CMF2012F Series
Common Mode SMD Filter for Signal Line
FEATURES
• This common mode filter is characterized by its
small sized
• Highly effective in noise suppression. High
common-mode impedance at noise band and low
differential-mode impedance at signal band.
• Due to the low differential-mode impedance with
high coupling factor, there is almost no distortion
PRODUCT IDENTIFICATION
on high speed signal.
• This series is micro-produced by auto machines
for its huge productivity and accuracy with
all-day CCD inspection.
CMF 2012 F - 900 - 2P - T
(1)
(2)
(3)
(4)
(5)
(6)
(1) Product name
(2) Shapes and Dimensions
APPLICATIONS
(3) Shielding type
• Used for noise suppression in any electronic
(4) Impedance[at 100MHz]
devices such as personal computer and peripheral
121:120Ω
equipment (USB), amusement equipment (IEEE 1394), (5) Number of line
LCD panels (LVDS) etc.
2P:2-Line
(6) Taping style
SHAPES AND DIMENSIONS
RECOMMENDED FOOTPRINT
(0.4)
1.2 ± 0.2
1.2 ± 0.2
2.0 ± 0.2
0.8
1.0
0.8
0.4*3
(0.4)
(0.45)
(0.45)
Unit:mm
ELECTRICAL CHARACTERISTICS
Our Product Part Number
CMF2012F-300-2P-T
CMF2012F-400-2P-T
CMF2012F-670-2P-T
CMF2012F-750-2P-T
CMF2012F-900-2P-T
CMF2012F-121-2P-T
CMF2012F-161-2P-T
CMF2012F-181-2P-T
CMF2012F-201-2P-T
CMF2012F-221-2P-T
CMF2012F-261-2P-T
CMF2012F-371-2P-T
CMF2012F-601-2P-T
CMF2012F-670-2P-T
CMF2012F-901-2P-T
CMF2012F-102-2P-T
CMF2012F-222-2P-T
Common-Mode
Impedance
Z(Ω) at 100MHz
30 ±25%
40 ±25%
67 ±25%
75 ±25%
90 ±25%
120±25%
160±25%
180±25%
200±25%
220±25%
260±25%
370±25%
600±25%
670±25%
900±25%
1000±25%
2200±25%
DC
Rated Current Rated Voltage
Resistance
Idc(mA) Max.
Vdc(V)
Rdc(Ω) Max.
0.20
450
50
0.12
500
50
0.25
400
50
0.30
400
50
0.30
400
50
0.30
370
50
0.30
340
50
0.35
330
50
0.35
330
50
0.35
330
50
0.40
300
50
0.40
280
50
0.375
250
50
0.60
150
50
0.80
120
50
0.80
100
50
0.14
100
50
Insulation
Resistance
(MΩ)Min.
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
CMF2012F Series
Characteristics(Impedance vs. Frequency)
CMF2012F-400-2P-T
CMF2012F-300-2P-T
1000
1000
Common Mode
Differential Mode
100
Impedance(Ω)
Impedance(Ω)
100
10
10
Common Mode
Differential Mode
1
1
0.1
1
0.1
1
10
100
Frequency(MHz)
1000
Frequency(MHz)
1000
Common Mode
Common Mode
Differential Mode
Differential Mode
100
Impedance(OHM)
Impedance(OHM)
100
10
1
10
1
0.1
0.1
1
10
100
Frequency(MHz)
1000
CMF2012F-121-2P-T
1000
Common Mode
Differential Mode
100
Impendance(OHM)
100 1000
CMF2012F-900-2P-T
CMF2012F-670-2P-T
1000
10
10
1
0.1
1
10
100
Frequency(MHz)
1000
1
10
100
Frequency(MHz)
1000
CMF2012F Series
CMF2012F-181-2P-T
10000
Common Mode
Common Mode
Differential Mode
Differential Mode
Impedance(OHM)
1000
Impedance(OHM)
CMF2012F-201-2P-T
1000
100
10
100
10
1
0.1
1
1
10
100
Frequency(MHz)
1000
1
10
100
1000
Frequency(MHz)
CMF2012F-221-2P-T
CMF2012F-261-2P-T
10000
Common Mode
10000
Differential Mode
1000
Differential Mode
1000
Impedance(OHM)
Impedance(OHM)
Common Mode
100
100
10
10
1
1
0.1
1
10
100
Frequency(MHz)
1000
1
10
100
Frequency(MHz)
1000
CMF2012F-371-2P-T
10000
Common Mode
CMF2012F-601-2P-T
10000
Common mode
Differential Mode
Differential mode
1000
Impedance(OHM)
Impedance(OHM)
1000
100
100
10
10
1
1
0.1
1
1
10
100
Frequency(MHz)
1000
10
100
Frequency(MHz)
1000
CMF2012F Series
很抱歉,暂时无法提供与“CMF2012F-102-2P-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.76486
- 10+0.60934
- 30+0.53158
