CMF4532F-601-2P-T
CMF4532F-601-2P-T
    EMTEK(兆欣)
    共模电感 1812
CMF4532F-601-2P-T 数据手册
PRODUCT SPECIFICATION SPEC. NO: T-0602-102D 新弘智 DATE: Nov.27,2018 CUSTOMER'S PRODUCT NAME: EMTEK PRODUCT NAME: CMF4532F-Series THIS SPECIFICATION IS: □ FULLY ACCEPTED □ DENIED □ ACCEPTED UNDER THE FOLLOWING CONDITIONS SIGNATURE: NAME(PRINT): TITLE: 本文件內容全部或部份,未經兆欣科技股份有限公 司同意不得以任何形式複製或其他用途 All rights reserved.This document or parts thereof,may not be reproduced by any means or used in any manner witout written permission of EMTEK CO.,LTD. DATE: FACTORY: 39,Chingao Rd.,(305)Hsinpu, Hsinchu Hsien,Taiwan,R.O.C TEL: 03-5894-433 FAX: 03-5894-523 1/8 SPEC. NO. PRODUCT SPECIFICATION T-0602-102D 1. Scope This specification applies ferrite Chip common mode filters CMF4532F-Series to be delivered to user. 2. Product Identification CMF 4532 F - 601 - 2P - T (1) (2) (3) (4) (5) (6) (1) Product name (2) Shapes and dimensions (3) Application (4) Impedance【 at 100MHz】 601:600Ω (5) Number of Line 2P:2-Line (6) Taping Type 3. Shapes and Dimensions [Dimensions in mm] A B Epoxy C A:4.5 ± 0.2 mm B:3.2 ± 0.2 mm C:2.8 ± 0.2 mm D1:1.0 ± 0.1 mm D2:1.2 ± 0.1 mm Termination Wires (D2) (D2) (D1) (D1) Drawn by Checked by Approved by 2/8 SPEC. NO. PRODUCT SPECIFICATION T-0602-102D 4. Electrical Characterisitics 4-1 Electrical Spec. Our Product Part Number Common-Mode Impedance Z(Ω) at 100MHz CMF4532F-601-2P-T 600±25% 0.24 50 CMF4532F-801-2P-T 800±25% 0.26 CMF4532F-102-2P-T 1000±25% CMF4532F-142-2P-T 1400±25% CMF4532F-252-2P-T 2500±25% 4-2Characteristics(Reference) 4-2-1 Z v.s. Freq. DC Rated Voltage Resistance Vdc(V) Rdc(Ω) Max. Insulation Withstand Resistance Voltage (MΩ)Min. Vdc(V) 10 125 1400 50 10 125 1000 0.30 50 10 125 1000 0.4 50 10 125 1000 0.9 50 10 125 200 Rated Current Idc(mA) Max. 3/8 SPEC. NO. PRODUCT SPECIFICATION 4-3 Test Equipment 4-3-1 Impedance Measured by using Agilent E4991A RF Impedance Analyzer. Measurement terminal ① ④ ② ③ 4-3-2 DC Resistance Measured by using Chroma 16502 mill ohm meter. Measurement terminal ① ④ ② ③ Measurement terminal 4-3-3 Insulation Resistance Measured by using Chroma 19073 Measurement voltage : 50v . Measurement terminal ① ④ ② ③ T-0602-102D 4/8 SPEC. NO. PRODUCT SPECIFICATION T-0602-102D 5.Reliability Test Operating temperature : -40 to +125℃ Item Specifications Solderability It can be connected on the Storage temp and humidity : 20~25℃ ,60%RH max. Test conditions Apply cream solder to the test circuit board . Recommendation soldering condition. It is mounted on the recommendation soldering condition. Dip pads in flux and dip in solder pot( 96.5 Sn/3.5 Ag solder) at 255°C ±5°C. Solder Heat Components should have not Resistance evidence of electrical and The device should be reflow soldered on PCB Preheating: 150℃, 60 secs mechannical damage Solder temperature: Peak 260±5℃ for 10secs Impedance:within ±15% of Solder Composition: 96.5Sn/3.5Ag initial value Terminal strength The terminal electrode and the ferrite Solder a chip to test substrate , and then laterally apply a must not be damaged. load 1.8Kg in the arrow direction. High Appearance : Ferrite shall not be temperature damaged. resistance Temperature : +125±2℃ Testing time : 168±12 hours Measurement : After placing for 24 hours min. initial value. Humidity resistance Thermal cycle insulation resistance: >10(MΩ) Temperature : +60±2℃ DC resistance : standard value Humidity : 90 to 95%RH inside. Testing time : 168±12 hours Measurement : After placing for 24 hours min. Temperature : -40℃,+125℃ kept stabilized for 30 minutes each. Cycle : 10 cycle Measurement : After placing for 24 hours min. 1 cycle +125℃ -40℃ 30 min. 3 min. 30 min. 5/8 SPEC. NO. PRODUCT SPECIFICATION Item Specifications Low temperature resistance T-0602-102D Test conditions Temperature : -40±2℃ Testing time : 168±12 hours Appearance : Ferrite shall not be damaged. Measurement : After placing for 24 hours min. initial value. insulation resistance: >10(MΩ) DC resistance : standard value inside. 6.Packaging The packaging must be done not to receive any damage during transporting and storing ( Dimensions in mm ) Symbol W Dimension 12.00 SPEC. ±0.1 P 8.00 E 1.75 F 5.50 P2 2.00 ±0.1 ±0.1 ±0.05 ±0.05 D 1.50 D1 1.50 Po 4.00 10Po 40.00 Ao 3.57 Bo 4.80 Ko 2.80 t 0.30 +0.10 -0.00 ±0.1 ±0.1 ±0.2 ±0.1 ±0.1 ±0.1 ±0.05 6/8 SPEC. NO. PRODUCT SPECIFICATION 6-2 Reel dimensions T-0602-102D D ( Dimensions in mm ) C B Symbol T A B 180 C 13 D E 16 13.2 A E 6-3 Tapping figure Top cover tape Carrier tape Sprocket hole Cavity (chip insert) 6-4 Packaging Form There shall not continuation more than two vacancies of the product. (360 mm) Blank Chip 50 pitches Material of carrier tape : Polystyrene Material of cover tape : Polyester Blank 70 pitches Leader. 60 7/8 SPEC. NO. PRODUCT SPECIFICATION T-0602-102D 6-5 Cover Tape Peel Strength The force for tearing off cover tape is 0.05~0.69(N) in the arrow direction at the following conditions: Temperature : 5 ~ 35℃ Humidity : 45 ~ 85% Atmospheric pressure : 860 ~ 1060 hpa 160 ~ 180。 Top cover tape Base tape 6-6 Packing Quantity φ180 mm reel T type : 500 pcs./reel 7. Recommended Soldering Conditions (Please use this product by reflow soldering) 7-1 Recommended Footprint Termination Number : Please refer to the equivalent circuit in chapter 3. 0.7 4.8 3.8 2.5 Unit:mm 8/8 PRODUCT SPECIFICATION SPEC. NO. T-0602-102D 7-2 Recommended Reflow Pattern Reflow : until two times 10sec. Min. 255℃ 217℃ Natural cooling 150sec Max.. 150℃ 60sec. Min. 7-3 Iron Soldering Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip directly touch the ferrite body outside of terminal electrode. 5 seconds max. at 260℃. 8. Attention in Case of Using In case of using product ,please avoid following matters: Splashing water or salt water Dew condenses Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia) Vibrations or shocks which exceed the specified condition Please be careful for the stress to this product by board flexure or something after the mounting. 9. Others 9-1 Operating temperature range : -40~+125℃ 9-2 Storage condition : Temperature 20~25℃ , Relative Humidity 40% ~ 60% 9-3 Recommended wire wound inductors should be used within 6 months from the time of delivery.
CMF4532F-601-2P-T 价格&库存
很抱歉,暂时无法提供与“CMF4532F-601-2P-T”相匹配的价格&库存,您可以联系我们找货
CMF4532F-601-2P-T
    • 5+2.49945
    • 50+1.96604
    • 150+1.73740
    • 500+1.45217
    • 2500+1.32516
    • 5000+1.24892
