CMF4532LC-101-2P-T
CMF4532LC-101-2P-T
    EMTEK(兆欣)
    SMD,4.5x3.2x2.7mm
CMF4532LC-101-2P-T 数据手册
PRODUCT SPECIFICATION SPEC. NO: T-0602-171A 新弘智 DATE: Aug.7,2018 CUSTOMER'S PRODUCT NAME: EMTEK PRODUCT NAME: CMF4532LC-Series AEC-Q200 THIS SPECIFICATION IS: □ FULLY ACCEPTED □ DENIED □ ACCEPTED UNDER THE FOLLOWING CONDITIONS SIGNATURE: NAME(PRINT): TITLE: 本文件內容全部或部份,未經兆欣科技股份有限公 司同意不得以任何形式複製或其他用途 All rights reserved.This document or parts thereof,may not be reproduced by any means or used in any manner witout written permission of EMTEK CO.,LTD. DATE: FACTORY: 39,Chingao Rd.,(305)Hsinpu, Hsinchu Hsien,Taiwan,R.O.C TEL: 03-5894-433 FAX: 03-5894-523 1/8 SPEC. NO. PRODUCT SPECIFICATION AEC-Q200 T-0602-171A 1. Scope This specification applies ferrite Chip common mode filters CMF4532LC-Series to be delivered to user. 2. Product Identification CMF 4532 LC - 101 - 2P - T (1) (2) (3) (4) (5) (6) (1) Product name (2) Shapes and dimensions (3) Automotive (4) Inductance【 at 100KHz】 101:100Ω (5) Number of Line 2P:2-Line (6) For Customer Design 3. Shapes and Dimensions [Dimensions in mm] A:4.5 ± 0.2 mm B:3.2 ± 0.2 mm C:2.7 ± 0.2 mm D:0.25 ± 0.1 mm E :1.2 Typ. mm F :1.0 Typ. mm Drawn by Checked by Approved by 2/8 SPEC. NO. PRODUCT SPECIFICATION AEC-Q200 T-0602-171A 4. Electrical Characterisitics 4-1 Electrical Spec. Our Product Part Number Z(Ω) Common Mode Impedance at 10MHz L(uH) Common Mode Inductance at 100KHz min. 300 (+50%/-30%) typ. 600 11 min. 500 (+50%/-30%) typ. 1200 22 min. 1000 (+50%/-30%) typ. 2800 51 min. 2000 (+50%/-30%) typ. 5800 100 DCR(Ω) Max. Idc(mA) Max. Rated Voltage Vdc (V)Typ. Withstand Voltage Vdc(V) Insulation Resistance IR (MΩ)Min. 0.6 250 50 125 10 1.0 200 50 125 10 1.0 200 50 125 10 2.0 150 50 125 10 4.5 100 50 125 10 CMF4532LC-110-2P-T CMF4532LC-220-2P-T CMF4532LC-510-2P-T CMF4532LC-101-2P-T min. (+50%/-30%) typ. 200 CMF4532LC-201-2P-T Operating temperature:-40 to 125℃ Storage temp. and humidity:-40 to +85℃,70%RH max 4-2Characteristics(Reference) 4-2-1 Z v.s. Freq. CMF4532LC-220-2P-T 10000 Common mode Z Differential mode Z 1000 Impedance(Ω) 100 10 1 1 10 100 1000 100 1000 0.1 Frequency (MHz) CMF4532LC-510-2P-T 100000 Common mode Z Differential mode Z Impedance(Ω) 10000 1000 100 10 1 1 10 Frequency (MHz) 3/8 SPEC. NO. PRODUCT SPECIFICATION AEC-Q200 T-0602-171A 4-2Characteristics(Reference) 4-2-1 Z v.s. Freq. CMF4532LC-101-2P-T 100000 Common mode Z Differential mode Z Impedance(Ω) 10000 1000 100 10 1 1 10 100 1000 Frequency (MHz) CMF4532LC-201-2P-T 100000 Common mode Z Differential mode Z Impedance(Ω) 10000 1000 100 10 1 1 10 100 Frequency (MHz) 1000 10000 4/8 SPEC. NO. PRODUCT SPECIFICATION AEC-Q200 4-3 Test Equipment 4-3-1 Inductance Measured by using Agilent HP4284A Precision LCR Meter. Measurement terminal ① ④ ② ③ 4-3-2 DC Resistance Measured by using Chroma 16502 mill ohm meter. Measurement terminal ① ④ ② ③ Measurement terminal 4-3-3 Insulation Resistance Measured by using Chroma 19073 Measurement voltage : 50v ,Measurement time:60 sec. Measurement terminal ① ④ ② ③ T-0602-171A 5/8 SPEC. NO. PRODUCT SPECIFICATION AEC-Q200 T-0602-171A 5.Reliability Test Operating temperature : -40 to +125℃ Item Board Flex Terminal strength Specifications The forces applied on the right conditions must not damage the terminal electrode and the ferrite. The chip must not damage the terminal electrode and the ferrite. Storage temp and humidity : 20~25℃ ,60%RH max. Test conditions Test device shall be soldered on the substrate Substrate Dimension: 100x40x1.6mm Deflection: 2.0mm Keeping Time: 60 sec Appendix 1 Note(AEC-Q200-006):Force of 1.8 kg for 60 seconds. Solderability The electrodes shall be at least 95% covered with new solder coating. Pre-heating: 150 ℃, 1min Solder Composition: Sn/3.0Ag/0.5Cu Solder Temperature: 255±5 ℃ Immersion Time: 4±1sec Resistance to Appearance:No damage Inductance change shall Soldering be within ±20%. Heat Pre-heating: 150℃ , 1min Solder Composition: Sn/Ag3.0/Cu0.5 Solder Temperature: 255±5℃ Immersion Time: 10±1sec Resistance to There must be no change in appearance or obliteration of Solvents marking. lnductors must withstand 6 minutes of alcohol or water. Mechanical Shock Pulse shape:Half-sine waveform lmpact acceleration:100g Pulse duration : 6ms Number of shocks: 18 shocks ( 3 shocks for each face) Orientation:Bottom,top,left,right,front and rear faces The forces applied on the right conditions must not damage the terminal electrode and the ferrite. 6/8 SPEC. NO. PRODUCT SPECIFICATION AEC-Q200 Item Specifications Vibration Appearance:No damage Inductance change shall be within ±20%. High Temperature Exposure Appearance:No damage (for microscope of MEIJI WF10X/22) Inductance change shall be within ±30%. T-0602-171A Test conditions Vibration waveform: Sine waveform Vibration frequency: 10Hz~2000Hz Vibration acceleration: 5g Sweep rate: 0.764386otcave/minute Duration of test: 12 cycles each of 3 orientations 20 minutes for each cycle Vibration axes: X, Y & Z Temperature: 125±3℃ Time:1000hrs Measured after exposure in the room condition for 24hrs (Storage) Biased Humidity Temperature: 85±2℃ Relative Humidity: 85% Time: 1000hrs Measured after exposure in the room condition for 24hrs Operational Life Temperature : 125±2℃ Appliend Current : Rated Current Time :1000±24 hrs Measured after exposure in the room condition for 24 hrs Temperature Cycling Total cycles: 1000 cycles Temperature Cycling Test Conditions : -40 to +125℃ Soak Mode Condition : 30 minutes Measured after exposure in the room condition for 24hrs 7/8 SPEC. NO. PRODUCT SPECIFICATION AEC-Q200 T-0602-171A 6. Reel Dimension & Tape Dimension 6-1 Reel Dimensions Unit: mm C D 13.2±0.5 B 60±2 13±0.5 180±2 D 1.50 D1 1.50 Po 4.00 10Po 40.00 ±0.1 ±0.1 ±0.2 A 6-2 Tape Dimensions Symbol Dimension W 12.00 P 8.00 E 1.75 F 5.50 P2 2.00 SPEC. ±0.1 ±0.1 ±0.1 ±0.05 ±0.05 Symbol Dimension SPEC. Ao 3.57 ±0.1 Bo 4.80 ±0.1 Ko 2.80 ±0.1 t 0.30 ±0.05 +0.10 -0.00 8/8 SPEC. NO. PRODUCT SPECIFICATION AEC-Q200 6-3 Packaging Quantity 500pcs/reel 7. Equivalent Circuit & Recommened Footprint T-0602-171A
CMF4532LC-101-2P-T 价格&库存
很抱歉,暂时无法提供与“CMF4532LC-101-2P-T”相匹配的价格&库存,您可以联系我们找货
