CMF4532L-110-2P-T
CMF4532L-110-2P-T
    EMTEK(兆欣)
    SMD,4.5x3.2x2.7mm
CMF4532L-110-2P-T 数据手册
PRODUCT SPECIFICATION SPEC. NO: T-0602-154D 新弘智 DATE: Aug.7,2018 CUSTOMER'S PRODUCT NAME: EMTEK PRODUCT NAME: CMF4532L-Series THIS SPECIFICATION IS: □ FULLY ACCEPTED □ DENIED □ ACCEPTED UNDER THE FOLLOWING CONDITIONS SIGNATURE: NAME(PRINT): TITLE: 本文件內容全部或部份,未經兆欣科技股份有限公 司同意不得以任何形式複製或其他用途 All rights reserved.This document or parts thereof,may not be reproduced by any means or used in any manner witout written permission of EMTEK CO.,LTD. DATE: FACTORY: 39,Chingao Rd.,(305)Hsinpu, Hsinchu Hsien,Taiwan,R.O.C TEL: 03-5894-433 FAX: 03-5894-523 1/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-154D 1. Scope This specification applies ferrite Chip common mode filters CMF4532L-Series to be delivered to user. 2. Product Identification CMF 4532 L - 101 - 2P - T (1) (2) (3) (4) (5) (6) (1) Product name (2) Shapes and dimensions (3) Application (4) Inductance【 at 100KHz】 101:100 (uH) (5) Number of Line 2P:2-Line (6) For Customer Design 3. Shapes and Dimensions [Dimensions in mm] A:4.5 ± 0.2 mm B:3.2 ± 0.2 mm C:2.7 ± 0.2 mm D:0.25 ± 0.1 mm E :1.2Typ. mm F :1.0Typ. mm Drawn by Checked by Approved by 2/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-154D 4. Electrical Characterisitics 4-1 Electrical Spec. Our Product Part Number CMF4532L-1R0-2P-T CMF4532L-110-2P-T CMF4532L-220-2P-T CMF4532L-510-2P-T CMF4532L-101-2P-T CMF4532L-201-2P-T Z(Ω) Common Mode Impedance at 10MHz L(uH) Common Mode Inductance at 100KHz min. 50 (+50%/-30%) typ. 60 1 min. 300 (+50%/-30%) typ. 600 11 min. 500 (+50%/-30%) typ. 1200 22 min. 1000 (+50%/-30%) typ. 2800 51 min. 2000 (+50%/-30%) typ. 5800 100 min. (+50%/-30%) typ. 200 DCR(Ω) Max. Idc(mA) Max. Rated Voltage Vdc (V)Typ. Insulation Resistance IR (MΩ)Min. 0.12 1200 50 10 0.6 250 50 10 1.0 200 50 10 1.0 200 50 10 2.0 150 50 10 4.5 100 50 10 Operating temperature:-40 to 125℃ Storage temp. and humidity:-40 to +85℃,70%RH max 4-2Characteristics(Reference) 4-2-1 Z v.s. Freq. CMF4532L-1R0-2P-T 10000 Z (common mode) Z(differential mode) Impedance( ohm) 1000 100 10 1 1 10 100 Frequency(MHz) 1000 10000 CMF4532L-220-2P-T 10000 Common mode Z Differential mode Z 1000 Impedance(Ω) 100 10 1 1 10 100 0.1 Frequency (MHz) 1000 3/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-154D 4-2Characteristics(Reference) 4-2-1 Z v.s. Freq. CMF4532L-510-2P-T 100000 Common mode Z Differential mode Z Impedance(Ω) 10000 1000 100 10 1 1 10 100 1000 Frequency (MHz) CMF4532L-101-2P-T 100000 Common mode Z Differential mode Z Impedance(Ω) 10000 1000 100 10 1 1 10 100 Frequency (MHz) 1000 4/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-154D 4-2Characteristics(Reference) 4-2-1 Z v.s. Freq. CMF4532L-201-2P-T 100000 Common mode Z Differential mode Z Impedance(Ω) 10000 1000 100 10 1 1 10 100 Frequency (MHz) 1000 10000 5/9 SPEC. NO. PRODUCT SPECIFICATION 4-3 Test Equipment 4-3-1 Inductance Measured by using Agilent HP4284A Precision LCR Meter. Measurement terminal ① ④ ② ③ 4-3-2 DC Resistance Measured by using Chroma 16502 mill ohm meter. Measurement terminal ① ④ ② ③ Measurement terminal 4-3-3 Insulation Resistance Measured by using Chroma 19073 Measurement voltage : 50v ,Measurement time:60 sec. Measurement terminal ① ④ ② ③ T-0602-154D 6/9 PRODUCT SPECIFICATION SPEC. NO. T-0602-154D 5.Reliability Test Operating temperature : -40 to +125℃ Item Solder ability Storage temp and humidity : 20~25℃ ,60%RH max. Specifications It can be connected on the Test conditions Apply cream solder to the test circuit board . Recommendation soldering condition. It is mounted on the recommendation soldering condition. Dip pads in flux and dip in solder pot( 96.5 Sn/3.5 Ag Terminal strength solder) at 255°C ±5°C. The terminal electrode and the ferriteSolder a chip to test substrate , and then laterally apply a must not be damaged. load 1.8Kg in the arrow direction. Strength on The terminal electrode and the ferriteSoldering a chip to a test substrate , must not be damaged. bend the substrate by 2mm and then return. pc board bending 45 45 Width side 40 100 10 20 length Force Dimensions in mm R10 Test board : Glass base epoxy multiplayer board pc board pattern. PC board pattern : Recommended PC board pattern. 7/9 SPEC. NO. PRODUCT SPECIFICATION Specifications Item High Appearance : Ferrite shall not be temperature damaged. resistance T-0602-154D Test conditions Temperature : +125±2℃ Applied voltage : Rated voltage Applied current : Rated current initial value. Testing time : 500±12 hours insulation resistance: >10(MΩ) Measurement : After placing for 24 hours min. DC resistance : standard value Humidity resistance inside. Temperature : +85±2℃ Humidity : 90 to 95%RH Applied current : Rated current Applied voltage : Rated voltage Testing time : 500±12 hours Measurement : After placing for 24 hours min. Thermal shock Temperature : -40℃,+125℃ kept stabilized for 30 minutes each. Cycle : 100 cycle Measurement : After placing for 24 hours min. 1 cycle +125℃ 30 min. -40℃ Low temperature resistance Vibration Appearance : Ferrite shall not be damaged. 3 min. 30 min. Temperature : -40±2℃ Testing time : 500±12 hours Measurement : After placing for 24 hours min. Frequency : 10 to 50 Hz Amplitude : 1.52 mm Dimension and times : X ,Y and Z directions for 2 hours each. 8/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-154D 6. Reel Dimension & Tape Dimension 6-1 Reel Dimensions Unit: mm C D 13.2±0.5 B 60±2 13±0.5 180±2 A 6-2 Tape Dimensions Symbol Dimension W 12.00 P 8.00 E 1.75 F 5.50 P2 2.00 D 1.50 D1 1.50 Po 4.00 10Po 40.00 SPEC. ±0.1 ±0.1 ±0.1 ±0.05 ±0.05 +0.10 -0.00 ±0.1 ±0.1 ±0.2 Symbol Dimension SPEC. Ao 3.57 ±0.1 Bo 4.80 ±0.1 Ko 2.80 ±0.1 t 0.30 ±0.05 9/9 SPEC. NO. PRODUCT SPECIFICATION 6-3 Packaging Quantity 500pcs/reel 7. Equivalent Circuit & Recommened Footprint T-0602-154D
CMF4532L-110-2P-T 价格&库存
很抱歉,暂时无法提供与“CMF4532L-110-2P-T”相匹配的价格&库存,您可以联系我们找货
CMF4532L-110-2P-T
    • 1+3.49920
    • 10+2.79720
    • 30+2.49480
    • 100+2.12760
    • 500+1.96560
    • 1000+1.85760
