CMF2520F-601-2P-T
CMF2520F-601-2P-T
    EMTEK(兆欣)
    SMD,2.5x2x1.8mm
CMF2520F-601-2P-T 数据手册
PRODUCT SPECIFICATION SPEC. NO: T-0602-070F DATE: Aug.7,2018 CUSTOMER'S PRODUCT NAME: EMTEK PRODUCT NAME: CMF2520F-601-2P-T THIS SPECIFICATION IS: □ FULLY ACCEPTED □ DENIED □ ACCEPTED UNDER THE FOLLOWING CONDITIONS SIGNATURE: NAME(PRINT): TITLE: 本文件內容全部或部份,未經兆欣科技股份有限公 司同意不得以任何形式複製或其他用途 All rights reserved.This document or parts thereof,may not be reproduced by any means or used in any manner witout written permission of EMTEK CO.,LTD. DATE: FACTORY: 39,Chingao Rd.,(305)Hsinpu, Hsinchu Hsien,Taiwan,R.O.C TEL: 03-5894-433 FAX: 03-5894-523 1/8 SPEC. NO. PRODUCT SPECIFICATION T-0602-070F 1. Scope This specification applies ferrite Chip common mode filters CMF2520F-Series to be delivered to user. 2. Product Identification CMF 2520 F - 601 - 2P - T (1) (2) (3) (4) (5) (6) (1) Product name (2) Shapes and dimensions (3) Shielding Type (4) Impedance【 at 100MHz】 601:600Ω (5) Number of Line 2P:2-Line (6) Taping Type 3. Shapes and Dimensions [Dimensions in mm] A B Epoxy C A : 2.5 ± 0.2 B : 2.0 ± 0.2 C : 1.2 ± 0.1 Terminations Wires ① ④ Equivalent circuit (0.5) (0.5) ② (0.45) ③ ① ④ ② ③ No Polarity (0.45) Drawn by Checked by Approved by 2/8 SPEC. NO. PRODUCT SPECIFICATION T-0602-070F 4. Electrical Characterisitics 4-1 Electrical Spec. CMF2520F-900-2P-T Common-Mode Impedance Z(Ω) at 100MHz 90±25% CMF2520F-301-2P-T Our Product Part Number DC Rated Rated Current Resistance Voltage Idc(A) Max. Rdc(Ω) Max. Vdc(V)max. 0.25 0.5 20 300±25% 0.35 0.4 20 CMF2520F-601-2P-T 600±25% 0.45 0.3 20 CMF2520F-102-2P-T 1000±25% 0.80 0.2 20 4-2Characteristics(Reference) CMF2520F-301-2P-T 10000 Z (common mode) Z(differential mode) Impedance(Ω) 1000 100 10 1 1 10 Frequency(MHz) 100 1000 3/8 SPEC. NO. PRODUCT SPECIFICATION 4-3 Test Equipment 4-3-1 Impedance Measured by using Agilent E4991A RF Impedance Analyzer. Measurement terminal ① ④ ② ③ 4-3-2 DC Resistance Measured by using Chroma 16502 mill ohm meter. Measurement terminal ① ④ ② ③ Measurement terminal 4-3-3 Insulation Resistance Measured by using Chroma 19073 Measurement voltage : 50v . Measurement terminal ① ④ ② ③ T-0602-070F 4/8 PRODUCT SPECIFICATION SPEC. NO. T-0602-070F 5.Reliability Test Operating temperature : -25 to +85℃ Item Solder ability Storage temp and humidity : 20~25℃ ,60%RH max. Specifications Test conditions It can be connected on the Apply cream solder to the test circuit board . Recommendation soldering condition. It is mounted on the recommendation soldering condition. Dip pads in flux and dip in solder pot( 96.5 Sn/3.5 Ag solder) at 255°C ±5°C. Terminal strength The terminal electrode and the ferriteSolder a chip to test substrate , and then laterally apply a must not be damaged. load 0.5Kg in the arrow direction. Strength on The terminal electrode and the ferriteSoldering a chip to a test substrate , must not be damaged. bend the substrate by 2mm and then return. pc board bending 45 45 Width side 40 100 length 10 20 Force Dimensions in mm R10 Test board : Glass base epoxy multiplayer board pc board pattern. PC board pattern : Recommended PC board pattern. 5/8 PRODUCT SPECIFICATION Item Specifications High Appearance : Ferrite shall not be temperature damaged. resistance SPEC. NO. T-0602-070F Test conditions Temperature : +85±2℃ Applied voltage : Rated voltage Applied current : Rated current initial value. Testing time : 500±12 hours insulation resistance: >10(MΩ) Measurement : After placing for 24 hours min. DC resistance : standard value Humidity resistance inside. Temperature : +85±2℃ Humidity : 90 to 95%RH Applied current : Rated current Applied voltage : Rated voltage Testing time : 500±12 hours Measurement : After placing for 24 hours min. Thermal cycle Temperature : -25℃,+85℃ kept stabilized for 30 minutes each. Cycle : 100 cycle Measurement : After placing for 24 hours min. 1 cycle +85℃ 30 min. -25℃ Low temperature resistance Vibration 3 min. 30 min. Temperature : -25±2℃ Testing time : 500±12 hours Measurement : After placing for 24 hours min. Appearance : Ferrite shall not be damaged. Frequency : 10 to 50 Hz Amplitude : 1.52 mm Dimension and times : X ,Y and Z directions for 2 hours each. 6/8 PRODUCT SPECIFICATION SPEC. NO. T-0602-070F 6. Recommended Soldering Conditions (Please use this product by reflow soldering) 6-1 Recommended Footprint Termination Number : Please refer to the equivalent circuit in chapter 3. 1.5 0.5 6-2 Recommended Reflow Pattern Reflow : until two times 10sec. Min. 255℃ 217℃ Natural cooling 150sec Max.. 150℃ 60sec. Min. 6-3 Iron Soldering Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip directly touch the ferrite body outside of terminal electrode. 5 seconds max. at 260℃. 7. Attention in Case of Using In case of using product ,please avoid following matters: Splashing water or salt water Dew condenses Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia) Vibrations or shocks which exceed the specified condition Please be careful for the stress to this product by board flexure or something after the mounting. 7/8 SPEC. NO. PRODUCT SPECIFICATION T-0602-070F 8. Others 8-1 Operating temperature range : -25~+85℃ 8-2 Storage condition : Temperature 20~25℃ , Relative Humidity 40% ~ 60% 8-3 Recommended wire wound inductors should be used within 6 months from the time of delivery. 9.Packaging The packaging must be done not to receive any damage during transporting and storing. 9-1 Tape dimensions P Ko P1 P0 W Bo t Ao ( Dimensions in mm; Tolerance:±0.1) Symbol W P P0 P1 Ao Bo Ko t Dimension 8 4 4 2 2.25 2.8 1.35 0.22 9-2 Reel dimensions D ( Dimensions in mm ) Symbol C B A B C D E A E T 180 60 13 14.4 8.4 8/8 SPEC. NO. PRODUCT SPECIFICATION T-0602-070F 9-3 Tapping figure Top cover tape Carrier tape Sprocket hole Cavity (chip insert) 9-4 Packaging Form There shall not continuation more than two vacancies of the product. (360 mm) Blank Chip 50 pitches Blank Leader. 70 pitches Material of carrier tape : Polystyrene Material of cover tape : Polyester 9-5 Cover Tape Peel Strength The force for tearing off cover tape is 0.05~0.69(N) in the arrow direction at the following conditions: Temperature : 5 ~ 35℃ Humidity : 45 ~ 85% Atmospheric pressure : 860 ~ 1060 hpa 160 ~ 180。 Top cover tape Base tape 9-6 Packing Quantity φ180 mm reel T type : 2000 pcs./reel
CMF2520F-601-2P-T 价格&库存
很抱歉,暂时无法提供与“CMF2520F-601-2P-T”相匹配的价格&库存,您可以联系我们找货
CMF2520F-601-2P-T
    • 5+1.96874
    • 50+1.56050
    • 150+1.38554
    • 500+1.16716
    • 2500+1.06996
    • 5000+1.01164
