HQC0805-15NJ-T
HQC0805-15NJ-T
    EMTEK(兆欣)
    IND_2.4X1.65MM_SM
    15NH ±5%
HQC0805-15NJ-T 数据手册
PRODUCT SPECIFICATION SPEC. NO: T-0621-002P DATE: Aug.21,2018 CUSTOMER'S PRODUCT NAME: EMTEK PRODUCT NAME: HQC0805-Series THIS SPECIFICATION IS: □ FULLY ACCEPTED □ DENIED □ ACCEPTED UNDER THE FOLLOWING CONDITIONS SIGNATURE: NAME(PRINT): TITLE: DATE: FACTORY: 本文件內容全部或部份,未經兆欣科技股份有限公 司同意不得以任何形式複製或其他用途 All rights reserved.This document or parts thereof,may not be reproduced by any means or used in any manner witout written permission of EMTEK CO.,LTD. 39,Chingao Rd.,(305)Hsinpu, Hsinchu Hsien,Taiwan,R.O.C TEL: 03-5894-433 FAX: 03-5894-523 1/9 SPEC. NO. PRODUCT SPECIFICATION T-0621-002P 1. Scope This specification applies Ceramic Chip Inductance HQC0805-Series to be delivered to user. 2. Product Identification HQC 0805 - 12N □ - T (1) (2) (3) (4) (5) (1) Product name (2) Shapes and dimensions (3) Inductance 12N : 12 nH (4) Tolerance G=±2% , J=±5% , K=±10% (5) Taping Type 3. Shapes and Dimensions A max. : 2.40 mm B max. : 1.65 mm C max. : 1.45 mm D ref. E: : 0.65 mm 0.44 mm Equivalent circuit No Polarity Drawn by Checked by Approved by 2/9 SPEC. NO. PRODUCT SPECIFICATION T-0621-002P 4. Electrical Characteristics Customer Our Product Inductance Inductance Q/MHz SRF(Min.) DCR Irms Max. Part Number Part Number (nH)/MHz Tolerance Min. (MHz) (Ω)Max. (mA) Color Coding HQC0805-2N5□-T 2.5/250 J 60/1500 >6000 0.030 1600 Black 98/1500 >6000 0.035 1600 Brown 70/1000 4750 0.035 1600 Red 75/1000 3000 0.050 1600 Gray 80/1000 3000 0.050 1600 Orange 72/500 2950 0.080 1500 White 72/500 2950 0.060 1500 Yellow 75/500 2550 0.065 1400 Green 70/500 2050 0.065 1400 Blue 70/500 2050 0.075 1400 Red 75/500 2000 0.075 1300 Violet 65/500 1950 0.095 1200 Gray 65/500 1800 0.100 1200 Orange 65/500 1600 0.100 1100 White 65/500 1500 0.110 1100 Yellow 65/500 1400 0.105 1200 Green 65/500 1400 0.100 1200 Black K HQC0805-5N6□-T 5.6/250 J K HQC0805-6N2□-T 6.2/250 J K HQC0805-10N□-T 10/250 J K G HQC0805-12N□-T 12/250 J K G HQC0805-15N□-T 15/250 J K G HQC0805-16N□-T 16/250 J K G HQC0805-18N□-T 18/250 J K G HQC0805-20N□-T 20/250 J K G HQC0805-22N□-T 22/250 J K G HQC0805-27N□-T 27/250 J K G HQC0805-30N□-T 30/250 J K G HQC0805-33N□-T 33/250 J K G HQC0805-39N□-T 39/250 J K G HQC0805-43N□-T 43/200 J K G HQC0805-47N□-T 47/200 J K G HQC0805-48N□-T 48/200 J K 3/9 SPEC. NO. PRODUCT SPECIFICATION T-0621-002P 4. Electrical Characteristics Customer Our Product Inductance Inductance Q/MHz SRF(Min.) DCR Irms Max. Part Number Part Number (nH)/MHz Min. (MHz) (Ω)Max. (mA) HQC0805-51N□-T 51/200 Tolerance G J K Color Coding 65/500 1400 0.120 1000 Brown HQC0805-56N□-T 56/200 65/500 1400 0.16 900 Blue 65/500 1400 0.20 800 Red 55/500 1300 0.29 700 Black 55/250 1300 0.510 700 Red 55/250 1300 0.540 650 Green 55/250 1300 0.600 600 Gray G J K HQC0805-82N□-T 82/200 J K HQC0805-R10□-T 100/150 J K HQC0805-R12□-T 120/150 J K HQC0805-R15□-T 150/100 J K HQC0805-R18□-T 180/100 J K 1. When ordering, please specify tolerance and packaging codes. Ex: HQC0805-12NJ-T Tolerance : G = ±2% , J = ±5% , K = ±10% Packaging : Clear tape and reel { standard }. 1st Code 2. L , Q、SRF : Agilent/HP E4991A+ Agilent/HP16197A (The electrical specification test by the smallest gap position) or HP16193A 3. Rdc : DIGITAL MILLIOHM METER Chroma 16502, or equivalent. 4. Irms for a 15℃ rise above 25℃ ambient. 5. Operating temperature range from -40℃ to 125℃. COLOR CODING 4/9 SPEC. NO. PRODUCT SPECIFICATION 5. Material list Item Core Wire Epoxy Material Al2O3 96% Copper wire UV Eopxy T-0621-002P 5/9 SPEC. NO. PRODUCT SPECIFICATION T-0621-002P 6.Reliability Test Specifications Item Solderability The metalized area must have 90% minimum solder coverage. Resistance to soldering heat Test conditions Dip pads in flux and dip in solder pot( 96.5 Sn/3.5 Ag solder) at 255°C ±5°C. There must be no case deformation or Inductors shall be reflowed onto a PC board using change in dimensions. 96.5 Sn/3.5 Ag solder paste. Inductance must not change more than Solder process shall be at a maximum temperature the stated tolerance. of 260°C. For 96.5 Sn/3.5 Ag solder paste:>217°C for 90 seconds Vibration There must be no case deformation or Solder specimen inductor on the test printed circuit board. Apply vibrations in each of the x,y and z change in dimensions. Inductance must not change more than directions for 2 hours for a total of 6 hours. the stated tolerance. Frequency : 10~50 Hz Amplitude : 1.5mm There must be no case deformation or Inductors shall be subjected to temperature 125±2℃ High for 50±12 hours. temperature change in dimensions. resistance Inductance must not change more thanMeasure the test items after leaving the inductors at the stated tolerance. Static Humidity room temperature and humidity for 2 hours. Inductors must not have a shorted or Inductors shall be subjected to temperature 85±2℃ and 90 to 95%RH. for ten 24-hours. openwinding. Measure the test items after leaving the inductors at room temperature and humidity for 2 hours. Component Inductors shall be subjected to 1.8Kg Inductors shall be reflow soldered (255°C ±5°C for 10 seconds) to a tinned copper substrate. adhesion A force gauge shall be applied to the side of the (push test) component. The device must withstand the stated force without a failure of the termination. 6/9 SPEC. NO. PRODUCT SPECIFICATION T-0621-002P Specifications Test conditions Item There must be no case deformation or Inductors shall be subjected to temperature Low -40±2℃ for 48±12 hours. temperature change in dimensions. Measure the test items after leaving the inductors resistance Inductance must not change more than the stated tolerance. at room temperature and humidity for 1 to 2 hours. Resistance to solvent There must be no case deformation, Thermal shock There must be no case deformation or Inductors shall be subjected to 10 cycles to the the following temperature cycle: change in dimensions. Inductors must withstand 6 minutes of alcohol or water. change in dimensions, or obliteration of marking. Inductance must not change more than the stated tolerance. 1 cycle 30 min. 30 sec +125℃ -40℃ 30 min. Measure the test items after leaving the inductors at room temperature and humidity for 2 hours. 7/9 SPEC. NO. PRODUCT SPECIFICATION T-0621-002P 7.Packaging The packaging must be done not to receive any damage during transporting and storing. 7-1 Tape dimensions Ko P1 P0 P W Bo t Ao ( Dimensions in mm; Tolerance:±0.1) Symbol W P P0 P1 Ao Bo Ko t Dimension 8 4 4 2 1.57 2.28 1.4 0.22 7-2 Reel dimensions D ( Dimensions in mm ) C B Symbol T A B 180 C 13 D 14.4 E 8.4 A E 7-3 Tapping figure Top cover tape Carrier tape Sprocket hole Cavity (chip insert) 60 8/9 SPEC. NO. PRODUCT SPECIFICATION T-0621-002P 7-4 Packaging Form There shall not continuation more than two vacancies of the product. (360 mm) Leader. Blank (50 pitches) Chip Blank (70 pitches) 7-5 Cover Tape Peel Strength The force for tearing off cover tape is 0.1~0.6(N) in the arrow direction at the following conditions: Temperature : 5 ~ 35℃ Humidity : 45 ~ 85% Atmospheric pressure : 860 ~ 1060 hpa 160 ~ 180。 Top cover tape Base tape 7-6 Packing Quantity φ180 mm reel type : 2,000 pcs./reel 9/9 SPEC. NO. PRODUCT SPECIFICATION T-0621-002P 8. Recommended Soldering Conditions (Please use this product by reflow soldering) 8-1 Recommended Footprint 1.02 0.76 1.02 1.78 Unit: mm 8-2 Recommended Reflow Pattern Reflow : until two times 10sec. Min. 255℃ 217℃ Natural cooling 150sec. Max. 150℃ 60sec. Min. 8-3 Iron Soldering Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip directly touch the Ceramic body outside of terminal electrode. 5 seconds max. at 260℃. 9. Attention in Case of Using In case of using product ,please avoid following matters: Splashing water or salt water Dew condenses Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia) Vibrations or shocks which exceed the specified condition Please be careful for the stress to this product by board flexure or something after the mounting. 10. Others 10-1 Operating temperature range : Ceramic Series :-40~+125℃ 10-2 Storage condition : Temperature 20°~25℃﹐Relative Humidity 40%~60% 10-3 Recommended wire wound inductors should be used within 6 months from the time of delivery.
HQC0805-15NJ-T 价格&库存
很抱歉,暂时无法提供与“HQC0805-15NJ-T”相匹配的价格&库存,您可以联系我们找货
HQC0805-15NJ-T
    • 5+0.29578
    • 50+0.15738
    • 150+0.06875
    • 500+0.06127
    • 2000+0.05530
    • 4000+0.05232
    库存:1413
