PRODUCT SPECIFICATION
SPEC. NO:
新弘智
DATE:
T-0602-058J
Aug.7,2018
CUSTOMER'S PRODUCT NAME:
EMTEK PRODUCT NAME:
CMF2012H4-Series
THIS SPECIFICATION IS:
□ FULLY ACCEPTED
□ DENIED
□ ACCEPTED UNDER THE FOLLOWING CONDITIONS
SIGNATURE:
NAME(PRINT):
TITLE:
DATE:
FACTORY:
本文件內容全部或部份,未經兆欣科技股份有限公
司同意不得以任何形式複製或其他用途
All rights reserved.This document or parts thereof,may
not be reproduced by any means or used in any manner
witout written permission of EMTEK CO.,LTD.
39,Chingao Rd.,(305)Hsinpu,
Hsinchu Hsien,Taiwan,R.O.C
TEL: 03-5894-433
FAX: 03-5894-523
1/13
SPEC. NO.
T-0602-058J
1. Scope
This specification applies ferrite Chip common mode filters CMF2012H4-Series
to be delivered to user.
2. Product Identification
CMF 2012 H4 - 900 - 2P - T
(1) (2) (3) (4) (5)
(6)
(1) Product name
(2) Shapes and dimensions
(3) Shielding Type
(4) Impedance【 at 100MHz】
65min. (90typ.)
(5) Number of Line
2P:2-Line
(6) Taping Type
3. Shapes and Dimensions [Dimensions in mm]
B
C
A
A : 2.0 ± 0.2
B : 1.2 ± 0.2
C : 1.2 ± 0.2
Terminations
Wires
①
④
Equivalent circuit
(0.4)
(0.4)
②
(0.45)
③
①
④
②
③
No Polarity
(0.45)
Drawn by
Checked by
Approved by
2/13
SPEC. NO.
T-0602-058J
4. Electrical Characterisitcs
4-1 Electrical Spec.
Common-Mode
Cut-off
The
Our
cutoff
Product
frequencyies
in differential mode for CMF2012H2 is 6GHz respectively.
Rated
DC Resistance Rated Current
Impedance
Voltage
Part Number
Frequency
Rdc(Ω) Max. Idc(mA) Max.
Insulation
Resistance
Z(Ω) at 100MHz
Vdc(V)
(GHz)Typ.
CMF2012H4-420-2P-T
42±25%
0.12
400
(MΩ)Min.
10
CMF2012H4-500-2P-T
50±25%
0.30
400
10
CMF2012H4-600-2P-T
60±25%
0.31
320
10
CMF2012H4-670-2P-T
67±25%
0.31
320
10
CMF2012H4-900-2P-T
65min. (90typ.)
0.25
300
10
CMF2012H4-121-2P-T
120±25%
0.25
300
10
4-2-1 Characteristics(Reference)
CMF2012H4-420-2P-T
10000
Z (common mode)
Z(differential mode)
1000
Z ( ohm)
100
10
1
0.1
10
100
1000
Frequency(MHz)
CMF2012H4-121-2P-T
10000
Z (common mode)
1000
Impedance ( ohm)
1
100
10
1
1
10
Frequency(MHz)
100
1000
3/13
4-2-2 Insertion loss(Reference)
CMF2012H4-420-2P-T
CMF2012H4-420-2P-T
SPEC. NO.
T-0602-058J
4/13
CMF2012H4-500-2P-T
CMF2012H4-500-2P-T
SPEC. NO.
T-0602-058J
5/13
SPEC. NO.
CMF2012H4-670-2P-T
CMF2012H4-670-2P-T
HDMI Choke Impedance Graphic result
T-0602-058J
6/13
CMF2012H4-900-2P-T
CMF2012H4-900-2P-T
SPEC. NO.
T-0602-058J
7/13
CMF2012H4-121-2P-T
CMF2012H4-121-2P-T
SPEC. NO.
T-0602-058J
8/13
SPEC. NO.
T-0602-058J
4-3 Test Equipment
4-3-1 Impedance
Measured by using Agilent E4991A RF Impedance Analyzer.
The cutoff frequencyies in differential mode for CMF2012H2 is 6GHz respectively.
Measurement terminal
①
④
②
③
4-3-2 DC Resistance
Measured by using Chroma 16502 mill ohm meter.
①
④
②
③
4-3-3 Insulation Resistance
①
④
②
③
9/13
SPEC. NO.
T-0602-058J
5. Reliability Test
Operating temperature : -40 to +105℃
Storage temp and humidity : 20~25℃ ,60%RH max.
Specifications
conditions
The
Item
cutoff frequencyies in differential mode for CMF2012H2 is 6GHzTest
respectively.
Apply cream solder to the test circuit board .
Solder ability It can be connected on the
It is mounted on the recommendation soldering condition.
Recommendation soldering
condition.
Terminal
The terminal electrode and
Solder a chip to test substrate , and then
strength
the ferrite must not be
laterally apply a load 0.5Kg in the arrow
damaged.
direction.
Strength on
pc board
bending
The terminal electrode and the
ferrite must not be damaged.
Soldering a chip to a test substrate ,
bend the substrate by 2mm and then return.
Test board : Glass base epoxy multiplayer board pc board pattern.
PC board pattern : Recommended PC board pattern.
10/13
SPEC. NO.
T-0602-058J
5. Reliability Test
Item
Specifications
Test conditions
+105±2℃
: Ferrite
shall not be Temperature
High
The cutoff Appearance
frequencyies
in differential
mode for :CMF2012H2
Applied voltage : Rated voltage
temperature
damaged.
resistance
Impedance : Within ±20% of
Applied current : Rated current
the initial value.
insulation resistance: >
10(MΩ)
DC resistance : standard
value inside.
Testing time : 50±12 hours
Measurement : After placing for 24 hours min.
Humidity
resistance
Temperature : +85±2℃
Humidity : 90 to 95%RH
Testing time : 500±12 hours
Thermal cycle
Temperature : -40℃,+105℃
kept stabilized for 30 minutes each.
Cycle : 5 cycle
1 cycle
+105℃
-40℃
Low
temperature
resistance
Vibration
30 min.
3 min
30 min.
Temperature : -40±2℃
Testing time : 48±12 hours
Appearance : Ferrite shall not be Frequency : 10 to 50 Hz
damaged.
Amplitude : 1.52 mm
Dimension and times : X ,Y and Z directions
for 2 hours each.
11/13
SPEC. NO.
T-0602-058J
6.Packaging
The packaging must be done not to receive any damage during transporting and storing
6-1The
Tape
cutoff
dimensions
Ko
P1
P0
P
W
Bo
t
Ao
( Dimensions in mm; Tolerance:±0.1)
Symbol
W
P
P0
P1
Ao
Bo
Ko
t
Dimension
8
4
4
2
1.5
2.25
1.35
0.24
6-2 Reel dimensions
w
φA
t
t
Symbol
R
Dimension in mm
T
φA
φB
180+0,-3
φC
13±0.2
D
2.2±0.5
W
9.0±0.3
t
1.2
R
1
φB
φC
D
6-3 Tapping figure
Top cover tape
Carrier tape
Sprocket hole
Cavity (chip insert)
60+1,-0
12/13
SPEC. NO.
T-0602-058J
6-4 Packaging Form
There shall not continuation more than two vacancies of the product.
(360 mm)
Blank
Chip
(50 pitches)
Blank
Leader.
(70 pitches)
Material of carrier tape : Polystyrene
Material of cover tape : Polyester
6-5 Cover Tape Peel Strength
The force for tearing off cover tape is 0.05~0.69(N) in the arrow direction at
the following conditions:
Temperature : 5 ~ 35℃
Humidity : 45 ~ 85%
Atmospheric pressure : 860 ~ 1060 hpa
160 ~ 180。
Top cover tape
Base tape
6-6 Packing Quantity
φ180 mm reel T type : 2000 pcs./reel
13/13
SPEC. NO.
T-0602-058J
7. Recommended Soldering Conditions (Please use this product by reflow soldering)
7-1 Recommended Footprint
Termination Number : Please refer to the equivalent circuit in chapter 3.
0.4 0.4
2.6for CMF2012H2 is 6GHz respectively.
1.2
0.8
1.0
7-2 Recommended Reflow Pattern
10sec. Max.
255℃
217℃
Natural cooling
150sec Max..
150℃
60sec. Min.
7-3 Iron Soldering
Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip
directly touch the ferrite body outside of terminal electrode.
4 seconds max. at 260℃.
8. Attention in Case of Using
In case of using product ,please avoid following matters:
Splashing water or salt water
Dew condenses
Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia)
Vibrations or shocks which exceed the specified condition
Please be careful for the stress to this product by board flexure or something
after the mounting.
9. Other
Recommended wire wound inductors should be used within 6 months from the time of delivery.
很抱歉,暂时无法提供与“CMF2012H4-900-2P-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.99090
- 10+0.78873
- 30+0.68764
- 100+0.61182
- 500+0.55113
- 1000+0.52078
