CMF2012F-801-2P-T
CMF2012F-801-2P-T
    EMTEK(兆欣)
    SMD,2x1.2x1.2mm
    特性:尺寸小。 噪声抑制效果好。 在噪声频段具有高共模阻抗,在信号频段具有低差模阻抗。 由于低差模阻抗和高耦合系数,高速信号几乎无失真。 由自动化机器微生产,产量大且精度高,全天进行CCD检测。应用:...
CMF2012F-801-2P-T 数据手册
CMF2012F Series Common Mode SMD Filter for Signal Line FEATURES • This common mode filter is characterized by its small sized • Highly effective in noise suppression. High common-mode impedance at noise band and low differential-mode impedance at signal band. • Due to the low differential-mode impedance with high coupling factor, there is almost no distortion PRODUCT IDENTIFICATION on high speed signal. • This series is micro-produced by auto machines for its huge productivity and accuracy with all-day CCD inspection. CMF 2012 F - 900 - 2P - T (1) (2) (3) (4) (5) (6) (1) Product name (2) Shapes and Dimensions APPLICATIONS (3) Shielding type • Used for noise suppression in any electronic (4) Impedance[at 100MHz] devices such as personal computer and peripheral 121:120Ω equipment (USB), amusement equipment (IEEE 1394), (5) Number of line LCD panels (LVDS) etc. 2P:2-Line (6) Taping style SHAPES AND DIMENSIONS RECOMMENDED FOOTPRINT (0.4) 1.2 ± 0.2 1.2 ± 0.2 2.0 ± 0.2 0.8 1.0 0.8 0.4*3 (0.4) (0.45) (0.45) Unit:mm ELECTRICAL CHARACTERISTICS Our Product Part Number CMF2012F-300-2P-T CMF2012F-400-2P-T CMF2012F-670-2P-T CMF2012F-750-2P-T CMF2012F-900-2P-T CMF2012F-121-2P-T CMF2012F-161-2P-T CMF2012F-181-2P-T CMF2012F-201-2P-T CMF2012F-221-2P-T CMF2012F-261-2P-T CMF2012F-371-2P-T CMF2012F-601-2P-T CMF2012F-670-2P-T CMF2012F-901-2P-T CMF2012F-102-2P-T CMF2012F-222-2P-T Common-Mode Impedance Z(Ω) at 100MHz 30 ±25% 40 ±25% 67 ±25% 75 ±25% 90 ±25% 120±25% 160±25% 180±25% 200±25% 220±25% 260±25% 370±25% 600±25% 670±25% 900±25% 1000±25% 2200±25% DC Rated Current Rated Voltage Resistance Idc(mA) Max. Vdc(V) Rdc(Ω) Max. 0.20 450 50 0.12 500 50 0.25 400 50 0.30 400 50 0.30 400 50 0.30 370 50 0.30 340 50 0.35 330 50 0.35 330 50 0.35 330 50 0.40 300 50 0.40 280 50 0.375 250 50 0.60 150 50 0.80 120 50 0.80 100 50 0.14 100 50 Insulation Resistance (MΩ)Min. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 CMF2012F Series Common Mode SMD Filter for Signal Line Characteristics(Impedance vs. Frequency) CMF2012F-400-2P-T CMF2012F-300-2P-T 1000 1000 Common Mode Differential Mode 100 Impedance(Ω) Impedance(Ω) 100 10 10 Common Mode Differential Mode 1 1 0.1 1 0.1 1 10 100 Frequency(MHz) 1000 Frequency(MHz) 1000 Common Mode Common Mode Differential Mode Differential Mode 100 Impedance(OHM) Impedance(OHM) 100 10 1 10 1 0.1 0.1 1 10 100 Frequency(MHz) 1000 CMF2012F-121-2P-T 1000 Common Mode Differential Mode 100 Impendance(OHM) 100 1000 CMF2012F-900-2P-T CMF2012F-670-2P-T 1000 10 10 1 0.1 1 10 100 Frequency(MHz) 1000 1 10 100 Frequency(MHz) 1000 CMF2012F Series Common Mode SMD Filter for Signal Line Characteristics(Impedance vs. Frequency) CMF2012F-181-2P-T 10000 Common Mode Common Mode Differential Mode Differential Mode Impedance(OHM) 1000 Impedance(OHM) CMF2012F-201-2P-T 1000 100 10 100 10 1 0.1 1 1 10 100 Frequency(MHz) 1000 1 10 100 1000 Frequency(MHz) CMF2012F-221-2P-T CMF2012F-261-2P-T 10000 Common Mode 10000 Differential Mode 1000 Differential Mode 1000 Impedance(OHM) Impedance(OHM) Common Mode 100 100 10 10 1 1 0.1 1 10 100 Frequency(MHz) 1000 1 10 100 Frequency(MHz) 1000 CMF2012F-371-2P-T 10000 Common Mode CMF2012F-601-2P-T 10000 Common mode Differential Mode Differential mode 1000 Impedance(OHM) Impedance(OHM) 1000 100 100 10 10 1 1 0.1 1 1 10 100 Frequency(MHz) 1000 10 100 Frequency(MHz) 1000 CMF2012F Series Common Mode SMD Filter for Signal Line Characteristics(Impedance vs. Frequency)
