HSC1008-4R7J-T
HSC1008-4R7J-T
    EMTEK(兆欣)
    SMD,2.9x2.5mm
    功率电感 SMD
HSC1008-4R7J-T 数据手册
PRODUCT SPECIFICATION SPEC. NO: 新弘智 T-0619-002L DATE: Aug.9,2018 CUSTOMER'S PRODUCT NAME: EMTEK PRODUCT NAME: HSC1008-SERIES THIS SPECIFICATION IS: □ FULLY ACCEPTED □ DENIED □ ACCEPTED UNDER THE FOLLOWING CONDITIONS SIGNATURE: NAME(PRINT): TITLE: DATE: FACTORY: 本文件內容全部或部份,未經兆欣科技股份有限公 司同意不得以任何形式複製或其他用途 All rights reserved.This document or parts thereof,may not be reproduced by any means or used in any manner witout written permission of EMTEK CO.,LTD. 39,Chingao Rd.,(305)Hsinpu, Hsinchu Hsien,Taiwan,R.O.C TEL: 03-5894-433 FAX: 03-5894-523 1/11 SPEC. NO. PRODUCT SPECIFICATION T-0619-002L 1. Scope This specification applies Ceramic Chip Inductance HSC1008-Series to be delivered to user. 2. Product Identification HSC 1008 - 10N □ - T (1) (2) (3) (4) (5) (1) Product name (2) Shapes and dimensions (3) Inductance 10N : 10 nH (4) Tolerance G=±2% , J=±5% , K=±10% (5) Taping Type 3. Shapes and Dimensions C B D A max. : 2.90 mm E B max. : 2.54 mm A C max. : 2.03 mm F D ref. E G Terminal Terminal wraparound : Approx. 0.38mm both ends : 1.30 mm E: 0.45 ± 0.1 mm F: 1.60 ± 0.1 mm G: 2.0 mm Equivalent circuit No Polarity Drawn by Checked by Approved by 2/11 SPEC. NO. PRODUCT SPECIFICATION T-0619-002L 4. Electrical Characteristics Customer Our Product Inductance Inductance Q/MHz SRF(Min.) RDC Irms Max. Part Number Part Number (nH)/MHz Tolerance Min. (MHz) (Ω)Max. (mA) 28/500 7500 0.15 600 Yellow Violet Black 50/500 4100 0.08 1000 Brown Black Black 50/500 3300 0.09 1000 Brown 45/500 2500 0.10 1000 Brown Green Black 50/350 2500 0.11 1000 Brown Gray 55/350 2400 0.12 1000 Red 55/350 1600 0.13 1000 Red 60/350 1600 0.14 1000 Orange Orange Black 60/350 1500 0.15 1000 Orange White Black 65/350 1500 0.16 1000 Yellow Violet Black 65/350 1300 0.18 1000 Green Blue Black 65/350 1300 0.20 1000 Blue Gray Black 60/350 1000 0.22 1000 Gray Red Black 60/350 1000 0.56 650 Brown Black Brown 60/350 950 0.63 650 Brown 45/100 850 0.70 580 Brown Green Brown HSC1008-4N7□-T 4.7/50 HSC1008-10N□-T 10/50 J K G J Color Coding 1st 2nd 3rd K G HSC1008-12N□-T 12/50 J Red Black K G HSC1008-15N□-T 15/50 J K G HSC1008-18N□-T 18/50 J Black K G HSC1008-22N□-T 22/50 J Red Black K G HSC1008-27N□-T 27/50 J Violet Black K G HSC1008-33N□-T 33/50 J K G HSC1008-39N□-T 39/50 J K G HSC1008-47N□-T 47/50 J K G HSC1008-56N□-T 56/50 J K G HSC1008-68N□-T 68/50 J K G HSC1008-82N□-T 82/50 J K G HSC1008-R10□-T 100/25 J K G HSC1008-R12□-T 120/25 J Red Brown K G HSC1008-R15□-T 150/25 J K 3/11 SPEC. NO. PRODUCT SPECIFICATION T-0619-002L 4. Electrical Characteristics Customer Part Number Our Product Inductance Inductance Q/MHz SRF(Min.) RDC Irms Max. Part Number (nH)/MHz Tolerance Min. (MHz) (Ω)Max. (mA) Color Coding HSC1008-R18□-T 180/25 45/100 750 0.77 620 45/100 700 0.84 500 Red 45/100 600 0.91 500 Red 45/100 570 1.05 450 Orange Orange Brown 45/100 500 1.12 470 Orange White Brown 45/100 450 1.19 470 Yellow Violet Brown 45/100 415 1.33 400 Green Blue Brown 45/100 375 1.40 300 Blue Red Brown 45/100 375 1.47 400 Blue Gray Brown 45/100 360 1.54 360 Violet Green Brown 45/100 350 1.61 400 Gray 35/50 320 1.68 380 White Brown Brown 35/50 290 1.75 370 Brown Black Red 35/50 250 2.00 310 Brown Red 1st 2nd 3rd G J Brown Gray Brown K G HSC1008-R22□-T 220/25 J Red Brown K G HSC1008-R27□-T 270/25 J Violet Brown K G HSC1008-R33□-T 330/25 J K G HSC1008-R39□-T 390/25 J K G HSC1008-R47□-T 470/25 J K G HSC1008-R56□-T 560/25 J K G HSC1008-R62□-T 620/25 J K G HSC1008-R68□-T 680/25 J K G HSC1008-R75□-T 750/25 J K G HSC1008-R82□-T 820/25 J Red Brown K G HSC1008-R91□-T 910/25 J K G HSC1008-1R0□-T 1000/25 J K G HSC1008-1R2□-T 1200/7.9 J K Red 4/11 SPEC. NO. PRODUCT SPECIFICATION T-0619-002L Customer Our Product Inductance Inductance Q/MHz SRF(Min.) RDC Irms Max. Part Number Part Number (nH)/MHz Tolerance Min. (MHz) (Ω)Max. (mA) HSC1008-1R5□-T 1500/7.9 28/50 200 2.30 330 Brown Green Red 28/50 160 2.60 300 Brown Gray Red 28/50 160 2.80 280 Red Red Red 22/25 135 3.20 290 Red Violet Red 22/25 110 3.40 290 Orange Orange Red 20/25 100 3.60 260 Orange White Red 20/25 90 4.00 260 Yellow Violet Red 18/7.9 40 4.20 240 Green Blue Red 18/7.9 40 4.90 200 Blue Gray Red 18/7.9 25 6.00 170 Gray Red Red 18/7.9 25 8.00 150 Color Coding 1st 2nd 3rd G J K G HSC1008-1R8□-T 1800/7.9 J K G HSC1008-2R2□-T 2200/7.9 J K G HSC1008-2R7□-T 2700/7.9 J K G HSC1008-3R3□-T 3300/7.9 J K G HSC1008-3R9□-T 3900/7.9 J K G HSC1008-4R7□-T 4700/7.9 J K G HSC1008-5R6□-T 5600/7.9 J K G HSC1008-6R8□-T 6800/7.9 J K G HSC1008-8R2□-T 8200/7.9 J K G HSC1008-100□-T 10000/2.5 J K Brown Black Orange 5/11 SPEC. NO. PRODUCT SPECIFICATION 1. All specifications are calibrated with Coilcraft 1008CS series 2. When ordering, please specify tolerance and packaging codes. Ex: HSC1008-R12J-T Tolerance : G = ±2% , J = ±5% , K = ±10% Packaging : Clear tape and reel { standard }. * 3. L , Q、SRF : Agilent/HP E4991A+ Agilent/HP16197A (The electrical specification test by the smallest gap position) or HP16193A 4. Rdc : DIGITAL MILLIOHM METER Chroma 16502, or equivalent. 5. Irms for a 15℃ rise above 25℃ ambient. 6. Operating temperature range from -40℃ to 125℃. * Parts/Reel: 7” 2,000 Tape Width: 8mm T-0619-002L 6/11 SPEC. NO. PRODUCT SPECIFICATION 5. Material list Item Material Core Al2O3 96% Wire Copper wire Epoxy UV Eopxy T-0619-002L 7/11 SPEC. NO. PRODUCT SPECIFICATION T-0619-002L 6.Reliability Test Specifications Item Solderability The metalized area must have 90% minimum solder coverage. Resistance to soldering heat Test conditions Dip pads in flux and dip in solder pot( 96.5 Sn/3.5 Ag solder) at 255°C ±5°C. There must be no case deformation or Inductors shall be reflowed onto a PC board using change in dimensions. 96.5 Sn/3.5 Ag solder paste. Inductance must not change more than Solder process shall be at a maximum temperature the stated tolerance. of 260°C. For 96.5 Sn/3.5 Ag solder paste:>217°C for 90 seconds Vibration There must be no case deformation or Solder specimen inductor on the test printed circuit board. Apply vibrations in each of the x,y and z change in dimensions. Inductance must not change more than directions for 2 hours for a total of 6 hours. the stated tolerance. Frequency : 10~50 Hz Amplitude : 1.5mm There must be no case deformation or Inductors shall be subjected to temperature 125±2℃ High for 500±12 hours. temperature change in dimensions. resistance Inductance must not change more thanMeasure the test items after leaving the inductors at the stated tolerance. Static Humidity room temperature and humidity for 2 hours. Inductors must not have a shorted or Inductors shall be subjected to temperature 85±2℃ and 90 to 95%RH. for ten 24-hours. openwinding. Measure the test items after leaving the inductors at room temperature and humidity for 2 hours. Component Inductors shall be subjected to 1.8Kg Inductors shall be reflow soldered (255°C ±5°C for 10 seconds) to a tinned copper substrate. adhesion A force gauge shall be applied to the side of the (push test) component. The device must withstand the stated force without a failure of the termination. 8/11 SPEC. NO. PRODUCT SPECIFICATION T-0619-002L Specifications Test conditions Item There must be no case deformation or Inductors shall be subjected to temperature Low -40±2℃ for 500±12 hours. temperature change in dimensions. Measure the test items after leaving the inductors resistance Inductance must not change more than the stated tolerance. at room temperature and humidity for 1 to 2 hours. Resistance to solvent There must be no case deformation, Thermal shock There must be no case deformation or Inductors shall be subjected to 10 cycles to the the following temperature cycle: change in dimensions. Inductors must withstand 6 minutes of alcohol or water. change in dimensions, or obliteration of marking. Inductance must not change more than the stated tolerance. 1 cycle 30 min. 3 min. +125℃ -40℃ 30 min. Measure the test items after leaving the inductors at room temperature and humidity for 2 hours. 9/11 SPEC. NO. PRODUCT SPECIFICATION T-0619-002L 7.Packaging The packaging must be done not to receive any damage during transporting and storing. 7-1 Tape dimensions Ko P1 P0 P W Bo t Ao ( Dimensions in mm; Tolerance:±0.1) Symbol W P P0 P1 Ao Bo Ko t Dimension 8 4 4 2 2.5 2.85 2 0.22 7-2 Reel dimensions D ( Dimensions in mm ) Symbol T C B A A B 180 C 13 D 14.4 E 8.4 E 7-3 Tapping figure Top cover tape Carrier tape Sprocket hole Cavity (chip insert) 60 10/11 SPEC. NO. PRODUCT SPECIFICATION T-0619-002L 7-4 Packaging Form There shall not continuation more than two vacancies of the product. (360 mm) Leader. Blank (50 pitches) Chip Blank (70 pitches) 7-5 Cover Tape Peel Strength The force for tearing off cover tape is 0.1~0.6(N) in the arrow direction at the following conditions: Temperature : 5 ~ 35℃ Humidity : 45 ~ 85% Atmospheric pressure : 860 ~ 1060 hpa 160 ~ 180。 Top cover tape Base tape 7-6 Packing Quantity φ180 mm reel type : 2,000 pcs./reel 11/11 SPEC. NO. PRODUCT SPECIFICATION T-0619-002L 8. Recommended Soldering Conditions (Please use this product by reflow soldering) 8-1 Recommended Footprint 1.02 1.27 1.02 2.54 Unit: mm 8-2 Recommended Reflow Pattern Reflow : until two times 10sec. Max. 255℃ 217℃ Natural cooling 150sec. Max. 150℃ 60sec. Min. 8-3 Iron Soldering Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip directly touch the Ceramic body outside of terminal electrode. 5 seconds max. at 260℃. 9. Attention in Case of Using In case of using product ,please avoid following matters: Splashing water or salt water Dew condenses Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia) Vibrations or shocks which exceed the specified condition Please be careful for the stress to this product by board flexure or something after the mounting. 10. Others 10-1 Operating temperature range : Ceramic Series :-40~+125℃ 10-2 Storage condition : Temperature 20°~25℃﹐Relative Humidity 40%~60% 10-3 Recommended wire wound inductors should be used within 6 months from the time of delivery.
HSC1008-4R7J-T 价格&库存
很抱歉,暂时无法提供与“HSC1008-4R7J-T”相匹配的价格&库存,您可以联系我们找货
HSC1008-4R7J-T
    • 5+0.19719
    • 50+0.10494
    • 150+0.04583
    • 500+0.04085
    • 2000+0.03688
    • 4000+0.03488
    库存:1692
