CMF3216F-222-2P-T
CMF3216F-222-2P-T
    EMTEK(兆欣)
    SMD,3.2x1.6x1.8mm
    特性:该共模滤波器的特点是尺寸小,在噪声抑制方面非常有效。在噪声频段具有高共模阻抗,在信号频段具有低差模阻抗。 由于低差模阻抗和高耦合系数,高速信号几乎没有失真。 该系列由自动机器微生产,生产率高、精...
CMF3216F-222-2P-T 数据手册
CMF3216F Series Common Mode SMD Filter for Signal Line FEATURES • This common mode filter is characterized by its small sized • Highly effective in noise suppression. High common-mode impedance at noise band and low differential-mode impedance at signal band. • Due to the low differential-mode impedance with high coupling factor, there is almost no distortion on high speed signal. • This series is micro-produced by auto machines for its huge productivity and accuracy with PRODUCT IDENTIFICATION all-day CCD inspection. CMF 3216 F - 900 - 2P - T (1) (2) (3) (4) (5) (1) Product name (2) Shapes and Dimensions APPLICATIONS (3) Shielding type • Used for noise suppression in any electronic (4) Impedance[at 100MHz] devices such as personal computer and periphera 900:90Ω (6) equipment (USB), amusement equipment (IEEE(5) Number of line LCD panels (LVDS) etc. 2P:2-Line (6) Taping style SHAPES AND DIMENSIONS 1.6 ± 0.2 RECOMMENDED FOOTPRINT 1.05 1.8 ± 0.2 3.2 ± 0.2 1.6 1.05 0.6 0.4 0.6 (0.6) (0.6) (0.6) (0.6) Unit:mm ELECTRICAL CHARACTERISTICS Our Product Part Number CMF3216F-750-2P-T CMF3216F-900-2P-T CMF3216F-121-2P-T CMF3216F-161-2P-T CMF3216F-181-2P-T CMF3216F-261-2P-T CMF3216F-431-2P-T CMF3216F-601-2P-T CMF3216F-102-2P-T CMF3216F-222-2P-T Common-Mode Impedance Z(Ω) at 100MHz 75 ±25% 90 ±25% 120 ±25% 160 ±25% 180 ±25% 260±25% 430±25% 600±25% 1000±25% 2200±25% DC Resistance Rdc(Ω) Max 0.30 0.30 0.30 0.40 0.40 0.50 0.60 0.80 1.00 1.20 Rated Current Idc(mA) Max 500 500 370 340 340 310 280 260 230 200 Rated Voltage Vdc(V) Withstanding Voltage Vdc(V) 50 50 50 50 50 50 50 50 50 50 125 125 125 125 125 125 125 125 125 125 Insulation Resistance (MΩ)Min. 10 10 10 10 10 10 10 10 10 10 CMF3216F Series Common Mode SMD Filter for Signal Line Characteristics(Impedance vs. Frequency) CMF3216F-900-2P-T 10000 CMF3216F-161-2P-T 1000 Common Mode Common Mode Differential Mode Differential Mode Impendance(OHM) Impedance(OHM) 1000 100 10 100 10 1 1 1 10 100 Frequency(MHz) 1 1000 CMF3216F-261-2P-T 10000 Common Mode Common Mode Differential Mode 1000 1000 Impedance(OHM) Impedance(OHM) 1000 CMF3216F-601-2P-T 10000 Differential Mode 100 100 10 10 1 1 1 10 100 Frequency(MHz) 1 1000 CMF3216F-102-2P-T 10000 10 100 Frequency(MHz) 1000 CMF3216F-222-2P-T 10000 Common Mode Common Mode Differential Mode Differential Mode 1000 Impedance(OHM) Impedance(OHM) 10 100 Frequency(MHz) 100 10 1 1000 100 10 1 1 10 100 Frequency(MHz) 1000 1 10 100 Frequency(MHz) 1000
