micro Chip Transformer BLN2012-500-2P-T to be delivered to user.
1-1 Features
1. BLN2012-500-2P-T is Wire Wound chip Transformer developed for high speed
differential signal interfaces.
2. BLN2012-500-2P-T suppress the radiated emission without the dstortion of
differential signal.
2. Product Identification
BLN 2012 - 500 - 2P - T
(1) (2) (3) (4) (5)
(1) Product name
(2) Shapes and dimensions
(3) Impedance:500: 50Ω
(4) Number of Line:2P: 2-Line
(5) Taping Type
3. Shapes and Dimensions
Drawn by
Checked by
Approved by
2/9
SPEC. No.
T-0634-002J
4. Equivalent Circuit
5. Electrical Characterisitcs
5-1 Electrical Spec.
Our Product
Part Number
Frequency
range
(MHz)
Blance
/Unbalance
Impedance(Ω)
DC
resistance
(Ω) max.
(1 line)
BLN2012-500-2P-T
40 to 860
50
0.85
Operating temperature range : -25deg.C.~+85deg.C.
BLN2012-500-2P-T
10000
Z (common mode)
Z(differential mode)
Z (ohm)
1000
100
10
1
1
10
100
1000
Frequency(MHz)
10000
Insertion
Loss(dB)
174MHz
Insertion
Loss(dB)
860MHz
0.4(dB)typ. 0.7(dB)typ.
CMRR
(dB)
Typ.
Rated
Rated
Insulation
Current
Voltage
Resistance
DC(mA)
DC(V)max. (MΩ) min.
max.
100
10
10
3/9
SPEC. No.
Insertion Loss(Reference)
CMRR(Reference)
T-0634-002J
4/9
SPEC. No.
5-2 Test Equipment
5-2-1 Impedance
Measured by using Agilent E4991A RF Impedance Analyzer.
5-2-2 DC Resistance
Measured by using Chroma 16502 mill ohm meter.
5-2-3 Insulation Resistance
Measured by using Chroma 19073
Measurement voltage : 50V
T-0634-002J
5/9
SPEC. No.
T-0634-002J
6. Reliability Test
Operating temperature : -25 to +85℃
Item
Solder ability
Storage temp and humidity : 20~25℃
60%RH max.
Test conditions
Specifications
It can be connected on the
Recommendation soldering
condition.
Apply cream solder to the test circuit board .
It is mounted on the recommendation soldering
condition.
Terminal
strength
The terminal electrode and the
ferrite must not be damaged.
Solder a chip to test substrate , and then laterally
apply a load 0.5Kg in the arrow direction.
Strength on
PC Board
bending
Soldering a chip to a test substrate ,
bend the substrate by 2mm and then return.
45
45
Width side
40
100
length
6/9
SPEC. No.
Item
Specifications
10
T-0634-002J
Test conditions
Force
Dimensions in mm
R10
Test board : Glass base epoxy multiplayer board pc board pattern.
PC board pattern : Recommended PC board pattern.
High
temperature
resistance
Humidity
resistance
Thermal cycle
Appearance : Ferrite shall not be
damaged.
Impedance : Within ±20% of the
initial value.
insulation resistance: >10(MΩ)
DC resistance : standard value
inside.
Temperature : +85±2℃
Applied voltage : Rated voltage
Applied current : Rated current
Testing time : 50±12 hours
Measurement : After placing for 24 hours min.
Humidity : 40 to 60%RH
Testing time : 500±12 hours
Temperature : -25℃,+85℃
kept stabilized for 30 minutes each.
Cycle : 5 cycle
1 cycle
+85℃
-25℃
30 min.
3 min.
30 min.
7/9
SPEC. No.
Item
Specifications
Test conditions
Low
temperature
resistance
Vibration
T-0634-002J
Temperature : -25±2℃
Testing time : 48±12 hours
damaged.
Frequency : 10 to 50 Hz
Amplitude : 1.52 mm
Dimension and times : X ,Y and Z directions
for 2 hours each.
7. Packaging
The packaging must be done not to receive any damage during transporting and storing.
7-1 Tape dimensions
Ko
P1
P0
P
W
Bo
t
Ao
( Dimensions in mm; Tolerance:±0.1)
Symbol
Dimension
W
8
P0
4
P
4
P1
2
Ao
1.6
Bo
2.42
Ko
1.14
t
0.22
7-2 Reel dimensions
D
( Dimensions in mm )
Symbol
C
B
A
B
C
D
E
A
E
T
180
60
13
14.4
8.4
8/9
SPEC. No.
T-0634-002J
7-3 Tapping figure
Top cover tape
Carrier tape
Sprocket hole
Cavity (chip insert)
7-4 Packaging Form
There shall not continuation more than two vacancies of the product.
Material of carrier tape : Polystyrene
Material of cover tape : Polyester
7-5 Cover Tape Peel Strength
The force for tearing off cover tape is 0.05~0.69(N) in the arrow direction at the following conditions:
Temperature : 5 ~ 35℃
Humidity : 45 ~ 85%
Atmospheric pressure : 860 ~ 1060 hpa
7-6 Packing Quantity
φ180 mm reel T type : 2000 pcs./reel
9/9
SPEC. No.
T-0634-002J
8. Recommended Soldering Conditions
(Please use this product by reflow soldering)
8-1 Recommended Footprint
0.4
0.4
Termination Number : Please refer to the equivalent circuit in chapter 3.
2.6
1.2
0.8
1.0
Unit : mm
8-2 Recommended Reflow Pattern
Reflow : until two times.
10sec. Max.
255℃
217℃
Natural cooling
150℃
150sec Max..
60sec. Min.
8-3 Iron Soldering
Use a solder iron of less than 30W when soldering, do not allow the soldering iron tip directly touch
the ferrite body outside of terminal electrode.
4 seconds max. at 260℃.
9. Attention in Case of Using
In case of using product ,please avoid following matters:
Splashing water or salt water
Dew condenses
Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia)
Vibrations or shocks which exceed the specified condition
Please be careful for the stress to this product by board flexure or something after the mounting.
10. Other
Recommended wire wound inductors should be used within 6 months from the time of delivery.
很抱歉,暂时无法提供与“BLN2012-500-2P-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.07126
- 50+0.84262
- 150+0.74466
- 500+0.62241
- 2500+0.56798
- 5000+0.53525
